Feedback Release Candidate 1
Kitmgue
Has thanked: 4 times
Re: Feedback Release Candidate 1
Beitrag von Kitmgue »
Ich habe heute mit der 2023-06-30 09:10:38 +0200 [8d4b348d3] auch einen Ladelog-Fehler im Mainlog:
2023-06-30 10:33:30,576 - {root:64} - {INFO:MainThread} - # ***Start***
2023-06-30 10:33:30,635 - {modules.common.component_context:51} - {DEBUG:device0} - Update Komponenten ['SMA Home Manager Zähler']
2023-06-30 10:33:30,638 - {modules.devices.sma_sunny_boy.device:72} - {DEBUG:device1} - Start device reading {'component2': <modules.devices.sma_sunny_boy.inverter.SmaSunnyBoyInverter object at 0x723d4b98>}
2023-06-30 10:33:30,643 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-06-30 10:33:30,647 - {modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-06-30 10:33:30,658 - {urllib3.connectionpool:227} - {DEBUG:cp4} - Starting new HTTP connection (1): 192.168.178.67:80
2023-06-30 10:33:30,659 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-06-30 10:33:30,693 - {urllib3.connectionpool:452} - {DEBUG:cp4} - http://192.168.178.67:80 "GET /getParameters HTTP/1.1" 200 387
2023-06-30 10:33:30,697 - {modules.common.req:11} - {DEBUG:cp4} - Get-Response: {"type":"parameters","list":[{"vehicleState":2,"evseState":false,"maxCurrent":32,"actualCurrent":0,"actualPower":0,"duration":41000,"alwaysActive":true,"lastActionUser":"vehicle","lastActionUID":"vehicle","energy":0,"mileage":0,"meterReading":2252.45,"currentP1":0,"currentP2":0,"currentP3":0,"voltageP1":230.2731,"voltageP2":228.9814,"voltageP3":228.3333,"useMeter":true,"RFIDUID":""}]}
2023-06-30 10:33:30,699 - {modules.common.store._api:26} - {DEBUG:cp4} - Raw data ChargepointState(voltages=[230.2731, 228.9814, 228.3333], currents=[0, 0, 0], power_factors=[0.0, 0.0, 0.0], imported=2252450.0, exported=0, power=0, phases_in_use=1, charge_state=False, plug_state=True, rfid=None)
2023-06-30 10:33:31,167 - {modules.devices.sma_sunny_boy.inverter:72} - {DEBUG:device1} - WR 192.168.178.102: InverterState(currents=[0.0, 0.0, 0.0], power=-1982, exported=31446866, dc_power=-2010)
2023-06-30 10:33:31,168 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-1982, exported=31446866, dc_power=-2010)
2023-06-30 10:33:31,343 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SMA Home Manager Zähler']
2023-06-30 10:33:31,344 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[228.579, 230.527, 228.951], powers=[950.0, -311.2, -435.5], currents=[4.671, -1.607, -2.224], power_factors=[0.914, 0.917, 0.924], imported=10433749.100000001, exported=22738664.700000003, power=203.4, frequency=49.98)
2023-06-30 10:33:31,346 - {modules.devices.sma_shm.device:29} - {DEBUG:device0} - All components updated
2023-06-30 10:33:31,351 - {modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-06-30 10:33:31,352 - {modules.common.store._api:26} - {DEBUG:component2} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-1982, exported=31446866, dc_power=None)
2023-06-30 10:33:31,354 - {modules.common.store._api:30} - {INFO:component2} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-1982, exported=31446866, dc_power=None)
2023-06-30 10:33:31,355 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-06-30 10:33:31,357 - {modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-06-30 10:33:31,360 - {modules.common.store._api:30} - {INFO:cp4} - Saving ChargepointState(voltages=[230.2731, 228.9814, 228.3333], currents=[0, 0, 0], power_factors=[0.0, 0.0, 0.0], imported=2252450.0, exported=0, power=0, phases_in_use=1, charge_state=False, plug_state=True, rfid=None)
2023-06-30 10:33:31,470 - {modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SMA Home Manager Zähler']
2023-06-30 10:33:31,475 - {modules.common.store._api:30} - {INFO:component0} - Saving CounterState(voltages=[228.579, 230.527, 228.951], powers=[950.0, -311.2, -435.5], currents=[4.671, -1.607, -2.224], power_factors=[0.914, 0.917, 0.924], imported=10433749.100000001, exported=22738664.700000003, power=203.4, frequency=49.98)
