OpenWB 2.1.5 Keine MQTT Topics
manlishi
Beitrag von manlishi »
Ich habe bereits einige Zeit hier gesucht, finde aber leider keine Lösung für meine fehlenden MQTT Topics.
Ich kann mit dem MQTT Explorer verbinden, bekomme aber keine Topics angezeigt.
MQTT Bridge ist deaktiviert.
Hat jemand eine Idee woran das liegt?
Bisher versucht:
/var/lib/mosquitto/mosquitto.db gelöscht und dienst neu gestartet
System neustart
debug im log aktiviert, hier ein aktueller Auszug:
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/counter/0/get/fault_state', ... (1 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/counter/0/get/fault_str', ... (376 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/chargepoint/get/power', ... (4 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/chargepoint/get/power', ... (0 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/chargepoint/get/imported', ... (7 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/chargepoint/get/imported', ... (0 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/counter/0/get/fault_state', ... (1 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/counter/0/get/fault_state', ... (0 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/counter/0/get/fault_str', ... (376 bytes))
2024-11-11T14:10:40: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/counter/0/get/fault_str', ... (0 bytes))
2024-11-11T14:10:41: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/vehicle/set/vehicle_update_completed', ... (4 bytes))
2024-11-11T14:10:41: Received PUBLISH from OPENWB.bridge-01 (d0, q0, r1, m0, 'openWB/set/vehicle/set/vehicle_update_completed', ... (0 bytes))
2024-11-11T14:10:47: No will message specified.
2024-11-11T14:10:47: Sending CONNACK to mqttjs_b3578f90 (0, 0)
Im Main.log habe ich diese Meldung gefunden:
2024-11-11 12:31:40,564 - {helpermodules.update_config:569} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_e4a5530b/messages/1731324665222
2024-11-11 12:31:40,564 - {helpermodules.update_config:569} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_e4a5530b/messages/1731324675901
2x DEYE 12Kw, Growatt MIC 3000, Hoymiles HMT-2250 30Kwp, 60Kwh DIY Speicher, OpenWB Pro, IONIQ6
manlishi
Re: OpenWB 2.1.5 Keine MQTT Topics
Ich habe den Fehler gefunden und antworte daher selbst.
in /etc/mosquitto/conf.d/openwb.conf war folgende Zeile einkommentiert. Dadurch war der MQTT Broker nur von localhost und nicht von anderen Clients zu erreichen.
listener 1883 localhost
Ist das ggf. mit dem Update auf 2.1.5 Patch 2 mitgekommen?
