Problem in der Nightly 1.9.249
fawick
Been thanked: 3 times
Re: Problem in der Nightly 1.9.249
Beitrag von fawick »
Hier das Log
2021-10-26 15:15:09: Sofort ladung erreicht bei 16 A (LV1) at 115 sofortlademodus sofortlademodus.sh
2021-10-26 15:15:08: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1182 loadvars loadvars.sh
2021-10-26 15:15:08: plugstatlp1 1	plugstatlp2 0	plugstatlp3 0 (LV1) at 1181 loadvars loadvars.sh
2021-10-26 15:15:08: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1180 loadvars loadvars.sh
2021-10-26 15:15:08: EVU 1:V/7A 2: V/-3A 3: V/-3A (LV1) at 1179 loadvars loadvars.sh
2021-10-26 15:15:08: lla3 0	llv3 0.0	llas13  llas23  soclp1 79 soclp2 (LV1) at 1178 loadvars loadvars.sh
2021-10-26 15:15:08: lla2 0	llv2 116.0	llas12  llas22  sofortll 16 hausverbrauch 244 wattbezug 96 uberschuss -96 (LV1) at 1177 loadvars loadvars.sh
2021-10-26 15:15:08: lla1 15	llv1 232.6	llas11  llas21  mindestuberschuss 1320 abschaltuberschuss 100 lademodus 0 (LV1) at 1176 loadvars loadvars.sh
2021-10-26 15:15:08: pv1watt -2766 pv2watt  pvwatt -2766 ladeleistung 3443 llalt 16 nachtladen 1 nachtladen 0 minimalA 16 maximalA 16 (LV1) at 1175 loadvars loadvars.sh
2021-10-26 15:15:08: speicherleistung -858 speichersoc 92 (LV1) at 1170 loadvars loadvars.sh
2021-10-26 15:15:07: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-10-26 15:15:07: PID: 9170: Frequenz: 50
2021-10-26 15:15:07: PID: 9170: Strom L3: -3.8
2021-10-26 15:15:07: PID: 9170: Strom L2: -3.63
2021-10-26 15:15:07: PID: 9170: Strom L1: 7.86
2021-10-26 15:15:07: PID: 9170: Spannung L3: 234.9
2021-10-26 15:15:07: PID: 9170: Spannung L2: 234.2
2021-10-26 15:15:07: PID: 9170: Spannung L1: 233.8
2021-10-26 15:15:07: PID: 9170: Power Faktor L3: -0.99
2021-10-26 15:15:07: PID: 9170: Power Faktor L2: -1.0
2021-10-26 15:15:07: PID: 9170: Power Faktor L1: 0.91
2021-10-26 15:15:07: PID: 9170: Leistung L3: -892.1
2021-10-26 15:15:07: PID: 9170: Leistung L2: -850.1
2021-10-26 15:15:07: PID: 9170: Leistung L1: 1838.8
2021-10-26 15:15:07: PID: 9170: Bezug: 1862336
2021-10-26 15:15:07: PID: 9170: Einspeisung: 584376
2021-10-26 15:15:07: PID: 9170: Watt: 96
2021-10-26 15:15:07: PID: 9170: Zaehlerort: 0
2021-10-26 15:15:07: PID: 9170: response_sm_data: {'Body': {'Data': {'PowerReactive_Q_Phase_2': -66.9, 'PowerReal_P_Sum': 96.6, 'PowerReactive_Q_Sum': -1012.1, 'EnergyReal_WAC_Minus_Absolute': 584376, 'PowerApparent_S_Phase_3': 897.1, 'PowerFactor_Phase_3': -0.994, 'PowerApparent_S_Phase_1': 2025.9, 'Voltage_AC_PhaseToPhase_12': 405.2, 'EnergyReactive_VArAC_Sum_Consumed': 84187, 'PowerReactive_Q_Phase_3': -94.8, 'Meter_Location_Current': 0, 'Current_AC_Phase_3': -3.815, 'Current_AC_Phase_1': 8.807, 'PowerReal_P_Phase_2': -850.1, 'PowerFactor_Phase_2': -0.997, 'Details': {'Model': 'Smart Meter TS 65A-3', 'Manufacturer': 'Fronius', 'Serial': '1642594792'}, 'TimeStamp': 1635254106, 'Enable': 1, 'EnergyReal_WAC_Sum_Consumed': 1862336, 'EnergyReal_WAC_Sum_Produced': 584376, 'PowerReal_P_Phase_1': 1838.8, 'Voltage_AC_PhaseToPhase_23': 406.2, 'PowerReal_P_Phase_3': -892.1, 'PowerApparent_S_Sum': 3775.8, 'Frequency_Phase_Average': 50, 'EnergyReactive_VArAC_Sum_Produced': 2281726, 'Current_AC_Sum': 1.3490000000000006, 'Current_AC_Phase_2': -3.643, 'EnergyReal_WAC_Plus_Absolute': 1862336, 'Voltage_AC_Phase_3': 234.9, 'PowerReactive_Q_Phase_1': -850.3, 'Visible': 1, 'Voltage_AC_Phase_2': 234.2, 'PowerFactor_Phase_1': 0.905, 'Voltage_AC_PhaseToPhase_31': 405.9, 'PowerApparent_S_Phase_2': 852.7, 'PowerFactor_Sum': 0.073, 'Voltage_AC_Phase_1': 233.8}}, 'Head': {'RequestArguments': {'DeviceClass': 'Meter', 'Scope': 'Device', 'DeviceId': '0'}, 'Timestamp': '2021-10-26T15:15:06+02:00', 'Status': {'Reason': '', 'UserMessage': '', 'Code': 0}}}
2021-10-26 15:15:07: PID: 9170: response_sm: <Response [200]>
2021-10-26 15:15:07: PID: 9170: Fronius SM Zaehlerort: 0
2021-10-26 15:15:07: PID: 9170: Fronius SM IP: 192.168.109.137
2021-10-26 15:15:07: PID: 9170: Fronius SM Erzeugung: 0
2021-10-26 15:15:07: PID: 9170: Fronius SM Variante: 0
2021-10-26 15:15:04: BattLeistung: -858 (LV1) at 31 main modules/speicher_alphaess/main.sh
2021-10-26 15:15:04: RET: 0 (LV2) at 27 main modules/speicher_alphaess/main.sh
