openWB Variante? (Selbst installiert, Standalone, series1/2) openWB series2 standard+
2023-07-04 16:25:11: PID: 4902: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
2023-07-04 16:25:07: PID: 3246: **** Regulation loop needs 6 seconds (LV2) at 62 cleanup /var/www/html/openWB/regel.sh
set-currents: setze ladung auf 6A
2023-07-04 16:25:06: PID: 3246: uberschuss 2221 wattbezug -2221 ladestatus 1 llsoll 6 pvwatt -2752 mindestuberschussphasen 1500 wattkombiniert 2233 schaltschwelle 230 (LV2) at 586 main /var/www/html/openWB/regel.sh
2023-07-04 16:25:06: PID: 3246: anzahlphasen 1 (LV1) at 585 main /var/www/html/openWB/regel.sh
2023-07-04 16:25:06: PID: 3246: Timing Umschaltung: 720 / 240 (LV1) at 17 u1p3pswitch u1p3p.sh
2023-07-04 16:25:05: PID: 3246: automatische Umschaltung aktiv (LV1) at 16 u1p3pswitch u1p3p.sh
2023-07-04 16:25:05: PID: 3246: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 186 main /var/www/html/openWB/regel.sh
2023-07-04 16:25:05: PID: 3246: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1310 loadvars loadvars.sh
2023-07-04 16:25:05: PID: 3246: plugstatlp1 0 plugstatlp2 0 plugstatlp3 0 (LV1) at 1309 loadvars loadvars.sh
2023-07-04 16:25:05: PID: 3246: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1308 loadvars loadvars.sh
2023-07-04 16:25:05: PID: 3246: EVU 1:V/-3A 2: V/-3A 3: V/-3A (LV1) at 1307 loadvars loadvars.sh
2023-07-04 16:25:05: PID: 3246: lla3 0 llv3 232.7 llas13 llas23 soclp1 90 soclp2 (LV1) at 1306 loadvars loadvars.sh
2023-07-04 16:25:05: PID: 3246: lla2 0 llv2 233.8 llas12 llas22 sofortll 16 hausverbrauch 519 wattbezug -2221 uberschuss 2221 (LV1) at 1305 loadvars loadvars.sh
2023-07-04 16:25:04: PID: 3246: lla1 0 llv1 233.6 llas11 llas21 mindestuberschuss 1500 abschaltuberschuss 250 lademodus 2 (LV1) at 1304 loadvars loadvars.sh
2023-07-04 16:25:04: PID: 3246: pv1watt -2752 pv2watt pvwatt -2752 ladeleistung 12 llalt 6 nachtladen 0 nachtladen 0 minimalA 10 maximalA 16 (LV1) at 1303 loadvars loadvars.sh
2023-07-04 16:25:04: PID: 3246: speicherleistung 0 speichersoc 100 (LV1) at 1298 loadvars loadvars.sh
2023-07-04 16:25:04: PID: 3760: EVU RET: 0 (LV2) at 16 main modules/bezug_solaredge/main.sh
2023-07-04 16:25:04: PID: 30240: legacy run server: Completed running command in 0.29s: ["modules.devices.solaredge.device","counter","192.168.2.94","1502","1"]
2023-07-04 16:25:04: PID: 30240: soc.modules.common.store._api: Saving CounterState(powers=[-799.0, -712.0, -708.0], frequency=49.99, imported=5235927.0, currents=[-3.5, -3.1, -3.3000000000000003], voltages=[233.63, 233.84, 232.81], power_factors=[-0.9670000000000001, -0.9670000000000001, -0.8909], power=-2221.0, exported=6748166.0)
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.scale: Registers [6748166, 2908003, 3124700, 3184016, 5235927, 2800408, 2471780, 2432293], Scale 0
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.scale: Registers [-9670, -9670, -8909], Scale -2
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.scale: Registers [4999], Scale -2
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.scale: Registers [23363, 23384, 23281, 0, 0, 0, 0], Scale -2
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.scale: Registers [35, 31, 33], Scale -1
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.scale: Registers [2221, 799, 712, 708], Scale 0
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.device: Start device reading {'componentNone': <modules.devices.solaredge.counter.SolaredgeCounter object at 0x75fd82f0>}
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.device: Solaredge ModbusID: 1
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.device: Synergy Units: 1
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.device: Solaredge Bat-WR-gleiche IP: None, Externer WR: None, 2. Speicher: None, Speicherleistung subtrahieren: None 2. IP: None, Num: None
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.device: Solaredge Slave-IDs: [1, None, None, None]
2023-07-04 16:25:04: PID: 30240: modules.devices.solaredge.device: Solaredge IP: 192.168.2.94:1502
2023-07-04 16:25:04: PID: 30240: legacy run server: Received command ["modules.devices.solaredge.device","counter","192.168.2.94","1502","1"]
2023-07-04 16:25:04: PID: 3245: ##### cron5min.sh finished ##### (LV0) at 313 main /var/www/html/openWB/runs/cron5min.sh
2023-07-04 16:25:03: PID: 3710: BAT RET: (LV2) at 20 main modules/speicher_solaredge/main.sh
2023-07-04 16:25:03: PID: 30240: legacy run server: Completed running command in 0.40s: ["modules.devices.solaredge.device","inverter","192.168.2.94:1502","","1","none","none","none","1","
