Keine Daten mehr nach Update
Stevie_AN
Has thanked: 5 times
Beitrag von Stevie_AN »
Guten Morgen,
nachdem ich gestern ein Update versucht hatte, bekommt die OpenWB keine Daten mehr von PV-Modul und EVU-Modul. Selbst nach Einspielen des Backups besteht das Problem weiterhin:
mportError: urllib3 v2.0 only supports OpenSSL 1.1.1+, currently the 'ssl' module is compiled with OpenSSL 1.1.0l  10 Sep 2019. See: https://github.com/urllib3/urllib3/issues/2168
"urllib3 v2.0 only supports OpenSSL 1.1.1+, currently "
File "/home/pi/.local/lib/python3.7/site-packages/urllib3/__init__.py", line 39, in <module>
import urllib3
File "/usr/local/lib/python3.7/site-packages/requests/__init__.py", line 43, in <module>
from requests import HTTPError
File "/var/www/html/openWB/packages/helpermodules/exceptions/requests.py", line 1, in <module>
from helpermodules.exceptions import registry, requests
File "/var/www/html/openWB/packages/helpermodules/exceptions/__init__.py", line 1, in <module>
from helpermodules import compatibility, exceptions, pub
File "/var/www/html/openWB/packages/modules/common/fault_state.py", line 7, in <module>
from modules.common.fault_state import ComponentInfo, FaultState
File "/var/www/html/openWB/packages/modules/common/component_context.py", line 5, in <module>
from modules.common.component_context import SingleComponentUpdateContext, MultiComponentUpdateContext
File "/var/www/html/openWB/packages/modules/common/configurable_device.py", line 6, in <module>
from modules.common.configurable_device import ConfigurableDevice, ComponentFactoryByType, MultiComponentUpdater
File "/var/www/html/openWB/packages/modules/devices/sma_shm/device.py", line 9, in <module>
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
return _bootstrap._gcd_import(name[level:], package, level)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
importlib.import_module(parsed[0]).main(parsed[1:])
File "/var/www/html/openWB/packages/legacy_run_server.py", line 109, in handle_message
self.__callback(read_all_bytes(connection))
File "/var/www/html/openWB/packages/legacy_run_server.py", line 87, in handle_connection
yield
File "/var/www/html/openWB/packages/legacy_run_server.py", line 48, in redirect_stdout_stderr_exceptions_to_log
2023-04-29 08:34:24: PID: 3895: legacy run server: Unhandled exception
ImportError: urllib3 v2.0 only supports OpenSSL 1.1.1+, currently the 'ssl' module is compiled with OpenSSL 1.1.0l  10 Sep 2019. See: https://github.com/urllib3/urllib3/issues/2168
import urllib3
from modules.common.fault_state import FaultState
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 18, in <module>
from modules.common import modbus
File "/var/www/html/openWB/packages/modules/devices/openwb_flex/device.py", line 6, in <module>
yield
2023-04-29 08:34:23: PID: 3895: legacy run server: Unhandled exception
import urllib3
File "/var/www/html/openWB/packages/modules/devices/sma_sunny_boy/device.py", line 8, in <module>
yield
import urllib3
yield
2023-04-29 08:34:14: PID: 3895: legacy run server: Unhandled exception
import urllib3
yield
2023-04-29 08:34:13: PID: 3895: legacy run server: Unhandled exception
import urllib3
yield
2023-04-29 08:34:09: PID: 4369: **** FATAL ********************************* (LV0)
2023-04-29 08:34:09: PID: 4369: **** FATAL Regulation loop needs 18 seconds (LV0)
2023-04-29 08:34:02: PID: 5464: Pause nach Umschaltung: 2s (LV0)
2023-04-29 08:34:02: PID: 5428: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
4369
loadvars.sh: Zeile 1908: ramdisk/mqttslavemode: Datei oder Verzeichnis nicht gefunden
import urllib3
yield
2023-04-29 08:33:57: PID: 3895: legacy run server: Unhandled exception
modules/goelp2/main.sh: Zeile 45: /var/www/html/openWB/ramdisk/tmpgoelp2rfid: Datei oder Verzeichnis nicht gefunden
Trying to read meter serial number once from meter at address /dev/ttyUSB0, ID 105
import urllib3
yield
2023-04-29 08:33:54: PID: 3895: legacy run server: Unhandled exception
from urllib3.util import parse_url
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 16, in <module>
yield
2023-04-29 08:33:46: at_reboot: 2023-04-29 08:33:46: boot done :-)
2023-04-29 08:33:46: at_reboot: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
2023-04-29 08:33:45: at_reboot: fix upload limit...OS Stretch
2023-04-29 08:33:45: at_reboot: not activated, skipping
2023-04-29 08:33:45: at_reboot: etprovider...