2021-10-26 15:15:04: PID: 9082: BAT Bezug: 629186.7411111111
2021-10-26 15:15:04: PID: 9082: BAT Einspeisung: 599474.7393883901
2021-10-26 15:15:04: PID: 9082: BAT Watt: -858
2021-10-26 15:15:04: PID: 9082: simcount Zwischenergebnisse atkuelle Berechnung: Import: 2265072268 Export: 2158109061.7982044 Power: -858.13
2021-10-26 15:15:04: PID: 9082: simcount Ergebnis: Bezug[Wh]: 629186.7411111111, Einspeisung[Wh]: 599474.7393883901
2021-10-26 15:15:04: PID: 9082: simcount aufsummierte Energie: Bezug[Ws]: 2265072268, Einspeisung[Ws]: 2158109061.7982044
2021-10-26 15:15:04: PID: 9082: simcount Gesamtenergie im Zeitintervall: -6918.7982046377665
2021-10-26 15:15:04: PID: 9082: simcount Berechnungsgrundlage: vergangene Zeit [s]8.984693765640259, vorherige Leistung[W]: -682, aktuelle Leistung[W]: -858.13
2021-10-26 15:15:04: PID: 9082: simcount Zwischenergebnisse letzte Berechnung: Import: 2265072268 Export: 2158102143 Power: -682
2021-10-26 15:15:04: PID: 9082: Alpha Ess Leistung[W]: -858.13, Speicher-Register: Spannung[V] 533 Strom[A] 161
2021-10-26 15:15:03: PID: 9082: Komponente Alpha Ess bat auslesen.
2021-10-26 15:15:03: PID: 9082: Komponenten von Alpha Ess auslesen.
2021-10-26 15:15:03: PID: 9082: alpha_ess Version: 1
2021-10-26 15:15:03: ##### cron5min.sh finished ##### (LV0) at 396 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:03: Speicher SoC: .RSOC (LV2) at 22 main modules/speicher_alphaess/main.sh
2021-10-26 15:15:03: Speicher Watt: .Consumption_W (LV2) at 21 main modules/speicher_alphaess/main.sh
2021-10-26 15:15:03: Speicher URL: 192.168.0.10/speicher (LV2) at 20 main modules/speicher_alphaess/main.sh
2021-10-26 15:15:02: logfile cleanup triggered (LV1) at 393 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02:  Load: 2.38 1.96 2.05
2021-10-26 15:15:02: starting evsecheck (LV1) at 389 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02: pingcheck configured; starting (LV1) at 384 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02: modbus tcp server already running (LV1) at 376 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02: external openWB or daemon mode not configured; checking network setup (LV1) at 311 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02: smarthome handler is already running (LV1) at 294 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02: mqtt handler is already running (LV1) at 285 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02: current ip: 192.168.109.178 (LV1) at 280 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:02: updating daily yield stats (LV1) at 150 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:01: electricity provider not set up; skipping price update (LV2) at 146 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:01: Netzschutz konfiguriert; aktuelle Frequenz: 4993 (LV1) at 95 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:01: daily csv updated: /var/www/html/openWB/web/logging/data/daily/20211026.csv (LV1) at 87 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:01: ##### cron5min.sh started ##### (LV0) at 8 main /var/www/html/openWB/runs/cron5min.sh
2021-10-26 15:15:01: **** Regulation loop start **** (LV1) at 50 main /var/www/html/openWB/regel.sh
2021-10-26 15:14:59: Sofort ladung erreicht bei 16 A (LV1) at 115 sofortlademodus sofortlademodus.sh
2021-10-26 15:14:57: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1182 loadvars loadvars.sh
2021-10-26 15:14:57: plugstatlp1 1	plugstatlp2 0	plugstatlp3 0 (LV1) at 1181 loadvars loadvars.sh
2021-10-26 15:14:57: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1180 loadvars loadvars.sh
2021-10-26 15:14:57: EVU 1:V/8A 2: V/-3A 3: V/-3A (LV1) at 1179 loadvars loadvars.sh
2021-10-26 15:14:57: lla3 0	llv3 0.0	llas13  llas23  soclp1 79 soclp2 (LV1) at 1178 loadvars loadvars.sh
2021-10-26 15:14:57: lla2 0	llv2 116.0	llas12  llas22  sofortll 16 hausverbrauch 305 wattbezug 172 uberschuss -172 (LV1) at 1177 loadvars loadvars.sh
2021-10-26 15:14:57: lla1 14	llv1 232.6	llas11  llas21  mindestuberschuss 1320 abschaltuberschuss 100 lademodus 0 (LV1) at 1176 loadvars loadvars.sh
2021-10-26 15:14:57: pv1watt -2901 pv2watt  pvwatt -2901 ladeleistung 3417 llalt 16 nachtladen 1 nachtladen 0 minimalA 16 maximalA 16 (LV1) at 1175 loadvars loadvars.sh
