pv laden mit min 6a geht nicht....
Been thanked: 33 times
Beitrag von okaegi »
ich habe zwei openwbpro. Es geht um lp6, es wird hier nicht mit 6a Mindestrom geladen, respektiv die Ladung startet überhaupt nicht.
Unten das Debug log
2023-12-26 16:05:40,354 - {root:74} - {INFO:MainThread} - # ***Start***
2023-12-26 16:05:40,454 - {modules.common.component_context:51} - {DEBUG:device1} - Update Komponenten ['E3DC Zähler', 'E3DC Speicher', 'E3DC externer Wechselrichter']
2023-12-26 16:05:40,455 - {modules.common.component_context:24} - {DEBUG:device3} - Update Komponente ['Shelly Wechselrichter']
2023-12-26 16:05:40,455 - {modules.common.component_context:24} - {DEBUG:set values cp6} - Update Komponente ['Ladepunkt']
2023-12-26 16:05:40,460 - {urllib3.connectionpool:227} - {DEBUG:device3} - Starting new HTTP connection (1): 192.168.1.7:80
2023-12-26 16:05:40,464 - {urllib3.connectionpool:227} - {DEBUG:set values cp6} - Starting new HTTP connection (1): 192.168.1.242:80
2023-12-26 16:05:40,466 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['E3DC Zähler']
2023-12-26 16:05:40,468 - {modules.devices.e3dc.counter:22} - {DEBUG:device1} - Beginning EVU update
2023-12-26 16:05:40,466 - {modules.common.component_context:24} - {DEBUG:set values cp7} - Update Komponente ['Ladepunkt']
2023-12-26 16:05:40,474 - {urllib3.connectionpool:227} - {DEBUG:set values cp7} - Starting new HTTP connection (1): 192.168.1.248:80
2023-12-26 16:05:40,477 - {modules.devices.e3dc.counter:30} - {DEBUG:device1} - meters: [0, 0, 0, 0, 2, -121, -113, -102, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 20, 10, -31]
2023-12-26 16:05:40,478 - {modules.devices.e3dc.counter:36} - {DEBUG:device1} - e3dc no farm detected
2023-12-26 16:05:40,479 - {modules.devices.e3dc.counter:38} - {DEBUG:device1} - power: -1, powers [20, 10, -31]
2023-12-26 16:05:40,479 - {modules.common.simcount._simcount:38} - {DEBUG:device1} - Previous state: SimCounterState(timestamp=1703603130.2171361, power=-2, imported=4850136.3809819855, exported=4757812.397073046)
2023-12-26 16:05:40,480 - {modules.common.simcount._calculate:13} - {DEBUG:device1} - time passed: 0.00285069, power1: -2, power2: -1
2023-12-26 16:05:40,480 - {modules.common.simcount._calculate:29} - {DEBUG:device1} - power did not change sign. Total energy: -0.00427604
2023-12-26 16:05:40,480 - {modules.common.simcount._simcount:47} - {DEBUG:device1} - imported: 0 Wh, exported: 0.00427604 Wh, new state: SimCounterState(timestamp=1703603140.4796252, power=-1, imported=4850136.3809819855, exported=4757812.4013490835)
2023-12-26 16:05:40,482 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data CounterState(currents=[0.08695652173913043, 0.043478260869565216, -0.13478260869565217], powers=[20, 10, -31], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=4850136.3809819855, exported=4757812.4013490835, power=-1, frequency=50)
2023-12-26 16:05:40,483 - {modules.devices.e3dc.counter:61} - {DEBUG:device1} - Update completed successfully
2023-12-26 16:05:40,486 - {urllib3.connectionpool:452} - {DEBUG:set values cp6} - http://192.168.1.242:80 "GET /connect.php HTTP/1.1" 200 414
2023-12-26 16:05:40,488 - {modules.common.req:11} - {DEBUG:set values cp6} - Get-Response: {"date":"2023:12:26-16:05:40","timestamp":1703603140,"powers":[0,0,0],"power_all":0,"currents":[0,0,0],"voltages":[237.72,238.22,239.51],"frequency":50,"imported":2784661,"exported":3512,"plug_state":false,"charge_state":false,"phases_actual":0,"phases_target":3,"phases_in_use":3,"offered_current":0,"evse_signaling":"basic","v2g_ready":0,"soc_value":null,"soc_timestamp":null,"vehicle_id":null,"serial":"575978"}
2023-12-26 16:05:40,490 - {modules.common.store._api:26} - {DEBUG:set values cp6} - Raw data ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[237.72, 238.22, 239.51], frequency=50, imported=2784661, exported=3512, power=0, phases_in_use=3, charge_state=False, plug_state=False, rfid=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0)
2023-12-26 16:05:40,491 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['E3DC Speicher']
2023-12-26 16:05:40,493 - {urllib3.connectionpool:452} - {DEBUG:set values cp7} - http://192.168.1.248:80 "GET /connect.php HTTP/1.1" 200 414
2023-12-26 16:05:40,502 - {urllib3.connectionpool:452} - {DEBUG:device3} - http://192.168.1.7:80 "GET /status HTTP/1.1" 200 1070
2023-12-26 16:05:40,503 - {modules.common.req:11} - {DEBUG:set values cp7} - Get-Response: {"date":"2023:12:26-16:05:40","timestamp":1703603140,"powers":[0,0,0],"power_all":0,"currents":[0,0,0],"voltages":[237.6,238.4,239.88],"frequency":49.98,"imported":5277118,"exported":1673,"plug_state":true,"charge_state":false,"phases_actual":0,"phases_target":3,"phases_in_use":1,"offered_current":0,"evse_signaling":"basic","v2g_ready":0,"soc_value":null,"soc_timestamp":null,"vehicle_id":null,"serial":"493794"}