2023-04-29 08:33:41: PID: 4094: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:33:36: at_reboot: update broker...
2023-04-29 08:33:34: PID: 3895: legacy run server: Changing log level DEBUG -> WARNING
2023-04-29 08:33:34: at_reboot: Starting legacy run server
2023-04-29 08:33:34: PID: 3826: legacy run server is not running. Restarting process (LV0)
2023-04-29 08:33:34: PID: 3826: smart home handler not running! restarting process (LV0)
2023-04-29 08:33:34: PID: 3826: mqtt handler not running! restarting process (LV0)
2023-04-29 08:33:34: PID: 3826: modbus tcp server not running! restarting process (LV0)
2023-04-29 08:33:34: PID: 3826: Starting OpenWB services (LV0)
2023-04-29 08:33:34: PID: 3826: OpenWB services stopped (LV0)
2023-04-29 08:33:34: PID: 3826: Stopping OpenWB services (LV0)
2023-04-29 08:33:34: at_reboot: clear warning...
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100    43    0     0  100    43      0    208 --:--:-- --:--:-- --:--:--   209
Stevie_AN
Re: Keine Daten mehr nach Update
[code...
yield
import urllib3
yield
import urllib3
yield
import urllib3
yield
import urllib3
yield
4369
import urllib3
yield
import urllib3
yield
yield
2023-04-29 08:33:33: at_reboot: Dload Upload Total Spent Left Speed
2023-04-29 08:33:33: at_reboot: % Total % Received % Xferd Average Speed Time Time Time Current
2023-04-29 08:33:33: at_reboot: version...
2023-04-29 08:33:33: at_reboot: Successfully installed urllib3-1.26.9
2023-04-29 08:33:32: at_reboot: Installing collected packages: urllib3
2023-04-29 08:33:32: at_reboot: Using cached https://files.pythonhosted.org/packages ... ne-any.whl
2023-04-29 08:33:31: PID: 3799: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:33:31: at_reboot: Cache entry deserialization failed, entry ignored
2023-04-29 08:33:29: at_reboot: Cache entry deserialization failed, entry ignored
2023-04-29 08:33:28: at_reboot: Collecting urllib3
2023-04-29 08:33:21: PID: 3706: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:33:20: at_reboot: You should consider upgrading via the '/usr/local/bin/python3 -m pip install --upgrade pip' command.
2023-04-29 08:33:20: at_reboot: WARNING: You are using pip version 21.2.4; however, version 23.1.2 is available.
2023-04-29 08:33:20: at_reboot: WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
2023-04-29 08:33:18: at_reboot: Requirement already satisfied: pkce in /usr/local/lib/python3.7/site-packages (1.0.3)
2023-04-29 08:33:18: at_reboot: Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2023-04-29 08:33:16: at_reboot: bs4 installed...
2023-04-29 08:33:15: at_reboot: soc_smarteq: enable local python3 secrets.py...
2023-04-29 08:33:15: at_reboot: soc_vwid: enable local python3 secrets.py...
2023-04-29 08:33:15: at_reboot: lxml installed...