2023-06-30 10:33:31,673 - {control.counter:138} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [45.33, 51.61, 52.22]A
2023-06-30 10:33:31,674 - {control.counter:161} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 33796.6W
2023-06-30 10:33:31,676 - {control.chargepoint.chargepoint:663} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-06-30 10:33:31,677 - {control.chargepoint.chargepoint:646} - {DEBUG:MainThread} - Phasenzahl Lademodus: 1
2023-06-30 10:33:31,680 - {control.chargepoint.chargepoint:846} - {DEBUG:MainThread} - LP 3, EV: eC4 (EV-Nr.1): Lademodus pv_charging, Submodus: Chargemode.STOP
2023-06-30 10:33:31,681 - {control.chargepoint.chargepoint:272} - {INFO:MainThread} - LP 3: Keine Ladung, da der maximale Soc bereits erreicht wurde.
2023-06-30 10:33:31,683 - {control.chargepoint.chargepoint:663} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-06-30 10:33:31,700 - {control.chargepoint.chargepoint:846} - {DEBUG:MainThread} - LP 4, EV: Standard-Fahrzeug (EV-Nr.0): Lademodus stop, Submodus: Chargemode.STOP
2023-06-30 10:33:31,703 - {control.chargepoint.chargepoint:272} - {INFO:MainThread} - LP 4: Keine Ladung, da der Lademodus Stop aktiv ist.
2023-06-30 10:33:31,709 - {control.data:307} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=False), get=Get(soc=0, daily_exported=0, daily_imported=0, imported=0, exported=0, power=0), set=Set(charging_power_left=0, switch_on_soc_reached=False))
2023-06-30 10:33:31,711 - {control.data:308} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=864.99, daily_exported=0, power=0, imported=3978347.95, exported=0))
2023-06-30 10:33:31,712 - {control.data:337} - {INFO:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=80), currents=[0.0, 0.0, 0.0], daily_imported=864.99, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=1725897.95, phases_in_use=0, plug_state=True, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da der maximale Soc bereits erreicht wurde.', voltages=[228.23, 230.19, 228.76]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', imported_at_mode_switch=1725032.96, imported_at_plugtime=1725032.96, imported_since_mode_switch=859.0100000000093, imported_since_plugged=859.0100000000093, range_charged=4.521105263157944, time_charged='0:33', timestamp_start_charging='06/30/2023, 08:03:11'), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time='06/30/2023, 07:34:11', required_power=0.0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x711308c8>), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 1}, ev=1, name='Interne openWB Garage', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-06-30 10:33:31,714 - {control.data:337} - {INFO:MainThread} - cp4
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0, 0, 0], daily_imported=0.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=2252450.0, phases_in_use=1, plug_state=True, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da der Lademodus Stop aktiv ist.', voltages=[230.27, 228.98, 228.33]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=0, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time='06/30/2023, 09:11:21', required_power=0.0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x71130d48>), config=Config(configuration={'ip_address': '192.168.178.67', 'timeout': 4}, ev=0, name='smartWB Carport', type='smartwb', template=0, connected_phases=3, phase_1=2, auto_phase_switch_hw=False, control_pilot_interruption_hw=True, id=4))
2023-06-30 10:33:31,716 - {control.data:337} - {INFO:MainThread} - cpt0
2023-06-30 10:33:31,717 - {control.data:337} - {INFO:MainThread} - cpt1
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=1, max_current_multi_phases=16, max_current_single_phase=16, name='Ladepunkt-Vorlage Garage', rfid_enabling=False, valid_tags=[])
2023-06-30 10:33:31,719 - {control.data:337} - {INFO:MainThread} - cpt2
