Support: Http
hulk66
Re: Support: Http
Beitrag von hulk66 »
Gerade eben angesteckt. Wert ist keine Ganzzahl, sollte aber kein Problem sein.
// 20231129102902
// http://192.168.0.5:17070/api/state
  "result": {
    "auth": {
      "vehicles": {
    "battery": [
        "power": -0,
        "soc": 2
    "batteryCapacity": 0,
    "batteryConfigured": true,
    "batteryDischargeControl": false,
    "batteryEnergy": 0,
    "batteryMode": 1,
    "batteryPower": 0,
    "batterySoc": 2,
    "bufferSoc": 0,
    "bufferStartSoc": 0,
    "currency": "EUR",
    "greenShareHome": 0.8462214411247804,
    "greenShareLoadpoints": 0,
    "gridConfigured": true,
    "gridPower": 1494,
    "homePower": 1138,
    "loadpoints": [
        "chargeCurrent": 0,
        "chargeCurrents": [
          5.7,
          0,
          0
        "chargeDuration": 150000000000,
        "chargePower": 1319,
        "chargeRemainingDuration": -3547000000000,
        "chargeTotalImport": 1705.45,
        "chargedEnergy": 55.000000000063665,
        "chargerFeatureHeating": false,
        "chargerFeatureIntegratedDevice": false,
        "chargerIcon": null,
        "charging": true,
        "connected": true,
        "connectedDuration": 0,
        "disableThreshold": 0,
        "enableThreshold": 0,
        "enabled": false,
        "guardAction": "inactive",
        "guardRemaining": 0,
        "maxCurrent": 16,
        "minCurrent": 6,
        "minSoc": 0,
        "mode": "off",
        "phaseAction": "inactive",
        "phaseRemaining": 0,
        "phasesActive": 1,
        "phasesConfigured": null,
        "phasesEnabled": 3,
        "planActive": false,
        "planProjectedStart": "0001-01-01T00:00:00Z",
        "priority": 0,
        "pvAction": "inactive",
        "pvRemaining": 0,
        "sessionCo2PerKWh": null,
        "sessionEnergy": 55.000000000063665,
        "sessionPrice": 0.02203850000002551,
        "sessionPricePerKWh": 0.4007,
        "sessionSolarPercentage": 0,
        "targetEnergy": 0,
        "targetSoc": 100,
        "targetTime": "0001-01-01T00:00:00Z",
        "title": "Carport",
        "vehicleCapacity": 14,
        "vehicleDetectionActive": false,
        "vehicleFeatureOffline": false,
        "vehicleIcon": "car",
        "vehicleOdometer": 10102,
        "vehiclePresent": true,
        "vehicleRange": 6,
        "vehicleSoc": 8.353571428571838,
        "vehicleTargetSoc": 0,
        "vehicleTitle": "A6"
    "prioritySoc": 0,
    "pv": [
        "power": 963
    "pvConfigured": true,
    "pvEnergy": 0,
    "pvPower": 963,
    "residualPower": 100,
    "siteTitle": "Home",
    "smartCostActive": false,
    "smartCostLimit": 0,
    "smartCostType": "pricestatic",
    "statistics": {
      "30d": {
        "avgCo2": 0,
        "avgPrice": 0.3845323308012336,
        "chargedKWh": 99.32199999999943,
        "solarPercentage": 5.690837451165873
      "365d": {
        "avgCo2": 0,
      "total": {
        "avgCo2": 0,
    "tariffFeedIn": 0.1166,
    "tariffGrid": 0.4007,
    "tariffPriceHome": 0.1602884885764499,
    "tariffPriceLoadpoints": 0.4007,
    "vehicles": [
      "A6"
    "version": "0.122.1"
Been thanked: 46 times
Re: Support: Http
Doch, das ist ein Problem. Wenn ich mir das im main.sh anschaue, dann wird über den re ein Regex Ausdruck verglichen. Da dürfen nur Zahlen drin vorkommen und keine weiteren Zeichen. Meiner Meinung nach kommt du da nicht durch mit deiner Dezimalzahl.
hulk66
Re: Support: Http
Ja, das habe ich auch gesehen. Dahinter ist aber auch ein cut, der die Dezimalstellen abschneidet.
soc=$(curl --connect-timeout 15 -s "$ip" | cut -f1 -d".")
Wenn dass das Problem wäre, sollte der Ausdruck
192.168.0.5:17070/api/state?jq=.result.loadpoints[].vehicleCapacity
eine 14 liefern. Tut er aber nicht.
Re: Support: Http
Du hast nicht zufällig SSH auf deiner Box freigeschaltet oder?
hulk66
Re: Support: Http
Nein, habe ich nicht (hätte ich aber gerne). Hab dir aber eine PN geschickt, wie du meine Werte testen kannst.
Re: Support: Http
Schon gesehen und schon geantwortet.
Machst du intern http oder https?
Re: Support: Http
Ichhab nen Pull Request für die V1.9 gemacht um globbing zu aktivieren, damit sollte es bei dir dann auch funktionieren.
https://github.com/snaptec/openWB/pull/2805
Re: Support: Http
Wenn du jetzt auf die aktuellste Nightly der 1.9 gehst, sollte es funktionieren. Der Pull Request ist gemerged
hulk66
Re: Support: Http
Klappt. Danke!