2023-04-29 08:33:14: at_reboot: You should consider upgrading via the '/usr/local/bin/python3 -m pip install --upgrade pip' command.
2023-04-29 08:33:14: at_reboot: WARNING: You are using pip version 21.2.4; however, version 23.1.2 is available.
2023-04-29 08:33:14: at_reboot: WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
2023-04-29 08:33:13: at_reboot: Requirement already satisfied: dnspython in /usr/local/lib/python3.7/site-packages (from ipparser) (2.1.0)
2023-04-29 08:33:13: at_reboot: Requirement already satisfied: ipparser in /usr/local/lib/python3.7/site-packages (0.3.8)
2023-04-29 08:33:13: at_reboot: Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2023-04-29 08:33:11: PID: 3576: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:33:10: at_reboot: jq installed...
2023-04-29 08:33:10: at_reboot: python requests installed...
2023-04-29 08:33:09: PID: 3554: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:33:09: PID: 3541: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:33:07: at_reboot: pymodbus installed...
2023-04-29 08:33:07: at_reboot: aiohttp installed...
2023-04-29 08:33:05: at_reboot: certifi installed...
2023-04-29 08:33:05: at_reboot: docopt installed...
2023-04-29 08:33:05: at_reboot: mqtt installed...
2023-04-29 08:33:04: at_reboot: packages 2...
2023-04-29 08:33:04: at_reboot: updating mosquitto config file
2023-04-29 08:33:04: at_reboot: mosquitto...
2023-04-29 08:33:04: at_reboot: cp: '/usr/share/zoneinfo/Europe/Berlin' und '/etc/localtime' sind die gleiche Datei
2023-04-29 08:33:03: at_reboot: timezone...
2023-04-29 08:33:01: PID: 3381: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:59: PID: 3340: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:59: PID: 3327: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:49: PID: 3226: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:49: PID: 3213: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:39: PID: 3126: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:39: PID: 3113: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:29: PID: 3012: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:29: PID: 2999: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:27: at_reboot: led...
2023-04-29 08:32:27: at_reboot: 2023-04-29 08:32:27: PID: 2916: upgradeChargeLogs: upgrading charge logs done
2023-04-29 08:32:27: at_reboot: 2023-04-29 08:32:27: PID: 2916: upgradeChargeLogs: upgrading charge logs with a price of 0.3 per kWh
2023-04-29 08:32:26: at_reboot: You should consider upgrading via the '/usr/local/bin/python3 -m pip install --upgrade pip' command.
2023-04-29 08:32:26: at_reboot: WARNING: You are using pip version 21.2.4; however, version 23.1.2 is available.
2023-04-29 08:32:26: at_reboot: WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
2023-04-29 08:32:25: at_reboot: Requirement already satisfied: evdev in /usr/local/lib/python3.7/site-packages (1.6.0)
2023-04-29 08:32:25: at_reboot: Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2023-04-29 08:32:21: at_reboot: evdev for python2 installed...
2023-04-29 08:32:21: at_reboot: packages 1...
2023-04-29 08:32:21: at_reboot: crontab 2...
2023-04-29 08:32:21: at_reboot: ...changed
2023-04-29 08:32:21: at_reboot: apache...
2023-04-29 08:32:20: at_reboot: LAN/WLAN...
2023-04-29 08:32:20: at_reboot: crontab 1...
2023-04-29 08:32:20: at_reboot: deleting browser cache
2023-04-29 08:32:20: at_reboot: already up to date
2023-04-29 08:32:20: at_reboot: display...
2023-04-29 08:32:19: PID: 2793: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:19: PID: 2750: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2023-04-29 08:32:16: at_reboot: triginit...
2023-04-29 08:32:16: at_reboot: Ramdisk init done.
2023-04-29 08:32:16: at_reboot: Trigger update of logfiles...
