openWB 2.0 erkennt Steckerstatus der externen openWB nicht
Re: openWB 2.0 erkennt Steckerstatus der externen openWB nicht
SW Aktuelle
**** REBOOT ****
2023-05-05 15:22:48,172 - {root:38} - ERROR - Loglevel: 2
2023-05-05 15:22:48,173 - {root:206} - DEBUG - Init isss
2023-05-05 15:22:49,402 - {modules.common.evse:50} - DEBUG - FW-Version: 18
File "/var/www/html/openWB/runs/isss.py", line 308, in <module>
Isss(IsssMode(sys.argv[1]), int(sys.argv[2])).loop()
File "/var/www/html/openWB/runs/isss.py", line 208, in __init__
self.cp0 = IsssChargepoint(self.serial_client, 0, mode, socket_max_current)
File "/var/www/html/openWB/runs/isss.py", line 282, in __init__
self.module = chargepoint_module.ChargepointModule(ClientConfig(0, serial_client))
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 90, in __init__
self._precise_current = self.__client.evse_client.is_precise_current_active()
File "/var/www/html/openWB/packages/modules/common/evse.py", line 63, in is_precise_current_active
str(value)+" definieren kein Format für die Stromstärke.")
modules.common.fault_state.FaultState: ('Unbekannter Zustand der EVSE: Bits 9 definieren kein Format für die Stromstärke.', <FaultStateLevel.ERROR: 2>)
2023-05-05 15:25:04,742 - {root:38} - ERROR - Loglevel: 2
2023-05-05 15:25:04,743 - {root:206} - DEBUG - Init isss
2023-05-05 15:25:05,977 - {modules.common.evse:50} - DEBUG - FW-Version: 18
2023-05-05 15:30:04,941 - {root:38} - ERROR - Loglevel: 2
2023-05-05 15:30:04,942 - {root:206} - DEBUG - Init isss
2023-05-05 15:30:06,186 - {modules.common.evse:50} - DEBUG - FW-Version: 18
2023-05-05 15:35:04,387 - {root:38} - ERROR - Loglevel: 2
2023-05-05 15:35:04,388 - {root:206} - DEBUG - Init isss
2023-05-05 15:35:05,608 - {modules.common.evse:50} - DEBUG - FW-Version: 18
2023-05-05 15:40:04,616 - {root:38} - ERROR - Loglevel: 2
2023-05-05 15:40:04,617 - {root:206} - DEBUG - Init isss
2023-05-05 15:40:05,881 - {modules.common.evse:50} - DEBUG - FW-Version: 18
modules.common.fault_state.FaultState: ('Unbekannter Zustand der EVSE: Bits 9 definieren kein Format für die Stromstärke.', <FaultStateLevel.ERROR: 2>)Re: openWB 2.0 erkennt Steckerstatus der externen openWB nicht
Hier der Aktuelle Log
--- Logging error ---
File "/usr/lib/python3.5/logging/__init__.py", line 983, in emit
stream.write(msg)
2023-05-05 15:57:00,270 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.23451805114746, 0.07180792838335037, 0.0783432126045227], voltages=[231.83480834960938, 242.6603546142578, 245.0349578857422], charge_state=True, power=3764.7582426071167, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204748.99291992188, exported=0)
2023-05-05 15:57:00,277 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:00,377 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:00,378 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:01,492 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:01,820 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.22531509399414, 0.07311355322599411, 0.0799420177936554], voltages=[231.9247589111328, 242.56430053710938, 245.17758178710938], charge_state=True, power=3766.6267671585083, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204750.99182128906, exported=0)
2023-05-05 15:57:01,827 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:01,921 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:01,921 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:03,034 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:03,371 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.21569061279297, 0.07319395244121552, 0.08016866445541382], voltages=[231.80178833007812, 242.69961547851562, 245.02597045898438], charge_state=True, power=3757.601333618164, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204751.9989013672, exported=0)
2023-05-05 15:57:03,378 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:03,496 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:03,497 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:04,625 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:04,969 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.2322998046875, 0.07269909977912903, 0.08084788918495178], voltages=[231.96780395507812, 242.9752197265625, 245.2678985595703], charge_state=True, power=3768.6264247894287, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204753.99780273438, exported=0)
2023-05-05 15:57:04,977 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:05,073 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:05,074 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:06,196 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:06,568 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.23240089416504, 0.07189907133579254, 0.07830493152141571], voltages=[231.8728790283203, 242.88194274902344, 245.05914306640625], charge_state=True, power=3766.83585357666, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204754.98962402344, exported=0)
2023-05-05 15:57:06,576 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:06,689 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:06,690 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:07,807 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:08,152 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.218000411987305, 0.0737786740064621, 0.08185520768165588], voltages=[231.989013671875, 243.03680419921875, 245.2131805419922], charge_state=True, power=3763.975631713867, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204757.99560546875, exported=0)
2023-05-05 15:57:08,159 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:08,253 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:08,254 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:09,368 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:09,703 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.241376876831055, 0.07333354651927948, 0.0789729654788971], voltages=[231.9093780517578, 242.97976684570312, 245.14865112304688], charge_state=True, power=3768.3612852096558, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204758.9874267578, exported=0)