CpTemplateData(autolock=Autolock(active=True, plans={}, wait_for_charging_end=True), id=2, max_current_multi_phases=16, max_current_single_phase=16, name='Ladepunkt-Vorlage Carport', rfid_enabling=True, valid_tags=['093d0836', 'ac36da17', 'e1c3501b'])
2023-06-30 10:33:31,720 - {control.data:337} - {INFO:MainThread} - counter0
CounterData(config=Config(max_currents=[50, 50, 50], max_total_power=34000), get=Get(powers=[950.0, -311.2, -435.5], currents=[4.67, -1.61, -2.22], voltages=[228.58, 230.53, 228.95], power_factors=[0.91, 0.92, 0.92], unbalanced_load=0, frequency=49.98, daily_exported=3192.000000003, daily_imported=3645.8, imported=10433749.100000001, exported=22738664.700000003, fault_state=0, fault_str='Kein Fehler.', power=203.4), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=33796.6, raw_currents_left=[45.33, 51.61, 52.22], surplus_power_left=0, state_str=''))
2023-06-30 10:33:31,721 - {control.data:312} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=False), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 2, 'type': 'inverter', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=2185.4, invalid_home_consumption=0, daily_yield_home_consumption=7811.809999997, disengageable_smarthome_power=0))
2023-06-30 10:33:31,723 - {control.data:337} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='stop', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2023-06-30 10:33:31,724 - {control.data:337} - {INFO:MainThread} - ct1
ChargeTemplateData(name='Ladeprofil-Vorlage e-Up - PV Laden 80%', disable_after_unplug=False, prio=False, load_default=True, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=80), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='soc', amount=1000, soc=80))))
2023-06-30 10:33:31,725 - {control.data:337} - {INFO:MainThread} - ct2
ChargeTemplateData(name='Ladeprofil-Vorlage eC4 - PV Laden 80%', disable_after_unplug=False, prio=False, load_default=True, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=80), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='soc', amount=1000, soc=80))))
2023-06-30 10:33:31,726 - {control.data:337} - {INFO:MainThread} - ct3
ChargeTemplateData(name='Ladeprofil-Vorlage - allgemein PV Laden unlimited', disable_after_unplug=False, prio=False, load_default=True, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=100))))
2023-06-30 10:33:31,728 - {control.data:337} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=True, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=2, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0, 0.0], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=['e1c3501b'], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2023-06-30 10:33:31,729 - {control.data:337} - {INFO:MainThread} - ev1
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Fahrzeug-Vorlage eC4', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=True, control_pilot_interruption_duration=4, average_consump=19000, min_current=6, max_current_single_phase=16, battery_capacity=48000, nominal_difference=2, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0, 0.0, 0.0], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=2, ev_template=1, name='eC4', tag_id=['ac36da17'], get=Get(soc=80, soc_timestamp='06/30/2023, 10:07:51', force_soc_update=False, range=254, fault_state=0, fault_str='Kein Fehler.'))
2023-06-30 10:33:31,730 - {control.data:337} - {INFO:MainThread} - ev2
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Fahrzeug-Vorlage e-Up', max_current_multi_phases=16, max_phases=2, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=True, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=32000, nominal_difference=2, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=2, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=1, ev_template=2, name='e-Up', tag_id=['093d0836'], get=Get(soc=73, soc_timestamp='06/30/2023, 07:37:21', force_soc_update=False, range=161.0, fault_state=0, fault_str='Kein Fehler.'))