2021-10-26 15:14:57: speicherleistung -682 speichersoc 92 (LV1) at 1170 loadvars loadvars.sh
2021-10-26 15:14:57: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-10-26 15:14:57: PID: 7652: Frequenz: 50
2021-10-26 15:14:57: PID: 7652: Strom L3: -3.82
2021-10-26 15:14:57: PID: 7652: Strom L2: -3.65
2021-10-26 15:14:57: PID: 7652: Strom L1: 8.24
2021-10-26 15:14:57: PID: 7652: Spannung L3: 234.7
2021-10-26 15:14:57: PID: 7652: Spannung L2: 234.2
2021-10-26 15:14:57: PID: 7652: Spannung L1: 233.7
2021-10-26 15:14:57: PID: 7652: Power Faktor L3: -0.99
2021-10-26 15:14:57: PID: 7652: Power Faktor L2: -1.0
2021-10-26 15:14:57: PID: 7652: Power Faktor L1: 0.91
2021-10-26 15:14:57: PID: 7652: Leistung L3: -897.6
2021-10-26 15:14:57: PID: 7652: Leistung L2: -856
2021-10-26 15:14:57: PID: 7652: Leistung L1: 1925.9
2021-10-26 15:14:57: PID: 7652: Bezug: 1862336
2021-10-26 15:14:57: PID: 7652: Einspeisung: 584376
2021-10-26 15:14:57: PID: 7652: Watt: 172
2021-10-26 15:14:57: PID: 7652: Zaehlerort: 0
2021-10-26 15:14:57: PID: 7652: response_sm_data: {'Body': {'Data': {'EnergyReactive_VArAC_Sum_Consumed': 84187, 'EnergyReactive_VArAC_Sum_Produced': 2281723, 'Voltage_AC_PhaseToPhase_31': 405.6, 'Voltage_AC_Phase_3': 234.7, 'PowerReal_P_Phase_1': 1925.9, 'Details': {'Model': 'Smart Meter TS 65A-3', 'Manufacturer': 'Fronius', 'Serial': '1642594792'}, 'PowerReactive_Q_Phase_1': -857.9, 'PowerReal_P_Phase_2': -856, 'PowerFactor_Sum': 0.146, 'Current_AC_Sum': 1.6420000000000003, 'EnergyReal_WAC_Sum_Consumed': 1862336, 'TimeStamp': 1635254096, 'PowerReactive_Q_Phase_3': -95.7, 'PowerFactor_Phase_1': 0.912, 'Voltage_AC_Phase_1': 233.7, 'PowerReactive_Q_Phase_2': -67.2, 'Current_AC_Phase_3': -3.864, 'EnergyReal_WAC_Plus_Absolute': 1862336, 'PowerFactor_Phase_3': -0.994, 'PowerFactor_Phase_2': -0.997, 'EnergyReal_WAC_Sum_Produced': 584376, 'Enable': 1, 'Meter_Location_Current': 0, 'Voltage_AC_PhaseToPhase_23': 406, 'PowerApparent_S_Phase_3': 902.7, 'Frequency_Phase_Average': 50, 'Visible': 1, 'PowerApparent_S_Sum': 3869.8, 'PowerApparent_S_Phase_1': 2108.3, 'PowerReactive_Q_Sum': -1020.9, 'Voltage_AC_Phase_2': 234.2, 'PowerReal_P_Phase_3': -897.6, 'PowerApparent_S_Phase_2': 858.7, 'PowerReal_P_Sum': 172.1, 'EnergyReal_WAC_Minus_Absolute': 584376, 'Current_AC_Phase_2': -3.693, 'Current_AC_Phase_1': 9.199, 'Voltage_AC_PhaseToPhase_12': 405.2}}, 'Head': {'Status': {'Reason': '', 'Code': 0, 'UserMessage': ''}, 'Timestamp': '2021-10-26T15:14:56+02:00', 'RequestArguments': {'DeviceId': '0', 'Scope': 'Device', 'DeviceClass': 'Meter'}}}
2021-10-26 15:14:57: PID: 7652: response_sm: <Response [200]>
2021-10-26 15:14:57: PID: 7652: Fronius SM Zaehlerort: 0
2021-10-26 15:14:57: PID: 7652: Fronius SM IP: 192.168.109.137
2021-10-26 15:14:57: PID: 7652: Fronius SM Erzeugung: 0
2021-10-26 15:14:57: PID: 7652: Fronius SM Variante: 0
2021-10-26 15:14:54: BattLeistung: -682 (LV1) at 31 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:54: RET: 0 (LV2) at 27 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:54: PID: 7605: BAT Bezug: 629186.7411111111
2021-10-26 15:14:54: PID: 7605: BAT Einspeisung: 599472.8177038947
2021-10-26 15:14:54: PID: 7605: BAT Watt: -682
2021-10-26 15:14:54: PID: 7605: simcount Zwischenergebnisse atkuelle Berechnung: Import: 2265072268 Export: 2158102143.7340207 Power: -682.24
2021-10-26 15:14:54: PID: 7605: simcount Ergebnis: Bezug[Wh]: 629186.7411111111, Einspeisung[Wh]: 599472.8177038947
2021-10-26 15:14:54: PID: 7605: simcount aufsummierte Energie: Bezug[Ws]: 2265072268, Einspeisung[Ws]: 2158102143.7340207
2021-10-26 15:14:54: PID: 7605: simcount Gesamtenergie im Zeitintervall: -5425.734020905495
2021-10-26 15:14:54: PID: 7605: simcount Berechnungsgrundlage: vergangene Zeit [s]8.97379183769226, vorherige Leistung[W]: -527, aktuelle Leistung[W]: -682.24
2021-10-26 15:14:54: PID: 7605: simcount Zwischenergebnisse letzte Berechnung: Import: 2265072268 Export: 2158096718 Power: -527
2021-10-26 15:14:54: PID: 7605: Alpha Ess Leistung[W]: -682.24, Speicher-Register: Spannung[V] 533 Strom[A] 128
2021-10-26 15:14:54: PID: 7605: Komponente Alpha Ess bat auslesen.
2021-10-26 15:14:54: PID: 7605: Komponenten von Alpha Ess auslesen.