2023-12-26 16:05:40,508 - {modules.common.req:11} - {DEBUG:device3} - Get-Response: {"wifi_sta":{"connected":true,"ssid":"ORKS2","ip":"192.168.1.7","rssi":-80},"cloud":{"enabled":true,"connected":false},"mqtt":{"connected":false},"time":"16:05","unixtime":1703603140,"serial":9004,"has_update":true,"mac":"8CAAB5437E96","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"source":"input"}],"meters":[{"power":0.87,"overpower":0.00,"is_valid":true,"timestamp":1703606740,"counters":[0.987, 1.161, 1.367],"total":189099}],"inputs":[{"input":0,"event":"","event_cnt":0}],"temperature":27.26,"overtemperature":false,"tmp":{"tC":27.26,"tF":81.07, "is_valid":true},"temperature_status":"Normal","ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"pending","has_update":true,"new_version":"20230913-113709/v1.14.0-gcb84623","old_version":"20221108-153925/v1.12.1-1PM-fix-g2821131","beta_version":"20231107-164450/v1.14.1-rc1-g0617c15"},"ram_total":51272,"ram_free":39212,"fs_size":233681,"fs_free":148843,"uptime":3137278}
2023-12-26 16:05:40,514 - {modules.common.simcount._simcount:38} - {DEBUG:device1} - Previous state: SimCounterState(timestamp=1703603130.2348711, power=-2334, imported=2570599.701471819, exported=2528478.9057255327)
2023-12-26 16:05:40,515 - {modules.common.store._api:26} - {DEBUG:set values cp7} - Raw data ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[237.6, 238.4, 239.88], frequency=49.98, imported=5277118, exported=1673, power=0, phases_in_use=1, charge_state=False, plug_state=True, rfid=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0)
2023-12-26 16:05:40,519 - {modules.common.simcount._simcount:38} - {DEBUG:device3} - Previous state: SimCounterState(timestamp=1703603130.5547152, power=0, imported=0.0, exported=85143.56902762323)
2023-12-26 16:05:40,521 - {modules.common.simcount._calculate:13} - {DEBUG:device1} - time passed: 0.00285532, power1: -2334, power2: -2295
2023-12-26 16:05:40,524 - {modules.common.simcount._calculate:13} - {DEBUG:device3} - time passed: 0.00276788, power1: 0, power2: 0
2023-12-26 16:05:40,526 - {modules.common.simcount._calculate:29} - {DEBUG:device1} - power did not change sign. Total energy: -6.60863
2023-12-26 16:05:40,527 - {modules.common.simcount._calculate:29} - {DEBUG:device3} - power did not change sign. Total energy: 0
2023-12-26 16:05:40,529 - {modules.common.simcount._simcount:47} - {DEBUG:device1} - imported: 0 Wh, exported: 6.60863 Wh, new state: SimCounterState(timestamp=1703603140.5140166, power=-2295, imported=2570599.701471819, exported=2528485.5143594802)
2023-12-26 16:05:40,531 - {modules.common.simcount._simcount:47} - {DEBUG:device3} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1703603140.5190966, power=0, imported=0.0, exported=85143.56902762323)
2023-12-26 16:05:40,536 - {modules.common.store._api:26} - {DEBUG:device3} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=85143.56902762323, dc_power=None)
2023-12-26 16:05:40,538 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data BatState(imported=2570599.701471819, exported=2528485.5143594802, power=-2295, soc=20)
2023-12-26 16:05:40,542 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['E3DC externer Wechselrichter']
2023-12-26 16:05:40,566 - {modules.common.simcount._simcount:38} - {DEBUG:device1} - Previous state: SimCounterState(timestamp=1703603130.2439682, power=-339, imported=369.8394811833567, exported=11736205.29868416)
2023-12-26 16:05:40,568 - {modules.common.simcount._calculate:13} - {DEBUG:device1} - time passed: 0.00286733, power1: -339, power2: -336
2023-12-26 16:05:40,568 - {modules.common.simcount._calculate:29} - {DEBUG:device1} - power did not change sign. Total energy: -0.967724
2023-12-26 16:05:40,568 - {modules.common.simcount._simcount:47} - {DEBUG:device1} - imported: 0 Wh, exported: 0.967724 Wh, new state: SimCounterState(timestamp=1703603140.5663555, power=-336, imported=369.8394811833567, exported=11736206.266407961)
2023-12-26 16:05:40,570 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-336, exported=11736206.266407961, dc_power=None)
2023-12-26 16:05:40,581 - {modules.common.component_context:24} - {DEBUG:component3} - Update Komponente ['E3DC Speicher']
2023-12-26 16:05:40,582 - {modules.common.store._api:30} - {INFO:component3} - Saving BatState(imported=2570599.701471819, exported=2528485.5143594802, power=-2295, soc=20)
2023-12-26 16:05:40,584 - {modules.common.component_context:24} - {DEBUG:component4} - Update Komponente ['E3DC externer Wechselrichter']
2023-12-26 16:05:40,586 - {modules.common.component_context:24} - {DEBUG:update values cp6} - Update Komponente ['Ladepunkt']
2023-12-26 16:05:40,589 - {modules.common.store._api:26} - {DEBUG:component4} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-336, exported=11736206.266407961, dc_power=None)
2023-12-26 16:05:40,591 - {modules.common.store._api:30} - {INFO:update values cp6} - Saving ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[237.72, 238.22, 239.51], frequency=50, imported=2784661, exported=3512, power=0, phases_in_use=3, charge_state=False, plug_state=False, rfid=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0)