2023-06-30 10:33:31,731 - {control.data:337} - {INFO:MainThread} - ev3
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-06-30 10:33:31,732 - {control.data:337} - {INFO:MainThread} - et0
2023-06-30 10:33:31,733 - {control.data:337} - {INFO:MainThread} - et1
2023-06-30 10:33:31,734 - {control.data:337} - {INFO:MainThread} - et2
2023-06-30 10:33:31,735 - {control.data:316} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=False, charging_power_reserve=200, control_range=[-230, 0], feed_in_yield=14000, phase_switch_delay=7, phases_to_use=0, rundown_power=1000, rundown_soc=50, switch_off_delay=120, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=60, switch_on_soc=60, switch_on_threshold=1200), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=3), unbalanced_load_limit=20, unbalanced_load=True), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.3, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-06-30 10:33:31,736 - {control.data:317} - {INFO:MainThread} - general_data-display
local
2023-06-30 10:33:31,737 - {control.data:318} - {INFO:MainThread} - graph_data
2023-06-30 10:33:31,738 - {control.data:319} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x71130790>), led=Led(active=False), rfid=Rfid(active=True))
2023-06-30 10:33:31,739 - {control.data:337} - {INFO:MainThread} - pv2
PvData(config=Config(max_ac_out=20400), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=8223, monthly_exported=0, yearly_exported=0, exported=31446866, fault_state=0, fault_str='Kein Fehler.', power=-1982))
2023-06-30 10:33:31,740 - {control.data:321} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=8223, monthly_exported=0, yearly_exported=0, exported=31446866, power=-1982))
2023-06-30 10:33:31,741 - {control.data:337} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'boot_done': True, 'ip_address': '192.168.178.110', 'current_commit': '2023-06-30 09:10:38 +0200 [8d4b348d3]', 'current_branch': 'master', 'current_branch_commit': '2023-06-30 09:10:38 +0200 [8d4b348d3]', 'current_missing_commits': [], 'dataprotection_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.RC1.1', 'datastore_version': 13, 'lastlivevaluesJson': {'timestamp': 1688114001, 'time': '10:33:21', 'grid': 1.272, 'house-power': 3.253, 'charging-all': 0.0, 'pv-all': 1.981, 'cp3-power': 0.0, 'cp4-power': 0.0, 'ev1-soc': 80, 'ev2-soc': 73}, 'module_update_completed': True}
2023-06-30 10:33:31,744 - {control.data:350} - {INFO:MainThread} - device0
{'name': 'SMA Home Manager', 'type': 'sma_shm', 'id': 0, 'configuration': {}}
2023-06-30 10:33:31,746 - {control.data:352} - {INFO:MainThread} - component0
{'name': 'SMA Home Manager Zähler', 'type': 'counter', 'id': 0, 'configuration': {'serials': None}}
2023-06-30 10:33:31,747 - {control.data:350} - {INFO:MainThread} - device1
{'name': 'SMA Sunny Boy', 'type': 'sma_sunny_boy', 'id': 1, 'configuration': {'ip_address': '192.168.178.102'}}
2023-06-30 10:33:31,748 - {control.data:352} - {INFO:MainThread} - component2
{'name': 'Sma Sunny Boy/Tripower Wechselrichter', 'type': 'inverter', 'id': 2, 'configuration': {'hybrid': False, 'version': 0}}
2023-06-30 10:33:31,748 - {control.data:324} - {INFO:MainThread} -
2023-06-30 10:33:31,749 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-06-30 10:33:31,750 - {control.algorithm.algorithm:31} - {INFO:MainThread} - **Mindestrom setzen**
2023-06-30 10:33:31,754 - {control.algorithm.algorithm:33} - {INFO:MainThread} - **Sollstrom setzen**
2023-06-30 10:33:31,757 - {control.counter:211} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-06-30 10:33:31,758 - {control.counter:470} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 0W
