SOC Citroen e-c4 seit 4 Tagen angeblich konstant
loderunner
Beitrag von loderunner »
ein Jahr lang funktionierte alles wunderbar - die openWB konnte das Fahrzeug im Modus "PV" auf den Punkt genau auf den gewünschten Ladezustand bringen. Seit dem letzten Wochenende ergibt die Abfrage beim Stellantis-Server nur noch seltsame Antworten:
Da bin ich morgens losgefahren:
2023-04-17 08:00:30: PID: 24586: Lp1: Fetched from Citroen: 65% but skipping as not newer than current known SoC. (LV0)
2023-04-17 08:00:24: PID: 24586: Lp1: Fetching SoC from Citroen (LV0)
2023-04-17 07:50:29: PID: 8365: Lp1: Fetched from Citroen: 65% but skipping as not different from last fetched SoC and car is plugged in. (LV0)
2023-04-17 07:50:23: PID: 8365: Lp1: Fetching SoC from Citroen (LV0)
Da bin ich abends wiedergekommen, immer noch gleicher Stand???
2023-04-17 19:34:59: PID: 2510: Lp1: Fetched from Citroen: 65% but skipping as not different from last fetched SoC and car is plugged in. (LV0)
2023-04-17 19:34:53: PID: 2510: Lp1: Fetching SoC from Citroen (LV0)
2023-04-17 19:33:29: PID: 22836: Lp1: Fetched from Citroen: 65% but skipping as not newer than current known SoC. (LV0)
2023-04-17 19:33:24: PID: 22836: Lp1: Fetching SoC from Citroen (LV0)
2023-04-17 19:23:36: PID: 6840: Lp1: Fetched from Citroen: 65% but skipping as not newer than current known SoC. (LV0)
2023-04-17 19:23:24: PID: 6840: Lp1: Fetching SoC from Citroen (LV0)
Am nächsten Morgen (es wurde nichts geladen):
2023-04-18 08:04:59: PID: 2137: Lp1: Fetched from Citroen: 65% but skipping as not newer than current known SoC. (LV0)
2023-04-18 08:04:54: PID: 2137: Lp1: Fetching SoC from Citroen (LV0)
2023-04-18 07:55:00: PID: 18318: Lp1: Fetched from Citroen: 65% but skipping as not different from last fetched SoC and car is plugged in. (LV0)
2023-04-18 07:54:54: PID: 18318: Lp1: Fetching SoC from Citroen (LV0)
2023-04-18 07:44:59: PID: 2002: Lp1: Fetched from Citroen: 65% but skipping as not different from last fetched SoC and car is plugged in. (LV0)
2023-04-18 07:44:53: PID: 2002: Lp1: Fetching SoC from Citroen (LV0)
Nachmittags dreimal Fehler bei der Abfrage:
2023-04-18 16:20:57: PID: 10407: Lp1: Fetching SoC from Citroen failed (LV0)
2023-04-18 16:19:54: PID: 10407: Lp1: Fetching SoC from Citroen (LV0)
Weiterhin keine Ladung (verständlich), dann sogar:
2023-04-19 06:40:10: PID: 10489: Lp1: Fetched from Citroen: 65% and using it. (LV0)
2023-04-19 06:40:04: PID: 10489: Lp1: Charging started. Fetching SoC from Citroen out of order. (LV0)
2023-04-19 06:37:39: PID: 29731: Lp1: Fetched from Citroen: 65% but skipping as not different from last fetched SoC and car is plugged in. (LV0)
2023-04-19 06:37:34: PID: 29731: Lp1: Fetching SoC from Citroen (LV0)
Und schließlich sogar:
2023-04-19 19:06:24: PID: 3706: Lp1: newSoC above 100, setting to 100. (LV0)
2023-04-19 19:06:04: PID: 929: Lp1: newSoC above 100, setting to 100. (LV0)
2023-04-19 19:05:44: PID: 30589: Lp1: newSoC above 100, setting to 100. (LV0)
2023-04-19 17:20:49: PID: 5042: Lp1: Fetched from Citroen: 65% and using it. (LV0)
Bis dann später wieder:
2023-04-19 20:32:10: PID: 30444: Lp1: Fetched from Citroen: 65% but skipping as not different from last fetched SoC and car is plugged in. (LV0)
2023-04-19 20:32:04: PID: 30444: Lp1: Fetching SoC from Citroen (LV0)
2023-04-19 20:22:04: PID: 13792: Lp1: newSoC above 100, setting to 100. (LV0)
Auch aktuell kommt immer nur:
2023-04-21 17:58:39: PID: 1425: Lp1: Fetched from Citroen: 65% but skipping as not newer than current known SoC. (LV0)
2023-04-21 17:58:33: PID: 1425: Lp1: Fetching SoC from Citroen (LV0)
Auch die Citroen-App meldet keinen Ladezustand, nur einen (veralteten) Standort und die gefahrenen Strecken. Aber das ist mir nichts neues, der Dreck hat nur bis zum ersten Firmware-Update des Fahrzeugs (übrigens erste Version, falls das wichtig ist) halbwegs funktioniert.
Version meiner openWB übrigens 1.9.295, bis vorhin noch die ältere 1.9.288.
Jedenfalls lädt er so natürlich nicht. Und wegen der 100%-Meldung musste ich sogar mal unterwegs nachladen - keine Zeit zur Korrektur morgens.
Kann irgendjemand was dazu sagen?
loderunner
rleidner
Has thanked: 5 times
Been thanked: 28 times
Re: SOC Citroen e-c4 seit 4 Tagen angeblich konstant
Beitrag von rleidner »
Sieht aus als wäre das EV offline.
Kannst Du den Netzwerk-Status im Infotainment sehen?
loderunner
laut Display sollte das Fahrzeug online sein.
Vor ein paar Wochen gab es ja das neue Update der Firmware, nach dem man sich anmelden sollte - was ich auch getan habe. Seitdem gibt es angeblich (noch nicht verwendet) schnellere/bessere Stauwarnungen von TomTom. Aber danach hat es noch funktioniert.
Ich werde aber morgen nochmal ein wenig damit rumspielen. Vielleicht hängt es ja doch damit zusammen und irgendwas läuft noch nicht richtig. Danke erstmal für den Tip.
loderunner
rleidner
Evtl. mal die Hotline der PSA Online Services kontaktieren.
Ich hatte das gleiche Problem kürzlich beim smart EQ.
2 Stunden nach meinem Anruf war das Problem gelöst.
loderunner
ich habe in der HandyApp (MyCitroen) einen vorher nicht vorhandenen Einstellungspunkt gefunden - unter "Services" tauchte ein "e-Remote Control" auf. Das war nicht aktiviert; nach Aktivierung (und etwas warten) funktioniert die Abfrage der openWB beim Citroen-server wieder.
Schon seltsam, dass irgendwas jahrelang funktionierendes bei einem Update plötzlich neu zu aktivieren ist.
Danke für eure Unterstützung - ich hätte den Fehler ohne eure Hinweise ewig in der openWB gesucht.
loderunner