2023-05-05 15:57:09,710 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:09,811 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:09,812 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:10,927 - {root:236} - DEBUG - ***Start***
UnicodeEncodeError: 'ascii' codec can't encode character '\xe4' in position 77: ordinal not in range(128)
Call stack:
File "/var/www/html/openWB/runs/isss.py", line 237, in loop
self.cp0.update()
File "/var/www/html/openWB/runs/isss.py", line 300, in update
state, _ = self.module.get_values(phase_switch_cp_active)
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 109, in get_values
plug_state, charge_state, self.set_current_evse = self.__client.evse_client.get_plug_charge_state()
File "/var/www/html/openWB/packages/modules/common/evse.py", line 41, in get_plug_charge_state
", Status: "+str(state_number)+", Modbus-ID: "+str(self.id))
Message: 'Gesetzte Stromst\xe4rke EVSE: 16, Status: 3, Modbus-ID: 1'
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
2023-05-05 15:57:11,254 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.21782875061035, 0.0727742537856102, 0.08084526658058167], voltages=[231.68255615234375, 242.85589599609375, 245.03921508789062], charge_state=True, power=3758.2787523269653, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204760.986328125, exported=0)
2023-05-05 15:57:11,262 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:11,368 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:11,369 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:12,495 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:12,851 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.233064651489258, 0.07376015186309814, 0.08053851872682571], voltages=[231.3298797607422, 242.55935668945312, 244.8735809326172], charge_state=True, power=3760.625352859497, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204762.9852294922, exported=0)
2023-05-05 15:57:12,855 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:12,977 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:12,978 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:14,092 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:14,452 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.215682983398438, 0.07109227031469345, 0.08044908940792084], voltages=[231.28756713867188, 242.68197631835938, 244.9248504638672], charge_state=True, power=3751.717141151428, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204763.9923095703, exported=0)
2023-05-05 15:57:14,460 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:14,574 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:14,575 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:15,707 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:16,051 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.233985900878906, 0.07089389860630035, 0.08010021597146988], voltages=[231.09913635253906, 242.55123901367188, 244.764892578125], charge_state=True, power=3753.2728939056396, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204765.9912109375, exported=0)
2023-05-05 15:57:16,059 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:16,151 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:16,151 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:17,271 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:17,618 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.222402572631836, 0.07245934009552002, 0.08026211708784103], voltages=[231.31863403320312, 242.8197021484375, 244.90948486328125], charge_state=True, power=3755.097755432129, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204766.99829101562, exported=0)
2023-05-05 15:57:17,626 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:17,723 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:17,723 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:18,843 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:19,201 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.229007720947266, 0.07264269143342972, 0.0797208920121193], voltages=[229.0638427734375, 243.09793090820312, 245.3870391845703], charge_state=True, power=3720.3248739242554, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204768.9971923828, exported=0)
2023-05-05 15:57:19,208 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:19,341 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:19,342 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:20,465 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:20,799 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.209190368652344, 0.07120267301797867, 0.07919629663228989], voltages=[229.0182342529297, 242.99330139160156, 245.26658630371094], charge_state=True, power=3715.0281171798706, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204770.99609375, exported=0)
2023-05-05 15:57:20,807 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:20,936 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:20,936 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:22,057 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:22,396 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.035104751586914, 0.07226226478815079, 0.08041001111268997], voltages=[229.04544067382812, 242.86553955078125, 245.05844116210938], charge_state=True, power=3672.404228210449, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204771.98791503906, exported=0)
2023-05-05 15:57:22,400 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:22,475 - {root:169} - DEBUG - Values from ramdisk: set_current16 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:22,476 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:23,609 - {root:236} - DEBUG - ***Start***
