Rückmeldungen 2.1.6 Release & Release 1
cgiesche
OCPP Feature
Beitrag von cgiesche »
ich habe mal einen Teil der OCPP-Features getestet und mir sind bislang folgende Dinge aufgefallen:
1. (OCPP 2.0.1) Nach der Auswahl von OCPP 2.0.1 sendet die OpenWB trotzdem OCPP 1.6 Payload (damit war mein Test Richtung 2.0.1 dann auch schon beendet):
  "5ae6057b-81b3-4b41-b7af-59b3fefef1cf",
  "BootNotification",
    "chargePointModel": "internal_openwb",
    "chargePointVendor": "openWB",
    "firmwareVersion": "2.1.6-Patch.1",
    "meterSerialNumber": "240576713"
2. (OCPP 1.6) Die Wallbox schickt (solange kein Fahrzeug angeschlossen ist) nach der ersten BootNotification anstelle von Heartbeats alle 5 Minuten weitere BootNotifications:
Request 1: [2,"dd2d2fa9-161a-4395-9603-a6f86ca3725b","BootNotification",{"chargePointModel":"internal_openwb","chargePointVendor":"openWB","firmwareVersion":"2.1.6-Patch.1","meterSerialNumber":"240576713"}]
Response 1: [3,"dd2d2fa9-161a-4395-9603-a6f86ca3725b",{"status":"Accepted","currentTime":"2024-12-16T09:50:02.2152762+01:00","interval":300}]
Request 2: [2,"00df8f82-79f2-4aaa-9502-c47c591c9f7e","BootNotification",{"chargePointModel":"internal_openwb","chargePointVendor":"openWB","firmwareVersion":"2.1.6-Patch.1","meterSerialNumber":"240576713"}]
Response 2: [3,"00df8f82-79f2-4aaa-9502-c47c591c9f7e",{"status":"Accepted","currentTime":"2024-12-16T09:55:01.8598552+01:00","interval":300}]
3. (OCPP 1.6) Die Wallbox startet (wenn ein Fahrzeug angesteckt ist) eine Transaktion, sendet Heartbeats und Metervalues, aber auch immer wieder BootNotifications
Request 1: [2,"5ded68d3-038b-4582-ba00-58e4396630e1","StartTransaction",{"connectorId":9,"idTag":"","meterStart":3954,"timestamp":"2024-12-16T10:11:31Z"}]
Response 1: [3,"5ded68d3-038b-4582-ba00-58e4396630e1",{"idTagInfo":{"status":"Accepted"},"transactionId":1337}]
Request 2: [2,"9bb57a0d-2035-4a46-9b5a-283d25891861","BootNotification",{"chargePointModel":"internal_openwb","chargePointVendor":"openWB","firmwareVersion":"2.1.6-Patch.1","meterSerialNumber":"240576713"}]
Response 2: [3,"9bb57a0d-2035-4a46-9b5a-283d25891861",{"status":"Accepted","currentTime":"2024-12-16T10:15:01.8751881+01:00","interval":300}]
Request 3: [2,"94b88cef-f295-40a2-a3bd-25d8c82f274c","Heartbeat",{}]
Response 3: [3,"94b88cef-f295-40a2-a3bd-25d8c82f274c",{"currentTime":"2024-12-16T10:15:03.9039156+01:00"}]
Request 4: [2,"fa9baec7-f3ac-4290-8a27-b371989fdafd","MeterValues",{"connectorId":9,"meterValue":[{"timestamp":"2024-12-16T10:20:06Z","sampledValue":[{"value":"3954","context":"Sample.Periodic","format":"Raw","measurand":"Energy.Active.Import.Register","unit":"Wh"}]}]}]
Und so weiter. Zu jedem Heartbeat gibt es aber auch weiter BootNotifications.
Ist das Verhalten so gewünscht? Normalerweise würde ich bei einer BootNotification davcon ausgehen, dass eine laufende Transaktion unerwartet beendet wurde.
gdfde
Has thanked: 13 times
Been thanked: 4 times
Re: Rückmeldungen 2.1.6 Release & Release 1
Beitrag von gdfde »
Was ist denn bei erlaubter Stromabweichung im Fahrzeug eingestellt?
Wenn das zu hoch ist, dann hat das auch Auswirkungen auf die Phasenumschaltung.
Ist bei mir auf 1 A eingestellt.
gdfde
Beitrag von gdfde »
mattberlin hat geschrieben: So Dez 15, 2024 2:41 pm Ich bin gerade von Sofortladen auf PV-Laden gewechselt.
Statt das Laden abzuschalten, wird mit 6 A weitergeladen und es beginnt die Umschaltverzögerung von 3 auf 1 Phase zu laufen.
Die PV-Erzeug ist mi 70 W gaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaanz weit weg vom Schwellwert für einphasiges Laden.
Die WB hätte aus meiner Sicht das Laden sofort beenden müssen.
Das war auch in den vorigen Versionen schon so.
gdfde
Beitrag von gdfde »
aiole hat geschrieben: Mo Dez 16, 2024 8:41 am
Mindest-SoC heißt nicht, dass dieser so schnell wie möglich erreicht werden soll. Bei mir reicht, wenn der irgendwann früh erreicht wird (gemütlich mit 1p). Dafür gibt es auch den extra Stromslider. -> Für das Thema am besten einen eigenen thread aufmachen.
