Feedback openWB software2 2.1.0
neotrace2
- Been thanked: 7 times
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.56.0.
ERROR: Failed building wheel for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
done
load versions...
To update pip, run:
done
load versions...
OpenWB selbstbau, Phasenumschaltung. Aktuelles Master. 14,1kWP. SMA tripower8.0 SE, SMA Tripower 8.0, SHM 2.0, BYD HVS 10.2. Model 3, ModelY
neotrace2
#### updating available version info ####
current commit: 2023-08-04 12:40:26 +0200 [25e6664b6]
fetching latest data from origin...
POST git-upload-pack (170 bytes)
Von https://github.com/openWB/core
= [aktuell] master -> origin/master
= [aktuell] Beta -> origin/Beta
= [aktuell] Release -> origin/Release
= [aktuell] feature-mercedeseq -> origin/feature-mercedeseq
= [aktuell] feature-web-themes -> origin/feature-web-themes
= [aktuell] feature_measurement_log -> origin/feature_measurement_log
= [aktuell] 0.1 -> 0.1
= [aktuell] 0.12 -> 0.12
= [aktuell] 0.14 -> 0.14
= [aktuell] 0.15 -> 0.15
= [aktuell] 0.2 -> 0.2
= [aktuell] 0.40 -> 0.40
= [aktuell] 0.99 -> 0.99
= [aktuell] 1.0 -> 1.0
= [aktuell] 1.6 -> 1.6
= [aktuell] 1.7 -> 1.7
= [aktuell] 1.99.002 -> 1.99.002
= [aktuell] 1.99.003 -> 1.99.003
= [aktuell] 1.99.004 -> 1.99.004
= [aktuell] 1.99.100 -> 1.99.100
= [aktuell] 1.99.100.1 -> 1.99.100.1
= [aktuell] 1.99.101.0 -> 1.99.101.0
= [aktuell] 1.99.102.0 -> 1.99.102.0
= [aktuell] 1.99.103.0 -> 1.99.103.0
= [aktuell] 1.99.RC1.0 -> 1.99.RC1.0
= [aktuell] 1.99.RC2.0 -> 1.99.RC2.0
= [aktuell] 2.0.0 -> 2.0.0
= [aktuell] 2.1.0 -> 2.1.0
done
branches:
checking commit for origin/Beta...2023-06-30 14:21:30 +0200 [ba9587142]
tags in branch:
0.1: changes
0.12: minor changes
0.14: minor changes
0.15: minor changes
0.2: changes
0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus
0.99: Merge pull request #33 from snaptec/master
1.0: Merge pull request #36 from snaptec/master
1.7: Update display.php
1.99.002: Alpha 2
1.99.003: Alpha 3
1.99.004: Alpha 4
1.99.100: Beta 1
1.99.100.1: Beta.2-RC1
1.99.101.0: Beta 2
1.99.102.0: Beta 3
1.99.103.0: Beta 4
1.99.RC1.0: Release Candidate 1
1.99.RC2.0: Release Candidate 2
Beta: {"0.1":"0.1: changes","0.12":"0.12: minor changes","0.14":"0.14: minor changes","0.15":"0.15: minor changes","0.2":"0.2: changes","0.40":"0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus","0.99":"0.99: Merge pull request #33 from snaptec/master","1.0":"1.0: Merge pull request #36 from snaptec/master","1.7":"1.7: Update display.php","1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2"}
checking commit for origin/Release...2023-08-03 12:57:11 +0200 [6746ba8e0]
tags in branch:
0.1: changes
0.12: minor changes
0.14: minor changes
0.15: minor changes
0.2: changes
1.99.002: Alpha 2
1.99.003: Alpha 3
1.99.004: Alpha 4
1.99.100: Beta 1
1.99.101.0: Beta 2
1.99.102.0: Beta 3
1.99.103.0: Beta 4
2.0.0: Release 2.0.0
2.1.0: 2.1.0 Release
Release: {"0.1":"0.1: changes","0.12":"0.12: minor changes","0.14":"0.14: minor changes","0.15":"0.15: minor changes","0.2":"0.2: changes","0.40":"0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus","0.99":"0.99: Merge pull request #33 from snaptec/master","1.0":"1.0: Merge pull request #36 from snaptec/master","1.7":"1.7: Update display.php","1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2","2.0.0":"2.0.0: Release 2.0.0","2.1.0":"2.1.0: 2.1.0 Release"}