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
2023-05-05 15:57:23,950 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[16.010101318359375, 0.07123751193284988, 0.07791496068239212], voltages=[229.08624267578125, 242.9470672607422, 244.97494506835938], charge_state=True, power=3671.39093875885, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204773.98681640625, exported=0)
2023-05-05 15:57:23,958 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:24,088 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:24,089 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:25,266 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:25,596 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.069936752319336, 0.028077194467186928, 0.032769665122032166], voltages=[234.50106811523438, 241.2208709716797, 243.0005340576172], charge_state=True, power=1429.9380917549133, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204774.99389648438, exported=0)
2023-05-05 15:57:25,605 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:25,715 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:25,715 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:26,841 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:27,180 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.091282367706299, 0.02656109444797039, 0.030953945592045784], voltages=[234.2520294189453, 241.1439208984375, 242.87307739257812], charge_state=True, power=1427.4863719940186, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204775.98571777344, exported=0)
2023-05-05 15:57:27,188 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:27,293 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:27,293 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:28,407 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:28,745 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.095376014709473, 0.026725728064775467, 0.03227531909942627], voltages=[233.98178100585938, 240.95538330078125, 242.62388610839844], charge_state=True, power=1426.1751766204834, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204775.98571777344, exported=0)
2023-05-05 15:57:28,753 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:28,845 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:28,846 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:29,967 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:30,297 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.107074737548828, 0.02704162523150444, 0.029924549162387848], voltages=[234.3908233642578, 241.17678833007812, 242.9041290283203], charge_state=True, power=1436.7822575569153, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204776.99279785156, exported=0)
2023-05-05 15:57:30,305 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:30,418 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:30,419 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:31,546 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:31,880 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.095884323120117, 0.027012009173631668, 0.030489519238471985], voltages=[234.2613067626953, 241.2589569091797, 242.7628173828125], charge_state=True, power=1428.4670734405518, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204777.9998779297, exported=0)
2023-05-05 15:57:31,887 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:31,999 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:32,000 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:33,128 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:33,479 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.1040849685668945, 0.026518207043409348, 0.031352486461400986], voltages=[234.41873168945312, 241.3968048095703, 242.8419189453125], charge_state=True, power=1436.8451571464539, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204777.9998779297, exported=0)
2023-05-05 15:57:33,488 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:33,600 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:33,601 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:34,718 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:35,046 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.102544784545898, 0.0265829898416996, 0.03077615424990654], voltages=[234.54660034179688, 241.521728515625, 242.97923278808594], charge_state=True, power=1432.2695565223694, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204778.99169921875, exported=0)
2023-05-05 15:57:35,054 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:35,160 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:35,161 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:36,275 - {root:236} - DEBUG - ***Start***
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Message: 'Gesetzte Stromst\xe4rke EVSE: 6, Status: 3, Modbus-ID: 1'
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
Arguments: ()
stream.write(msg)
Call stack:
self.cp0.update()
2023-05-05 15:57:36,629 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.093080520629883, 0.0, 0.03024219162762165], voltages=[234.3993682861328, 241.41969299316406, 242.99676513671875], charge_state=True, power=1429.806966304779, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204778.99169921875, exported=0)
2023-05-05 15:57:36,636 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:36,717 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:36,719 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:37,841 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:38,180 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.100235462188721, 0.027839025482535362, 0.03133329749107361], voltages=[234.46551513671875, 241.4893035888672, 243.06546020507812], charge_state=True, power=1436.3138179779053, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204779.99877929688, exported=0)
