Samba
- Has thanked: 11 times
- Been thanked: 42 times
Re: Samba
Noch mal getestet?
Re: Samba
Kannst du das Logfile der openWB noch mal einstellen. Bitte als Code Block </> über dem Eingabefeld hier.
Re: Samba
2024-01-17 13:18:30,558 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,588 - {modules.devices.openwb_evu_kit.device:50} - {DEBUG:device2} - Start device reading {'component6': <modules.devices.openwb_evu_kit.counter.EvuKit object at 0x70ba2a00>}
2024-01-17 13:18:30,589 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,589 - {modules.common.component_context:25} - {DEBUG:device2} - Update Komponente ['EVU-Kit']
2024-01-17 13:18:30,590 - {modules.common.component_context:25} - {DEBUG:set values cp1} - Update Komponente ['Ladepunkt']
2024-01-17 13:18:30,594 - {modules.common.component_context:25} - {DEBUG:set values cp7} - Update Komponente ['Ladepunkt']
2024-01-17 13:18:30,600 - {urllib3.connectionpool:227} - {DEBUG:set values cp7} - Starting new HTTP connection (1): 192.168.1.246:80
2024-01-17 13:18:30,602 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,612 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,625 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,634 - {urllib3.connectionpool:452} - {DEBUG:set values cp7} - http://192.168.1.246:80 "GET /connect.php HTTP/1.1" 200 449
2024-01-17 13:18:30,636 - {modules.common.req:11} - {DEBUG:set values cp7} - Get-Response: {"date":"2024:01:17-13:18:30","timestamp":1705493910,"powers":[0,0,0],"power_all":0,"currents":[0,0,0],"voltages":[227.37,228.37,225.4],"frequency":49.97,"imported":0,"exported":0,"plug_state":false,"charge_state":false,"phases_actual":0,"phases_target":3,"phases_in_use":1,"offered_current":0,"evse_signaling":"unclear\n","v2g_ready":0,"soc_value":null,"soc_timestamp":null,"vehicle_id":null,"rfid_tag":null,"rfid_timestamp":null,"serial":"830557"}
2024-01-17 13:18:30,637 - {modules.common.store._api:26} - {DEBUG:set values cp7} - Raw data ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[227.37, 228.37, 225.4], frequency=49.97, imported=0, exported=0, power=0, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, vehicle_id=None)
2024-01-17 13:18:30,639 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,654 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,664 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,675 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,682 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,690 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,698 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,706 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,716 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,724 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,731 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,739 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,746 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,754 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,761 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,769 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,776 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,784 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,791 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,799 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,806 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,814 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,822 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,829 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,837 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,844 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,852 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,860 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,867 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,874 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,882 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,890 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,897 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,905 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,912 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,920 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,927 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,935 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,943 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,956 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,967 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,986 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:30,998 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,012 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,025 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,037 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,047 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,058 - {modules.common.simcount._simcount:37} - {DEBUG:device2} - Previous state: SimCounterState(timestamp=1705493901.4539497, power=13.118846893310547, imported=19322.922911269143, exported=0)
2024-01-17 13:18:31,065 - {modules.common.simcount._calculate:11} - {DEBUG:device2} - time passed: 0.00266803, power1: 13.1188, power2: 12.276
2024-01-17 13:18:31,067 - {modules.common.simcount._calculate:27} - {DEBUG:device2} - power did not change sign. Total energy: 0.0338771
2024-01-17 13:18:31,071 - {modules.common.simcount._simcount:46} - {DEBUG:device2} - imported: 0.0338771 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1705493911.058856, power=12.275969505310059, imported=19322.95678832922, exported=0)
2024-01-17 13:18:31,073 - {modules.common.store._api:26} - {DEBUG:device2} - Raw data CounterState(currents=[0.1486302763223648, 0.0, 0.0], powers=[12.275969505310059, 0.0, 0.0], voltages=[227.2498016357422, 228.28726196289062, 225.3739776611328], power_factors=[0.4186127483844757, 0.0, 0.0], imported=19322.95678832922, exported=0, power=12.275969505310059, frequency=49.95000076293945)
