Feedback openWB software2 2.1.1 Beta 1
Frank-H
Has thanked: 40 times
Been thanked: 47 times
Re: Feedback openWB software2 2.1.1 Beta 1
Beitrag von Frank-H »
Im aktuellen Master (25.8.23, 13:34) wird durchgängig alle paar Sekunden im Mainlog folgende Fehlermeldung angezeigt:
2023-08-26 14:35:56,947 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.95
2023-08-26 14:35:58,628 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 50.0
2023-08-26 14:36:02,020 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.97
2023-08-26 14:36:05,383 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.95
2023-08-26 14:36:08,752 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.97
2023-08-26 14:36:12,504 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.95
2023-08-26 14:36:14,219 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 50.0
2023-08-26 14:36:17,474 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.95
Wenn dann das Fahrzeug angeschlossen wird, kommen folgende Fehler:
2023-08-26 15:48:02,215 - {helpermodules.setdata:351} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/powers, Payload [1390.98, 0.0, 3.5] sollte ein Float sein.
2023-08-26 15:48:03,895 - {helpermodules.setdata:351} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/powers, Payload [1390.64, 0.0, 3.56] sollte ein Float sein.
2023-08-26 15:48:03,912 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.92
2023-08-26 15:48:05,612 - {helpermodules.setdata:351} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/powers, Payload [1391.42, 0.0, 3.55] sollte ein Float sein.
2023-08-26 15:48:07,333 - {helpermodules.setdata:351} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/powers, Payload [1391.31, 0.0, 3.52] sollte ein Float sein.
2023-08-26 15:48:07,351 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.97
2023-08-26 15:48:09,042 - {helpermodules.setdata:351} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/powers, Payload [1391.11, 0.0, 3.42] sollte ein Float sein.
2023-08-26 15:48:09,056 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/3/get/frequency, 49.92
2023-08-26 15:48:11,525 - {helpermodules.setdata:351} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/powers, Payload [1391.17, 0.0, 3.63] sollte ein Float sein.
Das Fahrzeug lädt aber PV-Überschuss einwandfrei.
OpenDTU fusion
VW ID.4 (77 kwh)
Elchkopp
Has thanked: 23 times
Been thanked: 71 times
Beitrag von Elchkopp »
Und ich habe wieder ein extremes Beispiel von Lastspitzen während der 1p/3p-Umschaltung, das sieht im Diagramm wie folgt aus:
Los geht es um 16:58:51
Ich glaube nicht, dass das auf Dauer gut für die Relais ist, wenn die Box immer so viele Schaltungen vollzieht, nur um von 1p auf 3p zu kommen. Und ich vermute, dass es (auch) an der Pro liegt, denn mit der Series2 hatte ich dieses Phänomen während der Beta-Phase nicht beobachten können.
Sonstige Daten
Standalone 2.1.1 Beta 1
OpenWB Pro
Tesla Model 3
Hier die komplette Log-Dateien dazu:
main.log
(883.12 KiB) 111-mal heruntergeladen
Elchkopp
Und bei der Rückschaltung von 3p auf 1p das selbe Spiel:
17:40:11 geht es los um gegen 17:43:31 ist der Spuk vorbei (für das Finden in der Log-Datei)
Dazu die Log-Datei:
main (3).log
(3.26 MiB) 126-mal heruntergeladen
Was mir auch auffällt, ist die komische Delle bei bei ca. 17:14 Uhr - warum auch immer die Wallbox da die Ladung unterbrochen hat.
Hier die Log-Datei zu dem Ereignis:
main (4).log
(193.11 KiB) 135-mal heruntergeladen
Dein Auto braucht sehr lange, um mit den drei Phasen zu laden. Dann wird in der Zwischenzeit erneut eine Umschaltung getriggert. Bitte die Einstellung Mindestzeit zwischen Umschaltungen unter Konfiguration -> Fahrzeuge -> Fahrzeug-Profile erhöhen.
Das Problem im zweiten Log ist noch in Klärung.
FaKaBeFr
Beitrag von FaKaBeFr »
In der Nacht hat openWb den Vogel abgeschossen.
Gestern Abend hatte openWB trotz Dunkelheit weitergeladen. :oops:
PV Modus war eingeschaltet. Ich hatte dann direkt auf "Stop" gestellt.