2023-12-26 16:05:40,591 - {modules.common.component_context:24} - {DEBUG:update values cp7} - Update Komponente ['Ladepunkt']
2023-12-26 16:05:40,597 - {modules.common.component_context:24} - {DEBUG:component5} - Update Komponente ['Shelly Wechselrichter']
2023-12-26 16:05:40,601 - {modules.common.store._api:30} - {INFO:component4} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-336, exported=11736206.266407961, dc_power=None)
2023-12-26 16:05:40,612 - {modules.common.store._api:30} - {INFO:update values cp7} - Saving ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[237.6, 238.4, 239.88], frequency=49.98, imported=5277118, exported=1673, power=0, phases_in_use=1, charge_state=False, plug_state=True, rfid=None, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0)
2023-12-26 16:05:40,614 - {modules.common.store._api:26} - {DEBUG:component5} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=85143.56902762323, dc_power=None)
2023-12-26 16:05:40,629 - {modules.common.store._api:30} - {INFO:component5} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=85143.56902762323, dc_power=None)
2023-12-26 16:05:40,731 - {modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['E3DC Zähler']
2023-12-26 16:05:40,732 - {modules.common.store._api:30} - {INFO:component2} - Saving CounterState(currents=[0.08695652173913043, 0.043478260869565216, -0.13478260869565217], powers=[20, 10, -31], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=4850136.3809819855, exported=4757812.4013490835, power=-1, frequency=50)
2023-12-26 16:05:40,780 - {helpermodules.changed_values_handler:120} - {DEBUG:MainThread} - Topic openWB/set/bat/get/exported, Payload 2528485.51, vorherige Payload: 2528478.91
2023-12-26 16:05:40,781 - {helpermodules.changed_values_handler:120} - {DEBUG:MainThread} - Topic openWB/set/bat/get/power, Payload -2295, vorherige Payload: -2334
2023-12-26 16:05:40,888 - {control.bat_all:213} - {DEBUG:MainThread} - Verbleibende Speicher-Leistung: -2295W
2023-12-26 16:05:40,888 - {control.bat_all:173} - {INFO:MainThread} - -2295W verbleibende Speicher-Leistung
2023-12-26 16:05:40,892 - {control.counter:138} - {INFO:MainThread} - Verbleibende Ströme an Zähler 2: [64.91, 64.96, 65.13]A
2023-12-26 16:05:40,892 - {control.counter:161} - {INFO:MainThread} - Verbleibende Leistung an Zähler 2: 45001W
2023-12-26 16:05:40,896 - {control.chargepoint.chargepoint:277} - {INFO:MainThread} - LP 6: Keine Ladung, da kein Auto angesteckt ist.
2023-12-26 16:05:40,899 - {control.chargepoint.chargepoint:699} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-12-26 16:05:40,900 - {control.ev:572} - {DEBUG:MainThread} - Keine Ladung, da kein Zeitfenster für Zeitladen aktiv ist.
2023-12-26 16:05:40,903 - {control.chargepoint.chargepoint:898} - {INFO:MainThread} - LP 7, EV: Kona (EV-Nr.2): Theoretisch benötigter Strom 6A, Lademodus pv_charging, Submodus: Chargemode.INSTANT_CHARGING, Phasen: 0, Priorität: False, max. Ist-Strom: 0
2023-12-26 16:05:40,907 - {modules.common.simcount._simcount:38} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1703603130.8991535, power=2671, imported=3803439.264970422, exported=0)
2023-12-26 16:05:40,908 - {modules.common.simcount._calculate:13} - {DEBUG:MainThread} - time passed: 0.00278006, power1: 2671, power2: 2630
2023-12-26 16:05:40,910 - {modules.common.simcount._calculate:29} - {DEBUG:MainThread} - power did not change sign. Total energy: 7.36856
2023-12-26 16:05:40,913 - {modules.common.simcount._simcount:47} - {DEBUG:MainThread} - imported: 7.36856 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1703603140.9073832, power=2630, imported=3803446.6335295625, exported=0)
2023-12-26 16:05:40,916 - {control.data:266} - {INFO:MainThread} - bat3
BatData(get=Get(soc=20, daily_exported=2045.63, daily_imported=6232.6, imported=2570599.7, exported=2528485.51, fault_state=0, fault_str='Kein Fehler.', power=-2295))
2023-12-26 16:05:40,918 - {control.data:236} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=20, daily_exported=2045.63, daily_imported=6232.6, fault_str='Kein Fehler.', fault_state=0, imported=2570599.7, exported=2528485.51, power=-2295), set=Set(charging_power_left=-2295, switch_on_soc_reached=False))
2023-12-26 16:05:40,918 - {control.data:237} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=0, daily_exported=0, power=0, imported=8061779, exported=5185))
2023-12-26 16:05:40,920 - {control.data:266} - {INFO:MainThread} - cp6
ChargepointData(control_parameter=ControlParameter(chargemode='stop', current_plan=None, imported_at_plan_start=None, imported_instant_charging=None, limit=None, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=0, submode='stop', timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0, 0, 0], daily_imported=0, daily_exported=0, evse_current=0, exported=3512, fault_str='Kein Fehler.', fault_state=0, imported=2784661, phases_in_use=3, plug_state=False, power=0, rfid_timestamp=None, rfid=None, soc=35, soc_timestamp=1703429947, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[237.72, 238.22, 239.51]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=3, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x6a81f178>), config=Config(configuration={'ip_address': '192.168.1.242', 'duo_num': 0}, ev=1, name='Hof', type='openwb_pro', template=3, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=False, id=6))