2023-06-30 10:33:31,759 - {control.algorithm.algorithm:44} - {INFO:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-06-30 10:33:31,761 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-06-30 10:33:31,766 - {control.chargelog:151} - {ERROR:MainThread} - Fehler im Ladelog-Modul
  File "/var/www/html/openWB/packages/control/chargelog.py", line 136, in save_data
    content = json.load(json_file)
  File "/usr/lib/python3.9/json/__init__.py", line 293, in load
    return loads(fp.read(),
  File "/usr/lib/python3.9/json/__init__.py", line 346, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python3.9/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python3.9/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
2023-06-30 10:33:31,775 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-06-30 10:33:31,778 - {modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-06-30 10:33:31,785 - {urllib3.connectionpool:227} - {DEBUG:cp4} - Starting new HTTP connection (1): 192.168.178.67:80
2023-06-30 10:33:31,818 - {urllib3.connectionpool:452} - {DEBUG:cp4} - http://192.168.178.67:80 "GET /setCurrent?current=0 HTTP/1.1" 200 29
2023-06-30 10:33:31,819 - {modules.common.req:11} - {DEBUG:cp4} - Get-Response: S0_set current to given value
2023-06-30 10:33:31,822 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-06-30 10:33:32,078 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-06-30 10:33:32,161 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-06-30 10:33:35,170 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-06-30 10:33:40,182 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-06-30 10:33:40,184 - {root:64} - {INFO:MainThread} - # ***Start***
openWB series2 standard+
LP1 : intern
LP2: smartWB
(manueller SoC für beide LP)
EVU: Sunny Home Manager 2.0
kein Speicher
Has thanked: 8 times
Been thanked: 107 times
Beitrag von LenaK »
MartinH hat geschrieben: Fr Jun 30, 2023 7:49 am Hallo,
mit der Version aus dem RC1 Image lief bei mir alles ohne Probleme. Dann habe ich heute ein Update (Master Zweig) eingespielt und seit dem wird das Auto am Ladepunkt nicht mehr erkannt.
Die Oberfläche sagt nur "Keine Ladung, da kein Auto angesteckt ist." und das Auto läd im Notmodus (1 Phase 3,xy Kw) der Verbrauch wird im Hausverbrauch angezeigt. Dabei ist es auch egal welchen Lademodus ich einstelle, das Auto läd unverändert weiter.
Es handelt sich um eine frühe DUO Version die auch im 1.9 Zweig schon mal Probleme wegen den zwei USB Adaptern gemacht hat. Gibt es hier schon eine Anleitung um das entsprechend Umzubauen?
Martin
Ein Umbau ist nicht erforderlich.
Bitte das Debuglevel auf Details stellen und mindestens einen kompletten Durchlauf von # ***Start*** bis # ***Start*** aus dem main.log posten, wenn der Fehler auftritt. Sensible Daten wie Benutzernamen und Kennwörter unkenntlich machen.
MartinH
Beitrag von MartinH »
Im Log der Internen Ladepunkte steht ein Fehler:
2023-06-30 11:30:56,888 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-30 11:30:56,925 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr <class 'AttributeError'> __enter__, Traceback:
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 186, in loop
    with self.cp0_client_handler:
AttributeError: __enter__
Main.log
2023-06-30 11:35:20,681 - {root:64} - {INFO:MainThread} - # ***Start***
2023-06-30 11:35:20,720 - {modules.common.component_context:51} - {DEBUG:device0} - Update Komponenten ['EVU Zähler']
2023-06-30 11:35:20,721 - {modules.devices.sma_sunny_boy.device:72} - {DEBUG:device1} - Start device reading {'component3': <modules.devices.sma_sunny_boy.inverter.SmaSunnyBoyInverter object at 0x723dc790>}
2023-06-30 11:35:20,721 - {modules.devices.mqtt.device:47} - {DEBUG:device0} - MQTT-Module müssen nicht ausgelesen werden.