2023-07-04 16:25:03: PID: 30240: soc.modules.common.store._api: Saving InverterState(exported=6654696.280131862, dc_power=None, currents=[-3.95, -3.97, -3.96], power=-2752.9)
2023-07-04 16:25:03: PID: 30240: soc.modules.common.store._api: Saving BatState(exported=2450149.4741022177, imported=2881827.7542340783, power=0.0, soc=100.0)
2023-07-04 16:25:03: PID: 30240: modules.common.simcount._simcount: imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(exported=2450149.4741022177, imported=2881827.7542340783, power=0.0, timestamp=1688480703.44279)
2023-07-04 16:25:03: PID: 30240: modules.common.simcount._calculate: power did not change sign. Total energy: 0
2023-07-04 16:25:03: PID: 30240: modules.common.simcount._calculate: time passed: 0.00264194, power1: 0, power2: 0
2023-07-04 16:25:03: PID: 30240: modules.common.simcount._simcount: Previous state: SimCounterState(exported=2450149.4741022177, imported=2881827.7542340783, power=0.0, timestamp=1688480693.931793)
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.scale: Registers [2344, -1, -1], Scale -1
2023-07-04 16:25:03: PID: 3245: logfile cleanup triggered (LV1) at 310 main /var/www/html/openWB/runs/cron5min.sh
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.scale: Registers [4294967295, 4294967295, 4294967295, 4294967295, 65535, 4294770689, 4294836225, 65536], Scale 0
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.scale: Registers [-1, -1, -32768, -32768], Scale -32768
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.scale: Registers [27948], Scale -1
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.scale: Registers [395, 397, 396], Scale -2
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.scale: Registers [6223018], Scale 0
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.scale: Registers [27529], Scale -1
2023-07-04 16:25:03: PID: 30240: soc.modules.common.component_context: Update Komponente ['SolarEdge Wechselrichter']
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.device: Solaredge Bat-WR-gleiche IP: 1, Externer WR: 1, 2. Speicher: 0, Speicherleistung subtrahieren: 0 2. IP: none, Num: 1
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.device: Solaredge Slave-IDs: [1, none, none, none]
2023-07-04 16:25:03: PID: 30240: modules.devices.solaredge.device: Solaredge IP: 192.168.2.94:1502:
2023-07-04 16:25:03: PID: 30240: legacy run server: Received command ["modules.devices.solaredge.device","inverter","192.168.2.94:1502","","1","none","none","none","1","
2023-07-04 16:25:02: PID: 3495: push buttons disabled (LV1) at 41 pushButtonsSetup /var/www/html/openWB/runs/pushButtons/pushButtonsHelper.sh
2023-07-04 16:25:02: PID: 3495: rse disabled (LV1) at 41 rseSetup /var/www/html/openWB/runs/rse/rseHelper.sh
2023-07-04 16:25:02: PID: 3495: external openWB, daemon mode or socket mode not configured; checking network setup (LV1) at 96 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: legacy run server is already running (LV1) at 62 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: Starting legacy run server... (LV1) at 55 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: smart home handler is already running (LV1) at 48 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: Starting smart home handler... (LV1) at 45 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: mqtt handler is already running (LV1) at 38 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: Starting MQTT handler... (LV1) at 35 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: modbus tcp server already running (LV1) at 28 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: Starting modbus server... (LV1) at 25 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3495: Starting OpenWB services (LV0) at 22 start /var/www/html/openWB/runs/services.sh
2023-07-04 16:25:02: PID: 3245: current ip: 192.168.2.56 (LV1) at 293 main /var/www/html/openWB/runs/cron5min.sh
2023-07-04 16:25:01: PID: 3245: updating daily yield stats (LV1) at 164 main /var/www/html/openWB/runs/cron5min.sh
2023-07-04 16:25:01: PID: 3245: electricity provider not set up; skipping price update (LV2) at 160 main /var/www/html/openWB/runs/cron5min.sh
2023-07-04 16:25:01: PID: 3245: Netzschutz konfiguriert; aktuelle Frequenz: 4993 (LV1) at 109 main /var/www/html/openWB/runs/cron5min.sh
2023-07-04 16:25:01: PID: 3245: daily csv updated: /var/www/html/openWB/web/logging/data/daily/20230704.csv (LV1) at 101 main /var/www/html/openWB/runs/cron5min.sh
2023-07-04 16:25:01: PID: 3246: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
