2023-08-01 13:46:10,586 - {root:65} - {INFO:MainThread} - # ***Start***
2023-08-01 13:46:10,647 - {modules.common.component_context:51} - {DEBUG:device2} - Update Komponenten ['MQTT-Speicher', 'MQTT-Zähler', 'MQTT-Wechselrichter']
2023-08-01 13:46:10,648 - {modules.devices.mqtt.device:47} - {DEBUG:device2} - MQTT-Module müssen nicht ausgelesen werden.
2023-08-01 13:46:10,652 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-08-01 13:46:10,754 - {modules.common.component_context:24} - {DEBUG:component11} - Update Komponente ['MQTT-Wechselrichter']
2023-08-01 13:46:10,756 - {modules.common.component_context:24} - {DEBUG:component9} - Update Komponente ['MQTT-Speicher']
2023-08-01 13:46:10,757 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-08-01 13:46:10,788 - {modules.common.component_context:24} - {DEBUG:component10} - Update Komponente ['MQTT-Zähler']
2023-08-01 13:46:10,906 - {control.bat_all:200} - {DEBUG:MainThread} - Verbleibende Speicher-Leistung: -2091W
2023-08-01 13:46:10,923 - {control.bat_all:204} - {DEBUG:MainThread} - Reservierte Ladeleistung (200W) subtrahieren: -2291
2023-08-01 13:46:10,924 - {control.bat_all:164} - {INFO:MainThread} - -2291W verbleibende Speicher-Leistung
2023-08-01 13:46:10,929 - {control.counter:138} - {INFO:MainThread} - Verbleibende Ströme an Zähler 10: [11.96, 23.98, 11.8]A
2023-08-01 13:46:10,932 - {control.counter:161} - {INFO:MainThread} - Verbleibende Leistung an Zähler 10: 10972W
2023-08-01 13:46:10,942 - {control.chargepoint.chargepoint:271} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2023-08-01 13:46:10,956 - {control.data:337} - {INFO:MainThread} - bat9
BatData(get=Get(soc=52, daily_exported=3.69, daily_imported=1.14, imported=4529.15, exported=4304.68, fault_state=0, fault_str='Kein Fehler.', power=-2091))
2023-08-01 13:46:10,958 - {control.data:307} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=52, daily_exported=3.69, daily_imported=1.14, imported=4529.15, exported=4304.68, power=-2091), set=Set(charging_power_left=-2291, switch_on_soc_reached=False))
2023-08-01 13:46:10,959 - {control.data:308} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=0.0, daily_exported=0, power=0, imported=1633598.02, exported=0))
2023-08-01 13:46:10,961 - {control.data:337} - {INFO:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=81.0), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=1633598.02, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[231.45, 231.5, 233.42]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x711c50e8>), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=0, name='Interne openWB', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-08-01 13:46:10,962 - {control.data:337} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=0, max_current_multi_phases=16, max_current_single_phase=16, name='Standard Ladepunkt-Vorlage', rfid_enabling=False, valid_tags=[])
2023-08-01 13:46:10,964 - {control.data:337} - {INFO:MainThread} - counter10
CounterData(config=Config(max_currents=[16, 16, 16], max_total_power=11000), get=Get(powers=[874, -1844, 941], currents=[4.04, -7.98, 4.2], voltages=[231.3, 231.6, 233.8], power_factors=[0, 0, 0], unbalanced_load=0, frequency=50, daily_exported=0.0, daily_imported=0.0, imported=2854.7, exported=11246.44, fault_state=0, fault_str='Kein Fehler.', power=28), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=10972, raw_currents_left=[11.96, 23.98, 11.8], surplus_power_left=0, state_str=''))
2023-08-01 13:46:10,967 - {control.data:312} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=False), get=Get(hierarchy=[{'id': 10, 'type': 'counter', 'children': [{'id': 11, 'type': 'inverter', 'children': []}, {'id': 9, 'type': 'bat', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=3336, invalid_home_consumption=0, daily_yield_home_consumption=0.0, disengageable_smarthome_power=0))
2023-08-01 13:46:10,969 - {control.data:337} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=True, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=8, min_current=8, feed_in_limit=False, min_soc=0, max_soc=90), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='soc', amount=10000, soc=80))))
2023-08-01 13:46:10,971 - {control.data:337} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=True, control_pilot_interruption_duration=4, average_consump=14000, min_current=8, max_current_single_phase=16, battery_capacity=22000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=3, prio=True, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=81.0, soc_timestamp='07/30/2023, 20:07:00', force_soc_update=False, range=138.0, fault_state=0, fault_str='Kein Fehler.'))