2024-01-17 13:18:31,079 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,090 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,101 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,114 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,125 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,142 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,160 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,169 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,183 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,193 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,201 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,210 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,224 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,237 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,245 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,254 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,262 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,269 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,278 - {modules.common.component_context:25} - {DEBUG:update values cp1} - Update Komponente ['Ladepunkt']
2024-01-17 13:18:31,282 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,286 - {modules.common.component_context:25} - {DEBUG:update values cp7} - Update Komponente ['Ladepunkt']
2024-01-17 13:18:31,288 - {modules.common.store._api:30} - {INFO:update values cp7} - Saving ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[227.37, 228.37, 225.4], frequency=49.97, imported=0, exported=0, power=0, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, vehicle_id=None)
2024-01-17 13:18:31,299 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,308 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,316 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,327 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,343 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,355 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,368 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,378 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,388 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,400 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,412 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,426 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,428 - {modules.common.component_context:25} - {DEBUG:component6} - Update Komponente ['EVU-Kit']
2024-01-17 13:18:31,429 - {modules.common.store._api:30} - {INFO:component6} - Saving CounterState(currents=[0.1486302763223648, 0.0, 0.0], powers=[12.275969505310059, 0.0, 0.0], voltages=[227.2498016357422, 228.28726196289062, 225.3739776611328], power_factors=[0.4186127483844757, 0.0, 0.0], imported=19322.95678832922, exported=0, power=12.275969505310059, frequency=49.95000076293945)
2024-01-17 13:18:31,437 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,446 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,457 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,465 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,474 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,490 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,501 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,509 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,517 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,525 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,535 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,550 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,560 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,577 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,615 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,638 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,642 - {control.counter:145} - {INFO:MainThread} - Verbleibende Ströme an Zähler 6: [15.85, 16.0, 16.0]A
2024-01-17 13:18:31,649 - {control.counter:168} - {INFO:MainThread} - Verbleibende Leistung an Zähler 6: 10987.72403049469W
2024-01-17 13:18:31,652 - {control.chargepoint.chargepoint:83} - {INFO:MainThread} - LP 1: Keine Ladung, da kein Auto angesteckt ist.
2024-01-17 13:18:31,655 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,667 - {control.chargepoint.chargepoint:83} - {INFO:MainThread} - LP 7: Keine Ladung, da kein Auto angesteckt ist.
2024-01-17 13:18:31,672 - {modules.common.simcount._simcount:37} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1705493902.0220904, power=13.118846893310547, imported=19174.810354854515, exported=0)
2024-01-17 13:18:31,673 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,674 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00268056, power1: 13.1188, power2: 12.276
2024-01-17 13:18:31,683 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 0.0340362
2024-01-17 13:18:31,685 - {modules.common.simcount._simcount:46} - {DEBUG:MainThread} - imported: 0.0340362 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1705493911.6721072, power=12.275969505310059, imported=19174.844391021805, exported=0)
2024-01-17 13:18:31,689 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,690 - {control.data:236} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=False), get=Get(soc=0, daily_exported=0, daily_imported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, exported=0, power=0), set=Set(charging_power_left=0, regulate_up=False, switch_on_soc_reached=False))
2024-01-17 13:18:31,694 - {control.data:237} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=0.0, daily_exported=0, power=0, imported=0.0, exported=0))
2024-01-17 13:18:31,695 - {control.data:266} - {INFO:MainThread} - cp1
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, imported_at_plan_start=None, imported_instant_charging=None, limit=None, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0, evse_current=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=0.0, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, soc=None, soc_timestamp=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', vehicle_id=None, voltages=[227.26, 228.11, 225.39]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', costs=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, ev=-1, prio=False, rfid=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x71553868>), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=0, name='openWB Series 2 Custom', type='internal_openwb', template=0, connected_phases=3, phase_1=0, auto_phase_switch_hw=True, control_pilot_interruption_hw=False, id=1))
