Connecting a Type 2 cable question
courage2000
Beitrag von courage2000 »
Hello!
I need to put a cable to my OpenWB.
My Cable is 5 x 6 mm2 + 1x 0.5mm2 - CP cable.
There is NO PP cable.
The Female Jack (that goes inside the car) has a 220 OHM resitor PE-PP inside.
When I've made my own build I've put a 220 ohm resistor on the Simple EVSE, between PP-PE.
When connecting to the OpenWB, do I need to put a new resistor 220ohm somewhere?
Zuletzt geändert von courage2000 am Do Sep 21, 2023 4:46 am, insgesamt 1-mal geändert.
Has thanked: 161 times
Been thanked: 377 times
Re: Connecting a Typoe 2 cable question
Questions like this only to support@openwb.de
