Interner Ladepunkt lädt nicht mehr
Kitmgue
Has thanked: 6 times
Beitrag von Kitmgue »
Leider lädt aus irgendeinem Grund die openWB (interner Ladepunkt) bei mir nicht mehr.
Im Logfile des internen Ladepunkts finde ich sowas:
2023-08-19 13:09:44,082 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:09:44,084 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b49ec8>
2023-08-19 13:09:44,085 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-08-19 13:09:45,099 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b49ec8>
2023-08-19 13:09:45,100 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:5 antwortet nicht.
2023-08-19 13:09:45,149 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-08-19 13:09:45,310 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:09:45,501 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:09:45,504 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-08-19 13:09:45,511 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-08-19 13:09:45,512 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:167} - {DEBUG:Internal Chargepoint} - ***Start***
2023-08-19 13:09:45,514 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:169} - {DEBUG:Internal Chargepoint} - {'cp0': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp=None, phases_to_use=0, set_current=0, trigger_phase_switch=False), 'cp1': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp=None, phases_to_use=0, set_current=0, trigger_phase_switch=False), 'global_data': GlobalHandlerData(heartbeat=0, parent_ip=None, configured=True), 'rfid_data': RfidData(last_tag='')}
2023-08-19 13:09:46,075 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr <class 'KeyError'> 'debug_level', Traceback:
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 179, in loop
    _loop()
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 170, in _loop
    log.setLevel(SubData.system_data["system"].data["debug_level"])
KeyError: 'debug_level'
2023-08-19 13:09:54,380 - {modules.internal_chargepoint_handler.clients:134} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-08-19 13:09:54,535 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:09:54,536 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-08-19 13:09:55,605 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-08-19 13:09:55,765 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:09:55,973 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:09:56,441 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:231} - {ERROR:Internal Chargepoint} - Heartbeat Fehler seit 166s keine Verbindung. Stoppe Ladung.
2023-08-19 13:09:58,073 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:231} - {ERROR:Internal Chargepoint} - Heartbeat Fehler seit 168s keine Verbindung. Stoppe Ladung.
2023-08-19 13:09:59,676 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:231} - {ERROR:Internal Chargepoint} - Heartbeat Fehler seit 169s keine Verbindung. Stoppe Ladung.
2023-08-19 13:15:29,257 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:15:29,312 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 62, in get_values
    plug_state, charge_state, self.set_current_evse = self.__client.evse_client.get_plug_charge_state()
  File "/var/www/html/openWB/packages/modules/common/evse.py", line 39, in get_plug_charge_state
    set_current, _, state_number = self.client.read_holding_registers(
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 118, in read_holding_registers
    return self.__read_registers(
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 100, in __read_registers
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 222, in update
    state = self.module.get_values(phase_switch_cp_active, rfid_data.last_tag)[0]
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 103, in get_values
    raise FaultState.error(__name__ + " " + str(type(e)) + " " + str(e)) from e
modules.common.fault_state.FaultState: ('modules.internal_chargepoint_handler.chargepoint_module <class \'modules.common.fault_state.FaultState\'> ("modules.common.modbus <class \'modules.common.fault_state.FaultState\'> (\'modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)\', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)', <FaultStateLevel.ERROR: 2>)
2023-08-19 13:31:16,288 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:131} - {DEBUG:Internal Chargepoint} - Init internal chargepoint as series
2023-08-19 13:31:16,289 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Interner Ladepunkt 0']
2023-08-19 13:31:16,291 - {modules.internal_chargepoint_handler.clients:121} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0-port0')]
2023-08-19 13:31:16,292 - {modules.internal_chargepoint_handler.clients:123} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-08-19 13:31:16,292 - {modules.internal_chargepoint_handler.clients:134} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-08-19 13:31:16,443 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:31:16,444 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b8f0b8>
2023-08-19 13:31:16,444 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-08-19 13:31:17,456 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b8f0b8>
2023-08-19 13:31:17,457 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:5 antwortet nicht.
