Laut Hilfetext hast du recht, ändert aber nichts.
2023-07-01 08:40:30,325 - {root:64} - {INFO:MainThread} - # ***Start***
2023-07-01 08:40:30,411 - {modules.devices.solax.device:55} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.solax.counter.SolaxCounter object at 0x72375e08>, 'component1': <modules.devices.solax.inverter.SolaxInverter object at 0x72367e20>, 'component2': <modules.devices.solax.bat.SolaxBat object at 0x7236e550>}
2023-07-01 08:40:30,413 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['Solax Zähler']
2023-07-01 08:40:30,413 - {modules.devices.solaredge.device:100} - {DEBUG:device1} - Start device reading {'component3': <modules.devices.solaredge.inverter.SolaredgeInverter object at 0x72375d18>}
2023-07-01 08:40:30,416 - {modules.common.component_context:51} - {DEBUG:device2} - Update Komponenten ['openDTU']
2023-07-01 08:40:30,419 - {modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-07-01 08:40:30,421 - {modules.common.component_context:24} - {DEBUG:cp6} - Update Komponente ['Ladepunkt']
2023-07-01 08:40:30,439 - {urllib3.connectionpool:227} - {DEBUG:device2} - Starting new HTTP connection (1): 192.168.0.30:80
2023-07-01 08:40:30,594 - {urllib3.connectionpool:452} - {DEBUG:device2} - http://192.168.0.30:80 "GET /api/livedata/status HTTP/1.1" 200 1113
2023-07-01 08:40:30,596 - {modules.common.req:11} - {DEBUG:device2} - Get-Response: {"inverters":[{"serial":"112483194497","name":"PV-Tisch","order":0,"data_age":0,"poll_enabled":true,"reachable":true,"producing":true,"limit_relative":100,"limit_absolute":500,"AC":{"0":{"Power":{"v":44.40000153,"u":"W","d":1},"Voltage":{"v":239.6000061,"u":"V","d":1},"Current":{"v":0.189999998,"u":"A","d":2},"Power DC":{"v":46.90000153,"u":"W","d":1},"YieldDay":{"v":83,"u":"Wh","d":0},"YieldTotal":{"v":14.03999996,"u":"kWh","d":3},"Frequency":{"v":50.00999832,"u":"Hz","d":2},"PowerFactor":{"v":1,"u":"","d":3},"ReactivePower":{"v":0,"u":"var","d":1},"Efficiency":{"v":94.66950989,"u":"%","d":3}}},"DC":{"0":{"name":{"u":""},"Power":{"v":46.90000153,"u":"W","d":1},"Voltage":{"v":44.59999847,"u":"V","d":1},"Current":{"v":1.049999952,"u":"A","d":2},"YieldDay":{"v":83,"u":"Wh","d":0},"YieldTotal":{"v":14.03999996,"u":"kWh","d":3}}},"INV":{"0":{"Temperature":{"v":20.5,"u":"°C","d":1}}},"events":1}],"total":{"Power":{"v":44.40000153,"u":"W","d":1},"YieldDay":{"v":83,"u":"Wh","d":0},"YieldTotal":{"v":14.03999996,"u":"kWh","d":3}},"hints":{"time_sync":false,"radio_problem":false,"default_password":false}}
2023-07-01 08:40:31,323 - {modules.common.store._api:26} - {DEBUG:device2} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-44.40000153, exported=14039.99996, dc_power=None)
2023-07-01 08:40:31,324 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['SolarEdge Wechselrichter']
2023-07-01 08:40:31,400 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[230.0, 230.0, 230.0], powers=[970, -611, -355], currents=[4.217391304347826, -2.6565217391304348, -1.5434782608695652], power_factors=[0.0, 0.0, 0.0], imported=3609480, exported=7847650, power=0, frequency=50.0)
2023-07-01 08:40:31,402 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['Solax Wechselrichter']
2023-07-01 08:40:31,411 - {modules.devices.solaredge.scale:16} - {DEBUG:device1} - Registers [20240], Scale -1
2023-07-01 08:40:31,419 - {modules.devices.solaredge.scale:16} - {DEBUG:device1} - Registers [72778168], Scale 0
2023-07-01 08:40:31,556 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-375, exported=2215100, dc_power=None)
2023-07-01 08:40:31,558 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['Solax Speicher']
2023-07-01 08:40:31,693 - {modules.devices.solaredge.scale:16} - {DEBUG:device1} - Registers [288, 285, 288], Scale -2
2023-07-01 08:40:31,718 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1688193621.494054, power=612, imported=67859.98131216201, exported=48198.17199214435)
2023-07-01 08:40:31,719 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.00284016, power1: 612, power2: 576
2023-07-01 08:40:31,720 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: 1.68706
