Newbie Frage zu Fehler in den Logs
aMUSEd
Has thanked: 3 times
Beitrag von aMUSEd »
Guten Morgen,
habe eine OpenWB standard2 und mittels MQTT Zähler an mein Smarthome angebunden. Auto ist ein PlugIn BMW 330e. Mein WR ist ein Fronius Symo.
Vielen Dank schon mal im Voraus!
Bekomme folgende Fehler im SOC Log:
2024-03-03 13:58:36,565 - {modules.vehicles.bmw.api:73} - {ERROR:fetch soc_ev2} - bmw.getHTTP: Request failed, StatusCode: 403
2024-03-03 13:58:36,566 - {modules.vehicles.bmw.api:258} - {ERROR:fetch soc_ev2} - bmw.requestData: Data Request Error err=RuntimeError(), type(err)=<class 'RuntimeError'>
2024-03-03 13:58:36,567 - {modules.vehicles.bmw.api:278} - {ERROR:fetch soc_ev2} - bmw.fetch_soc: requestData Error, vehicle: 2 err=RuntimeError(), type(err)=<class 'RuntimeError'>
2024-03-03 13:58:36,569 - {modules.common.fault_state:55} - {ERROR:fetch soc_ev2} - BMW: FaultState FaultStateLevel.ERROR, FaultStr <class 'RuntimeError'> , Traceback:
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 66, in update
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 109, in _get_carstate_by_source
  File "/var/www/html/openWB/packages/modules/vehicles/bmw/soc.py", line 20, in updater
    return api.fetch_soc(
  File "/var/www/html/openWB/packages/modules/vehicles/bmw/api.py", line 273, in fetch_soc
    data = requestData(token, vin)
  File "/var/www/html/openWB/packages/modules/vehicles/bmw/api.py", line 255, in requestData
    body = getHTTP(url, headers)
  File "/var/www/html/openWB/packages/modules/vehicles/bmw/api.py", line 74, in getHTTP
    raise RuntimeError
RuntimeError
2024-03-03 18:17:16,938 - {modules.vehicles.bmw.api:73} - {ERROR:fetch soc_ev2} - bmw.getHTTP: Request failed, StatusCode: 403
2024-03-03 18:17:16,940 - {modules.vehicles.bmw.api:258} - {ERROR:fetch soc_ev2} - bmw.requestData: Data Request Error err=RuntimeError(), type(err)=<class 'RuntimeError'>
2024-03-03 18:17:16,942 - {modules.vehicles.bmw.api:278} - {ERROR:fetch soc_ev2} - bmw.fetch_soc: requestData Error, vehicle: 2 err=RuntimeError(), type(err)=<class 'RuntimeError'>
2024-03-03 18:17:16,944 - {modules.common.fault_state:55} - {ERROR:fetch soc_ev2} - BMW: FaultState FaultStateLevel.ERROR, FaultStr <class 'RuntimeError'> , Traceback:
    raise RuntimeError
RuntimeError
Bekomme folgende Fehler im Log vom internen Ladepunkt:
2024-03-04 08:07:09,379 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2024-03-04 08:07:09,428 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 90, in __read_registers
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 80, in get_values
    plug_state, charge_state, self.set_current_evse = self.__client.evse_client.get_plug_charge_state()
  File "/var/www/html/openWB/packages/modules/common/evse.py", line 39, in get_plug_charge_state
    set_current, _, state_number = self.client.read_holding_registers(
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 123, in read_holding_registers
    return self.__read_registers(
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 105, in __read_registers
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 242, in update
    state = self.module.get_values(phase_switch_cp_active, rfid_data.last_tag)[0]
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 125, in get_values
    raise FaultState.error(__name__ + " " + str(type(e)) + " " + str(e)) from e
modules.common.fault_state.FaultState: ('modules.internal_chargepoint_handler.chargepoint_module <class \'modules.common.fault_state.FaultState\'> ("modules.common.modbus <class \'modules.common.fault_state.FaultState\'> (\'modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)\', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)', <FaultStateLevel.ERROR: 2>)
2024-03-04 08:19:25,688 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2024-03-04 08:19:25,740 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
2024-03-04 08:42:36,616 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2024-03-04 08:42:36,665 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
2024-03-04 08:49:43,966 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2024-03-04 08:49:44,015 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
2024-03-04 08:53:09,703 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2024-03-04 08:53:09,752 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
Has thanked: 26 times
Been thanked: 161 times
Re: Newbie Frage zu Fehler in den Logs
403 ist Not Authorized.
Bei dem anderen Fehler: Hast Du die openWB-Hardware auch korrekt eingestellt?
aMUSEd
Danke für die Info betreffend HTTP 403 Gero.
Was meinst du mit korrekt eingestellt? MQTT Zähler liefert Werte, Fronius WR liefert auch Werte - kann man sich in den Diagrammen gut ansehen und prüfen. Was gibt es denn noch einzustellen?
LG Thomas
Naja, der Hausverbrauch wird errechnet aus den Leistungen von EVU, PV und Speicher. (Einspeisung / Produktion / Speicherentladung ist jeweils negativ) Und wenn da Hausverbrauch fehlt, scheint da mit der Berechnung etwas nicht zu funktionieren.
aMUSEd
Der Hausverbrauch wird korrekt berechnet und die unterschiedlichen Vorzeichen wurden auch lt. Doku beachtet. LG
Das war die Antwort auf eine andere Fragestellung. Sorry.
Es gibt ja einen Fehler beim Auslesen des internen Ladepunkts. Mit der Hardwareeinstellung meine ich das hier:
(95.7 KiB) Noch nie heruntergeladen
aMUSEd
Da ist dasselbe wie bei dir eingestellt.
Vermutlich lädt das Auto auch nicht, oder? Ich denke ein Ticket beim Support aufmachen hilft da schneller weiter.
aMUSEd
Danke. Mache ich morgen gleich.
aMUSEd
Liebe community,
leider wurde mir durch den Support nicht geholfen und mich auf die Unterstützung durch die community verwiesen.
Kann mir bitte jemand helfen?!
LG Thomas