2023-08-19 13:31:17,513 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-08-19 13:31:17,706 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:31:17,929 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:31:17,930 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-08-19 13:31:17,955 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-08-19 13:31:19,962 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:131} - {DEBUG:Internal Chargepoint} - Init internal chargepoint as series
2023-08-19 13:31:19,963 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Interner Ladepunkt 0']
2023-08-19 13:31:19,965 - {modules.internal_chargepoint_handler.clients:121} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0-port0')]
2023-08-19 13:31:19,966 - {modules.internal_chargepoint_handler.clients:123} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-08-19 13:31:19,967 - {modules.internal_chargepoint_handler.clients:134} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-08-19 13:31:20,137 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:31:20,157 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b8fee0>
2023-08-19 13:31:20,164 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-08-19 13:31:21,217 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b8fee0>
2023-08-19 13:31:21,218 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:5 antwortet nicht.
2023-08-19 13:31:21,270 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-08-19 13:31:21,446 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:31:21,670 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 15
2023-08-19 13:31:21,671 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-08-19 13:31:21,694 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-08-19 13:31:21,695 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:169} - {DEBUG:Internal Chargepoint} - ***Start***
2023-08-19 13:31:21,696 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:171} - {DEBUG:Internal Chargepoint} - {'cp0': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='3', phases_to_use=3, set_current=0, trigger_phase_switch=False), 'cp1': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp=None, phases_to_use=0, set_current=0, trigger_phase_switch=False), 'global_data': GlobalHandlerData(heartbeat=1692444680, parent_ip='localhost', configured=True), 'rfid_data': RfidData(last_tag='')}
2023-08-19 13:31:21,702 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr <class 'KeyError'> 'debug_level', Traceback:
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 181, in loop
    _loop()
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 172, in _loop
Ist da irgendwas von der Hardware kaputt?
Verhalten ist sowohl mit dem 2.1.0 Release als auch mit dem aktuellen Master (2023-08-17 16:08:06 +0200 [8e5805847]).
Gleiches BEV lädt am externen Ladepunkt (smartWB) ohne Probleme.
openWB series2 standard+
LP1 : intern
LP2: smartWB
(manueller SoC für beide LP)
EVU: Sunny Home Manager 2.0
kein Speicher
crazy
Re: Interner Ladepunkt lädt nicht mehr
Beitrag von crazy »
Kitmgue
Interessant. Danke für den Hinweis.
Wobei dort ja auch das eingesteckte BEV nicht erkannt wird. Das hingegen ist bei mir der Fall. Es wird auch angeblich die üblichen 6A zur Verfügung gestellt.
Aber vielleicht ist es trotzdem die gleiche Ursache. Mal schauen, was das nächste Update bringt.
Frage mich nur, wieso es vorher funktioniert hat.
LP1 : intern
LP2: smartWB
kein Speicher
crazy
Beitrag von crazy »
bin auf meiner wallbox zurueck auf stand fff5be1a9 (08.08., 10:27)
da funktioniert noch alles. meine, so um den 15.08. rum
hat sich was essentielles geaendert. aber updates kommen ja
zut
Has thanked: 41 times
Been thanked: 34 times
Beitrag von zut »
Ich hatte gerade Ähnliches erlebt: viewtopic.php?t=7404
Du könntest - angefangen beim Ladepunkt - die Geräte löschen und neu anlegen. Das hat mir geholfen.
etnie83
Beitrag von etnie83 »
crazy hat geschrieben: Sa Aug 19, 2023 12:12 pm bin auf meiner wallbox zurueck auf stand fff5be1a9 (08.08., 10:27)
War bei mir auch auf das Update vom 15.8.
Den Fehler hört man...
Er gibt die 6A frei aber man hört das Schütz nicht anziehen!
PV: 19.6 kWp SMA + 11 kWh BYD HVM, OpenWB Series 2 custom
Fahrzeug: Tesla Model Y LR AWD, Renault Zoe