2021-10-26 15:14:54: PID: 7605: alpha_ess Version: 1
2021-10-26 15:14:53: Speicher SoC: .RSOC (LV2) at 22 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:53: Speicher Watt: .Consumption_W (LV2) at 21 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:53: Speicher URL: 192.168.0.10/speicher (LV2) at 20 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:52: **** Regulation loop start **** (LV1) at 50 main /var/www/html/openWB/regel.sh
2021-10-26 15:14:49: Sofort ladung erreicht bei 16 A (LV1) at 115 sofortlademodus sofortlademodus.sh
2021-10-26 15:14:48: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1182 loadvars loadvars.sh
2021-10-26 15:14:48: plugstatlp1 1	plugstatlp2 0	plugstatlp3 0 (LV1) at 1181 loadvars loadvars.sh
2021-10-26 15:14:48: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1180 loadvars loadvars.sh
2021-10-26 15:14:48: EVU 1:V/8A 2: V/-3A 3: V/-4A (LV1) at 1179 loadvars loadvars.sh
2021-10-26 15:14:48: lla3 0	llv3 0.0	llas13  llas23  soclp1 79 soclp2 (LV1) at 1178 loadvars loadvars.sh
2021-10-26 15:14:48: lla2 0	llv2 115.9	llas12  llas22  sofortll 16 hausverbrauch 325 wattbezug 146 uberschuss -146 (LV1) at 1177 loadvars loadvars.sh
2021-10-26 15:14:48: lla1 14	llv1 232.5	llas11  llas21  mindestuberschuss 1320 abschaltuberschuss 100 lademodus 0 (LV1) at 1176 loadvars loadvars.sh
2021-10-26 15:14:47: pv1watt -3107 pv2watt  pvwatt -3107 ladeleistung 3422 llalt 16 nachtladen 1 nachtladen 0 minimalA 16 maximalA 16 (LV1) at 1175 loadvars loadvars.sh
2021-10-26 15:14:47: speicherleistung -527 speichersoc 92 (LV1) at 1170 loadvars loadvars.sh
2021-10-26 15:14:47: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-10-26 15:14:47: PID: 6453: Frequenz: 50
2021-10-26 15:14:47: PID: 6453: Strom L3: -4.14
2021-10-26 15:14:47: PID: 6453: Strom L2: -3.97
2021-10-26 15:14:47: PID: 6453: Strom L1: 8.77
2021-10-26 15:14:47: PID: 6453: Spannung L3: 234.9
2021-10-26 15:14:47: PID: 6453: Spannung L2: 234.2
2021-10-26 15:14:47: PID: 6453: Spannung L1: 233.6
2021-10-26 15:14:47: PID: 6453: Power Faktor L3: -0.99
2021-10-26 15:14:47: PID: 6453: Power Faktor L2: -1.0
2021-10-26 15:14:47: PID: 6453: Power Faktor L1: 0.92
2021-10-26 15:14:47: PID: 6453: Leistung L3: -972.3
2021-10-26 15:14:47: PID: 6453: Leistung L2: -930
2021-10-26 15:14:47: PID: 6453: Leistung L1: 2048.7
2021-10-26 15:14:47: PID: 6453: Bezug: 1862336
2021-10-26 15:14:47: PID: 6453: Einspeisung: 584376
2021-10-26 15:14:47: PID: 6453: Watt: 146
2021-10-26 15:14:47: PID: 6453: Zaehlerort: 0
2021-10-26 15:14:47: PID: 6453: response_sm_data: {'Body': {'Data': {'EnergyReal_WAC_Plus_Absolute': 1862336, 'Enable': 1, 'PowerReactive_Q_Phase_1': -880.3, 'PowerReactive_Q_Sum': -1046, 'Current_AC_Sum': 1.7269999999999994, 'EnergyReactive_VArAC_Sum_Consumed': 84187, 'PowerApparent_S_Phase_1': 2229.9, 'PowerFactor_Phase_1': 0.92, 'Voltage_AC_PhaseToPhase_23': 406.2, 'PowerFactor_Sum': 0.17, 'Current_AC_Phase_3': -4.143, 'Voltage_AC_Phase_1': 233.6, 'TimeStamp': 1635254086, 'Details': {'Serial': '1642594792', 'Model': 'Smart Meter TS 65A-3', 'Manufacturer': 'Fronius'}, 'PowerFactor_Phase_3': -0.995, 'EnergyReal_WAC_Sum_Produced': 584376, 'Visible': 1, 'Meter_Location_Current': 0, 'Voltage_AC_PhaseToPhase_12': 405.1, 'Current_AC_Phase_1': 9.84, 'PowerApparent_S_Phase_2': 932.5, 'EnergyReactive_VArAC_Sum_Produced': 2281720, 'PowerFactor_Phase_2': -0.997, 'PowerReal_P_Phase_3': -972.3, 'Voltage_AC_Phase_2': 234.2, 'PowerReal_P_Phase_1': 2048.7, 'PowerApparent_S_Sum': 4139.7, 'PowerApparent_S_Phase_3': 977.2, 'PowerReactive_Q_Phase_3': -96.9, 'Frequency_Phase_Average': 50, 'EnergyReal_WAC_Sum_Consumed': 1862336, 'Current_AC_Phase_2': -3.97, 'Voltage_AC_Phase_3': 234.9, 'PowerReactive_Q_Phase_2': -68.6, 'Voltage_AC_PhaseToPhase_31': 405.7, 'EnergyReal_WAC_Minus_Absolute': 584376, 'PowerReal_P_Phase_2': -930, 'PowerReal_P_Sum': 146.3}}, 'Head': {'RequestArguments': {'DeviceClass': 'Meter', 'Scope': 'Device', 'DeviceId': '0'}, 'Status': {'Reason': '', 'Code': 0, 'UserMessage': ''}, 'Timestamp': '2021-10-26T15:14:46+02:00'}}
2021-10-26 15:14:47: PID: 6453: response_sm: <Response [200]>
2021-10-26 15:14:47: PID: 6453: Fronius SM Zaehlerort: 0
2021-10-26 15:14:47: PID: 6453: Fronius SM IP: 192.168.109.137
2021-10-26 15:14:47: PID: 6453: Fronius SM Erzeugung: 0
2021-10-26 15:14:47: PID: 6453: Fronius SM Variante: 0
2021-10-26 15:14:44: BattLeistung: -527 (LV1) at 31 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:44: RET: 0 (LV2) at 27 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:44: PID: 6406: BAT Bezug: 629186.7411111111
2021-10-26 15:14:44: PID: 6406: BAT Einspeisung: 599471.3107990433
2021-10-26 15:14:44: PID: 6406: BAT Watt: -527
2021-10-26 15:14:44: PID: 6406: simcount Zwischenergebnisse atkuelle Berechnung: Import: 2265072268 Export: 2158096718.876556 Power: -527.67
2021-10-26 15:14:44: PID: 6406: simcount Ergebnis: Bezug[Wh]: 629186.7411111111, Einspeisung[Wh]: 599471.3107990433
2021-10-26 15:14:44: PID: 6406: simcount aufsummierte Energie: Bezug[Ws]: 2265072268, Einspeisung[Ws]: 2158096718.876556
2021-10-26 15:14:44: PID: 6406: simcount Gesamtenergie im Zeitintervall: -4771.876555932759
2021-10-26 15:14:44: PID: 6406: simcount Berechnungsgrundlage: vergangene Zeit [s]9.049041986465454, vorherige Leistung[W]: -527, aktuelle Leistung[W]: -527.67
2021-10-26 15:14:44: PID: 6406: simcount Zwischenergebnisse letzte Berechnung: Import: 2265072268 Export: 2158091947 Power: -527
2021-10-26 15:14:44: PID: 6406: Alpha Ess Leistung[W]: -527.67, Speicher-Register: Spannung[V] 533 Strom[A] 99
2021-10-26 15:14:44: PID: 6406: Komponente Alpha Ess bat auslesen.