2023-06-30 11:35:20,722 - {modules.common.component_context:24} - {DEBUG:cp1} - Update Komponente ['Ladepunkt']
2023-06-30 11:35:20,724 - {modules.common.component_context:24} - {DEBUG:cp2} - Update Komponente ['Ladepunkt']
2023-06-30 11:35:20,725 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-06-30 11:35:21,236 - {modules.devices.sma_sunny_boy.inverter:72} - {DEBUG:device1} - WR 192.168.0.6: InverterState(currents=[0.0, 0.0, 0.0], power=-10587, exported=58637383, dc_power=-10867)
2023-06-30 11:35:21,237 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-10587, exported=58637383, dc_power=-10867)
2023-06-30 11:35:21,248 - {modules.common.component_context:24} - {DEBUG:component3} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-06-30 11:35:21,250 - {modules.common.store._api:26} - {DEBUG:component3} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-10587, exported=58637383, dc_power=None)
2023-06-30 11:35:21,252 - {modules.common.component_context:24} - {DEBUG:cp1} - Update Komponente ['Ladepunkt']
2023-06-30 11:35:21,254 - {modules.common.store._api:30} - {INFO:component3} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-10587, exported=58637383, dc_power=None)
2023-06-30 11:35:21,260 - {modules.common.component_context:24} - {DEBUG:cp2} - Update Komponente ['Ladepunkt']
2023-06-30 11:35:21,309 - {modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['EVU Zähler']
2023-06-30 11:35:21,447 - {control.counter:138} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [51.00521739130435, 65.47478260869565, 65.31826086956522]A
2023-06-30 11:35:21,449 - {control.counter:161} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 352303W
2023-06-30 11:35:21,453 - {control.chargepoint.chargepoint:272} - {INFO:MainThread} - LP 1: Keine Ladung, da kein Auto angesteckt ist.
2023-06-30 11:35:21,457 - {control.chargepoint.chargepoint:272} - {INFO:MainThread} - LP 2: Keine Ladung, da kein Auto angesteckt ist.
2023-06-30 11:35:21,467 - {control.data:307} - {INFO:MainThread} - bat_all_data
2023-06-30 11:35:21,468 - {control.data:308} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=0, daily_exported=0, power=0, imported=10147350, exported=0))
2023-06-30 11:35:21,471 - {control.data:337} - {INFO:MainThread} - cp1
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0.02, 0.02, 0.02], daily_imported=0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=8181120, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[235.6, 236.1, 235.9]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x71b7ae80>), config=Config(configuration={'mode': 'duo', 'ip_address': 'localhost', 'duo_num': 1}, ev=3, name='Interne openWB LP 1', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=1))
2023-06-30 11:35:21,475 - {control.data:337} - {INFO:MainThread} - cp2
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0.02, 0.02, 0.02], daily_imported=0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=1966230, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[235.8, 235.3, 235.8]), set=Set(change_ev_permitted=None, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x71192c70>), config=Config(configuration={'mode': 'duo', 'ip_address': 'localhost', 'duo_num': 2}, ev=4, name='Interne openWB LP 2', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=True, id=2))
2023-06-30 11:35:21,478 - {control.data:337} - {INFO:MainThread} - cpt0
2023-06-30 11:35:21,480 - {control.data:337} - {INFO:MainThread} - counter0
CounterData(config=Config(max_currents=[50, 50, 50], max_total_power=345000), get=Get(powers=[-222, -3550, -3514], currents=[-0.9652173913043478, -15.434782608695652, -15.278260869565218], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], unbalanced_load=0, frequency=0, daily_exported=10114.1058200005, daily_imported=1054.0110399998, imported=1570319.34408, exported=5469056.765860001, fault_state=0, fault_str='Kein Fehler.', power=-7303), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=352303, raw_currents_left=[51.00521739130435, 65.47478260869565, 65.31826086956522], surplus_power_left=0, state_str=''))
