Soc PSA / Opel wird nicht abgerufen
Pascal Naumann
Beitrag von Pascal Naumann »
ich bekomme bei abrufen des Soc's von Opel einen HTTP Fehler 400. Anbei der Auszug aus dem Log.
2024-01-16 15:07:35,687 - {modules.common.fault_state:55} - {ERROR:fetch soc_ev4} - PSA: FaultState FaultStateLevel.ERROR, FaultStr <class 'Exception'> Error requesting PSA data for vehicle: 4, Traceback:
  File "/var/www/html/openWB/packages/modules/vehicles/psa/api.py", line 111, in fetch_soc
    session = create_session(
  File "/var/www/html/openWB/packages/modules/vehicles/psa/api.py", line 70, in create_session
    access_token = session.post(
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 590, in post
    return self.request('POST', url, data=data, json=json, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 662, in send
    r = dispatch_hook('response', hooks, r, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/hooks.py", line 31, in dispatch_hook
    _hook_data = hook(hook_data, **kwargs)
  File "/var/www/html/openWB/packages/modules/common/req.py", line 10, in <lambda>
    session.hooks['response'].append(lambda r, *args, **kwargs: r.raise_for_status())
  File "/usr/lib/python3/dist-packages/requests/models.py", line 943, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://idpcvs.opel.com/am/oauth2/access_token
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 66, in update
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 109, in _get_carstate_by_source
  File "/var/www/html/openWB/packages/modules/vehicles/psa/soc.py", line 20, in updater
    return api.fetch_soc(vehicle_config.configuration, vehicle)
  File "/var/www/html/openWB/packages/modules/vehicles/psa/api.py", line 119, in fetch_soc
    raise Exception("Error requesting PSA data for vehicle: %s" % vehicle_id)
Exception: Error requesting PSA data for vehicle: 4
2024-01-16 15:12:32,874 - {modules.common.fault_state:55} - {ERROR:fetch soc_ev4} - PSA: FaultState FaultStateLevel.ERROR, FaultStr <class 'Exception'> Error requesting PSA data for vehicle: 4, Traceback:
2024-01-16 15:24:33,924 - {modules.common.configurable_vehicle:56} - {DEBUG:fetch soc_ev4} - Vehicle Instance <class 'modules.vehicles.psa.config.PSA'>
2024-01-16 15:24:33,925 - {modules.common.configurable_vehicle:57} - {DEBUG:fetch soc_ev4} - Calculated SoC-State CalculatedSocState(imported_start=None, manual_soc=None, soc_start=100)
2024-01-16 15:24:33,927 - {modules.common.configurable_vehicle:58} - {DEBUG:fetch soc_ev4} - Vehicle Update Data VehicleUpdateData(plug_state=False, charge_state=False, imported=None, battery_capacity=50000, efficiency=95, soc_from_cp=None, timestamp_soc_from_cp=None)
2024-01-16 15:24:33,931 - {modules.common.configurable_vehicle:59} - {DEBUG:fetch soc_ev4} - General Config GeneralVehicleConfig(use_soc_from_cp=False, request_interval_charging=300, request_interval_not_charging=43200, request_only_plugged=False)
2024-01-16 15:24:33,933 - {modules.common.component_context:24} - {DEBUG:fetch soc_ev4} - Update Komponente ['PSA']
2024-01-16 15:24:33,950 - {urllib3.connectionpool:973} - {DEBUG:fetch soc_ev4} - Starting new HTTPS connection (1): idpcvs.opel.com:443
2024-01-16 15:24:34,257 - {urllib3.connectionpool:452} - {DEBUG:fetch soc_ev4} - https://idpcvs.opel.com:443 "POST /am/oauth2/access_token HTTP/1.1" 400 None
2024-01-16 15:24:34,265 - {modules.common.fault_state:55} - {ERROR:fetch soc_ev4} - PSA: FaultState FaultStateLevel.ERROR, FaultStr <class 'Exception'> Error requesting PSA data for vehicle: 4, Traceback:
Ich benutze folgende OpenWb Software Stand: Zweig Release -> 2024-01-03 11:43:47 +0100 [de44d68b8]
Es scheint als ob sich an der URL was geändert hat. Gibt es jemand der ähnliche Probleme hat?
Pascal
9,88 kWp PV mit Solar Edge WR und SENEC 10KW Li Speicher, Ioniq 5 9/2021, openWB series 2 ;)
Has thanked: 28 times
Been thanked: 202 times
Re: Soc PSA / Opel wird nicht abgerufen
Sieh Dir mal die letzten Beiträge an.
viewtopic.php?t=1206&start=510
Damit es nicht zwei Beiträge zu dem Thema gibt, mache ich hier zu.