2021-10-26 15:14:44: PID: 6406: Komponenten von Alpha Ess auslesen.
2021-10-26 15:14:44: PID: 6406: alpha_ess Version: 1
2021-10-26 15:14:43: Speicher SoC: .RSOC (LV2) at 22 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:43: Speicher Watt: .Consumption_W (LV2) at 21 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:43: Speicher URL: 192.168.0.10/speicher (LV2) at 20 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:42: **** Regulation loop start **** (LV1) at 50 main /var/www/html/openWB/regel.sh
2021-10-26 15:14:41: Sofort ladung erreicht bei 16 A (LV1) at 115 sofortlademodus sofortlademodus.sh
2021-10-26 15:14:40: LP1 Modbus 16 korrekt (LV1) at 236 evsemodbuscheck evsedintest.sh
2021-10-26 15:14:38: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1182 loadvars loadvars.sh
2021-10-26 15:14:38: plugstatlp1 1	plugstatlp2 0	plugstatlp3 0 (LV1) at 1181 loadvars loadvars.sh
2021-10-26 15:14:38: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1180 loadvars loadvars.sh
2021-10-26 15:14:38: EVU 1:V/8A 2: V/-4A 3: V/-4A (LV1) at 1179 loadvars loadvars.sh
2021-10-26 15:14:38: lla3 0	llv3 0.0	llas13  llas23  soclp1 79 soclp2 (LV1) at 1178 loadvars loadvars.sh
2021-10-26 15:14:38: lla2 0	llv2 116.0	llas12  llas22  sofortll 16 hausverbrauch 197 wattbezug 10 uberschuss -10 (LV1) at 1177 loadvars loadvars.sh
2021-10-26 15:14:38: lla1 14	llv1 232.7	llas11  llas21  mindestuberschuss 1320 abschaltuberschuss 100 lademodus 0 (LV1) at 1176 loadvars loadvars.sh
2021-10-26 15:14:38: pv1watt -3118 pv2watt  pvwatt -3118 ladeleistung 3425 llalt 16 nachtladen 1 nachtladen 0 minimalA 16 maximalA 16 (LV1) at 1175 loadvars loadvars.sh
2021-10-26 15:14:38: speicherleistung -527 speichersoc 92 (LV1) at 1170 loadvars loadvars.sh
2021-10-26 15:14:37: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-10-26 15:14:37: PID: 5243: Frequenz: 50
2021-10-26 15:14:37: PID: 5243: Strom L3: -4.34
2021-10-26 15:14:37: PID: 5243: Strom L2: -4.17
2021-10-26 15:14:37: PID: 5243: Strom L1: 8.59
2021-10-26 15:14:37: PID: 5243: Spannung L3: 235.1
2021-10-26 15:14:37: PID: 5243: Spannung L2: 234.5
2021-10-26 15:14:37: PID: 5243: Spannung L1: 233.9
2021-10-26 15:14:37: PID: 5243: Power Faktor L3: -0.99
2021-10-26 15:14:37: PID: 5243: Power Faktor L2: -1.0
2021-10-26 15:14:37: PID: 5243: Power Faktor L1: 0.92
2021-10-26 15:14:37: PID: 5243: Leistung L3: -1020.1
2021-10-26 15:14:37: PID: 5243: Leistung L2: -978.9
2021-10-26 15:14:37: PID: 5243: Leistung L1: 2009.4
2021-10-26 15:14:37: PID: 5243: Bezug: 1862335
2021-10-26 15:14:37: PID: 5243: Einspeisung: 584376
2021-10-26 15:14:37: PID: 5243: Watt: 10
2021-10-26 15:14:37: PID: 5243: Zaehlerort: 0