2023-08-01 13:46:10,973 - {control.data:337} - {INFO:MainThread} - ev1
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=1, name='Ioniq 5', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str=''))
2023-08-01 13:46:10,977 - {control.data:337} - {INFO:MainThread} - ev3
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-08-01 13:46:10,978 - {control.data:337} - {INFO:MainThread} - et0
2023-08-01 13:46:10,979 - {control.data:337} - {INFO:MainThread} - et1
EvTemplateData(name='Ioniq Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=True, control_pilot_interruption=True, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=16, battery_capacity=77000, nominal_difference=1, keep_charge_active_duration=40)
2023-08-01 13:46:10,980 - {control.data:316} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=False, charging_power_reserve=200, control_range=[0, 230], feed_in_yield=15000, phase_switch_delay=7, phases_to_use=0, rundown_power=1000, rundown_soc=50, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=3), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.3, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-08-01 13:46:10,983 - {control.data:317} - {INFO:MainThread} - general_data-display
local
2023-08-01 13:46:10,987 - {control.data:318} - {INFO:MainThread} - graph_data
2023-08-01 13:46:10,988 - {control.data:319} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=300, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x711c5130>), led=Led(active=False), rfid=Rfid(active=False))
2023-08-01 13:46:10,989 - {control.data:337} - {INFO:MainThread} - pv11
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=6440, monthly_exported=0, yearly_exported=0, exported=18925500, fault_state=0, fault_str='Kein Fehler.', power=-1217))
2023-08-01 13:46:10,990 - {control.data:321} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=6440, monthly_exported=0, yearly_exported=0, exported=18925500, power=-1217))
2023-08-01 13:46:10,991 - {control.data:337} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.20.225', 'current_commit': '2023-07-31 16:11:22 +0200 [891eff2d6]', 'current_branch': 'master', 'current_branch_commit': '2023-07-31 16:11:22 +0200 [891eff2d6]', 'current_missing_commits': [], 'boot_done': True, 'datastore_version': 17, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.0.1-alpha.1', 'lastlivevaluesJson': {'timestamp': 1690890290, 'time': '13:44:50', 'grid': 0.028, 'house-power': 3.336, 'charging-all': 0.0, 'pv-all': 1.217, 'cp3-power': 0.0, 'ev0-soc': 81.0, 'bat-all-power': -2.091, 'bat-all-soc': 52}, 'module_update_completed': True}
2023-08-01 13:46:10,994 - {control.data:350} - {INFO:MainThread} - device2
{'name': 'MQTT', 'type': 'mqtt', 'id': 2, 'configuration': {}}
2023-08-01 13:46:10,995 - {control.data:352} - {INFO:MainThread} - component9
{'name': 'MQTT-Speicher', 'type': 'bat', 'id': 9, 'configuration': {}}
2023-08-01 13:46:10,996 - {control.data:352} - {INFO:MainThread} - component10
{'name': 'MQTT-Zähler', 'type': 'counter', 'id': 10, 'configuration': {}}
2023-08-01 13:46:10,998 - {control.data:352} - {INFO:MainThread} - component11
{'name': 'MQTT-Wechselrichter', 'type': 'inverter', 'id': 11, 'configuration': {}}
2023-08-01 13:46:10,999 - {control.data:324} - {INFO:MainThread} -
2023-08-01 13:46:11,000 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-08-01 13:46:11,002 - {control.algorithm.algorithm:31} - {INFO:MainThread} - **Mindestrom setzen**
2023-08-01 13:46:11,007 - {control.algorithm.algorithm:33} - {INFO:MainThread} - **Sollstrom setzen**
2023-08-01 13:46:11,012 - {control.counter:211} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-08-01 13:46:11,014 - {control.counter:470} - {DEBUG:MainThread} - Zähler 10: Begrenzung der verbleibenden Leistung auf 0W
2023-08-01 13:46:11,015 - {control.algorithm.algorithm:44} - {INFO:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-08-01 13:46:11,017 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-08-01 13:46:11,025 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-08-01 13:46:11,046 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-08-01 13:46:11,267 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-08-01 13:46:11,444 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-08-01 13:46:15,456 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-08-01 13:46:15,458 - {root:52} - {DEBUG:MainThread} - Don't start multiple instances of smarthome thread.
2023-08-01 13:46:20,469 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-08-01 13:46:20,471 - {root:65} - {INFO:MainThread} - # ***Start***