2024-01-17 13:18:31,697 - {control.data:266} - {INFO:MainThread} - cp7
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, imported_at_plan_start=None, imported_instant_charging=None, limit=None, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0, 0, 0], daily_imported=0, daily_exported=0, evse_current=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, phases_in_use=1, plug_state=False, power=0, rfid_timestamp=None, rfid=None, soc=None, soc_timestamp=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', vehicle_id=None, voltages=[227.37, 228.37, 225.4]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', costs=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, ev=-1, prio=False, rfid=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x7018d850>), config=Config(configuration={'ip_address': '192.168.1.246', 'duo_num': 0}, ev=0, name='openWB Pro', type='openwb_pro', template=0, connected_phases=3, phase_1=0, auto_phase_switch_hw=False, control_pilot_interruption_hw=False, id=7))
2024-01-17 13:18:31,699 - {control.data:266} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=0, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[])
2024-01-17 13:18:31,699 - {control.data:266} - {INFO:MainThread} - cpt1
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=1, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[])
2024-01-17 13:18:31,701 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,702 - {control.data:266} - {INFO:MainThread} - cpt2
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=2, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[])
2024-01-17 13:18:31,712 - {control.data:266} - {INFO:MainThread} - cpt3
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=3, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[])
2024-01-17 13:18:31,717 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,718 - {control.data:266} - {INFO:MainThread} - counter6
CounterData(config=Config(max_currents=[16, 16, 16], max_total_power=11000), get=Get(powers=[12.28, 0.0, 0.0], currents=[0.15, 0.0, 0.0], voltages=[227.25, 228.29, 225.37], power_factors=[0.42, 0.0, 0.0], unbalanced_load=0, frequency=49.95000076293945, daily_exported=0, daily_imported=158.291695242792, imported=19322.95678832922, exported=0, fault_state=0, fault_str='Kein Fehler.', power=12.275969505310059), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=10987.72403049469, raw_currents_left=[15.85, 16.0, 16.0], surplus_power_left=0, state_str=''))
2024-01-17 13:18:31,725 - {control.data:241} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=True), get=Get(hierarchy=[{'id': 6, 'type': 'counter', 'children': [{'id': 1, 'type': 'cp', 'children': []}, {'id': 7, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=12.275969505310059, invalid_home_consumption=0, daily_yield_home_consumption=158.292036938001, imported_home_consumption=19174.844391021805, disengageable_smarthome_power=0))
2024-01-17 13:18:31,727 - {control.data:266} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Lade-Profil', disable_after_unplug=False, prio=False, load_default=False, et=Et(active=True, max_price=0.0002), time_charging=TimeCharging(active=True, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2024-01-17 13:18:31,728 - {control.data:266} - {INFO:MainThread} - ev0
EvData(set=Set(soc_error_counter=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp=0, force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.'))
2024-01-17 13:18:31,729 - {control.data:266} - {INFO:MainThread} - ev1
2024-01-17 13:18:31,730 - {control.data:266} - {INFO:MainThread} - et0
EvTemplateData(name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40)
2024-01-17 13:18:31,731 - {control.data:245} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=1), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=200, control_range=[0, 230], feed_in_yield=15000, phase_switch_delay=7, phases_to_use=1, rundown_power=1000, rundown_soc=50, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, prices=Prices(bat=0.00026000000000000003, cp=0, grid=0.00026000000000000003, pv=0.00026000000000000003), range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2024-01-17 13:18:31,732 - {control.data:246} - {INFO:MainThread} - general_data-display
local
2024-01-17 13:18:31,732 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,733 - {control.data:247} - {INFO:MainThread} - graph_data
2024-01-17 13:18:31,740 - {control.data:248} - {INFO:MainThread} - optional_data
OptionalData(et=Et(get=EtGet(fault_state=0, fault_str='Kein Fehler.', prices={'1705492800': 0.0003227, '1705496400': 0.0003228, '1705500000': 0.0003272, '1705503600': 0.0003309, '1705507200': 0.00034510000000000004, '1705510800': 0.000325, '1705514400': 0.0003139, '1705518000': 0.00030859999999999997, '1705521600': 0.00029820000000000004, '1705525200': 0.0002901, '1705528800': 0.00027810000000000004, '1705532400': 0.0002747, '1705536000': 0.0002698, '1705539600': 0.0002675, '1705543200': 0.0002671, '1705546800': 0.0002702, '1705550400': 0.0002743, '1705554000': 0.00028670000000000003, '1705557600': 0.00031069999999999996, '1705561200': 0.0003277, '1705564800': 0.0003233, '1705568400': 0.0003099, '1705572000': 0.0003064, '1705575600': 0.00028920000000000004})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x70ba2490>), led=Led(active=False), rfid=Rfid(active=False))
2024-01-17 13:18:31,745 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,746 - {control.data:250} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=False), get=Get(daily_exported=0, monthly_exported=0, yearly_exported=0, exported=0, power=0))