checking commit for origin/feature-mercedeseq...2023-07-26 12:52:46 +0200 [bdf31b922]
tags in branch:
0.1: changes
0.12: minor changes
0.14: minor changes
0.15: minor changes
0.2: changes
1.99.002: Alpha 2
1.99.003: Alpha 3
1.99.004: Alpha 4
1.99.100: Beta 1
1.99.101.0: Beta 2
1.99.102.0: Beta 3
1.99.103.0: Beta 4
feature-mercedeseq: {"0.1":"0.1: changes","0.12":"0.12: minor changes","0.14":"0.14: minor changes","0.15":"0.15: minor changes","0.2":"0.2: changes","0.40":"0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus","0.99":"0.99: Merge pull request #33 from snaptec/master","1.0":"1.0: Merge pull request #36 from snaptec/master","1.7":"1.7: Update display.php","1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2","2.0.0":"2.0.0: Release 2.0.0"}
checking commit for origin/feature-web-themes...2023-07-26 13:02:18 +0200 [1487da45a]
tags in branch:
0.1: changes
0.12: minor changes
0.14: minor changes
0.15: minor changes
0.2: changes
1.99.002: Alpha 2
1.99.003: Alpha 3
1.99.004: Alpha 4
1.99.100: Beta 1
1.99.101.0: Beta 2
1.99.102.0: Beta 3
1.99.103.0: Beta 4
feature-web-themes: {"0.1":"0.1: changes","0.12":"0.12: minor changes","0.14":"0.14: minor changes","0.15":"0.15: minor changes","0.2":"0.2: changes","0.40":"0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus","0.99":"0.99: Merge pull request #33 from snaptec/master","1.0":"1.0: Merge pull request #36 from snaptec/master","1.7":"1.7: Update display.php","1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2","2.0.0":"2.0.0: Release 2.0.0"}
checking commit for origin/feature_measurement_log...2023-08-04 08:27:17 +0200 [597809712]
tags in branch:
0.1: changes
0.12: minor changes
0.14: minor changes
0.15: minor changes
0.2: changes
1.99.002: Alpha 2
1.99.003: Alpha 3
1.99.004: Alpha 4
1.99.100: Beta 1
1.99.101.0: Beta 2
1.99.102.0: Beta 3
1.99.103.0: Beta 4
feature_measurement_log: {"0.1":"0.1: changes","0.12":"0.12: minor changes","0.14":"0.14: minor changes","0.15":"0.15: minor changes","0.2":"0.2: changes","0.40":"0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus","0.99":"0.99: Merge pull request #33 from snaptec/master","1.0":"1.0: Merge pull request #36 from snaptec/master","1.7":"1.7: Update display.php","1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2","2.0.0":"2.0.0: Release 2.0.0","2.1.0":"2.1.0: 2.1.0 Release"}
checking commit for origin/master...2023-08-04 12:40:26 +0200 [25e6664b6]
tags in branch:
0.1: changes
0.12: minor changes
0.14: minor changes
0.15: minor changes
0.2: changes
1.99.002: Alpha 2
1.99.003: Alpha 3
1.99.004: Alpha 4
1.99.100: Beta 1
1.99.101.0: Beta 2
1.99.102.0: Beta 3
1.99.103.0: Beta 4
master: {"0.1":"0.1: changes","0.12":"0.12: minor changes","0.14":"0.14: minor changes","0.15":"0.15: minor changes","0.2":"0.2: changes","0.40":"0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus","0.99":"0.99: Merge pull request #33 from snaptec/master","1.0":"1.0: Merge pull request #36 from snaptec/master","1.7":"1.7: Update display.php","1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2","2.0.0":"2.0.0: Release 2.0.0","2.1.0":"2.1.0: 2.1.0 Release"}
"feature-web-themes": {
"commit": "2023-07-26 13:02:18 +0200 [1487da45a]",
"tags": {
"0.1": "0.1: changes",
"0.12": "0.12: minor changes",
"0.14": "0.14: minor changes",
"0.15": "0.15: minor changes",
"0.2": "0.2: changes",
