Hilfe bei der Inbetriebnahme
Stroti
Beitrag von Stroti »
Hi, Openwallbox Pro hängt, über die IP komme ich auf die GUI, kann aber nichts einstellen.
Log
Debug Output:
Dec 13 17:06:05 openWBPro-831293 hwinitd[144]: [09:05:16.190] [INFO] Starting hwinitd 0.2
Dec 13 17:06:05 openWBPro-831293 hwinitd[144]: [09:05:16.265] [INFO] Shutting down with exit code 0
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.641] [INFO] Entry[0] phase_count 1 current_limit 6
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.645] [INFO] Entry[1] phase_count 1 current_limit 10
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.645] [INFO] Entry[2] phase_count 1 current_limit 13
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.645] [INFO] Entry[3] phase_count 1 current_limit 16
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.645] [INFO] Entry[4] phase_count 1 current_limit 20
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.646] [INFO] Entry[5] phase_count 1 current_limit 32
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.646] [INFO] Entry[6] phase_count 1 current_limit 40
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.671] [INFO] Entry[7] phase_count 1 current_limit 63
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.671] [INFO] Entry[8] phase_count 3 current_limit 6
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.671] [INFO] Entry[9] phase_count 3 current_limit 10
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.680] [INFO] Entry[10] phase_count 3 current_limit 13
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.681] [INFO] Entry[11] phase_count 3 current_limit 16
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.681] [INFO] Entry[12] phase_count 3 current_limit 20
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.681] [INFO] Entry[13] phase_count 3 current_limit 32
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.682] [INFO] Entry[14] phase_count 3 current_limit 40
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.682] [INFO] Entry[15] phase_count 3 current_limit 63
Dec 13 17:06:09 openWBPro-831293 rotaryencd[234]: [17:06:09.998] [INFO] Publish grid current limit 32 A, phase count 3
Dec 13 17:06:10 openWBPro-831293 rotaryencd[234]: [17:06:10.001] [INFO] shutting down with exit code 0
Dec 13 17:06:10 openWBPro-831293 watchdogd[241]: [17:06:10.422] [INFO] enter init loop [ ]
Dec 13 17:06:11 openWBPro-831293 configd[245]: [17:06:10.976] [INFO] ConfigD module initialized
Dec 13 17:06:11 openWBPro-831293 configd[245]: [17:06:11.018] [INFO] Disconnected from the MQTT broker
Dec 13 17:06:11 openWBPro-831293 configd[245]: [17:06:11.040] [WARN] MQTT connection to broker lost, reconnecting
Dec 13 17:06:11 openWBPro-831293 configd[245]: [17:06:11.112] [INFO] ConfigD module stopped
Dec 13 17:06:11 openWBPro-831293 configd[245]: [17:06:11.112] [INFO] Disconnected from the MQTT broker
Dec 13 17:06:11 openWBPro-831293 configd[245]: [17:06:11.113] [INFO] Stopped MQTT module
Dec 13 17:06:11 openWBPro-831293 gpioauthd[246]: [17:06:11.148] [INFO] starting main loop with 0 fds in poll_fds
Dec 13 17:06:11 openWBPro-831293 iec61851d[251]: [17:06:11.400] [INFO] /usr/bin/iec61851d (iec61851d 0.11)
Dec 13 17:06:11 openWBPro-831293 iec61851d[251]: [17:06:11.416] [INFO] enabling IEC_INIT_STATE_CABLE_CURRENT_LIMIT
Dec 13 17:06:11 openWBPro-831293 iec61851d[251]: [17:06:11.416] [INFO] option from config: force_wake_up = true
Dec 13 17:06:11 openWBPro-831293 iec61851d[251]: [17:06:11.416] [INFO] option from config: wake_up_after_timeout = false
Dec 13 17:06:11 openWBPro-831293 iec61851d[251]: [17:06:11.417] [INFO] switch3to1phase/switch_delay = 10000 ms