2024-01-17 13:18:31,752 - {control.data:266} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.1.180', 'current_commit': '2024-01-17 09:41:21 +0100 [8c331fcb9]', 'current_branch': 'master', 'current_branch_commit': '2024-01-17 09:41:21 +0100 [8c331fcb9]', 'current_missing_commits': [], 'datastore_version': 34, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.1.3-Alpha.2', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1705493902, 'time': '13:18:22', 'grid': 0.013, 'house-power': 0.013, 'charging-all': 0.0, 'cp1-power': 0.0, 'cp7-power': 0.0}, 'module_update_completed': True}
2024-01-17 13:18:31,753 - {control.data:279} - {INFO:MainThread} - device2
{'name': 'EVU-Kit', 'type': 'openwb_evu_kit', 'id': 2, 'configuration': {}}
2024-01-17 13:18:31,755 - {control.data:281} - {INFO:MainThread} - component6
{'name': 'EVU-Kit', 'type': 'counter', 'id': 6, 'configuration': {'id': 115, 'version': 2}}
2024-01-17 13:18:31,757 - {control.data:253} - {INFO:MainThread} -
2024-01-17 13:18:31,761 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,766 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2024-01-17 13:18:31,778 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen**
2024-01-17 13:18:31,783 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Sollstrom setzen**
2024-01-17 13:18:31,790 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,792 - {control.counter:249} - {DEBUG:MainThread} - Anpassen des Regelbereichs 0W
2024-01-17 13:18:31,798 - {control.counter:217} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: -12.275969505310059W
2024-01-17 13:18:31,800 - {control.counter:484} - {DEBUG:MainThread} - Zähler 6: Begrenzung der verbleibenden Leistung auf -12.275969505310059W
2024-01-17 13:18:31,801 - {control.algorithm.algorithm:43} - {INFO:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2024-01-17 13:18:31,803 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2024-01-17 13:18:31,804 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,813 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,820 - {modules.common.component_context:25} - {DEBUG:set current cp1} - Update Komponente ['Ladepunkt']
2024-01-17 13:18:31,822 - {modules.common.component_context:25} - {DEBUG:set current cp7} - Update Komponente ['Ladepunkt']
2024-01-17 13:18:31,827 - {urllib3.connectionpool:227} - {DEBUG:set current cp7} - Starting new HTTP connection (1): 192.168.1.246:80
2024-01-17 13:18:31,832 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,845 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,851 - {urllib3.connectionpool:452} - {DEBUG:set current cp7} - http://192.168.1.246:80 "POST /connect.php HTTP/1.1" 200 19
2024-01-17 13:18:31,858 - {modules.common.req:11} - {DEBUG:set current cp7} - Get-Response: OK Value:0 accepted
2024-01-17 13:18:31,862 - {control.counter:193} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2024-01-17 13:18:31,865 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,889 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,917 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,929 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,942 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,954 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,975 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,986 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:31,997 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,007 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,015 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,023 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,031 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,040 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,048 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,056 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,064 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,072 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,080 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,088 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,096 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,104 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,113 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,121 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,130 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,139 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,146 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2024-01-17 13:18:32,149 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,162 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,180 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,191 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,242 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,254 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,263 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,271 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,278 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,286 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,294 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,301 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,309 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,313 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001)
2024-01-17 13:18:32,314 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_CLOSE" (command:0x0006 flags:0x0001)
2024-01-17 13:18:32,315 - {helpermodules.system:87} - {DEBUG:cloud backup} - Nächtliche Sicherung erstellt und hochgeladen
Re: Samba
Phoenix hat geschrieben: Mi Jan 17, 2024 12:49 pmCode: Alles auswählen