2023-04-29 08:32:15: at_reboot: 'mqttwizzarddone' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttwattbezug' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttversion' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttverbraucher2_name' missing: Setting to provided default value 'notset'
2023-04-29 08:32:15: at_reboot: 'mqttverbraucher2_aktiv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttverbraucher1_name' missing: Setting to provided default value 'notset'
2023-04-29 08:32:15: at_reboot: 'mqttverbraucher1_aktiv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttupdateinprogress' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttu1p3pstandby' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttu1p3psofort' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttu1p3pnurpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttu1p3pnl' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttu1p3pminundpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttu1p3paktiv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttstopchargepvpercentagelp2' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttstopchargepvpercentagelp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttstopchargepvatpercentlp2' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttstopchargepvatpercentlp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttspeicherwattnurpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttspeichersocnurpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttspeichersocminpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttspeichersochystminpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttspeicherpvui' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttspeicherpveinbeziehen' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttspeichermaxwatt' missing: Setting to provided default value '-1'
2023-04-29 08:32:15: at_reboot: 'mqttsofortsocstatlp2' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttsofortsocstatlp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttsofortsoclp2' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttsofortsoclp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttsocvorhanden' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttsoc' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttsoc1vorhanden' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttrfidakt' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttrestzeitlp3' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttrestzeitlp2' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttrestzeitlp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttpvwatt' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttpvbezugeinspeisung' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttpreisjekwh' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttoffsetpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnurpv70dynw' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnurpv70dynact' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnlakt_standby' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnlakt_sofort' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnlakt_nurpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnlakt_minpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnachtladens1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttnachtladen' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttminnurpvsoclp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttminnurpvsocll' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttminimalstromstaerke' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttminimalapv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttminimalampv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttminimalalp2pv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttmindestuberschuss' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttmaxnurpvsoclp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttmaximalstromstaerke' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlastlademodus' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstats2' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstats1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstatlp8' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstatlp7' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstatlp6' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstatlp5' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstatlp4' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademstat' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademkwhlp8' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademkwhlp7' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademkwhlp6' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademkwhlp5' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademkwhlp4' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlademkwh' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqtthook3_aktiv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqtthook2_aktiv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqtthook1_aktiv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttheutegeladen' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqtthausverbrauchstat' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqtthausverbrauch' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttevuglaettungakt' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp8etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp7etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp6etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp5etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp4etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp3etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp2etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttlp1etbasedcharging' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttetprovider' missing: Setting to provided default value 'notset'
2023-04-29 08:32:14: at_reboot: 'mqttetprovideraktiv' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqtteinschaltverzoegerung' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdurchslp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdisplayspeichermax' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdisplaypvmax' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdisplayhausmax' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdisplayhausanzeigen' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdisplayevumax' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdatenschutzack' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdailychargelp3' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdailychargelp2' missing: Setting to provided default value '-1'