2023-06-30 11:35:21,481 - {control.data:312} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=False), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 3, 'type': 'inverter', 'children': []}, {'id': 1, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=3284, invalid_home_consumption=0, daily_yield_home_consumption=8493.905219999298, disengageable_smarthome_power=0))
2023-06-30 11:35:21,482 - {control.data:337} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected=None, pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=6, limit=Limit(selected='none', amount=1000, soc=50))))
2023-06-30 11:35:21,484 - {control.data:337} - {INFO:MainThread} - ct1
ChargeTemplateData(name='LP 1', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=32, limit=Limit(selected='none', amount=1000, soc=50))))
2023-06-30 11:35:21,485 - {control.data:337} - {INFO:MainThread} - ct2
ChargeTemplateData(name='LP 2', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2023-06-30 11:35:21,486 - {control.data:337} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=32, battery_capacity=82, nominal_difference=0.5, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=2, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=None, chargemode=None, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2023-06-30 11:35:21,488 - {control.data:337} - {INFO:MainThread} - ev1
2023-06-30 11:35:21,490 - {control.data:337} - {INFO:MainThread} - ev2
2023-06-30 11:35:21,502 - {control.data:337} - {INFO:MainThread} - ev3
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=1, ev_template=0, name='Golf an LP 1', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2023-06-30 11:35:21,505 - {control.data:337} - {INFO:MainThread} - ev4
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=2, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=None, chargemode=None, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=2, ev_template=0, name='Golf an LP 2', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2023-06-30 11:35:21,508 - {control.data:337} - {INFO:MainThread} - et0
EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=0.5, keep_charge_active_duration=40)
2023-06-30 11:35:21,514 - {control.data:316} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=200, control_range=[-230, 0], feed_in_yield=15000, phase_switch_delay=7, phases_to_use=0, rundown_power=1000, rundown_soc=50, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.3, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-06-30 11:35:21,515 - {control.data:317} - {INFO:MainThread} - general_data-display
local
2023-06-30 11:35:21,515 - {control.data:318} - {INFO:MainThread} - graph_data
2023-06-30 11:35:21,517 - {control.data:319} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x711889a0>), led=Led(active=False), rfid=Rfid(active=False))
2023-06-30 11:35:21,518 - {control.data:337} - {INFO:MainThread} - pv3
PvData(config=Config(max_ac_out=16000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=17554, monthly_exported=0, yearly_exported=0, exported=58637383, fault_state=0, fault_str='Kein Fehler.', power=-10587))
2023-06-30 11:35:21,519 - {control.data:321} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=17554, monthly_exported=0, yearly_exported=0, exported=58637383, power=-10587))
2023-06-30 11:35:21,520 - {control.data:337} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.0.5', 'current_commit': '2023-06-30 11:19:44 +0200 [184a26662]', 'current_branch': 'master', 'current_branch_commit': '2023-06-30 11:19:44 +0200 [184a26662]', 'current_missing_commits': [], 'boot_done': True, 'datastore_version': 13, 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.RC1.1', 'lastlivevaluesJson': {'timestamp': 1688117711, 'time': '11:35:11', 'grid': -7.265, 'house-power': 3.336, 'charging-all': 0.0, 'pv-all': 10.601, 'cp1-power': 0.0, 'cp2-power': 0.0}, 'module_update_completed': True}
2023-06-30 11:35:21,522 - {control.data:350} - {INFO:MainThread} - device0
{'name': 'MQTT', 'type': 'mqtt', 'id': 0, 'configuration': {}}