2023-07-01 08:40:31,721 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 1.68706 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1688193631.7186334, power=576, imported=67861.66836775217, exported=48198.17199214435)
2023-07-01 08:40:31,727 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=67861.66836775217, exported=48198.17199214435, power=576, soc=91)
2023-07-01 08:40:31,806 - {modules.devices.solaredge.scale:16} - {DEBUG:device1} - Registers [20538], Scale -1
2023-07-01 08:40:31,807 - {modules.common.component_state:95} - {DEBUG:device1} - currents sign wrong [2.88, 2.85, 2.88]
2023-07-01 08:40:31,807 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[2.88, 2.85, 2.88], power=-2024.0, exported=72778168.0, dc_power=-2053.8)
2023-07-01 08:40:31,811 - {modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['Solax Wechselrichter']
2023-07-01 08:40:31,813 - {modules.common.store._api:26} - {DEBUG:component1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-375, exported=2215100, dc_power=None)
2023-07-01 08:40:31,813 - {modules.common.component_context:24} - {DEBUG:component3} - Update Komponente ['SolarEdge Wechselrichter']
2023-07-01 08:40:31,814 - {modules.common.store._api:30} - {INFO:component1} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-375, exported=2215100, dc_power=None)
2023-07-01 08:40:31,815 - {modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['Solax Speicher']
2023-07-01 08:40:31,817 - {modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-07-01 08:40:31,817 - {modules.common.store._api:26} - {DEBUG:component3} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-2024.0, exported=72778168.0, dc_power=None)
2023-07-01 08:40:31,835 - {modules.common.store._api:30} - {INFO:component3} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-2024.0, exported=72778168.0, dc_power=None)
2023-07-01 08:40:31,824 - {modules.common.component_context:24} - {DEBUG:component7} - Update Komponente ['openDTU']
2023-07-01 08:40:31,831 - {modules.common.store._api:30} - {INFO:component2} - Saving BatState(imported=67861.66836775217, exported=48198.17199214435, power=576, soc=91)
2023-07-01 08:40:31,821 - {modules.common.component_context:24} - {DEBUG:cp6} - Update Komponente ['Ladepunkt']
2023-07-01 08:40:31,839 - {modules.common.store._api:26} - {DEBUG:component7} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-44.40000153, exported=14039.99996, dc_power=None)
2023-07-01 08:40:31,853 - {modules.common.store._api:30} - {INFO:component7} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-44.40000153, exported=14039.99996, dc_power=None)
2023-07-01 08:40:31,918 - {modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['Solax Zähler']
2023-07-01 08:40:31,919 - {modules.common.store._api:30} - {INFO:component0} - Saving CounterState(voltages=[230.0, 230.0, 230.0], powers=[970, -611, -355], currents=[4.217391304347826, -2.6565217391304348, -1.5434782608695652], power_factors=[0.0, 0.0, 0.0], imported=3609480, exported=7847650, power=0, frequency=50.0)
2023-07-01 08:40:32,110 - {control.bat_all:153} - {DEBUG:MainThread} - Verbleibende Speicher-Leistung durch maximale Ausgangsleistung auf 626W begrenzt.
2023-07-01 08:40:32,110 - {control.bat_all:192} - {DEBUG:MainThread} - Erlaubte Entlade-Leistung nutzen 626W
2023-07-01 08:40:32,111 - {control.bat_all:164} - {INFO:MainThread} - 626W verbleibende Speicher-Leistung
2023-07-01 08:40:32,114 - {control.counter:138} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [66.07, 65.69, 64.57]A
2023-07-01 08:40:32,115 - {control.counter:161} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 44640.7W
2023-07-01 08:40:32,117 - {control.chargepoint.chargepoint:663} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-07-01 08:40:32,118 - {control.chargepoint.chargepoint:646} - {DEBUG:MainThread} - Phasenzahl Lademodus: 1
2023-07-01 08:40:32,121 - {control.chargepoint.chargepoint:855} - {INFO:MainThread} - LP 4, EV: Standard-Fahrzeug (EV-Nr.0): Theoretisch benötigter Strom 6A, Lademodus pv_charging, Submodus: Chargemode.PV_CHARGING, Phasen: 1, Priorität: False, max. Ist-Strom: 7.29
2023-07-01 08:40:32,136 - {control.chargepoint.chargepoint:272} - {INFO:MainThread} - LP 6: Keine Ladung, da kein Auto angesteckt ist.
