Rückmeldungen Stable 1.9.271
Verfasst: Di Jun 14, 2022 12:49 pm
Die Ankündigung mit den Änderungen findet ihr dort: https://www.openwb.de/forum/viewtopic.php?f=3&t=5484
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
str(e)) from e
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 105, in __read_registers
return self.__read_registers(self.delegate.read_input_registers, address, types, byteorder, wordorder, **kwargs)
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 142, in read_input_registers
powers = self.client.read_input_registers(0x0C, [ModbusDataType.FLOAT_32]*3, unit=self.id)
File "/var/www/html/openWB/packages/modules/common/sdm.py", line 60, in get_power
self.process_error(e)
File "/var/www/html/openWB/packages/modules/common/sdm.py", line 64, in get_power
powers, power = self.__client.get_power()
File "/var/www/html/openWB/packages/modules/openwb_flex/inverter.py", line 41, in update
self.components[component].update()
File "/var/www/html/openWB/packages/modules/openwb_flex/device.py", line 60, in update
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>)
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 89, in __read_registers
2022-06-15 08:51:15: PID: 10523: soc.modules.common.fault_state: PV-Kit flex: FaultState FaultStateLevel.ERROR, FaultStr modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>), Traceback:
2022-06-15 08:51:10: PID: 861: **** FATAL ********************************* (LV0)
2022-06-15 08:51:10: PID: 861: **** FATAL Regulation loop needs 10 seconds (LV0)
str(e)) from e
Hallo @LarsBr87, bist Du sicher, dass das PV-Kit gar nicht mehr läuft? Oder nur ab zu, eine Zeitlang, nicht? Wir haben hier beschrieben viewtopic.php?t=5454 das gleiche Fehlerbild im LogLarsBr87 hat geschrieben: Mi Jun 15, 2022 6:48 am Hallo,
... nur leider läuft das PV Kit aus dem Shop nicht mehr....
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt connect done: FHEM
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish PV W: 5033
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish PV WhCounter: 11078480
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish PV done:
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY W: 2454
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY WhImported: 1771650
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY WhExported: 1720220
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY SOC: 76
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY done:
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU W: -3998
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU APhase1: 3.70
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU APhase2: 9.67
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU APhase3: 9.67
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU WhImported: 1656450.00
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU WhExported: 7026710.00
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU VPhase1: 233.90
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU VPhase2: 234.80
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU VPhase3: 236.30
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU HzFrequenz: 50.05
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU done:
2022.06.16 09:50:46 4: [FHEM::Senec::Senec_mqtt] mqtt disconnected:
PV: 7,5 kW
Netz: 18 W
Aktueller Verbrauch: 7,5 k
Haus: 5,1 kW
Geräte: 1 W
Speicher: 77% > Bat: 2,4 kW
2022-06-16 09:54:53 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 09:54:53 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 09:54:52 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 09:54:52 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 09:54:52 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 09:54:52 Topic: openWB/set/pv/1/faultState Message: 0Code: Alles auswählen
2022-06-16 11:17:25 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 11:17:25 Topic: openWB/set/evu/faultStr Message: "Kein Fehler."
2022-06-16 11:17:25 Topic: openWB/set/evu/WHExport_temp Message: 24650184341.025745
2022-06-16 11:17:24 Topic: openWB/set/lp/2/faultStr Message: Kein Fehler
2022-06-16 11:17:24 Topic: openWB/set/lp/2/faultState Message: 0
2022-06-16 11:17:19 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 11:17:19 Topic: openWB/set/evu/Hz Message: 50.05
2022-06-16 11:17:19 Topic: openWB/set/evu/PfPhase3 Message: -0.9812
2022-06-16 11:17:19 Topic: openWB/set/evu/PfPhase2 Message: -0.8404
2022-06-16 11:17:19 Topic: openWB/set/evu/PfPhase1 Message: -0.9814
2022-06-16 11:17:19 Topic: openWB/set/pv/1/W Message: -5308
2022-06-16 11:17:19 Topic: openWB/set/evu/WPhase1 Message: -1249
2022-06-16 11:17:19 Topic: openWB/set/evu/WPhase2 Message: -288
2022-06-16 11:17:19 Topic: openWB/set/evu/WPhase3 Message: -1246
2022-06-16 11:17:19 Topic: openWB/set/evu/APhase2 Message: 1.72
2022-06-16 11:17:19 Topic: openWB/set/evu/APhase3 Message: 5.356
2022-06-16 11:17:19 Topic: openWB/set/evu/APhase1 Message: 5.432
2022-06-16 11:17:19 Topic: openWB/set/evu/WhExported Message: 6847263.237582641
2022-06-16 11:17:19 Topic: openWB/set/evu/VPhase1 Message: 235.82
2022-06-16 11:17:19 Topic: openWB/set/evu/VPhase3 Message: 237.99
2022-06-16 11:17:19 Topic: openWB/set/evu/VPhase2 Message: 237.13
2022-06-16 11:17:19 Topic: openWB/set/lp/1/VPhase3 Message: 235.1
2022-06-16 11:17:19 Topic: openWB/set/lp/1/VPhase2 Message: 236.4
2022-06-16 11:17:19 Topic: openWB/set/evu/faultState Message: 0Code: Alles auswählen
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] begin: 192.168.178.85
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt connect done: FHEM
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish PV W: openWB/set/pv/1/W = 7132
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish PV WhCounter: openWB/set/pv/1/WhCounter = 11094780
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish PV done:
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY W: openWB/set/houseBattery/W = -13
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY WhImported: openWB/set/houseBattery/WhImported = 1773840
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY WhExported: openWB/set/houseBattery/WhExported = 1720230