2023-04-29 08:32:14: at_reboot: 'mqttdailychargelp1' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttaktgeladens2' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttaktgeladens1' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttaktgeladen' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttadaptpv' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttadaptfaktor' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttabschaltverzoegerung' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttabschaltuberschuss' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttRandomSleepValue' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: 'mqttCp1Configured' missing: Setting to provided default value '-1'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp8' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp8max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp8name' missing: no MQTT topic set: Setting to default of 'Lp8'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp8' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp8' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp8' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:13: at_reboot: '/var/www/html/openWB/ramdisk/lp8sofortll' missing: Setting from MQTT topic 'lp8sofortll' to value '10'
2023-04-29 08:32:12: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:12: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp8' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:12: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp8' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:12: at_reboot: '/var/www/html/openWB/ramdisk/lp8enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:32:12: at_reboot: '/var/www/html/openWB/ramdisk/lp8phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:12: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp8' missing: Setting from MQTT topic 'pluggedladungaktlp8' to value '0'
2023-04-29 08:32:11: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp8startkwh' missing: Setting from MQTT topic 'pluggedladunglp8startkwh' to value '0'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp7' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp7max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp7name' missing: no MQTT topic set: Setting to default of 'Lp7'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp7' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp7' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp7' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:10: at_reboot: '/var/www/html/openWB/ramdisk/lp7sofortll' missing: Setting from MQTT topic 'lp7sofortll' to value '10'
2023-04-29 08:32:09: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:09: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp7' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:09: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp7' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:09: at_reboot: '/var/www/html/openWB/ramdisk/lp7enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:32:09: at_reboot: '/var/www/html/openWB/ramdisk/lp7phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:09: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp7' missing: Setting from MQTT topic 'pluggedladungaktlp7' to value '0'
2023-04-29 08:32:08: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp7startkwh' missing: Setting from MQTT topic 'pluggedladunglp7startkwh' to value '0'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp6' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp6max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp6name' missing: no MQTT topic set: Setting to default of 'Lp6'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp6' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp6' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:07: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:06: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp6' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:06: at_reboot: '/var/www/html/openWB/ramdisk/lp6sofortll' missing: Setting from MQTT topic 'lp6sofortll' to value '10'
2023-04-29 08:32:05: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:05: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp6' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:05: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp6' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:05: at_reboot: '/var/www/html/openWB/ramdisk/lp6enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:32:05: at_reboot: '/var/www/html/openWB/ramdisk/lp6phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:05: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp6' missing: Setting from MQTT topic 'pluggedladungaktlp6' to value '0'
2023-04-29 08:32:04: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp6startkwh' missing: Setting from MQTT topic 'pluggedladunglp6startkwh' to value '0'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp5' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp5max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp5name' missing: no MQTT topic set: Setting to default of 'Lp5'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp5' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp5' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp5' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:32:03: at_reboot: '/var/www/html/openWB/ramdisk/lp5sofortll' missing: Setting from MQTT topic 'lp5sofortll' to value '10'
2023-04-29 08:30:44: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:44: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp5' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:44: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp5' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:44: at_reboot: '/var/www/html/openWB/ramdisk/lp5enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:30:44: at_reboot: '/var/www/html/openWB/ramdisk/lp5phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:44: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp5' missing: Setting from MQTT topic 'pluggedladungaktlp5' to value '0'
2023-04-29 08:30:42: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp5startkwh' missing: Setting from MQTT topic 'pluggedladunglp5startkwh' to value '0'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp4' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp4max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp4name' missing: no MQTT topic set: Setting to default of 'Lp4'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp4' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp4' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp4' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:41: at_reboot: '/var/www/html/openWB/ramdisk/lp4sofortll' missing: Setting from MQTT topic 'lp4sofortll' to value '10'