2023-07-01 08:40:32,144 - {control.data:337} - {INFO:MainThread} - bat2
BatData(get=Get(soc=91, daily_exported=1692.29, daily_imported=1737.14, imported=67861.67, exported=48198.17, fault_state=0, fault_str='Kein Fehler.', power=576))
2023-07-01 08:40:32,149 - {control.data:307} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=91, daily_exported=1692.29, daily_imported=1737.14, imported=67861.67, exported=48198.17, power=576), set=Set(charging_power_left=626, switch_on_soc_reached=True))
2023-07-01 08:40:32,155 - {control.data:308} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=1599.12, daily_exported=0, power=1640.7, imported=8509569.58, exported=0))
2023-07-01 08:40:32,157 - {control.data:337} - {INFO:MainThread} - cp4
ChargepointData(get=Get(charge_state=True, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[7.29, 0.03, 0.03], daily_imported=1599.12, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=2532096.92, phases_in_use=1, plug_state=True, power=1640.7, rfid_timestamp=None, rfid=None, state_str=None, voltages=[237.41, 238.99, 240.63]), set=Set(change_ev_permitted=[True, ''], charging_ev=0, charging_ev_prev=0, current=9.19, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', imported_at_mode_switch=2532006.84, imported_at_plugtime=2510919.92, imported_since_mode_switch=85.93000000016764, imported_since_plugged=21172.850000000093, range_charged=0.5370625000010477, time_charged='0:03', timestamp_start_charging='07/01/2023, 08:37:24'), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time='06/30/2023, 16:22:11', required_power=1380.0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x707514d8>), config=Config(configuration={'mode': 'duo', 'ip_address': 'localhost', 'duo_num': 1}, ev=0, name='Draußen', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=4))
2023-07-01 08:40:32,159 - {control.data:337} - {INFO:MainThread} - cp6
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=5977472.66, phases_in_use=1, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[240.35, 237.45, 239.27]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=1, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x7076d058>), config=Config(configuration={'mode': 'duo', 'ip_address': 'localhost', 'duo_num': 2}, ev=0, name='Drinnen', type='internal_openwb', template=0, connected_phases=3, phase_1=3, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=6))
2023-07-01 08:40:32,160 - {control.data:337} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=0, max_current_multi_phases=16, max_current_single_phase=16, name='Standard Ladepunkt-Vorlage', rfid_enabling=False, valid_tags=[])
2023-07-01 08:40:32,162 - {control.data:337} - {INFO:MainThread} - counter0
CounterData(config=Config(max_currents=[63, 63, 63], max_total_power=43000), get=Get(powers=[970, -611, -355], currents=[4.22, -2.66, -1.54], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], unbalanced_load=0, frequency=50.0, daily_exported=2350, daily_imported=2350, imported=3609480, exported=7847650, fault_state=0, fault_str='Kein Fehler.', power=0), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=44640.7, raw_currents_left=[66.07, 65.69, 64.57], surplus_power_left=0, state_str=''))
2023-07-01 08:40:32,163 - {control.data:312} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=True), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': []}, {'id': 3, 'type': 'inverter', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}, {'id': 6, 'type': 'cp', 'children': []}, {'id': 7, 'type': 'inverter', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=226.69999999999996, invalid_home_consumption=0, daily_yield_home_consumption=17897.03, disengageable_smarthome_power=0))
2023-07-01 08:40:32,164 - {control.data:337} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=101), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='none', amount=1000, soc=50))))
2023-07-01 08:40:32,165 - {control.data:337} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=4, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=True, control_pilot_interruption_duration=4, average_consump=16000, min_current=6, max_current_single_phase=16, battery_capacity=64000, nominal_difference=2, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=6, required_currents=[6, 0.0, 0.0], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.PV_CHARGING: 'pv_charging'>, chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=4), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2023-07-01 08:40:32,166 - {control.data:337} - {INFO:MainThread} - ev4
