Hello openWB community,
I'm currently integrating my openWB system with several energy management devices and I want to ensure the network security of all connected devices, especially when used in larger, more complex setups. In particular, I'm interested in optimizing network redundancy and security using HSRP (Hot Standby Router Protocol) and VRRP (Virtual Router Redundancy Protocol) for improving uptime and preventing single points of failure.
Could anyone provide insights on the following:
How can HSRP and VRRP improve the security of my EV charger network?
Are there specific network configurations within openWB that I should consider to implement these protocols?
What are the best practices for securing the communication between openWB devices in a redundant network setup?
Is there any known compatibility or issue with these protocols when using openWB alongside other smart grid or energy management systems?
Looking forward to your suggestions!
Best regards,
How to Optimize Network Security Using HSRP and VRRP in OpenWB Setups?
Exploring network security and redundancy solutions | Enthusiast in smart energy and connected systems
Check out my insights: https://cyberopti.com/hsrp-maitriser-le ... te-reseau/
hominidae
- Has thanked: 44 times
- Been thanked: 32 times
Re: How to Optimize Network Security Using HSRP and VRRP in OpenWB Setups?
They can't, as both methods have nothing to do with security.gabin8207 hat geschrieben: Mi Dez 11, 2024 8:06 pm Could anyone provide insights on the following:
Maybe you are confusing security with availability (like in security of supply).
No, as both methods will be used between routers...clients would not notice the change of their local gateway.Are there specific network configurations within openWB that I should consider to implement these protocols?
That said, having HA on the internet gateway is nice, but not essentially required for local EV charging.
Only some features rely on internet connection, but not heavily (like time, dynamic prices, cloud-UI - where the first two can "live" without internet for hours or longer)
avoid different networks/ip-segments in openWB components on a local site, as some protocols and features could rely on a heartbeat between components which might have a problem when connection is routed/via a router.What are the best practices for securing the communication between openWB devices in a redundant network setup?
All openWB boxed are single homed anyway, so no chance for redundancy.
some other brands / components, like inverters and EMS from SMA use multicast communication as standard.Is there any known compatibility or issue with these protocols when using openWB alongside other smart grid or energy management systems?
Hello,
Thanks for the clarification! I now see that HSRP and VRRP are more about improving network availability than security. I’ll focus on using them to avoid single points of failure.
I’ll also avoid separating OpenWB components into different IP networks to ensure smooth communication between devices.
Good to know that most OpenWB features don’t rely heavily on the internet for local EV charging. I’ll keep the multicast issue in mind when using systems like SMA inverters.
Thanks again for the advice!
hominidae
As a side-note, it might be useful to separate your openWB, PV-Inverters, Home-Battery Inverter/charger in a single but separate (V)LAN, as many inverters have their own cloud and remote access (for maintenance by the manufacturer) feature.gabin8207 hat geschrieben: So Dez 15, 2024 9:54 am I’ll also avoid separating OpenWB components into different IP networks to ensure smooth communication between devices.
You want to be able to access your devices from your local side (Home LAN), but prevent entering "unwanted guests" via these connections into your Home-LAN.