2023-06-30 11:35:21,524 - {control.data:352} - {INFO:MainThread} - component0
{'name': 'EVU Zähler', 'type': 'counter', 'id': 0, 'configuration': {}}
2023-06-30 11:35:21,524 - {control.data:350} - {INFO:MainThread} - device1
{'name': 'SMA Sunny Boy', 'type': 'sma_sunny_boy', 'id': 1, 'configuration': {'ip_address': '192.168.0.6'}}
2023-06-30 11:35:21,525 - {control.data:352} - {INFO:MainThread} - component3
{'name': 'Sma Sunny Boy/Tripower Wechselrichter', 'type': 'inverter', 'id': 3, 'configuration': {'hybrid': False, 'version': 0}}
2023-06-30 11:35:21,526 - {control.data:324} - {INFO:MainThread} -
2023-06-30 11:35:21,527 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-06-30 11:35:21,529 - {control.algorithm.algorithm:31} - {INFO:MainThread} - **Mindestrom setzen**
2023-06-30 11:35:21,535 - {control.algorithm.algorithm:33} - {INFO:MainThread} - **Sollstrom setzen**
2023-06-30 11:35:21,539 - {control.counter:211} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 7188.0W
2023-06-30 11:35:21,540 - {control.counter:470} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 7188.0W
2023-06-30 11:35:21,541 - {control.algorithm.algorithm:39} - {INFO:MainThread} - **PV-geführten Strom setzen**
2023-06-30 11:35:21,545 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-06-30 11:35:21,549 - {modules.common.component_context:24} - {DEBUG:cp1} - Update Komponente ['Ladepunkt']
2023-06-30 11:35:21,552 - {modules.common.component_context:24} - {DEBUG:cp2} - Update Komponente ['Ladepunkt']
2023-06-30 11:35:21,587 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-06-30 11:35:21,805 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-06-30 11:35:21,864 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-06-30 11:35:25,890 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-06-30 11:35:30,904 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-06-30 11:35:30,905 - {root:64} - {INFO:MainThread} - # ***Start***
Beitrag von LenaK »
Die Hardware wird nicht erkannt, bitte ein Support-Ticket unter Verweis auf den Forumsbeitrag erstellen.
MartinH
ok, habe ich gemacht
lessthanmore
Beitrag von lessthanmore »
Mit dem aktuellen Release kommt die Bitte den Nutzungsbedingungen und Datenschutzerklärung zuzustimmen.
Ich kann den Nutzungsbedingungen aber nicht zustimmen. Ich kann da so oft draufklicken wie ich will, es passiert nichts.
Ich kann aber auch nichts anderes mehr machen, da die Seite allem vorangeschaltet ist.
Wie kann ich jetzt bspw. ein Update machen oder überhaupt meine owb nutzen?
Ihaglc
Has thanked: 26 times
Been thanked: 14 times
Beitrag von Ihaglc »
Kann ich bestätigen.
Nach Update auf den aktuellen Master, wird man gezwungen die Nutzungsbedingungen zu akzeptieren.
Dies ist aber nicht möglich. da die Eingabe nicht gespeichert wird.
Wie komme ich hier wieder raus?
Ein Restore ist ja nicht möglich, weil man im "System - Rechtliches Nutzungsbedingungen & Datenschutzerklärung" hängen bleibt...
Gibt es ein Kommando hierfür?
Vielen Dank
Thomas
PV Modul JaSolar
WR Solaredge SE7K Hybrid
Speicher LG Resu13
EV Ford Mustang Mach E
Has thanked: 19 times
Been thanked: 135 times
Ist im master inzwischen behoben. Das Update muss dann über die Kommandozeile gestartet werden:
cd /var/www/html/openWB
git fetch origin
git checkout --force master
git reset --hard origin/master
sudo reboot
Ihaglc
Vielen Dank, Lutz
hat geklappt. :)
bin jetzt auf aktuellem Stand 2023-06-30 12:52:17 +0200 [3a966672e]
Thomas
PV Modul JaSolar
Speicher LG Resu13
NicolasGlatz
Beitrag von NicolasGlatz »
gibt es einen neuen Download Link?
hier https://openwb.de/uploads/openWB-2-rc1.img.gz bekomme ich einen 404
habe ich es richtig verstanden, den Download entpacken und dann damit auf die SD Karte übertragen?
https://www.heise.de/download/product/w ... ager-92033
mehr nicht?
ich will die 2.0 eigentlich "nur" um insgesamt 3 Wechselrichter einzubinden
Gruß Nicolas
aktuelle Ausstattung:
2* 13kw Tesla Powerwall
Walmdach 4-seitig + Garage gesamt 21kwp
1* SolarEdge Wechselrichter l
2* Growatt Wechselrichter
1* openWB Series 2
1* "DaheimLaden" mit ocpp zu Charge@friends