Dec 13 17:06:11 openWBPro-831293 hilinkd[247]: [17:06:11.719] [INFO] No APN configuration in config file
Dec 13 17:06:11 openWBPro-831293 hilinkd[247]: [17:06:11.729] [INFO] Shutting down (exit code 0)
Dec 13 17:06:11 openWBPro-831293 iso15118d[255]: [17:06:11.706] [INFO] /usr/bin/iso15118d (iso15118d 0.11)
Dec 13 17:06:11 openWBPro-831293 lockctrld[256]: [17:06:11.845] [INFO] starting init loop
Dec 13 17:06:11 openWBPro-831293 lockctrld[256]: [17:06:11.856] [INFO] worker thread started
Dec 13 17:06:11 openWBPro-831293 iso15118d[255]: [17:06:11.970] [INFO] Configured HLC protocols: 0x4
Dec 13 17:06:11 openWBPro-831293 iso15118d[255]: [17:06:11.978] [INFO] Charging type: basic
Dec 13 17:06:12 openWBPro-831293 iso15118d[255]: [17:06:12.034] [INFO] TCP server on eth1 is listening on port [fe80::201:87ff:fe13:9974%3]:61341
Dec 13 17:06:12 openWBPro-831293 iso15118d[255]: [17:06:12.093] [INFO] starting socket server(s)
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.192] [INFO] Use relay 0 for primary contactor
Dec 13 17:06:12 openWBPro-831293 meteringd[258]: [17:06:12.200] [INFO] using metering protocol 'eastron', timeout 2000 ms
Dec 13 17:06:12 openWBPro-831293 meteringd[258]: [17:06:12.200] [INFO] Port: /dev/ttymxc0, Baudrate: 9600, Parity: N
Dec 13 17:06:12 openWBPro-831293 meteringd[258]: [17:06:12.201] [INFO] enabling local echo suppression
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.211] [INFO] using gpio 131 as primary contactor feedback gpio
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.294] [INFO] primary contactor feedback type = NO
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.341] [INFO] Use relay 1 for secondary contactor
Dec 13 17:06:12 openWBPro-831293 meteringd[258]: [17:06:12.391] [INFO] Eastron SDM72D-M meter detected (S/N: 22379187, HW Revision: v2, 3P4W)
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.404] [INFO] using gpio 130 as secondary contactor feedback gpio
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.448] [INFO] secondary contactor feedback type = NO
Dec 13 17:06:12 openWBPro-831293 proximityd[266]: [17:06:12.500] [INFO] starting init loop
Dec 13 17:06:12 openWBPro-831293 meteringd[258]: [17:06:12.423] [INFO] Starting meteringd 0.6
Dec 13 17:06:12 openWBPro-831293 pwmd[268]: [17:06:12.671] [INFO] Using PWM7/0
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.684] [INFO] starting init loop with 2 fds in poll_fds
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.709] [INFO] Maximum phase count: 3
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.709] [INFO] Feature switch3to1phase: possible
Dec 13 17:06:12 openWBPro-831293 pwmd[268]: [17:06:12.795] [INFO] starting init loop
Dec 13 17:06:12 openWBPro-831293 powerctrld[262]: [17:06:12.819] [INFO] starting main loop with 2 fds in poll_fds
Dec 13 17:06:12 openWBPro-831293 watchdogd[241]: [17:06:12.953] [INFO] enter main loop
Dec 13 17:06:13 openWBPro-831293 pwmd[268]: [17:06:13.085] [INFO] starting main loop
Dec 13 17:06:13 openWBPro-831293 proximityd[266]: [17:06:13.095] [INFO] starting main loop
Dec 13 17:06:13 openWBPro-831293 lockctrld[256]: [17:06:13.095] [INFO] starting main loop with 0 fds in poll_fds
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.089] [INFO] starting initialization
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.135] [INFO] entering init loop
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.191] [INFO] enabling IEC_INIT_STATE_GRID_CURRENT_LIMIT
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.191] [INFO] enabling IEC_INIT_STATE_PLUG_LOCK
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.192] [INFO] enabling IEC_INIT_STATE_EMERGENCY_SHUTDOWN