2023-05-05 15:57:38,188 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:38,290 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:38,291 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:39,424 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:39,763 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.104310035705566, 0.027736393734812737, 0.03335455805063248], voltages=[234.41078186035156, 241.49620056152344, 243.062744140625], charge_state=True, power=1432.007263660431, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204780.99060058594, exported=0)
2023-05-05 15:57:39,770 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:39,881 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:39,882 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:40,998 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:41,330 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.078530788421631, 0.026362204924225807, 0.029418770223855972], voltages=[235.51638793945312, 241.5147247314453, 240.9335174560547], charge_state=True, power=1438.3066005706787, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204780.99060058594, exported=0)
2023-05-05 15:57:41,338 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:41,432 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 0 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:41,433 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:42,561 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:42,926 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.098051071166992, 0.025746561586856842, 0.03152413293719292], voltages=[234.1078338623047, 241.10256958007812, 242.531982421875], charge_state=True, power=1428.7593502998352, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204781.99768066406, exported=0)
2023-05-05 15:57:42,930 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:43,018 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:43,019 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:44,155 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:44,511 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.094953536987305, 0.026264267042279243, 0.03140778839588165], voltages=[234.18142700195312, 241.27552795410156, 242.50277709960938], charge_state=True, power=1428.0640864372253, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204782.98950195312, exported=0)
2023-05-05 15:57:44,519 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:44,630 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:44,630 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:45,757 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:46,095 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.086668491363525, 0.025902114808559418, 0.03031238354742527], voltages=[234.4952392578125, 241.51365661621094, 242.75877380371094], charge_state=True, power=1434.6010665893555, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204782.98950195312, exported=0)
2023-05-05 15:57:46,102 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:46,190 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:46,190 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']
2023-05-05 15:57:47,317 - {root:236} - DEBUG - ***Start***
2023-05-05 15:57:47,646 - {soc.modules.common.store._api:20} - DEBUG - Saving ChargepointState(plug_state=True, currents=[6.083637714385986, 0.026644034311175346, 0.031440284103155136], voltages=[234.38262939453125, 241.3450469970703, 242.66226196289062], charge_state=True, power=1427.1462759971619, power_factors=[0.0, 0.0, 0.0], rfid=0, phases_in_use=1, imported=204783.99658203125, exported=0)
2023-05-05 15:57:47,653 - {root:301} - DEBUG - Published plug state True
2023-05-05 15:57:47,763 - {root:169} - DEBUG - Values from ramdisk: set_current6 heartbeat 10 phases_to_use 1cp_interruption_duration0
2023-05-05 15:57:47,763 - {soc.modules.common.component_context:24} - DEBUG - Update Komponente ['Ladepunkt 0']Re: openWB 2.0 erkennt Steckerstatus der externen openWB nicht
Habe ein ähnliches Problem, Openwb2 erkennt die nun als externen Ladepunkt betriebene Series 1 aus Rechnung RG-2019-0349, allerdings nicht Steckerstatus
Series1 hat nur den ersten Ladepunkt als sich selber konfiguriert, per "Series1/2 Autoerkennung".
Was kann ich tun? Die neueste Nightly ist auf der Series 1, anbei ein paar Screenshot,
Bg
Bg
- Has thanked: 159 times
- Been thanked: 177 times
Es sieht so aus, als kommen dort gar keine Daten über Modbus rein. Ansonsten wären die LP-Zählerstände ersichtlich.
Werden die LP-Spannungen unter "Status" angezeigt?
Ja und nein. Er zeigt immer 230V an, keine Bewegung.
Sieht so aus, als ob das keine echten Spannungsmesswerte sind.
Wird die Series 1 von einer (Master-)Standalone oder einer anderen Master-oWB mit integriertem Controller und SW2 gesteuert?
Beschreibe bitte den genauen Aufbau/Verschaltung deiner Anlage. Eine Skizze wird auch gern gesehen.
Wo läuft SW2, wo 1.9? Was ist externer LP usw.?
Das verstehe ich nicht. Wieso ERSTER LP? Gibt's noch einen zweiten?Limpel hat geschrieben: Fr Jun 02, 2023 5:03 pm Series1 hat nur den ersten Ladepunkt als sich selber konfiguriert, per "Series1/2 Autoerkennung".
Ich habe eine openwb Series 1 mit 1.9er Installation und eine Satellite v2. Beide sollen von einem Raspi mit 2.0 gesteuert werden. Für die Satellite v2 funktioniert das, die Series1 ist wie beschrieben von der openwb 2.0 Installation nicht korrekt erkannt.
Mein Satz mit dem ersten Ladepunkt bezieht sich auf den Hinweis der Openwb Series 1 1.9 Installation selbst, wenn man diese in den Modus "nur Ladepunkt" versetzen will. Ich wollte nur zum Ausdruck bringen, dass genau dies umgesetzt ist. Die folgenden Screenshots sind aus der 1.9er Openwb Series 1. Die Screenshots aus den Beiträgen zuvor stammen aus der SW2 des raspis. Ich hoffe es ist nun klarer.