2024-01-17 13:18:30,558 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,588 - {modules.devices.openwb_evu_kit.device:50} - {DEBUG:device2} - Start device reading {'component6': <modules.devices.openwb_evu_kit.counter.EvuKit object at 0x70ba2a00>} 2024-01-17 13:18:30,589 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,589 - {modules.common.component_context:25} - {DEBUG:device2} - Update Komponente ['EVU-Kit'] 2024-01-17 13:18:30,590 - {modules.common.component_context:25} - {DEBUG:set values cp1} - Update Komponente ['Ladepunkt'] 2024-01-17 13:18:30,594 - {modules.common.component_context:25} - {DEBUG:set values cp7} - Update Komponente ['Ladepunkt'] 2024-01-17 13:18:30,600 - {urllib3.connectionpool:227} - {DEBUG:set values cp7} - Starting new HTTP connection (1): 192.168.1.246:80 2024-01-17 13:18:30,602 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,612 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,625 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,634 - {urllib3.connectionpool:452} - {DEBUG:set values cp7} - http://192.168.1.246:80 "GET /connect.php HTTP/1.1" 200 449 2024-01-17 13:18:30,636 - {modules.common.req:11} - {DEBUG:set values cp7} - Get-Response: {"date":"2024:01:17-13:18:30","timestamp":1705493910,"powers":[0,0,0],"power_all":0,"currents":[0,0,0],"voltages":[227.37,228.37,225.4],"frequency":49.97,"imported":0,"exported":0,"plug_state":false,"charge_state":false,"phases_actual":0,"phases_target":3,"phases_in_use":1,"offered_current":0,"evse_signaling":"unclear\n","v2g_ready":0,"soc_value":null,"soc_timestamp":null,"vehicle_id":null,"rfid_tag":null,"rfid_timestamp":null,"serial":"830557"} 2024-01-17 13:18:30,637 - {modules.common.store._api:26} - {DEBUG:set values cp7} - Raw data ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[227.37, 228.37, 225.4], frequency=49.97, imported=0, exported=0, power=0, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, vehicle_id=None) 2024-01-17 13:18:30,639 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,654 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,664 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,675 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,682 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,690 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,698 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,706 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,716 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,724 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,731 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,739 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,746 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,754 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,761 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,769 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,776 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,784 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,791 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,799 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,806 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,814 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,822 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,829 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,837 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,844 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,852 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,860 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,867 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,874 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,882 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,890 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,897 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,905 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,912 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,920 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,927 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,935 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,943 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,956 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,967 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,986 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:30,998 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,012 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,025 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,037 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,047 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,058 - {modules.common.simcount._simcount:37} - {DEBUG:device2} - Previous state: SimCounterState(timestamp=1705493901.4539497, power=13.118846893310547, imported=19322.922911269143, exported=0) 2024-01-17 13:18:31,065 - {modules.common.simcount._calculate:11} - {DEBUG:device2} - time passed: 0.00266803, power1: 13.1188, power2: 12.276 2024-01-17 13:18:31,067 - {modules.common.simcount._calculate:27} - {DEBUG:device2} - power did not change sign. Total energy: 0.0338771 2024-01-17 13:18:31,071 - {modules.common.simcount._simcount:46} - {DEBUG:device2} - imported: 0.0338771 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1705493911.058856, power=12.275969505310059, imported=19322.95678832922, exported=0) 2024-01-17 13:18:31,073 - {modules.common.store._api:26} - {DEBUG:device2} - Raw data CounterState(currents=[0.1486302763223648, 0.0, 0.0], powers=[12.275969505310059, 0.0, 0.0], voltages=[227.2498016357422, 228.28726196289062, 225.3739776611328], power_factors=[0.4186127483844757, 0.0, 0.0], imported=19322.95678832922, exported=0, power=12.275969505310059, frequency=49.95000076293945) 2024-01-17 13:18:31,079 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,090 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,101 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,114 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,125 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,142 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,160 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,169 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,183 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,193 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,201 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,210 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,224 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,237 