2023-12-26 16:05:40,921 - {control.data:266} - {INFO:MainThread} - cp7
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, current_plan=None, imported_at_plan_start=5277118, imported_instant_charging=None, limit=None, phases=0, prio=False, required_current=6, required_currents=[0.0, 0.0, 0.0], state=0, submode=<Chargemode.INSTANT_CHARGING: 'instant_charging'>, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0, 0, 0], daily_imported=0, daily_exported=0, evse_current=0, exported=1673, fault_str='Kein Fehler.', fault_state=0, imported=5277118, phases_in_use=1, plug_state=True, power=0, rfid_timestamp=None, rfid=None, soc=70, soc_timestamp=170359891, state_str=None, voltages=[237.6, 238.4, 239.88]), set=Set(change_ev_permitted=[True, ''], charging_ev=2, charging_ev_prev=2, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=5277118, imported_at_plugtime=5277118, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=True, plug_time='12/26/2023, 16:04:10', required_power=0.0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x6a822448>), config=Config(configuration={'ip_address': '192.168.1.248', 'duo_num': 0}, ev=2, name='Garage', type='openwb_pro', template=4, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=False, id=7))
2023-12-26 16:05:40,922 - {control.data:266} - {INFO:MainThread} - cpt0
2023-12-26 16:05:40,925 - {control.data:266} - {INFO:MainThread} - cpt3
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=3, max_current_multi_phases=32, max_current_single_phase=32, name='Hof', rfid_enabling=False, valid_tags=[])
2023-12-26 16:05:40,928 - {control.data:266} - {INFO:MainThread} - cpt4
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=4, max_current_multi_phases=32, max_current_single_phase=32, name='Garage', rfid_enabling=False, valid_tags=[])
2023-12-26 16:05:40,929 - {control.data:266} - {INFO:MainThread} - counter2
CounterData(config=Config(max_currents=[65, 65, 65], max_total_power=45000), get=Get(powers=[20, 10, -31], currents=[0.09, 0.04, -0.13], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], unbalanced_load=0, frequency=50, daily_exported=37.053209632, daily_imported=18444.752130209, imported=4850136.3809819855, exported=4757812.4013490835, fault_state=0, fault_str='Kein Fehler.', power=-1), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=45001, raw_currents_left=[64.91, 64.96, 65.13], surplus_power_left=0, state_str=''))
2023-12-26 16:05:40,931 - {control.data:241} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=False), get=Get(hierarchy=[{'id': 2, 'type': 'counter', 'children': [{'id': 3, 'type': 'bat', 'children': []}, {'id': 4, 'type': 'inverter', 'children': []}, {'id': 6, 'type': 'cp', 'children': []}, {'id': 7, 'type': 'cp', 'children': []}, {'id': 5, 'type': 'inverter', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=2630, invalid_home_consumption=0, daily_yield_home_consumption=28545.8314109958, imported_home_consumption=3803446.6335295625, disengageable_smarthome_power=0))
2023-12-26 16:05:40,934 - {control.data:266} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=True, load_default=False, time_charging=TimeCharging(active=True, plans={'0': TimeChargingPlan(active=False, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['06:00', '07:00'], name='Zeitladen-Standard', current=16, limit=Limit(selected='none', amount=1000, soc=50))}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=6, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={'0': ScheduledChargingPlan(active=False, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), current=14, name='Zielladen-Standard', limit=ScheduledLimit(selected='amount', amount=1000, soc_limit=90, soc_scheduled=80), time='07:00'), '1': ScheduledChargingPlan(active=False, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), current=14, name='Zielladen-Standard', limit=ScheduledLimit(selected='amount', amount=1000, soc_limit=90, soc_scheduled=80), time='07:00')}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2023-12-26 16:05:40,936 - {control.data:266} - {INFO:MainThread} - ct1
ChargeTemplateData(name='PvundNachtkona2019', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=True, plans={'1': TimeChargingPlan(active=True, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['00:05', '07:00'], name='Zeitladen-Standard', current=32, limit=Limit(selected='soc', amount=1000, soc=100))}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=6, min_current=6, feed_in_limit=False, min_soc=99, max_soc=101), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=32, limit=Limit(selected='none', amount=1000, soc=50))))
2023-12-26 16:05:40,937 - {control.data:266} - {INFO:MainThread} - ct2