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-07-01 08:40:32,169 - {control.data:337} - {INFO:MainThread} - ev5
2023-07-01 08:40:32,171 - {control.data:337} - {INFO:MainThread} - ev6
2023-07-01 08:40:32,171 - {control.data:337} - {INFO:MainThread} - et0
2023-07-01 08:40:32,174 - {control.data:316} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=200, control_range=[-230, 0], feed_in_yield=15000, phase_switch_delay=5, phases_to_use=0, rundown_power=4000, rundown_soc=50, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1000), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.35, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-07-01 08:40:32,175 - {control.data:317} - {INFO:MainThread} - general_data-display
local
2023-07-01 08:40:32,176 - {control.data:318} - {INFO:MainThread} - graph_data
2023-07-01 08:40:32,180 - {control.data:319} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x70749418>), led=Led(active=False), rfid=Rfid(active=False))
2023-07-01 08:40:32,181 - {control.data:337} - {INFO:MainThread} - pv1
PvData(config=Config(max_ac_out=17000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=1800, monthly_exported=0, yearly_exported=0, exported=2215100, fault_state=0, fault_str='Kein Fehler.', power=-375))
2023-07-01 08:40:32,181 - {control.data:337} - {INFO:MainThread} - pv3
PvData(config=Config(max_ac_out=6000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=3704.0, monthly_exported=0, yearly_exported=0, exported=72778168.0, fault_state=0, fault_str='Kein Fehler.', power=-2024.0))
2023-07-01 08:40:32,185 - {control.data:337} - {INFO:MainThread} - pv7
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=14037.0, monthly_exported=0, yearly_exported=0, exported=14040.0, fault_state=0, fault_str='Kein Fehler.', power=-44.4))
2023-07-01 08:40:32,186 - {control.data:321} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=19541.0, monthly_exported=0, yearly_exported=0, exported=75007308.0, power=-2443.4))
2023-07-01 08:40:32,187 - {control.data:337} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.0.221', 'current_commit': '2023-06-30 14:22:42 +0200 [6139031a3]', 'current_branch': 'master', 'current_branch_commit': '2023-06-30 15:24:54 +0200 [c0c5f511c]', 'current_missing_commits': ['2023-06-30 15:24:54 +0200 [c0c5f511c] - fix duo with two busses, configurable/backup_clouds is valid topic (#996)'], 'boot_done': True, 'datastore_version': 13, 'dataprotection_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.RC2.1', 'lastlivevaluesJson': {'timestamp': 1688193621, 'time': '08:40:21', 'grid': 0.0, 'house-power': 0.286, 'charging-all': 1.566, 'pv-all': 2.464, 'cp4-power': 1.566, 'cp6-power': 0.0, 'bat-all-power': 0.612, 'bat-all-soc': 91}, 'usage_terms_acknowledged': True, 'module_update_completed': True}
2023-07-01 08:40:32,188 - {control.data:350} - {INFO:MainThread} - device0
{'name': 'Solax', 'type': 'solax', 'id': 0, 'configuration': {'modbus_id': 1, 'ip_address': '192.168.0.132'}}
2023-07-01 08:40:32,189 - {control.data:352} - {INFO:MainThread} - component0
{'name': 'Solax Zähler', 'type': 'counter', 'id': 0, 'configuration': {}}
2023-07-01 08:40:32,191 - {control.data:352} - {INFO:MainThread} - component1
{'name': 'Solax Wechselrichter', 'type': 'inverter', 'id': 1, 'configuration': {}}
2023-07-01 08:40:32,192 - {control.data:352} - {INFO:MainThread} - component2
{'name': 'Solax Speicher', 'type': 'bat', 'id': 2, 'configuration': {}}
2023-07-01 08:40:32,193 - {control.data:350} - {INFO:MainThread} - device1
{'name': 'SolarEdge', 'type': 'solaredge', 'id': 1, 'configuration': {'port': 502, 'ip_address': '192.168.0.207'}}
2023-07-01 08:40:32,196 - {control.data:352} - {INFO:MainThread} - component3
{'name': 'SolarEdge Wechselrichter', 'type': 'inverter', 'id': 3, 'configuration': {'modbus_id': 1}}
2023-07-01 08:40:32,200 - {control.data:350} - {INFO:MainThread} - device2
{'name': 'openDTU', 'type': 'json', 'id': 2, 'configuration': {'url': 'http://192.168.0.30/api/livedata/status'}}
2023-07-01 08:40:32,203 - {control.data:352} - {INFO:MainThread} - component7
{'name': 'openDTU', 'type': 'inverter', 'id': 7, 'configuration': {'jq_power': '.total.Power.v', 'jq_exported': '.total.YieldTotal.v *1000'}}
2023-07-01 08:40:32,204 - {control.data:324} - {INFO:MainThread} -
2023-07-01 08:40:32,205 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-07-01 08:40:32,206 - {control.algorithm.algorithm:63} - {DEBUG:MainThread} - Ladepunkt 4: Prüfen, ob Phasenumschaltung durchgeführt werden soll.