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY SOC: openWB/set/houseBattery/%Soc = 100
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish BATTERY done:
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU W: openWB/set/evu/W = -6783
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU APhase1: openWB/set/evu/APhase1 = 9.39
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU APhase2: openWB/set/evu/APhase2 = 9.78
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU APhase3: openWB/set/evu/APhase3 = 9.78
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU WhImported: openWB/set/evu/WhImported = 1656450.00
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU WhExported: openWB/set/evu/WhExported = 7039740.00
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU VPhase1: openWB/set/evu/VPhase1 = 239.30
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU VPhase2: openWB/set/evu/VPhase2 = 237.40
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU VPhase3: openWB/set/evu/VPhase3 = 239.40
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU HzFrequenz: openWB/set/evu/HzFrequenz = 50.01
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt publish EVU done:
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] mqtt disconnected:
2022.06.16 12:05:44 4: [FHEM::Senec::Senec_mqtt] end: 192.168.178.85
2022-06-16 12:09:03 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:09:03 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:09:03 Topic: openWB/set/pv/1/W Message: 7159
2022-06-16 12:09:02 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:09:02 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:09:02 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:09:02 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:08:59 Topic: openWB/set/graph/RequestDayGraph Message: 0
2022-06-16 12:08:56 Topic: openWB/set/system/topicSender Message: local client uid: fjlbt sent: openWB/set/graph/RequestDayGraph
2022-06-16 12:08:56 Topic: openWB/set/graph/RequestDayGraph Message: 0
2022-06-16 12:08:56 Topic: openWB/set/graph/RequestDayGraph Message: 20220616
2022-06-16 12:08:53 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:08:53 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:08:53 Topic: openWB/set/houseBattery/%Soc Message: 100
2022-06-16 12:08:53 Topic: openWB/set/houseBattery/WhExported Message: 1720230
2022-06-16 12:08:53 Topic: openWB/set/houseBattery/WhImported Message: 1773840
2022-06-16 12:08:52 Topic: openWB/set/houseBattery/W Message: -13
2022-06-16 12:08:52 Topic: openWB/set/pv/1/WhCounter Message: 11095170
2022-06-16 12:08:52 Topic: openWB/set/pv/1/W Message: 7139
2022-06-16 12:08:52 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:08:52 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:08:52 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:08:52 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:08:43 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:08:43 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:08:42 Topic: openWB/set/pv/1/WhCounter Message: 11095150
2022-06-16 12:08:42 Topic: openWB/set/pv/1/W Message: 7148
2022-06-16 12:08:42 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:08:42 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:08:42 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:08:42 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:08:33 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:08:33 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:08:32 Topic: openWB/set/pv/1/WhCounter Message: 11095130
2022-06-16 12:08:32 Topic: openWB/set/pv/1/W Message: 7138
2022-06-16 12:08:32 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:08:32 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:08:32 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:08:32 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:08:23 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:08:23 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:08:22 Topic: openWB/set/pv/1/WhCounter Message: 11095110
2022-06-16 12:08:22 Topic: openWB/set/pv/1/W Message: 7135
2022-06-16 12:08:22 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:08:22 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:08:22 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:08:22 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:08:13 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:08:13 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:08:12 Topic: openWB/set/pv/1/WhCounter Message: 11095090
2022-06-16 12:08:12 Topic: openWB/set/pv/1/W Message: 7129
2022-06-16 12:08:12 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:08:12 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:08:12 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:08:12 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:08:03 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:08:03 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:08:02 Topic: openWB/set/pv/1/W Message: 7138
2022-06-16 12:08:02 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:08:02 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:08:02 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:08:02 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:07:54 Topic: openWB/set/evu/faultStr Message: Kein Fehler
2022-06-16 12:07:54 Topic: openWB/set/evu/faultState Message: 0
2022-06-16 12:07:53 Topic: openWB/set/houseBattery/faultState Message: 0
2022-06-16 12:07:53 Topic: openWB/set/houseBattery/faultStr Message: Kein Fehler
2022-06-16 12:07:53 Topic: openWB/set/pv/1/faultStr Message: Kein Fehler
2022-06-16 12:07:53 Topic: openWB/set/pv/1/faultState Message: 0
2022-06-16 12:07:52 Topic: openWB/set/pv/1/WhCounter Message: 11095050
2022-06-16 12:07:52 Topic: openWB/set/pv/1/W Message: 7126Code: Alles auswählen
connection openwbprod
address 192.168.1.171:1883
start_type automatic
topic evu/# in 1 openWB/set/ openWB/
topic pv/# in 1 openWB/set/ openWB/
topic lp/# in 1 openWB/set/ openWB/
local_clientid openwb.mosquitto
try_private false
cleansession false