ChargeTemplateData(name='PvundNachtKona', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=True, plans={'2': TimeChargingPlan(active=True, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['00:10', '07:00'], name='Zeitladen-Standard', current=32, limit=Limit(selected='none', amount=1000, soc=50))}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=6, min_current=6, feed_in_limit=False, min_soc=99, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=32, limit=Limit(selected='none', amount=1000, soc=50))))
2023-12-26 16:05:40,939 - {control.data:266} - {INFO:MainThread} - ct3
ChargeTemplateData(name='Standard-Lade-Profil', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='stop', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2023-12-26 16:05:40,940 - {control.data:266} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp=None, force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-12-26 16:05:40,941 - {control.data:266} - {INFO:MainThread} - ev1
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Ph1', max_current_multi_phases=16, max_phases=1, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=65000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), charge_template=1, ev_template=1, name='Kona2019', tag_id=[], get=Get(soc=0, soc_timestamp=None, force_soc_update=True, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-12-26 16:05:40,942 - {control.data:266} - {INFO:MainThread} - ev2
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Ph3', max_current_multi_phases=32, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=65000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), charge_template=2, ev_template=2, name='Kona', tag_id=[], get=Get(soc=0, soc_timestamp=None, force_soc_update=True, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-12-26 16:05:40,944 - {control.data:266} - {INFO:MainThread} - et0
EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, efficiency=90, nominal_difference=2, keep_charge_active_duration=40)
2023-12-26 16:05:40,945 - {control.data:266} - {INFO:MainThread} - et1
EvTemplateData(name='Ph1', max_current_multi_phases=32, max_phases=1, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=65000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40)
2023-12-26 16:05:40,948 - {control.data:266} - {INFO:MainThread} - et2
2023-12-26 16:05:40,949 - {control.data:245} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=False, charging_power_reserve=0, control_range=[0, 230], feed_in_yield=0, phase_switch_delay=7, phases_to_use=0, rundown_power=1000, rundown_soc=0, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=3), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=False, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.3, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-12-26 16:05:40,951 - {control.data:246} - {INFO:MainThread} - general_data-display
local
2023-12-26 16:05:40,952 - {control.data:247} - {INFO:MainThread} - graph_data
2023-12-26 16:05:40,954 - {control.data:248} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=False, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x6a802b50>), led=Led(active=False), rfid=Rfid(active=False))
2023-12-26 16:05:40,955 - {control.data:266} - {INFO:MainThread} - pv4
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=14248.985, monthly_exported=0, yearly_exported=0, exported=11736206.266, fault_state=0, fault_str='Kein Fehler.', power=-336))
2023-12-26 16:05:40,956 - {control.data:266} - {INFO:MainThread} - pv5
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=73.883, monthly_exported=0, yearly_exported=0, exported=85143.569, fault_state=0, fault_str='Kein Fehler.', power=0))
2023-12-26 16:05:40,957 - {control.data:250} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=14322.868, monthly_exported=0, yearly_exported=0, exported=11821349.835, power=-336))
2023-12-26 16:05:40,958 - {control.data:266} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'boot_done': True, 'ip_address': '192.168.1.246', 'current_commit': '2023-11-17 09:21:40 +0100 [43b29ac34]', 'current_branch': 'master', 'current_branch_commit': '2023-12-22 12:29:57 +0100 [2d75c6556]', 'current_missing_commits': ['2023-12-22 12:29:57 +0100 [2d75c6556] - Merge pull request #1307 from benderl/fix-sungrow-divisionByZero', '2023-12-22 09:00:54 +0100 [1eb25a628] - Merge pull request #1319 from LKuemmel/fix', '2023-12-22 08:57:52 +0100 [e321c6e23] - improve default values counter config, ev standard template', '2023-12-21 08:06:13 +0100 [c93da913b] - catch exception in component_state.py', '2023-12-21 08:03:10 +0100 [14bfd031f] - Merge pull request #1311 from benderl/display-theme-cards', '2023-12-20 15:45:52 +0100 [e024ad51c] - Merge pull request #1318 from LKuemmel/fix', '2023-12-20 15:43:46 +0100 [10983db8e] - fix missing timecheck function', '2023-12-20 15:27:02 +0100 [c64442e3f] - Merge pull request #1317 from LKuemmel/fix', '2023-12-20 15:25:25 +0100 [ccdcca7ab] - fix deye', '2023-12-20 12:40:21 +0100 [70e3f69b4] - Merge pull request #1316 from LKuemmel/fix', '2023-12-20 12:37:46 +0100 [48f328a0f] - fix logging evse version', '2023-12-20 12:32:52 +0100 [85e4a96bf] - Merge pull request #1315 from LKuemmel/fix', '2023-12-20 12:27:50 +0100 [0bb58a77f] - fix fault state handling', '2023-12-20 11:20:51 +0100 [167ac4ef6] - Merge pull request #1290 from LKuemmel/fault_state_handling', '2023-12-20 11:17:10 +0100 [376f0651a] - fault handling for warnings', '2023-12-20 09:53:35 +0100 [ac918d018] - rfid identification with openWB Pro (#1313)', '2023-12-20 08:31:03 +0100 [9438ab453] - Unix timestamps (#753)', '2023-12-19 11:30:35 +0100 [ffaf62da3] - remove outdated rollup plugin', '2023-12-14 09:00:09 +0100 [632881f09] - Merge pull request #1305 from benderl/dependencies', '2023-12-14 08:58:00 +0100 [73cb09410] - cards-display: build', '2023-12-14 08:56:00 +0100 [9a32e5080] - cards-display: vite vitest jsdom', '2023-12-14 08:55:57 +0100 [4c81bdfc0] - cards-display: prettier eslint', '2023-12-14 08:55:13 +0100 [8e605485b] - cards-display: mqtt', '2023-12-14 08:55:13 +0100 [8fb29c150] - cards-display: npm up', '2023-12-12 09:38:38 +0100 [0fa67f864] - Merge pull request #1304 from benderl/dependencies', '2023-12-12 09:36:54 +0100 [208e262ea] - build ui', '2023-12-11 19:38:03 +0100 [836c2f45c] - Merge pull request #1271 from LKuemmel/soc_request_interval', "2023-12-11 19:36:34 +0100 [58328ba70] - Merge branch 'master' into soc_request_interval", '2023-12-11 19:21:51 +0100 [821d16246] - Merge pull request #1303 from benderl/cards-display-id-tag', '2023-12-11 19:18:31 +0100 [7a0de08ed] - build cards display theme', '2023-12-11 19:18:19 +0100 [f9716a2f4] - fix id-tag state for charge points in cards display theme', '2023-12-11 12:27:20 +0100 [e6f44bdf9] - Merge pull request #1302 from benderl/build', '2023-12-11 12:26:02 +0100 [0b328e967] - build settings', '2023-12-11 12:25:50 +0100 [ae7ad24f1] - build cards display theme', '2023-12-11 12:22:30 +0100 [6c16f95ed] - Merge pull request #1301 from benderl/rename-rfid', '2023-12-11 12:22:17 +0100 [ce5e7492a] - Merge pull request #1300 from benderl/module-cleanup', '2023-12-11 12:19:03 +0100 [0540b2c6e] - add manual id-tag input on cards display theme', '2023-12-11 12:19:03 +0100 [cba0ddfc7] - backend', '2023-12-11 12:19:03 +0100 [881fa003f] - wiki', '2023-12-11 12:17:59 +0100 [8c2459273] - tesla', '2023-12-11 12:17:59 +0100 [879bd3201] - evnotify', '2023-12-11 12:10:32 +0100 [d5c6f7839] - Merge pull request #1299 from benderl/cards-display-theme', '2023-12-05 07:57:09 +0100 [6ff8081e0] - hide energy/range charged in dashboard', '2023-12-04 12:31:19 +0100 [69f973931] - Merge pull request #1295 from benderl/build-ui', '2023-12-04 12:29:29 +0100 [bcfb74e2e] - rebuild', '2023-12-04 12:18:54 +0100 [311f436a5] - Merge pull request #1284 from benderl/fixes', '2023-12-04 12:18:16 +0100 [0885e987d] - build cards display theme', '2023-12-04 12:16:24 +0100 [3c398e4ff] - Merge pull request #1291 from cshagen/master', '2023-12-04 12:14:36 +0100 [23be74028] - Merge pull request #1256 from okaegi/sm25040', '2023-12-04 10:42:44 +0100 [62443a15a] - Merge pull request #1294 from LKuemmel/fix', '2023-12-04 10:40:46 +0100 [bcf496a2b] - fix setdata expected type', '2023-12-03 12:46:41 +0100 [05ea579aa] - reload graph when unhiding', '2023-12-02 17:33:29 +0100 [8a064eb3f] - Change kWh to kW in graph', '2023-12-01 15:37:47 +0100 [428b8efc4] - Failed phase switches (#1227)', '2023-12-01 15:21:31 +0100 [93cb9dd25] - Deye (#1287)', '2023-12-01 15:18:39 +0100 [2ab78dfb3] - Fix surplus controlled (#1288)', '2023-12-01 15:17:38 +0100 [15d97c630] - Merge pull request #1293 from LKuemmel/web', '2023-12-01 15:15:12 +0100 [eb9a90eb3] - build UI(dev)', '2023-12-01 14:58:31 +0100 [2b533d022] - Merge pull request #1226 from LKuemmel/power_source', '2023-12-01 14:58:03 +0100 [add1e0f2b] - Merge pull request #1223 from LKuemmel/smartwb', '2023-12-01 14:57:27 +0100 [42658daa6] - Kostal Plenticore device.py für Hybrid-WR geändert (#1231)', '2023-12-01 14:52:52 +0100 [cb472dfc1] - Merge pull request #1229 from LKuemmel/hierarchy', '2023-12-01 11:58:29 +0100 [0f1862522] - cards display - instant update of chargemode and priority', '2023-12-01 11:57:40 +0100 [bf6a6556a] - fix installing service definition', '2023-12-01 11:57:40 +0100 [187842635] - update readme', '2023-12-01 11:57:40 +0100 [b0ccda05f] - sorting of configurable modules', '2023-12-01 11:57:40 +0100 [10c58a04e] - Mindeststrom -> Minimaler Dauerstrom', '2023-11-30 12:31:57 +0100 [c055abe8b] - Update version 2.1.3-Alpha.2', '2023-11-30 12:22:44 +0100 [6b8c1a23b] - Update version 2.1.2-Patch.1', '2023-11-30 12:18:04 +0100 [8ef179792] - Merge pull request #1289 from benderl/url-error', '2023-11-30 10:31:53 +0100 [ebc7989b2] - Fix graph width', '2023-11-30 09:33:22 +0100 [d7aae86ab] - add custom 404 page', '2023-11-30 09:20:06 +0100 [5fc86004a] - an additional fix for the year graph', '2023-11-30 07:23:42 +0100 [18aec512d] - Merge pull request #1286 from cshagen/master', '2023-11-29 22:08:28 +0100 [a1fe9c898] - fix month and year graph', '2023-11-29 20:26:05 +0100 [33659b8d3] - fix livegraph display', '2023-11-29 20:00:07 +0100 [b3b9440ba] - Fix Soc