2021-10-26 15:14:37: PID: 5243: response_sm_data: {'Body': {'Data': {'EnergyReal_WAC_Sum_Produced': 584376, 'Details': {'Serial': '1642594792', 'Model': 'Smart Meter TS 65A-3', 'Manufacturer': 'Fronius'}, 'Current_AC_Sum': 1.0839999999999996, 'Frequency_Phase_Average': 50, 'Enable': 1, 'Voltage_AC_PhaseToPhase_12': 405.6, 'Current_AC_Phase_1': 9.625, 'PowerApparent_S_Sum': 4202.4, 'Current_AC_Phase_3': -4.354, 'PowerApparent_S_Phase_2': 981.3, 'EnergyReactive_VArAC_Sum_Consumed': 84187, 'Meter_Location_Current': 0, 'PowerReactive_Q_Phase_2': -69.3, 'EnergyReal_WAC_Minus_Absolute': 584376, 'Voltage_AC_Phase_1': 233.9, 'EnergyReal_WAC_Plus_Absolute': 1862335, 'PowerApparent_S_Phase_1': 2196.1, 'PowerReactive_Q_Phase_1': -886, 'PowerReal_P_Phase_1': 2009.4, 'PowerFactor_Phase_3': -0.995, 'PowerReal_P_Phase_2': -978.9, 'PowerFactor_Phase_1': 0.915, 'PowerReactive_Q_Sum': -1054, 'PowerApparent_S_Phase_3': 1024.9, 'PowerReal_P_Phase_3': -1020.1, 'Visible': 1, 'EnergyReal_WAC_Sum_Consumed': 1862335, 'EnergyReactive_VArAC_Sum_Produced': 2281717, 'PowerFactor_Sum': 0.025, 'TimeStamp': 1635254076, 'PowerFactor_Phase_2': -0.998, 'PowerReal_P_Sum': 10.3, 'Current_AC_Phase_2': -4.187, 'Voltage_AC_PhaseToPhase_23': 406.6, 'Voltage_AC_Phase_3': 235.1, 'PowerReactive_Q_Phase_3': -98.7, 'Voltage_AC_Phase_2': 234.5, 'Voltage_AC_PhaseToPhase_31': 406.1}}, 'Head': {'Status': {'UserMessage': '', 'Code': 0, 'Reason': ''}, 'RequestArguments': {'DeviceClass': 'Meter', 'DeviceId': '0', 'Scope': 'Device'}, 'Timestamp': '2021-10-26T15:14:36+02:00'}}
2021-10-26 15:14:37: PID: 5243: response_sm: <Response [200]>
2021-10-26 15:14:37: PID: 5243: Fronius SM Zaehlerort: 0
2021-10-26 15:14:37: PID: 5243: Fronius SM IP: 192.168.109.137
2021-10-26 15:14:37: PID: 5243: Fronius SM Erzeugung: 0
2021-10-26 15:14:37: PID: 5243: Fronius SM Variante: 0
2021-10-26 15:14:34: BattLeistung: -527 (LV1) at 31 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:34: RET: 0 (LV2) at 27 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:34: PID: 5195: BAT Bezug: 629186.7411111111
2021-10-26 15:14:34: PID: 5195: BAT Einspeisung: 599469.9855234979
2021-10-26 15:14:34: PID: 5195: BAT Watt: -527
2021-10-26 15:14:34: PID: 5195: simcount Zwischenergebnisse atkuelle Berechnung: Import: 2265072268 Export: 2158091947.8845925 Power: -527.67
2021-10-26 15:14:34: PID: 5195: simcount Ergebnis: Bezug[Wh]: 629186.7411111111, Einspeisung[Wh]: 599469.9855234979
2021-10-26 15:14:34: PID: 5195: simcount aufsummierte Energie: Bezug[Ws]: 2265072268, Einspeisung[Ws]: 2158091947.8845925
2021-10-26 15:14:34: PID: 5195: simcount Gesamtenergie im Zeitintervall: -4763.884592363835
2021-10-26 15:14:34: PID: 5195: simcount Berechnungsgrundlage: vergangene Zeit [s]9.025329113006592, vorherige Leistung[W]: -528, aktuelle Leistung[W]: -527.67
2021-10-26 15:14:34: PID: 5195: simcount Zwischenergebnisse letzte Berechnung: Import: 2265072268 Export: 2158087184 Power: -528
2021-10-26 15:14:34: PID: 5195: Alpha Ess Leistung[W]: -527.67, Speicher-Register: Spannung[V] 533 Strom[A] 99
2021-10-26 15:14:33: PID: 5195: Komponente Alpha Ess bat auslesen.
2021-10-26 15:14:33: PID: 5195: Komponenten von Alpha Ess auslesen.
