LenaK hat geschrieben: Mi Feb 16, 2022 9:13 am
Kommen unter openWB/graph/lastlivevaluesJson Daten auf dem externen Broker (Port 1883) an? Und unter openWB/graph/alllivevaluesJson, openWB/graph/alllivevaluesJson1, openWB/graph/alllivevaluesJson2, ...? Sind im Main-Log Fehlermeldungen?
Nein, das Topic existiert erst gar nicht, keine Daten:
- Screenshot 2022-02-16 102053.png (25.96 KiB) 2721 mal betrachtet
Fehlermeldungen gibts noch ein paar, ja:
2022-02-16 10:21:08,225 - {/packages/main.py:39} - INFO - # ***Start***
2022-02-16 10:21:08,228 - {/packages/modules/loadvars.py:104} - ERROR - Fehler im loadvars-Modul
File "/var/www/html/openWB/packages/main.py", line 40, in handler10Sec
exit_time = data.data.general_data["general"].data["control_interval"]
KeyError: 'general'
File "/var/www/html/openWB/packages/modules/loadvars.py", line 100, in _get_general
if data.data.general_data["general"].data[
KeyError: 'general'
2022-02-16 10:21:08,565 - {/packages/control/prepare.py:96} - ERROR - Fehler im Prepare-Modul
KeyError: 'general'
File "/var/www/html/openWB/packages/control/prepare.py", line 66, in copy_module_data
self.__copy_counter_data()
File "/var/www/html/openWB/packages/control/prepare.py", line 53, in __copy_counter_data
if component[9:] == counter[7:]:
TypeError: 'SpeedwireComponent' object is not subscriptable
2022-02-16 10:21:08,568 - {/packages/main.py:97} - ERROR - Fehler im Main-Modul
KeyError: 'general'
File "/var/www/html/openWB/packages/main.py", line 95, in handler10Sec
handler_without_contronl_interval()
File "/var/www/html/openWB/packages/helpermodules/system.py", line 83, in inner
result = fn(*args, **kwargs)
File "/var/www/html/openWB/packages/main.py", line 85, in handler_without_contronl_interval
loadvars.get_virtual_values()
File "/var/www/html/openWB/packages/modules/loadvars.py", line 24, in get_virtual_values
data.data.pv_data["all"].calc_power_for_all_components()
KeyError: 'all'
2022-02-16 10:21:18,225 - {/packages/main.py:39} - INFO - # ***Start***
2022-02-16 10:21:18,227 - {/packages/modules/loadvars.py:104} - ERROR - Fehler im loadvars-Modul
KeyError: 'general'
KeyError: 'general'
2022-02-16 10:21:18,547 - {/packages/control/prepare.py:96} - ERROR - Fehler im Prepare-Modul
KeyError: 'general'
2022-02-16 10:21:18,550 - {/packages/main.py:97} - ERROR - Fehler im Main-Modul
KeyError: 'general'
KeyError: 'all'
