Kernel panic
Kernel panic
meine openWB begrüsste mich eben mit einer Kernelpanic. Ich hatte die Tage ein update gemacht, daher sollte die Version recht aktuell sein. Ein Reboot brachte keinen Erfolg, jemand eine Idee?
c)
I
3.215087] [(807a3abc)](
irg _suc) from [(B0108a50>1 (arch_cpu_idle+0x34/0x4c)
3.2197731 [(8010Ba50>] (arch_cpu_idle) from [(B07a323c›] (default _idle call+0x34/0x48)
3.2245381 [(807a323c)] (default idle call) from [(80161494›] (do idle+0xd8/Ox150)
3.229309] [<80161494>] (do_idle) from [(801617a8>1 (cpu_startup_entry+0x28/0xZc)
3.234007] [<B01617a8>] (cpu_startup entry) from (<8010df50>1 (secondary_start_kernel +0x130/0>
3.2431861 [<8010df50>1 (secondary_start _kernel) from [<0010196c>1 (0x10196c)
3.247846] CPUZ: stopping
3.2523761 CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.14.71-07+ #1145
7569961 Hardware name: BCM2835
15211 ((8010ffd4>] (unwind_ backtrace) from ((B010c240>] (show stack+0x20/0x24)
51611 [<8010c240>] (show stack) from [(80787{24>1 (dump_stack+0xd4/0x118)
751 [<80787124›1 (dump_stack) from I<8010e458>] Chandle_IPI+0x2bc/0x33c)
36] ((8010e458>] (handle_IPI) from [<801014d8>] (bcm2836_arm_irqchip_handle_irq+0x7c/Oxi
3.2844101 [<8010148>] (bcm2836 _arm_irqchip_handle_irq) from [(807a3abc>l
3.289136] Exception stack(0xb9d27138 to Oxb9d27f80)
irq_suc+0x5c/0x7c
3.293829] 7f20:
00000000 0000067c
3.2986111 7840: 397e3000 00000000 b9d26000 80c03dcc B0c03d68 80c885b2 00000001 410fd034
3.3034031 7860: 00000000 b9d27(94 80c04174 b9d27f88 80108a4c 80108a50 60000013 ffffffff
3.3001741 [(807a3abc>](
_irq_suc) from (<80108a50>] (arch_cpu_idle+0x34/0x4c)
3.3129551 [ (80108a50>] (arch_ cpu_idle) from [(807a323c›] (default_idle call+0x34/0x48)
3.3178151 ((807a323c>] (default_idle_call) from (<80161494>] (do_idle+Oxd8/0x150)
C)
3.3226741 [<80161494>] (do_idle) from [(801617a8›] (cpu_startup_entry+0x28/0x2c)
I
3.3274621 [<801617a8>] (cpu_startup entry) from (<8010df50>] (secondary_start kernel+0x130/0x1:
I
3.3368211 ((B010d150>1 (secondary_start kernel) from [<0010196c›] (0x10196c)
3.3416201
9,2)
end Kernel panic
not syncing: UFS: Unable to mount root fs on unknown-block(17
c)
I
irq_suc+0x5c/0x7c
3.293829] 7f20:
00000000 0000067c
C)
I
I
3.3416201
9,2)
end Kernel panic
Heavendenied
- Has thanked: 6 times
- Been thanked: 32 times
Re: Kernel panic
Klingt nach defekter SD Karte. Ticket aufmachen und du bekommst ne neue.
Gruß,
Jürgen
Jürgen
Re: Kernel panic
Danke, werde ich dann direkt machen. Meine Config ist vermutlich futsch, oder?
Kein Backup, kein Mitleid, jaja.....
Heavendenied
Re: Kernel panic
Tja, du kennst den Spruch schon...
Versuch für die Zukunft daraus zu lernen, aber klar, ich verstehe, dass das im Moment sehr ärgerlich ist.
Gruß,
Jürgen
Jürgen
Re: Kernel panic
Support hat direkt reagiert, keine 30 Minuten. Das ist Weltklasse! Ich schließe hier. Danke!
Re: Kernel panic
Im Ernst? Gestern Abend noch gedacht "die Karte lebt schon lange, Backup wäre mal angebracht...."Heavendenied hat geschrieben: Mo Jun 27, 2022 2:09 pm Tja, du kennst den Spruch schon...
Heavendenied
Re: Kernel panic
Wenn man zumindest vor jedem Update ein Backup macht hat man schonmal immer ein halbwegs aktuelles Backup bei dem dann auch die Config passen sollte. Aber natürlich sind dann trotzdem die ganzen Daten wie Ladelog, PV Erzeugung etc futsch... Ich hab mir daher mittlerweile das hier im Forum irgendwo beschriebene tägliche Backup eingerichtet. Aber dazu braucht man halt nen Server o.ä. zuhause.
Gruß,
Jürgen
Jürgen
- Has thanked: 12 times
- Been thanked: 50 times
Re: Kernel panic
Ja, definitiv die SD Karte.
ABER: dass die Box nicht mehr startet ist klar, da das Root FS Read/Write gemountet werden muss.
Es besteht noch die Chance, dass die SD Karte noch gelesen werden kann. Dazu benötigt man aber dann ein weiteres Gerät, das ein Ext4 Filesystem lesen kann. Also z.B. einen weiteren Raspi oder einen Mac oder Linux Rechner. Falls du also sowas hast, SD in den Cardreader und schauen, ob sie sich mounten lässt.
Re: Kernel panic
Habe Zugriff auf einen Mac. Werde später am Tag schauen was da noch geht, dann könnte ich noch ein Backup machen *hust*
Re: Kernel panic
Na zumindest kannst du die Log Verzeichnisse kopieren, um die Statistiken der letzten Monate/Jahre zu haben.
Die Konfig sollte recht schnell wieder zu bauen sein.