2021-10-26 15:14:33: PID: 5195: alpha_ess Version: 1
2021-10-26 15:14:33: Speicher SoC: .RSOC (LV2) at 22 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:33: Speicher Watt: .Consumption_W (LV2) at 21 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:33: Speicher URL: 192.168.0.10/speicher (LV2) at 20 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:32: **** Regulation loop start **** (LV1) at 50 main /var/www/html/openWB/regel.sh
2021-10-26 15:14:29: Sofort ladung erreicht bei 16 A (LV1) at 115 sofortlademodus sofortlademodus.sh
2021-10-26 15:14:28: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1182 loadvars loadvars.sh
2021-10-26 15:14:27: plugstatlp1 1	plugstatlp2 0	plugstatlp3 0 (LV1) at 1181 loadvars loadvars.sh
2021-10-26 15:14:27: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1180 loadvars loadvars.sh
2021-10-26 15:14:27: EVU 1:V/8A 2: V/-4A 3: V/-4A (LV1) at 1179 loadvars loadvars.sh
2021-10-26 15:14:27: lla3 0	llv3 0.0	llas13  llas23  soclp1 79 soclp2 (LV1) at 1178 loadvars loadvars.sh
2021-10-26 15:14:27: lla2 0	llv2 116.1	llas12  llas22  sofortll 16 hausverbrauch 192 wattbezug 35 uberschuss -35 (LV1) at 1177 loadvars loadvars.sh
2021-10-26 15:14:27: lla1 14	llv1 232.9	llas11  llas21  mindestuberschuss 1320 abschaltuberschuss 100 lademodus 0 (LV1) at 1176 loadvars loadvars.sh
2021-10-26 15:14:27: pv1watt -3091 pv2watt  pvwatt -3091 ladeleistung 3429 llalt 16 nachtladen 1 nachtladen 0 minimalA 16 maximalA 16 (LV1) at 1175 loadvars loadvars.sh
2021-10-26 15:14:27: speicherleistung -528 speichersoc 92 (LV1) at 1170 loadvars loadvars.sh
2021-10-26 15:14:27: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-10-26 15:14:27: PID: 4042: Frequenz: 50
2021-10-26 15:14:27: PID: 4042: Strom L3: -4.29
2021-10-26 15:14:27: PID: 4042: Strom L2: -4.11
2021-10-26 15:14:27: PID: 4042: Strom L1: 8.6
2021-10-26 15:14:27: PID: 4042: Spannung L3: 235
2021-10-26 15:14:27: PID: 4042: Spannung L2: 235.4
2021-10-26 15:14:27: PID: 4042: Spannung L1: 234
2021-10-26 15:14:27: PID: 4042: Power Faktor L3: -0.99
2021-10-26 15:14:27: PID: 4042: Power Faktor L2: -1.0
2021-10-26 15:14:27: PID: 4042: Power Faktor L1: 0.92
2021-10-26 15:14:27: PID: 4042: Leistung L3: -1009.1
2021-10-26 15:14:27: PID: 4042: Leistung L2: -968.1
2021-10-26 15:14:27: PID: 4042: Leistung L1: 2013
2021-10-26 15:14:27: PID: 4042: Bezug: 1862335
2021-10-26 15:14:27: PID: 4042: Einspeisung: 584376
2021-10-26 15:14:27: PID: 4042: Watt: 35
2021-10-26 15:14:27: PID: 4042: Zaehlerort: 0
2021-10-26 15:14:27: PID: 4042: response_sm_data: {'Body': {'Data': {'Voltage_AC_PhaseToPhase_31': 406.1, 'EnergyReactive_VArAC_Sum_Produced': 2281714, 'Current_AC_Phase_2': -4.195, 'PowerFactor_Phase_1': 0.916, 'Frequency_Phase_Average': 50, 'PowerReal_P_Phase_1': 2013, 'Voltage_AC_Phase_2': 235.4, 'TimeStamp': 1635254066, 'Voltage_AC_Phase_3': 235, 'Voltage_AC_PhaseToPhase_12': 406.5, 'PowerFactor_Phase_2': -0.998, 'Enable': 1, 'Voltage_AC_PhaseToPhase_23': 407.3, 'EnergyReal_WAC_Plus_Absolute': 1862335, 'PowerReactive_Q_Sum': -1052.8, 'PowerReal_P_Phase_3': -1009.1, 'Voltage_AC_Phase_1': 234, 'PowerReactive_Q_Phase_1': -885, 'PowerApparent_S_Phase_3': 1013.9, 'Current_AC_Sum': 1.1099999999999994, 'PowerFactor_Phase_3': -0.995, 'Current_AC_Phase_1': 9.645, 'PowerApparent_S_Sum': 4183.6, 'PowerReactive_Q_Phase_2': -69.7, 'EnergyReal_WAC_Minus_Absolute': 584376, 'EnergyReal_WAC_Sum_Consumed': 1862335, 'Visible': 1, 'Meter_Location_Current': 0, 'PowerReal_P_Sum': 35.7, 'Details': {'Manufacturer': 'Fronius', 'Model': 'Smart Meter TS 65A-3', 'Serial': '1642594792'}, 'PowerApparent_S_Phase_1': 2199, 'PowerReal_P_Phase_2': -968.1, 'EnergyReactive_VArAC_Sum_Consumed': 84187, 'PowerReactive_Q_Phase_3': -97.9, 'PowerApparent_S_Phase_2': 970.6, 'Current_AC_Phase_3': -4.34, 'PowerFactor_Sum': 0.03, 'EnergyReal_WAC_Sum_Produced': 584376}}, 'Head': {'RequestArguments': {'DeviceId': '0', 'Scope': 'Device', 'DeviceClass': 'Meter'}, 'Status': {'Reason': '', 'Code': 0, 'UserMessage': ''}, 'Timestamp': '2021-10-26T15:14:26+02:00'}}
2021-10-26 15:14:27: PID: 4042: response_sm: <Response [200]>
2021-10-26 15:14:27: PID: 4042: Fronius SM Zaehlerort: 0
2021-10-26 15:14:27: PID: 4042: Fronius SM IP: 192.168.109.137
2021-10-26 15:14:27: PID: 4042: Fronius SM Erzeugung: 0
2021-10-26 15:14:27: PID: 4042: Fronius SM Variante: 0
2021-10-26 15:14:24: BattLeistung: -528 (LV1) at 31 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:24: RET: 0 (LV2) at 27 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:24: PID: 3995: BAT Bezug: 629186.7411111111
2021-10-26 15:14:24: PID: 3995: BAT Einspeisung: 599468.662368928
2021-10-26 15:14:24: PID: 3995: BAT Watt: -528
2021-10-26 15:14:24: PID: 3995: simcount Zwischenergebnisse atkuelle Berechnung: Import: 2265072268 Export: 2158087184.5281405 Power: -528.66
2021-10-26 15:14:24: PID: 3995: simcount Ergebnis: Bezug[Wh]: 629186.7411111111, Einspeisung[Wh]: 599468.662368928
2021-10-26 15:14:24: PID: 3995: simcount aufsummierte Energie: Bezug[Ws]: 2265072268, Einspeisung[Ws]: 2158087184.5281405
2021-10-26 15:14:24: PID: 3995: simcount Gesamtenergie im Zeitintervall: -4570.528140392303
2021-10-26 15:14:24: PID: 3995: simcount Berechnungsgrundlage: vergangene Zeit [s]9.06257438659668, vorherige Leistung[W]: -480, aktuelle Leistung[W]: -528.66
2021-10-26 15:14:24: PID: 3995: simcount Zwischenergebnisse letzte Berechnung: Import: 2265072268 Export: 2158082614 Power: -480
2021-10-26 15:14:24: PID: 3995: Alpha Ess Leistung[W]: -528.66, Speicher-Register: Spannung[V] 534 Strom[A] 99
2021-10-26 15:14:23: PID: 3995: Komponente Alpha Ess bat auslesen.