2023-07-01 08:40:32,212 - {control.counter:198} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 511.0W
2023-07-01 08:40:32,213 - {control.ev:519} - {DEBUG:MainThread} - Genutzter Strom: 7.29A, Überschuss: 511.0W, benötigte neue Leistung: -460W
2023-07-01 08:40:32,214 - {control.counter:198} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 511.0W
2023-07-01 08:40:32,216 - {control.counter:198} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 511.0W
2023-07-01 08:40:32,217 - {control.counter:361} - {DEBUG:MainThread} - LP4 Switch-Off-Threshold prüfen: -511.0W, Schwelle: 50W, freigegebener Überschuss 0W, Einspeisegrenze 0W
2023-07-01 08:40:32,218 - {control.algorithm.algorithm:31} - {INFO:MainThread} - **Mindestrom setzen**
2023-07-01 08:40:32,226 - {control.algorithm.min_current:18} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.PV_CHARGING - False, Zähler 0
2023-07-01 08:40:32,231 - {control.counter:169} - {DEBUG:MainThread} - Zähler 0: [60.06999999999999, 65.69, 64.57]A verbleibende Ströme, 43260.7W verbleibende Leistung
2023-07-01 08:40:32,232 - {control.algorithm.common:87} - {INFO:MainThread} - LP4: Stromstärke 6A
2023-07-01 08:40:32,234 - {control.algorithm.algorithm:33} - {INFO:MainThread} - **Sollstrom setzen**
2023-07-01 08:40:32,241 - {control.counter:211} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 771.6999999999971W
2023-07-01 08:40:32,242 - {control.counter:470} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 771.6999999999971W
2023-07-01 08:40:32,242 - {control.algorithm.algorithm:39} - {INFO:MainThread} - **PV-geführten Strom setzen**
2023-07-01 08:40:32,246 - {control.algorithm.filter_chargepoints:118} - {DEBUG:MainThread} - Geordnete Ladepunkte [4]
2023-07-01 08:40:32,247 - {control.algorithm.surplus_controlled:42} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.PV_CHARGING - False, Zähler 0
2023-07-01 08:40:32,248 - {control.loadmanagement:82} - {DEBUG:MainThread} - Leistungsüberschreitung auf 771.6999999999971W korrigieren: [10.0, 0.0, 0.0]
2023-07-01 08:40:32,251 - {control.counter:176} - {DEBUG:MainThread} - Zähler 0: [56.71478260869566, 65.69, 64.57]A verbleibende Ströme, -2.2737367544323206e-13W verbleibender Überschuss
2023-07-01 08:40:32,253 - {control.algorithm.common:87} - {INFO:MainThread} - LP4: Stromstärke 9.355217391304336A
2023-07-01 08:40:32,258 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-07-01 08:40:32,263 - {control.chargelog:52} - {DEBUG:MainThread} - imported_since_mode_switch 90.0800000000745 counter 2532096.92
2023-07-01 08:40:32,271 - {control.process:115} - {INFO:MainThread} - LP4: set current 9.36 A, state CHARGING_ALLOWED
2023-07-01 08:40:32,278 - {modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-07-01 08:40:32,280 - {modules.common.component_context:24} - {DEBUG:cp6} - Update Komponente ['Ladepunkt']
2023-07-01 08:40:32,325 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-07-01 08:40:32,534 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-07-01 08:40:32,589 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-07-01 08:40:35,625 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-07-01 08:40:40,639 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-07-01 08:40:40,640 - {root:64} - {INFO:MainThread} - # ***Start***