"0.40": "0.40: lastmanagement fuer Hauptladepunkt, Bezug/Einspeiseregelung PV Modus",
"0.99": "0.99: Merge pull request #33 from snaptec/master",
"1.0": "1.0: Merge pull request #36 from snaptec/master",
"1.7": "1.7: Update display.php",
"1.99.002": "1.99.002: Alpha 2",
"1.99.003": "1.99.003: Alpha 3",
"1.99.004": "1.99.004: Alpha 4",
"1.99.100": "1.99.100: Beta 1",
"1.99.100.1": "1.99.100.1: Beta.2-RC1",
"1.99.101.0": "1.99.101.0: Beta 2",
"1.99.102.0": "1.99.102.0: Beta 3",
"1.99.103.0": "1.99.103.0: Beta 4",
"1.99.RC1.0": "1.99.RC1.0: Release Candidate 1",
"1.99.RC2.0": "1.99.RC2.0: Release Candidate 2",
"2.0.0": "2.0.0: Release 2.0.0"
"feature-mercedeseq": {
"commit": "2023-07-26 12:52:46 +0200 [bdf31b922]",
"tags": {
"feature_measurement_log": {
"commit": "2023-08-04 08:27:17 +0200 [597809712]",
"tags": {
"2.0.0": "2.0.0: Release 2.0.0",
"2.1.0": "2.1.0: 2.1.0 Release"
"Release": {
"commit": "2023-08-03 12:57:11 +0200 [6746ba8e0]",
"tags": {
"master": {
"commit": "2023-08-04 12:40:26 +0200 [25e6664b6]",
"tags": {
"Beta": {
"commit": "2023-06-30 14:21:30 +0200 [ba9587142]",
"tags": {
currently selected branch: master
last commit to master branch: 2023-08-04 12:40:26 +0200 [25e6664b6]
changes:
* OpenWB selbstbau, Phasenumschaltung. Aktuelles Master. 14,1kWP. SMA tripower8.0 SE, SMA Tripower 8.0, SHM 2.0, BYD HVS 10.2. Model 3, ModelY
- Has thanked: 86 times
- Been thanked: 192 times
Also das stable Image von gestern frisch geflashed?neotrace2 hat geschrieben: Fr Aug 04, 2023 1:13 pm Meine Basis war das master von gestern. Also absolut aktuell. Und ich habe den gekauften Raspi von euch mit der original Software drauf
neotrace2
Nein auch als update von der stable release 2.0. Sprich nicht geflascht sondern über die update Funktion. Entwicklungszweig master
neotrace2
Wäre schön wenn das image 2.0 stable zu downloaden wäre. dann könnte ich auf einer zweiten karte flashen damit die openwb wieder geht
neotrace2
So habe das release neu geflasht und hierbei geht es.
Habe die Datei openWB-software2-2_1_0.img.gz genommen .
Es steht zweig release
03.08.2023 12:57:11 +0200(6746ba8e0)
Die geht einwandfrei
![Bild]()
Ja die Version von gestern funktionierte auch einwandfrei. Mein Problem ist dass ich nur ein deutlich älteres Backup habe und jetzt keins mehr erstellen kann, sonst hätte ich das auch so gemacht.
Ist natürlich doof jetzt, so direkt vorm Wochenende
- Has thanked: 8 times
- Been thanked: 110 times
Das Problem hat nichts mit dem Release zu tun, sondern hat nur den Master-Branch betroffen. Ich habe den betreffenden PR rückgängig gemacht.
Bitte bedenkt, dass wir immer darauf Hinweisen, dass der Master-Branch durchaus Fehler enthalten kann. Ich bitte den Fehler zu entschuldigen.
Um das Problem zu lösen, bitte eine E-Mail an den Support schicken mit einem Verweis auf das Problem und den Cloudzugangsdaten (wir können Euch leider nur helfen, wenn der Cloudzugang aktiviert war!)
Alternativ hier das Release-Image herunterladen, neu flashen und die vor dem Update erstellte Sicherung einspielen.
Ich habe euch gerade eine Mail geschrieben, meinst Du ihr könnt das noch vor dem Wochenende fixen? Ich kann mein Auto sonst nicht laden.LenaK hat geschrieben: Fr Aug 04, 2023 1:47 pm Das Problem hat nichts mit dem Release zu tun, sondern hat nur den Master-Branch betroffen. Ich habe den betreffenden PR rückgängig gemacht.