2021-10-26 15:14:23: PID: 3995: Komponenten von Alpha Ess auslesen.
2021-10-26 15:14:23: PID: 3995: alpha_ess Version: 1
2021-10-26 15:14:23: Speicher SoC: .RSOC (LV2) at 22 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:23: Speicher Watt: .Consumption_W (LV2) at 21 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:23: Speicher URL: 192.168.0.10/speicher (LV2) at 20 main modules/speicher_alphaess/main.sh
2021-10-26 15:14:22: **** Regulation loop start **** (LV1) at 50 main /var/www/html/openWB/regel.sh
Been thanked: 170 times
Beitrag von LenaK »
fawick hat geschrieben: Di Okt 26, 2021 12:52 pm Hi, kann ich gerne spaeter machen, sobald der Speicher entladen wird.
Ich vermute aber, dass hat sich durch manuelle Vorzeichenaenderung von ramdisk/speicherwatt0neg inzwischen komplett geklaert.
Das "alte simcount.py", das bis gestern vormittag fuer den Speicher verantwortlich war, hat Export-Wh und Export-Ws mit unterschiedlichen Vorzeichen in der Ramdisk gespeichert (siehe https://github.com/snaptec/openWB/blob/ ... unt.py#L60)
Wenn ich das neue helpermodules/simcount.py (https://github.com/snaptec/openWB/blob/ ... imcount.py) richtig verstehe, wachsen dort die Betraege in Ws und Wh aber jeweils positiv, richtig?
Das war das Problem. Ich habe einen PR gestellt, sodass es zukünftig ohne manuelle Änderung funktionieren sollte.
LarsBr87
Has thanked: 6 times
Beitrag von LarsBr87 »
Nach Update auf die neuste Nightly, läuft das VAG Modul nicht mehr
 2021-10-27 16:51:35: Lp2: Error from EVCC: 2021/10/27 16:51:35 missing required token (LV0)
2021-10-27 16:51:34: Lp2: Requesting SoC (LV0)
2021-10-27 16:51:27: Lp1: Error from EVCC: 2021/10/27 16:51:27 missing required token (LV0)
Has thanked: 252 times
Been thanked: 273 times
Der Fehler gehört nicht zum VAG-SoC-Modul, sondern zum kostenpflichtigen EVCC-Modul (abgelaufener Token?)
Besser im SoC-Bereich diskutieren.
viewforum.php?f=12
aiole hat geschrieben: Mi Okt 27, 2021 3:46 pm Der Fehler gehört nicht zum VAG-SoC-Modul, sondern zum kostenpflichtigen EVCC-Modul (abgelaufener Token?)
viewforum.php?f=12
aiole,
da muss ich leider widersprechen.
Das könnte aus den "Altbeständen" noch darin enthalten sein.
EVCC hatte ich bei mir nie eingerichtet, dennoch erscheint es in der Fehlermeldung.
Meine beiden LP fragen über VAG/ID jeweils einen Golf8GTE ab, wobei der SoC für den GTE auf LP 1 nicht abgerufen werden kann. Scheint am Backend bei VW zu liegen, da es funktioniert, wenn der 2 GTE dort eingerichtet ist. Gleiches Problem über VW ID- Auswahl.
2021-10-27 17:50:40: Lp2: SoC: 88 (LV0) at 76 getAndWriteSoc /var/www/html/openWB/modules/soc_vag/main.sh
2021-10-27 17:50:39: Lp1: Error from EVCC: 2021/10/27 17:50:39 cannot create type 'id': unexpected status: 412 (LV0) at 79 getAndWriteSoc modules/soc_vag/main.sh
2021-10-27 17:50:35: Lp1: Requesting SoC (LV0) at 70 getAndWriteSoc modules/soc_vag/main.sh
2021-10-27 17:50:35: Lp2: Requesting SoC (LV0) at 70 getAndWriteSoc /var/www/html/openWB/modules/soc_vag/main.sh
LarsBr87
HSC hat geschrieben: Mi Okt 27, 2021 3:57 pm
viewforum.php?f=12
aiole,
Ja, so ist es. Carnet läuft auch nicht. Ich habe bei mir auch beide LP‘s mit dem VAG Modul am laufen, einmal VW und einmal ID.
Aber warum läuft der Token- Fehler bei Dir im Log auf?
Habe hier noch Version: 1.9.249 (2021-10-21 09:21:39 drauf.
Welche bei Dir??
Könnte es dann gegenchecken auf meiner Testinst.
LarsBr87
HSC hat geschrieben: Mi Okt 27, 2021 4:09 pm Aber warum läuft der Token- Fehler bei Dir im Log auf?
Welche bei Dir??
Das kann ich dir auch nicht sagen. Habe nur ein Update gefahren und dann ging’s nicht mehr.
installierte Version: 1.9.249 (2021-10-27 09:08:05 +0200 [3a617dee] )
Ok, ich richte dort mein funktionierendes Auto ein und lade danach mal das update.
Bis denne..
vor update unter VAG/ID:
2021-10-27 18:26:16: Lp1: SoC: 88 (LV0) at 76 getAndWriteSoc modules/soc_vag/main.sh
2021-10-27 18:26:14: Lp2: SoC: 88 (LV0) at 76 getAndWriteSoc /var/www/html/openWB/modules/soc_vag/main.sh
2021-10-27 18:26:11: Lp1: Requesting SoC (LV0) at 70 getAndWriteSoc modules/soc_vag/main.sh
2021-10-27 18:26:10: Lp2: Requesting SoC (LV0) at 70 getAndWriteSoc /var/www/html/openWB/modules/soc_vag/main.sh