Ein zusätzliches Thema ist aber, dass er dann alle x MInuten zwischen 1ph und 3ph hin- und herschaltet, wie eben die Zeiten bei der Phasenumschaltung definiert sind.
Somit wird der Ladevorgang alle paar Minuten unterbrochen.
Ich hab das so konfiguriert, dass bis auf 25 % Mindest SoC im PV Modus so schnell wie möglich geladen werden soll, damit ich das Auto auch kurzfristig nutzen kann, wenn ich spontan weg muß.
Für das gemütliche Laden habe ich Zeitladen, dass am nächsten Tag in der Fürh das EV den gewünschten SoC hat.
Has thanked: 75 times
Been thanked: 381 times
gdfde hat geschrieben: Mo Dez 16, 2024 9:55 am Ein zusätzliches Thema ist aber, dass er dann alle x MInuten zwischen 1ph und 3ph hin- und herschaltet, wie eben die Zeiten bei der Phasenumschaltung definiert sind.
Das mit dem Umschalten ist neu. Bislang wurde immer einphasig auf den Mindest-SoC geladen.
Da würde mich ja mal interessieren, was Du da mehr als ich eingestellt hast. Ich habe 32A eingestellt, das macht bei mir dann 7,2kW einphasig. Bei einer 11kW-openWB gehen da nur 16A, das resultiert dann in 3,6kW einphasig.
gdfde
Beitrag von gdfde »
Gero hat geschrieben: Mo Dez 16, 2024 11:35 am Das mit dem Umschalten ist neu. Bislang wurde immer einphasig auf den Mindest-SoC geladen.
Bei mir eben nicht, das ist schon seit mehreren Versionen vorher auch so...eigentlich schon seit jeher (zumindest 2.0), wenn ich mich richtig erinnere.
gdfde hat geschrieben: Mo Dez 16, 2024 9:55 am Da würde mich ja mal interessieren, was Du da mehr als ich eingestellt hast. Ich habe 32A eingestellt, das macht bei mir dann 7,2kW einphasig. Bei einer 11kW-openWB gehen da nur 16A, das resultiert dann in 3,6kW einphasig.
Ich hab 16 A eingestellt, aber das funktioniert eben nicht, es wird hin- und hergeschalten zwischen 1ph und 3ph.
PV Ladeeinstellung steht auf AUtomatik.
32 A ist in Österreich nicht erlaubt wegen Schieflast...ist das bei dir kein Thema?
schrej
Beitrag von schrej »
bei mir bietet die OpenWB (Stand 2.1.5 Release Patch 1) keinen Release-Update auf 2.1.6 an, auch nicht nach Aktualisierung der Versionsinfos.
Ist das so beabsichtigt?
PV 5,2 kWp, Kostal Plenticore 8.5, BYD HVS 7.7, KSEM, OpenWB Standard+, Homeassistant mit zahlreichen WLAN (Tasmota-flashed), Zigbee, Bluetooth & DECT Devices, Volvo XC40 Recharge Single Extended Range MJ24
Been thanked: 170 times
Beitrag von LenaK »
capo hat geschrieben: Di Dez 03, 2024 10:54 am nochmal reproduziert, jetzt mit main-log
- PV-Laden
- 6 A Dauerstrom
- autom. Phasenumschaltung steht auf 8/8 Min.
- es wird an einer secondary openWB 2 geladen
Es erfolgt keine Phasenumschaltung nach 8 Min., obwohl genug PV-Überschuss verfügbar ist. In der Anzeige wird kein Timer für Phasenumschaltung angezeigt, wie dies sonst ohne eingestellten Dauerstrom erfolgt. Der Ladevorgang wurde mit 6A Dauerstrom gestartet.
Ist im Master behoben.
KLez
Been thanked: 5 times
Beitrag von KLez »
Ich hatte die Box auf Werkseinstellung zurückgesetzt und anschließend ein Update auf Release 2.1.6, Patch 1 durchgeführt.
Danach habe ich einen "Virtuellen Zähler" und einen "internen OpenWB" Ladepunkt angelegt. Seitdem bekomme ich immer wieder die folgende Fehlermeldung im Status:
<class 'Exception'> ("modules.common.modbus <class 'Exception'> modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response", 'Anhaltender Fehler beim Auslesen von EVSE und/oder Zähler. Lade- und Stecker-Status werden zurückgesetzt.')
Wie lässt sich das beheben?
Der Zähler in der Box scheint sich auch ständig zu restarten.
Sobald ich den "Internen OpenWB" Ladepunkt lösche oder die Software wieder auf Werkseinstellungen zurücksetze, hört auch das restarten des Eastron Zählers auf.
Ich habe sogar das offizielle Release Image neu auf die SD Karte geflasht...
Der Fehler kommt aber wieder, sobald ich den "Internen OpenWB" Ladepunkt konfiguriert habe.
hominidae
Has thanked: 44 times
Been thanked: 32 times
Beitrag von hominidae »
schrej hat geschrieben: Di Dez 17, 2024 10:45 am Hallo,
...kann ich so nicht bestätigen.
Bei mir ist der Eintrag da...allerdings tauchte er nicht gleich nach dem Update der Versionsinfos auf.