Editor', '2023-11-28 21:24:10 +0100 [270614cde] - Fix border colors in chargepointlist and device list', '2023-11-28 15:08:19 +0100 [303ff820d] - Update version 2.1.3-Alpha.1', '2023-11-28 15:00:49 +0100 [e6421871c] - Update version 2.1.2', '2023-11-28 11:59:46 +0100 [23737b71b] - Merge pull request #1282 from benderl/colors-theme', '2023-11-28 11:57:43 +0100 [b5479ab71] - build colors theme', '2023-11-28 11:50:54 +0100 [3cdab7a73] - remove outdated soc_config message handling', '2023-11-28 11:50:54 +0100 [e4547c190] - fix style of soc edit box', '2023-11-28 11:50:54 +0100 [5d07d4cc6] - fix setting socConfigured', '2023-11-28 11:12:25 +0100 [066288be0] - fix manual soc (#1283)', '2023-11-28 07:49:32 +0100 [07d9153ab] - Merge pull request #1281 from cshagen/master', '2023-11-27 15:42:31 +0100 [da2526c02] - Fix simple chargepoint list', '2023-11-27 13:43:54 +0100 [778529518] - Merge pull request #1279 from benderl/colors-theme', '2023-11-27 13:38:59 +0100 [b8bf93d74] - fix onMounted hook', '2023-11-27 13:14:47 +0100 [06fe18bec] - small code cleanup', '2023-11-27 13:10:21 +0100 [39e4245c7] - fix time update interval', '2023-11-27 13:10:21 +0100 [750fea242] - add top border to compact charge point list', '2023-11-27 13:10:21 +0100 [b88aaa348] - make top button bar configurable', '2023-11-27 13:09:19 +0100 [6d4274c24] - Merge pull request #1274 from cshagen/master', '2023-11-27 13:00:17 +0100 [1ce22266e] - Merge pull request #1280 from LKuemmel/fix', '2023-11-27 12:56:03 +0100 [f6ba7cbfc] - fix soc set to 0', '2023-11-27 10:10:31 +0100 [29390f546] - Merge pull request #1278 from LKuemmel/fix', '2023-11-27 10:06:01 +0100 [8dc6ac720] - fix phases scheduled charging', '2023-11-27 09:05:40 +0100 [d905be670] - Merge pull request #1277 from benderl/cards-display', '2023-11-27 08:58:22 +0100 [4999456b8] - build cards display theme', '2023-11-27 08:51:37 +0100 [e4ba4a66b] - replace last checkbox with on/off button group', '2023-11-27 08:51:37 +0100 [fd9c3dc04] - close visible modals on lock', '2023-11-25 15:23:57 +0100 [cf9e979b2] - Fix month graph', '2023-11-25 08:34:05 +0100 [1cc23e61b] - Fix Soc Limit display', '2023-11-24 12:54:27 +0100 [b3661d41c] - Merge pull request #1255 from benderl/cards-display', '2023-11-24 12:50:51 +0100 [0d3ce09b9] - Merge pull request #1264 from cshagen/master', '2023-11-24 11:28:00 +0100 [8fd5b10f4] - Merge pull request #1273 from LKuemmel/fix', '2023-11-24 11:25:52 +0100 [330d75944] - improve text', '2023-11-24 11:10:08 +0100 [0322c9af7] - scheduled charging: calc current if it is too late (#1272)', '2023-11-24 10:43:07 +0100 [9081ffdeb] - build cards display theme', '2023-11-24 10:41:59 +0100 [daa0f606d] - fix cursor type for clickable elements', '2023-11-24 10:36:23 +0100 [45a828ec4] - restructure charge point settings', '2023-11-24 10:34:20 +0100 [861687a46] - add modal vehicle select', '2023-11-22 13:02:15 +0100 [2f259068d] - fix scheduled charging, soc request interval in s', '2023-11-22 13:01:10 +0100 [a327c63a4] - fix scheduled charging (#1270)', '2023-11-22 08:03:15 +0100 [4a573611f] - Update version 2.1.2-Beta.4', '2023-11-21 18:23:32 +0100 [8d64cae75] - build new version', '2023-11-21 18:16:27 +0100 [77d575c55] - remove mac artefacts, correct limit setting', '2023-11-21 12:36:53 +0100 [8009e5a8b] - Merge pull request #1268 from openWB/feature_fix_soc_source', '2023-11-21 12:23:20 +0100 [3c8db2b7b] - fix soc source', '2023-11-21 08:36:40 +0100 [13aa1380e] - Merge pull request #1267 from LKuemmel/fix', '2023-11-21 08:34:43 +0100 [4ece82340] - flake8', '2023-11-21 08:17:21 +0100 [c5275d55f] - fix duo phase switch', '2023-11-20 14:16:53 +0100 [c6548715c] - Merge pull request #1266 from LKuemmel/fix', '2023-11-20 14:14:25 +0100 [08ccf9a98] - fix duo with phase switch at cp 2', '2023-11-20 12:23:11 +0100 [3d7589aa3] - Merge pull request #1265 from LKuemmel/soc_pro', '2023-11-20 12:21:22 +0100 [334bf4291] - improve logging', '2023-11-20 11:53:59 +0100 [cd75a355c] - Fix MQTT SoC', '2023-11-19 22:24:15 +0100 [d10dbb5f9] - Fix errors, add enhancements', '2023-11-17 18:03:58 +0100 [1fa3f3b7c] - hotfix for one and two phase openWB (#1260)', '2023-11-17 14:39:53 +0100 [fc070c043] - Merge pull request #1258 from LKuemmel/fix', '2023-11-17 14:38:01 +0100 [50468213c] - fix unused evse current', '2023-11-17 14:14:17 +0100 [4da5fd0e2] - Update version 2.1.2-Beta.3', '2023-11-17 11:44:08 +0100 [0e81ad176] - idm Anpassungen', '2023-11-17 11:32:53 +0100 [142a027f0] - add autolock', '2023-11-17 11:32:53 +0100 [f71805cf9] - add charge mode select and charged energy', '2023-11-02 14:54:59 +0100 [ac1973904] - fix validate hierarchy if evu counter is missing', '2023-10-31 14:09:02 +0100 [cabc654e5] - add power_source to graph data', '2023-10-30 12:20:56 +0100 [058e937fd] - add cp interruption for smartwb'], 'dataprotection_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.1.2-Beta.2', 'datastore_version': 29, 'lastlivevaluesJson': {'timestamp': 1703603131, 'time': '16:05:31', 'grid': -0.002, 'house-power': 2.671, 'charging-all': 0.0, 'pv-all': 0.339, 'cp6-power': 0.0, 'cp7-power': 0.0, 'bat-all-power': -2.334, 'bat-all-soc': 20}, 'usage_terms_acknowledged': True, 'module_update_completed': True}