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,245 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,254 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,262 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,269 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,278 - {modules.common.component_context:25} - {DEBUG:update values cp1} - Update Komponente ['Ladepunkt'] 2024-01-17 13:18:31,282 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,286 - {modules.common.component_context:25} - {DEBUG:update values cp7} - Update Komponente ['Ladepunkt'] 2024-01-17 13:18:31,288 - {modules.common.store._api:30} - {INFO:update values cp7} - Saving ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[227.37, 228.37, 225.4], frequency=49.97, imported=0, exported=0, power=0, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, vehicle_id=None) 2024-01-17 13:18:31,299 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,308 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,316 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,327 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,343 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,355 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,368 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,378 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,388 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,400 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,412 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,426 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,428 - {modules.common.component_context:25} - {DEBUG:component6} - Update Komponente ['EVU-Kit'] 2024-01-17 13:18:31,429 - {modules.common.store._api:30} - {INFO:component6} - Saving CounterState(currents=[0.1486302763223648, 0.0, 0.0], powers=[12.275969505310059, 0.0, 0.0], voltages=[227.2498016357422, 228.28726196289062, 225.3739776611328], power_factors=[0.4186127483844757, 0.0, 0.0], imported=19322.95678832922, exported=0, power=12.275969505310059, frequency=49.95000076293945) 2024-01-17 13:18:31,437 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,446 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,457 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,465 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,474 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,490 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,501 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,509 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,517 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,525 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,535 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,550 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,560 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,577 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,615 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,638 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,642 - {control.counter:145} - {INFO:MainThread} - Verbleibende Ströme an Zähler 6: [15.85, 16.0, 16.0]A 2024-01-17 13:18:31,649 - {control.counter:168} - {INFO:MainThread} - Verbleibende Leistung an Zähler 6: 10987.72403049469W 2024-01-17 13:18:31,652 - {control.chargepoint.chargepoint:83} - {INFO:MainThread} - LP 1: Keine Ladung, da kein Auto angesteckt ist. 2024-01-17 13:18:31,655 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,667 - {control.chargepoint.chargepoint:83} - {INFO:MainThread} - LP 7: Keine Ladung, da kein Auto angesteckt ist. 2024-01-17 13:18:31,672 - {modules.common.simcount._simcount:37} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1705493902.0220904, power=13.118846893310547, imported=19174.810354854515, exported=0) 2024-01-17 13:18:31,673 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,674 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00268056, power1: 13.1188, power2: 12.276 2024-01-17 13:18:31,683 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 0.0340362 2024-01-17 13:18:31,685 - {modules.common.simcount._simcount:46} - {DEBUG:MainThread} - imported: 0.0340362 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1705493911.6721072, power=12.275969505310059, imported=19174.844391021805, exported=0) 2024-01-17 13:18:31,689 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,690 - {control.data:236} - {INFO:MainThread} - bat_all_data BatAllData(config=Config(configured=False), get=Get(soc=0, daily_exported=0, daily_imported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, exported=0, power=0), set=Set(charging_power_left=0, regulate_up=False, switch_on_soc_reached=False)) 2024-01-17 13:18:31,694 - {control.data:237} - {INFO:MainThread} - cp_all_data AllChargepointData(get=AllGet(daily_imported=0.0, daily_exported=0, power=0, imported=0.0, exported=0)) 2024-01-17 13:18:31,695 - {control.data:266} - {INFO:MainThread} - cp1 ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, imported_at_plan_start=None, imported_instant_charging=None, limit=None, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0, evse_current=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=0.0, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, soc=None, soc_timestamp=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', vehicle_id=None, voltages=[227.26, 228.11, 225.39]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', costs=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, ev=-1, prio=False, rfid=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x71553868>), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=0, name='openWB Series 2 Custom', type='internal_openwb', template=0, connected_phases=3, phase_1=0, auto_phase_switch_hw=True, control_pilot_interruption_hw=False, id=1)) 2024-01-17 13:18:31,697 - {control.data:266} - {INFO:MainThread} - cp7 ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, imported_at_plan_start=None, imported_instant_charging=None, limit=None, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0, 0, 