Anscheinend sorgt irgendwas in der cron5min.sh für die Abschaltung.
Version: openWB Version: 1.9.289 (2022-12-05 13:02:49 +0100 [9eac3ae6]
2022-12-18 01:10:05: PID: 14726: **** Regulation loop needs 4 seconds (LV2) at 62 cleanup /var/www/html/openWB/regel.sh
2022-12-18 01:10:05: PID: 14726: nachtladen mit socmodul soc_kia (LV1) at 77 nachtlademodus nachtladen.sh
2022-12-18 01:10:04: PID: 14726: Timing Umschaltung: 480 / 480 (LV1) at 17 u1p3pswitch u1p3p.sh
2022-12-18 01:10:04: PID: 14726: automatische Umschaltung aktiv (LV1) at 16 u1p3pswitch u1p3p.sh
2022-12-18 01:10:04: PID: 14726: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 186 main /var/www/html/openWB/regel.sh
2022-12-18 01:10:03: PID: 14726: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1310 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: plugstatlp1 0 plugstatlp2 0 plugstatlp3 0 (LV1) at 1309 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: lp1enabled 0 lp2enabled 0 lp3enabled 0 (LV1) at 1308 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: EVU 1:V/2A 2: V/2A 3: V/2A (LV1) at 1307 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: lla3 0 llv3 237.2 llas13 llas23 soclp1 66 soclp2 (LV1) at 1306 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: lla2 0 llv2 238.9 llas12 llas22 sofortll 32 hausverbrauch 1385 wattbezug 1385 uberschuss -1385 (LV1) at 1305 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: lla1 0 llv1 236.2 llas11 llas21 mindestuberschuss 500 abschaltuberschuss 0 lademodus 2 (LV1) at 1304 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: pv1watt 0 pv2watt pvwatt 0 ladeleistung 0 llalt 0 nachtladen 1 nachtladen 0 minimalA 6 maximalA 24 (LV1) at 1303 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: etproviderprice etprovidermaxprice (LV1) at 1301 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14726: speicherleistung 0 speichersoc 13 (LV1) at 1298 loadvars loadvars.sh
2022-12-18 01:10:03: PID: 14725: ##### cron5min.sh finished ##### (LV0) at 317 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:03: PID: 14725: logfile cleanup triggered (LV1) at 314 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:03: PID: 14725: starting evsecheck (LV1) at 310 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:02: Load: 0.26 0.75 1.17
2022-12-18 01:10:02: PID: 14725: pingcheck configured; starting (LV1) at 300 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:02: PID: 15009: push buttons disabled (LV1) at 41 pushButtonsSetup /var/www/html/openWB/runs/pushButtons/pushButtonsHelper.sh
2022-12-18 01:10:02: PID: 15009: rse disabled (LV1) at 41 rseSetup /var/www/html/openWB/runs/rse/rseHelper.sh
2022-12-18 01:10:02: PID: 15009: external openWB or daemon mode not configured; checking network setup (LV1) at 77 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: legacy run server is already running (LV1) at 62 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: Starting legacy run server... (LV1) at 55 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: smart home handler is already running (LV1) at 48 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: Starting smart home handler... (LV1) at 45 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: mqtt handler is already running (LV1) at 38 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: Starting MQTT handler... (LV1) at 35 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: modbus tcp server already running (LV1) at 28 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: Starting modbus server... (LV1) at 25 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 15009: Starting OpenWB services (LV0) at 22 start /var/www/html/openWB/runs/services.sh
2022-12-18 01:10:02: PID: 14725: current ip: 192.168.11.130 (LV1) at 293 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:01: PID: 14725: updating daily yield stats (LV1) at 164 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:01: PID: 14725: electricity provider configured; trigger price update (LV1) at 157 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:01: PID: 14725: Netzschutz konfiguriert; aktuelle Frequenz: 4990 (LV1) at 109 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:01: PID: 14725: daily csv updated: /var/www/html/openWB/web/logging/data/daily/20221218.csv (LV1) at 101 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:10:01: PID: 14726: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
2022-12-18 01:10:01: PID: 14725: ##### cron5min.sh started ##### (LV0) at 23 main /var/www/html/openWB/runs/cron5min.sh
2022-12-18 01:09:55: PID: 13454: **** Regulation loop needs 4 seconds (LV2) at 62 cleanup /var/www/html/openWB/regel.sh
2022-12-18 01:09:55: PID: 13454: nachtladen mit socmodul soc_kia (LV1) at 77 nachtlademodus nachtladen.sh
2022-12-18 01:09:54: PID: 13454: Timing Umschaltung: 480 / 480 (LV1) at 17 u1p3pswitch u1p3p.sh
2022-12-18 01:09:54: PID: 13454: automatische Umschaltung aktiv (LV1) at 16 u1p3pswitch u1p3p.sh
2022-12-18 01:09:54: PID: 13454: Zeit zum abfragen aller Werte 2 Sekunden (LV1) at 186 main /var/www/html/openWB/regel.sh
2022-12-18 01:09:53: PID: 13454: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1310 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: plugstatlp1 0 plugstatlp2 0 plugstatlp3 0 (LV1) at 1309 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: lp1enabled 1 lp2enabled 0 lp3enabled 0 (LV1) at 1308 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: EVU 1:V/2A 2: V/2A 3: V/2A (LV1) at 1307 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: lla3 0 llv3 237.2 llas13 llas23 soclp1 66 soclp2 (LV1) at 1306 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: lla2 0 llv2 238.9 llas12 llas22 sofortll 32 hausverbrauch 1385 wattbezug 1385 uberschuss -1385 (LV1) at 1305 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: lla1 0 llv1 236.5 llas11 llas21 mindestuberschuss 500 abschaltuberschuss 0 lademodus 2 (LV1) at 1304 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: pv1watt 0 pv2watt pvwatt 0 ladeleistung 0 llalt 0 nachtladen 1 nachtladen 0 minimalA 6 maximalA 24 (LV1) at 1303 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: etproviderprice etprovidermaxprice (LV1) at 1301 loadvars loadvars.sh
2022-12-18 01:09:53: PID: 13454: speicherleistung 0 speichersoc 13 (LV1) at 1298 loadvars loadvars.sh
2022-12-18 01:09:51: PID: 13454: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