2023-12-26 16:05:40,961 - {control.data:279} - {INFO:MainThread} - device1
{'name': 'E3DC', 'type': 'e3dc', 'id': 1, 'configuration': {'address': '192.168.1.245'}}
2023-12-26 16:05:40,963 - {control.data:281} - {INFO:MainThread} - component2
{'name': 'E3DC Zähler', 'type': 'counter', 'id': 2, 'configuration': {}}
2023-12-26 16:05:40,963 - {control.data:281} - {INFO:MainThread} - component3
{'name': 'E3DC Speicher', 'type': 'bat', 'id': 3, 'configuration': {}}
2023-12-26 16:05:40,965 - {control.data:281} - {INFO:MainThread} - component4
{'name': 'E3DC externer Wechselrichter', 'type': 'external_inverter', 'id': 4, 'configuration': {}}
2023-12-26 16:05:40,965 - {control.data:279} - {INFO:MainThread} - device3
{'name': 'Shelly', 'type': 'shelly', 'id': 3, 'configuration': {'ip_address': '192.168.1.7', 'generation': 1}}
2023-12-26 16:05:40,968 - {control.data:281} - {INFO:MainThread} - component5
{'name': 'Shelly Wechselrichter', 'type': 'inverter', 'id': 5, 'configuration': {}}
2023-12-26 16:05:40,969 - {control.data:253} - {INFO:MainThread} -
2023-12-26 16:05:40,970 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-12-26 16:05:40,970 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen**
2023-12-26 16:05:40,972 - {control.algorithm.min_current:18} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 2
2023-12-26 16:05:40,974 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Sollstrom setzen**
2023-12-26 16:05:40,977 - {control.algorithm.filter_chargepoints:117} - {DEBUG:MainThread} - Geordnete Ladepunkte [7]
2023-12-26 16:05:40,978 - {control.algorithm.filter_chargepoints:46} - {INFO:MainThread} - LP 7: Keine Zuteilung des Mindeststroms, daher keine weitere Berücksichtigung
2023-12-26 16:05:40,979 - {control.counter:211} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-12-26 16:05:40,979 - {control.counter:457} - {DEBUG:MainThread} - Zähler 2: Begrenzung der verbleibenden Leistung auf 0W
2023-12-26 16:05:40,982 - {control.algorithm.algorithm:43} - {INFO:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-12-26 16:05:40,982 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-12-26 16:05:40,985 - {control.process:111} - {INFO:MainThread} - LP7: set current 0 A, state NO_CHARGING_ALLOWED
2023-12-26 16:05:40,992 - {modules.common.component_context:24} - {DEBUG:set current cp6} - Update Komponente ['Ladepunkt']
2023-12-26 16:05:40,996 - {modules.common.component_context:24} - {DEBUG:set current cp7} - Update Komponente ['Ladepunkt']
2023-12-26 16:05:41,005 - {urllib3.connectionpool:227} - {DEBUG:set current cp7} - Starting new HTTP connection (1): 192.168.1.248:80
2023-12-26 16:05:41,009 - {urllib3.connectionpool:227} - {DEBUG:set current cp6} - Starting new HTTP connection (1): 192.168.1.242:80
2023-12-26 16:05:41,029 - {urllib3.connectionpool:452} - {DEBUG:set current cp7} - http://192.168.1.248:80 "POST /connect.php HTTP/1.1" 200 19
2023-12-26 16:05:41,032 - {urllib3.connectionpool:452} - {DEBUG:set current cp6} - http://192.168.1.242:80 "POST /connect.php HTTP/1.1" 200 19
2023-12-26 16:05:41,037 - {modules.common.req:11} - {DEBUG:set current cp7} - Get-Response: OK Value:0 accepted
2023-12-26 16:05:41,041 - {modules.common.req:11} - {DEBUG:set current cp6} - Get-Response: OK Value:0 accepted
2023-12-26 16:05:41,045 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-12-26 16:05:41,322 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-12-26 16:05:45,347 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-12-26 16:05:50,362 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-12-26 16:05:50,363 - {root:74} - {INFO:MainThread} - # ***Start***
Re: pv laden mit min 6a geht nicht....
wenn ich übers menu kurz auf sofortladen gehe, startet die Ladung. Nachher kann ich wieder auf PV Ladenumstellen und die PV Ladung läuft weiter.
hier noch die Konfig vom Lastmanagement und die Struktur.
EVU- Zähler
Struktur
Has thanked: 192 times
Been thanked: 228 times
Ich kenne mich bei E3DC nicht aus, aber wenn das ein Hybrid ist, dann müsste der Speicher UNTER der E3DC-PV liegen.
Welcher Branch und welche Version verwendest Du?
Ist die E3DC-PVA richtig konfiguriert?
Kommst Du einzeln auf die Webseiten der beiden Pro's? Ich vermute ja, da sie im log unter 1.248 und 1.242 zu sehen sind.
Guten morgen zusammen,
Der e3dc ist ein separater ac Speicher (kein hybrid). Er bietet noch die Möglichkeit meinen solaredge als externer Wr auszulesen. Habe für e3dc selber keine Pva. Sonst habe ich noch einen shelly pva. Webseiten der pros sind aufrufbar (beide 22kwh). Version ist der Master vom november (korrektur).
Konfig sollte m.e. passen.
Has thanked: 143 times
Been thanked: 342 times
Was passiert bei minimalstromstärke 7 oder 8 A?
Sind beides Konas (2019 und 2023). Ich teste mal mit 8 und sag Bescheid.
Bei Sollstromstärke mit 7a minimum funktioniert es bis jetzt problemlos.
Betroffen sind kona2019 und kona 2023.