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.192] [INFO] enabling IEC_INIT_STATE_CONTACTOR
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.193] [WARN] Ignoring hlc contactor state target: 0
Dec 13 17:06:13 openWBPro-831293 recloserd[275]: [17:06:13.168] [INFO] recloser not enabled in config file
Dec 13 17:06:13 openWBPro-831293 recloserd[275]: [17:06:13.181] [INFO] shutting down with exit code 0
Dec 13 17:06:13 openWBPro-831293 pwmd[268]: [17:06:13.086] [INFO] changed CP enable 1, duty cycle 100.000 %
Dec 13 17:06:13 openWBPro-831293 pwmd[268]: [17:06:13.199] [INFO] main loop: set new CP state: A (CP (+) 11937 (-) -2 mV)
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.267] [INFO] enabling IEC_INIT_STATE_DIODE_PRESENT
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.268] [INFO] enabling IEC_INIT_STATE_CP_STATE
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.268] [INFO] init states achieved, setting initial safe state
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.269] [INFO] forcing safe state
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.269] [INFO] IEC_STATE_CONTACTOR_OPEN_LOCK_OPEN
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.269] [INFO] Charging: Basic only (free) [AC]
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.272] [INFO] Cable: non-pluggable, fixed
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.272] [INFO] Current limits - Grid: 32 A, EVSE: 32 A, Cable: 32 A, Failsafe: -1 A
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.273] [INFO] Ventilation: disabled,internal, always accept CP state D
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.273] [INFO] entering main loop
Dec 13 17:06:13 openWBPro-831293 iec61851d[251]: [17:06:13.359] [INFO] main loop: setting new duty cycle 100.000%
Dec 13 17:06:13 openWBPro-831293 rfidd[278]: [17:06:13.521] [INFO] starting rfidd 0.12 (RFID disabled)
Dec 13 17:06:13 openWBPro-831293 proximityd[266]: [17:06:13.602] [INFO] main loop: set new cable limit: -1 (PP 3297 mV)
Dec 13 17:06:13 openWBPro-831293 slacd[283]: [17:06:13.561] [INFO] /usr/bin/slacd (slacd 0.13)
Dec 13 17:06:13 openWBPro-831293 rgbledd[279]: [17:06:13.618] [INFO] starting main loop
Dec 13 17:06:13 openWBPro-831293 slacd[283]: [17:06:13.644] [INFO] Basic charging -> disable SLAC
Dec 13 17:06:13 openWBPro-831293 ventilationd[288]: [17:06:13.917] [INFO] ventilation control: disabled, internal
Dec 13 17:06:13 openWBPro-831293 ventilationd[288]: [17:06:13.924] [INFO] starting main loop
Dec 13 17:06:14 openWBPro-831293 ocppd[299]: [17:06:14.616] [ERROR] GetAvailabilityFlags() failed to open file '/var/lib/ocppd/ocpp_data.json' (falling back to "Operative"): No such file or directory
Dec 13 17:06:14 openWBPro-831293 ocppd[299]: [17:06:14.624] [INFO] /usr/bin/ocppd (ocppd 0.11)
Dec 13 17:06:14 openWBPro-831293 ocppd[299]: [17:06:14.640] [INFO] using local state directory '/var/lib/ocppd'
Dec 13 17:06:14 openWBPro-831293 ocppd[299]: [17:06:14.648] [INFO] upload thread started
Dec 13 17:06:14 openWBPro-831293 ocppd[299]: [17:06:14.689] [INFO] GetGlobalConfigurationValue(".ocpp.enable") got 'false'
Dec 13 17:06:14 openWBPro-831293 ocppd[299]: [17:06:14.693] [INFO] ocpp disabled by config, terminating (doing nothing forever)
Dec 13 17:06:14 openWBPro-831293 updated[302]: [17:06:14.932] [INFO] Starting updated 0.3
Dec 13 17:08:18 openWBPro-831293 sh[316]: Warning: Unable to locate configuration directory, default config not loaded.
Has thanked: 28 times
Been thanked: 202 times
Re: Hilfe bei der Inbetriebnahme
Bitte nicht doppelt posten. Es geht im ursprünglichen Beitrag weiter.
viewtopic.php?p=98200#p98200