Im log steht davon nichts!
Heute werde ich gegen 05:20 wach, meldet meine Hyundai App, Ladung in 10min beendet.
Bitte was? wie Ladung? Hat openWb trotz "Stop" Befehl einfach angefangen zu laden.
Die 2er Version ist eine Katastrophe! :evil:
openWB series2 standard+ mit PV-Anlage
KLez
Been thanked: 5 times
Beitrag von KLez »
Katastrophe ist vielleicht übertrieben, aber wie man an den Häufungen hier in den Threads sieht, gibt es leider noch einige Fehler.
Und wenn es nur solche Dinger hier sind:
2023-08-27 17:55:04,960 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/1/get/frequency, 49.99
2023-08-27 17:55:08,281 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/1/get/frequency, 49.94
2023-08-27 17:55:09,955 - {helpermodules.setdata:371} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/chargepoint/1/get/frequency, 49.99
Das main.log ist voll davon. Sowas sollte doch in nahezu jeder Testphase sofort auffallen.
Zuletzt geändert von KLez am Mo Aug 28, 2023 8:59 am, insgesamt 3-mal geändert.
Has thanked: 227 times
Been thanked: 248 times
FaKaBeFr hat geschrieben: So Aug 27, 2023 1:28 pm Die 2er Version ist eine Katastrophe! :evil:
Etwas Zurückhaltung wäre angebracht. Mittlerweile laufen hunderte sw2.x problemfrei. Die Testphase ging über ein halbes Jahr.
Bei Problemen sind Infos zu den Einstellungen und Logs wichtig, damit die Entwickler:innen prüfen können.
Elchkopp
Also irgendwie ist in der Regelung aktuell noch der Wurm drin - zumindest bei mir. Es läuft noch nicht rund.
Ich hatte heute wieder eine Ladeunterbrechung und kann mir nicht erklären, warum eigentlich.
Hardware: Standalone 2.1.1 Beta und OpenWB Pro
Einmal der Screenshot, passiert so gegen 12:02Uhr, angestecktes Auto war der Cupra Born:
Und hier die Log-Datei dazu:
main1.txt
(1.08 MiB) 91-mal heruntergeladen
Und dann, als ich die Auto umgesteckt und diesmal der Tesla MOdel 3 dran hing, folgende Situation:
Zum Einen wieder die Spitze während der 1p/3p-Umschaltung (ca. 12:13 Uhr) und danach aber deutliche Schwinger (ca. 12:15 Uhr), die eigentlich nicht sein müssten:
main.log
(2.7 MiB) 120-mal heruntergeladen
Falls ihr noch mehr Daten braucht, bitte melden. Würde mich über eine kurze Rückmeldung freuen...
Sascha
Been thanked: 167 times
Beitrag von LenaK »
Elchkopp hat geschrieben: Mo Aug 28, 2023 10:41 am Also irgendwie ist in der Regelung aktuell noch der Wurm drin - zumindest bei mir. Es läuft noch nicht rund.
main1.txt
main.log
Sascha
Die Schankungen entsprechen ca 600W, was bei 3phasigem Laden einer Änderung des Sollstroms um 1A entspricht. Der Sollstrom wird nur in ganzen A-Schritten umgesetzt. Genauer kann die openWB nicht regeln.
Elchkopp
LenaK hat geschrieben: Di Aug 29, 2023 10:48 am Die Schankungen entsprechen ca 600W, was bei 3phasigem Laden einer Änderung des Sollstroms um 1A entspricht. Der Sollstrom wird nur in ganzen A-Schritten umgesetzt. Genauer kann die openWB nicht regeln.
Danke für die Rückmeldung Lena. Mit anderen Worten: die Schwankungen sind normal ;)
Kannst Du noch was zu dem Spitzen beim Umschalten der Phasen (1p zu 3p) sagen? Auch normal? Oder nur ein Phänomen der Pro? Bei der 1.9er-Version gab es diese Spitzen nicht…
weichi
Beitrag von weichi »
Wenn kommuniziert würde, was gefixt sein wurde, so könnte ein Test auch gezielter durchgeführt werden.
Ansonsten läufen die eigentlichen Rückmeldung aus dem Ruder.
openWB series 2 - SW2.x
Victron Anlage mit 11kW
überwiegend PV Überschussladung