2023-04-29 08:30:40: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:40: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp4' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:40: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp4' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:40: at_reboot: '/var/www/html/openWB/ramdisk/lp4enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:30:40: at_reboot: '/var/www/html/openWB/ramdisk/lp4phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:40: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp4' missing: Setting from MQTT topic 'pluggedladungaktlp4' to value '0'
2023-04-29 08:30:39: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp4startkwh' missing: Setting from MQTT topic 'pluggedladunglp4startkwh' to value '0'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp3' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp3max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp3name' missing: no MQTT topic set: Setting to default of 'Lp3'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp3' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp3' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp3' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:38: at_reboot: '/var/www/html/openWB/ramdisk/lp3sofortll' missing: Setting from MQTT topic 'lp3sofortll' to value '10'
2023-04-29 08:30:37: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:37: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp3' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:37: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp3' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:37: at_reboot: '/var/www/html/openWB/ramdisk/lp3enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:30:37: at_reboot: '/var/www/html/openWB/ramdisk/lp3phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:37: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp3' missing: Setting from MQTT topic 'pluggedladungaktlp3' to value '0'
2023-04-29 08:30:36: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp3startkwh' missing: Setting from MQTT topic 'pluggedladunglp3startkwh' to value '0'
2023-04-29 08:30:35: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:35: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp2' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:35: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp2max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:35: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp2name' missing: no MQTT topic set: Setting to default of 'Lp2'
2023-04-29 08:30:34: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp2' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:34: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp2' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:34: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:34: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:34: at_reboot: '/var/www/html/openWB/ramdisk/lp2sofortll' missing: Setting from MQTT topic 'lp2sofortll' to value '32'
2023-04-29 08:30:33: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:33: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp2' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:33: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp2' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:33: at_reboot: '/var/www/html/openWB/ramdisk/lp2enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:30:33: at_reboot: '/var/www/html/openWB/ramdisk/lp2phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:33: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp2' missing: Setting from MQTT topic 'pluggedladungaktlp2' to value '0'
2023-04-29 08:30:32: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp2startkwh' missing: Setting from MQTT topic 'pluggedladunglp2startkwh' to value '1569.500'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp1' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp1max' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp1name' missing: no MQTT topic set: Setting to default of 'Lp1'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp1' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp1' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '-1'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:31: at_reboot: '/var/www/html/openWB/ramdisk/lp1sofortll' missing: Setting from MQTT topic 'lp1sofortll' to value '32'
2023-04-29 08:30:30: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:30: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp1' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:30: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp1' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:30: at_reboot: '/var/www/html/openWB/ramdisk/lp1enabled' missing: no MQTT topic set: Setting to default of '1'
2023-04-29 08:30:30: at_reboot: '/var/www/html/openWB/ramdisk/lp1phasen' missing: no MQTT topic set: Setting to default of '0'
2023-04-29 08:30:30: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp1' missing: Setting from MQTT topic 'pluggedladungaktlp1' to value '0'
2023-04-29 08:30:29: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp1startkwh' missing: Setting from MQTT topic 'pluggedladunglp1startkwh' to value '5902.954'
2023-04-29 08:30:28: at_reboot: Initializing Ramdisk /var/www/html/openWB/ramdisk
2023-04-29 08:30:28: at_reboot: Config file Update done.
2023-04-29 08:30:23: at_reboot: Updating /var/www/html/openWB/openwb.conf...
2023-04-29 08:30:15: at_reboot: already up to date
2023-04-29 08:30:15: at_reboot: checking init in /boot/config.txt...
2023-04-29 08:30:14: at_reboot: loading config
2023-04-29 08:30:14: at_reboot: atreboot.sh started[/code]
Stevie_AN
Bin einen Schritt weiter, scheinbar liegt es an der Kommunikation zu den SMA Komponenten. Sowohl vom Sunny Home Manager, als auch vom SMA Wechselrichter kommen keine Daten mehr.
Bin nun wirklich gerade ratlos :-(
Been thanked: 52 times
Auf welche Version hast du denn aktualisiert?
Stevie_AN
Aktuell auf die aktuelle Nighty. Versuchsweise dann auch wieder zurück auf die Beta und Stable.
Auch ein anschließendes Einspielen des vorher angelegten Backups brachte nichts.
Echt komisch...!
Stevie_AN
ERLEDIGT! Keine Daten mehr nach Update
So, jetzt läuft es wieder einigermaßen.
Leider kann ich nicht sagen, was genau dazu geführt hat, dass keinerlei Kommunikation zwischen der OpenWB und den SMA-Komponenten mehr funktioniert hat. Meine Vermutung ist aktuell, dass durch das Update irgendwie ein Modul auf der OpenWB beschädigt wurde.
Glücklicherweise hab ich damals vor Inbetriebnahme der OpenWB ein Image der SD-Karte angefertigt, welches ich heute neu auf die SD-Karte geschrieben habe. Anschließend direkt ein Update auf die aktuelle Beta: 1.9.299.6 gemacht und alles neu konfiguriert.
Jetzt brauche ich nur leider wieder bei Gelegenheit meinen SSH-Zugang zurück ;)
Has thanked: 269 times
Been thanked: 287 times
Bitte an den Support wenden. Ab Di sollte das wieder möglich sein.
