Sorry, dass es etwas gedauert hat. Ich musste erst nochmals die SD-Karte wechseln, da ich im Moment noch die 1.9 produktiv verwende. Die zwei EVSE und die zwei Zähler werden erkannt, aber es gibt einen Fehler "LP1 gleiches Device wie LP0". Sie selbst:
2023-08-17 07:56:29,752 - {modules.internal_chargepoint_handler.clients:134} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-08-17 07:56:29,904 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:56:29,906 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-08-17 07:56:30,972 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-08-17 07:56:31,174 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:56:31,382 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:56:31,392 - {modules.internal_chargepoint_handler.clients:139} - {ERROR:Internal Chargepoint} - LP1 gleiches Device wie LP0
2023-08-17 07:56:31,547 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-17 07:56:31,549 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP1: 2
2023-08-17 07:56:32,620 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 106
2023-08-17 07:56:32,771 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-17 07:56:32,964 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-17 07:56:35,003 - {modules.internal_chargepoint_handler.clients:134} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-08-17 07:56:35,157 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:56:35,159 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-08-17 07:56:36,215 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-08-17 07:56:36,400 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:56:36,590 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:56:36,606 - {modules.internal_chargepoint_handler.clients:139} - {ERROR:Internal Chargepoint} - LP1 gleiches Device wie LP0
2023-08-17 07:56:36,759 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-17 07:56:36,761 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP1: 2
2023-08-17 07:56:37,818 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 106
2023-08-17 07:56:37,972 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-17 07:56:38,195 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-17 07:57:46,027 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:57:46,081 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 62, in get_values
plug_state, charge_state, self.set_current_evse = self.__client.evse_client.get_plug_charge_state()
File "/var/www/html/openWB/packages/modules/common/evse.py", line 39, in get_plug_charge_state
set_current, _, state_number = self.client.read_holding_registers(
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 118, in read_holding_registers
return self.__read_registers(
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 100, in __read_registers
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 222, in update
state = self.module.get_values(phase_switch_cp_active, rfid_data.last_tag)[0]
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 103, in get_values
raise FaultState.error(__name__ + " " + str(type(e)) + " " + str(e)) from e
modules.common.fault_state.FaultState: ('modules.internal_chargepoint_handler.chargepoint_module <class \'modules.common.fault_state.FaultState\'> ("modules.common.modbus <class \'modules.common.fault_state.FaultState\'> (\'modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response\', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)', <FaultStateLevel.ERROR: 2>)
2023-08-17 07:59:01,342 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:59:01,385 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
2023-08-17 07:59:42,401 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 07:59:42,443 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
2023-08-17 08:00:59,955 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 08:01:00,000 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
2023-08-17 08:02:17,502 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 08:02:17,548 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
2023-08-17 08:02:52,888 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 08:02:52,935 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
modules.common.fault_state.FaultState: ('modules.internal_chargepoint_handler.chargepoint_module <class \'modules.common.fault_state.FaultState\'> ("modules.common.modbus <class \'modules.common.fault_state.FaultState\'> (\'modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)\', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)', <FaultStateLevel.ERROR: 2>)
2023-08-17 08:03:10,366 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-08-17 08:03:10,409 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