0], daily_imported=0, daily_exported=0, evse_current=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, phases_in_use=1, plug_state=False, power=0, rfid_timestamp=None, rfid=None, soc=None, soc_timestamp=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', vehicle_id=None, voltages=[227.37, 228.37, 225.4]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', costs=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, ev=-1, prio=False, rfid=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x7018d850>), config=Config(configuration={'ip_address': '192.168.1.246', 'duo_num': 0}, ev=0, name='openWB Pro', type='openwb_pro', template=0, connected_phases=3, phase_1=0, auto_phase_switch_hw=False, control_pilot_interruption_hw=False, id=7)) 2024-01-17 13:18:31,699 - {control.data:266} - {INFO:MainThread} - cpt0 CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=0, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[]) 2024-01-17 13:18:31,699 - {control.data:266} - {INFO:MainThread} - cpt1 CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=1, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[]) 2024-01-17 13:18:31,701 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,702 - {control.data:266} - {INFO:MainThread} - cpt2 CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=2, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[]) 2024-01-17 13:18:31,712 - {control.data:266} - {INFO:MainThread} - cpt3 CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=3, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[]) 2024-01-17 13:18:31,717 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,718 - {control.data:266} - {INFO:MainThread} - counter6 CounterData(config=Config(max_currents=[16, 16, 16], max_total_power=11000), get=Get(powers=[12.28, 0.0, 0.0], currents=[0.15, 0.0, 0.0], voltages=[227.25, 228.29, 225.37], power_factors=[0.42, 0.0, 0.0], unbalanced_load=0, frequency=49.95000076293945, daily_exported=0, daily_imported=158.291695242792, imported=19322.95678832922, exported=0, fault_state=0, fault_str='Kein Fehler.', power=12.275969505310059), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=10987.72403049469, raw_currents_left=[15.85, 16.0, 16.0], surplus_power_left=0, state_str='')) 2024-01-17 13:18:31,725 - {control.data:241} - {INFO:MainThread} - counter_all_data CounterAllData(config=Config(reserve_for_not_charging=True), get=Get(hierarchy=[{'id': 6, 'type': 'counter', 'children': [{'id': 1, 'type': 'cp', 'children': []}, {'id': 7, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=12.275969505310059, invalid_home_consumption=0, daily_yield_home_consumption=158.292036938001, imported_home_consumption=19174.844391021805, disengageable_smarthome_power=0)) 2024-01-17 13:18:31,727 - {control.data:266} - {INFO:MainThread} - ct0 ChargeTemplateData(name='Standard-Lade-Profil', disable_after_unplug=False, prio=False, load_default=False, et=Et(active=True, max_price=0.0002), time_charging=TimeCharging(active=True, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50)))) 2024-01-17 13:18:31,728 - {control.data:266} - {INFO:MainThread} - ev0 EvData(set=Set(soc_error_counter=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp=0, force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.')) 2024-01-17 13:18:31,729 - {control.data:266} - {INFO:MainThread} - ev1 EvData(set=Set(soc_error_counter=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp=0, force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.')) 2024-01-17 13:18:31,730 - {control.data:266} - {INFO:MainThread} - et0 EvTemplateData(name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40) 2024-01-17 13:18:31,731 - {control.data:245} - {INFO:MainThread} - general_data GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=1), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=200, control_range=[0, 230], feed_in_yield=15000, phase_switch_delay=7, phases_to_use=1, rundown_power=1000, rundown_soc=50, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, prices=Prices(bat=0.00026000000000000003, cp=0, grid=0.00026000000000000003, pv=0.00026000000000000003), range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False)) 2024-01-17 13:18:31,732 - {control.data:246} - {INFO:MainThread} - general_data-display local 2024-01-17 13:18:31,732 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,733 - {control.data:247} - {INFO:MainThread} - graph_data GraphData(config=Config(duration=120)) 2024-01-17 13:18:31,740 - {control.data:248} - {INFO:MainThread} - optional_data OptionalData(et=Et(get=EtGet(fault_state=0, fault_str='Kein Fehler.', prices={'1705492800': 0.0003227, '1705496400': 0.0003228, '1705500000': 0.0003272, '1705503600': 0.0003309, '1705507200': 0.00034510000000000004, '1705510800': 0.000325, '1705514400': 0.0003139, '1705518000': 0.00030859999999999997, '1705521600': 0.00029820000000000004, '1705525200': 0.0002901, '1705528800': 0.00027810000000000004, '1705532400': 0.0002747, '1705536000': 0.0002698, '1705539600': 0.0002675, '1705543200': 0.0002671, '1705546800': 0.0002702, '1705550400': 0.0002743, '1705554000': 0.00028670000000000003, '1705557600': 0.00031069999999999996, '1705561200': 0.0003277, '1705564800': 0.0003233, '1705568400': 0.0003099, '1705572000': 0.0003064, '1705575600': 0.00028920000000000004})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x70ba2490>), led=Led(active=False), rfid=Rfid(active=False)) 2024-01-17 13:18:31,745 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,746 - {control.data:250} - {INFO:MainThread} - pv_all_data PvAllData(config=Config(configured=False), get=Get(daily_exported=0, monthly_exported=0, yearly_exported=0, exported=0, power=0)) 2024-01-17 13:18:31,752 - {control.data:266} - {INFO:MainThread} - system {'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.1.180', 'current_commit': '2024-01-17 09:41:21 +0100 [8c331fcb9]', 'current_branch': 'master', 'current_branch_commit': '2024-01-17 09:41:21 +0100 [8c331fcb9]', 'current_missing_commits': [], 'datastore_version': 34, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.1.3-Alpha.2', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1705493902, 'time': '13:18:22', 'grid': 0.013, 'house-power': 0.013, 'charging-all': 0.0, 'cp1-power': 0.0, 'cp7-power': 0.0}, 'module_update_completed': True} 2024-01-17 13:18:31,753 - {control.data:279} - {INFO:MainThread} - device2 {'name': 'EVU-Kit', 'type': 'openwb_evu_kit', 'id': 2, 'configuration': {}} 2024-01-17 13:18:31,755 - {control.data:281} - {INFO:MainThread} - component6 {'name': 'EVU-Kit', 'type': 'counter', 'id': 6, 'configuration': {'id': 115, 'version': 2}} 2024-01-17 13:18:31,757 - {control.data:253} - {INFO:MainThread} - 2024-01-17 13:18:31,761 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,766 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus 2024-01-17 13:18:31,778 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen** 2024-01-17 13:18:31,783 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Sollstrom setzen** 2024-01-17 13:18:31,790 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,792 - {control.counter:249} - {DEBUG:MainThread} - Anpassen des Regelbereichs 0W 2024-01-17 13:18:31,798 - {control.counter:217} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: -12.275969505310059W 2024-01-17 13:18:31,800 - {control.counter:484} - {DEBUG:MainThread} - Zähler 6: Begrenzung der verbleibenden Leistung auf -12.275969505310059W 2024-01-17 13:18:31,801 - {control.algorithm.algorithm:43} - {INFO:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.** 2024-01-17 13:18:31,803 - {control.process:23} - {INFO:MainThread} - # Ladung starten. 2024-01-17 13:18:31,804 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,813 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,820 - {modules.common.component_context:25} - {DEBUG:set current cp1} - Update Komponente ['Ladepunkt'] 2024-01-17 13:18:31,822 - {modules.common.component_context:25} - {DEBUG:set current cp7} - Update Komponente ['Ladepunkt'] 2024-01-17 13:18:31,827 - {urllib3.connectionpool:227} - {DEBUG:set current cp7} - Starting new HTTP connection (1): 192.168.1.246:80 2024-01-17 13:18:31,832 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,845 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,851 - {urllib3.connectionpool:452} - {DEBUG:set current cp7} - http://192.168.1.246:80 "POST /connect.php HTTP/1.1" 200 19 2024-01-17 13:18:31,858 - {modules.common.req:11} - {DEBUG:set current cp7} - Get-Response: OK Value:0 accepted 2024-01-17 13:18:31,862 - {control.counter:193} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung 2024-01-17 13:18:31,865 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,889 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,917 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,929 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,942 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,954 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,975 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,986 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:31,997 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,007 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,015 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,023 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,031 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,040 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,048 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,056 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,064 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,072 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,080 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,088 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,096 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,104 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,113 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,121 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,130 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,139 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,146 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={}) 2024-01-17 13:18:32,149 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,162 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,180 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,191 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,242 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,254 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,263 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,271 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,278 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,286 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,294 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,301 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,309 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,313 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_WRITE" (command:0x0009 flags:0x0001) 2024-01-17 13:18:32,314 - {SMB.SMBConnection:147} - {DEBUG:cloud backup} - Received SMB2 message "SMB2_COM_CLOSE" (command:0x0006 flags:0x0001) 2024-01-17 13:18:32,315 - {helpermodules.system:87} - {DEBUG:cloud backup} - Nächtliche Sicherung erstellt und hochgeladen
Häää, da steht aber dass es gelaufen ist und auch hoch geladen wurde
- mrinas
- Has thanked: 69 times
- Been thanked: 78 times
Re: Samba
ja eben, das war doch seine Message - es läuft jetzt. Gilt nur noch herauszufinden woran es lag, ich wette eine Hopfenkaltschale darauf dass der Ordner manuell erstellt werden musste.derNeueDet hat geschrieben: Mi Jan 17, 2024 1:56 pm Häää, da steht aber dass es gelaufen ist und auch hoch geladen wurde.
Falls sich das Bewahrheitet sollte das ggf. im Samba Modul entweder abgefragt, oder besser noch gehandabt werden. Also den Pfad auf Existenz prüfen und fehlende Ordern ggf. erstellen.
- Has thanked: 11 times
- Been thanked: 42 times
Re: Samba
Den Update hatte ich noch nicht gesehen. Mein Stand war noch geht nicht, als ich das Log angefragt hatte.
