BMW i5 SoC geht nicht
chwunder
Beitrag von chwunder »
Hallo Community,
seit ca. 3 Monaten habe ich einen neuen BMW i5. Ich würde gerne den SoC aus dem Fahrzeug auslesen und habe folgendes versucht:
Benutzername und Kennwort habe ich aus der MyBMW App genommen. VIN ist eh klar und Captcha habe ich laut Doku erstellt. Gibt es etwas, was ich vergessen habe.
Leider bekomme ich aber immer folgendes:
es.bmwbc.api:175} - {ERROR:fetch soc_ev3} - bmwbc.fetch_soc: requestData Error, vnum: 3 err=MyBMWAuthError('HTTPStatusError: invalid_client - Client authentication failed (e.g., login failure, unknown client, no client authentication included or unsupported authentication method)'), type(err)=<class 'bimmer_connected.models.MyBMWAuthError'>
2025-09-30 10:04:25,891 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev3} - BMW & Mini : FaultState FaultStateLevel.ERROR, FaultStr <class 'bimmer_connected.models.MyBMWAuthError'> ('HTTPStatusError: invalid_client - Client authentication failed (e.g., login failure, unknown client, no client authentication included or unsupported authentication method)',), Traceback:
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 411, in raise_for_status_event_handler
    response.raise_for_status()
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_models.py", line 763, in raise_for_status
    raise HTTPStatusError(message, request=request, response=self)
httpx.HTTPStatusError: Client error '401 Unauthorized' for url 'https://customer.bmwgroup.com/gcdm/oauth/authenticate'
For more information check: https://developer.mozilla.org/en-US/docs/Web/HTTP/Status/401
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 66, in update
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 117, in _get_carstate_by_source
  File "/var/www/html/openWB/packages/modules/vehicles/bmwbc/soc.py", line 20, in updater
    return api.fetch_soc(
  File "/var/www/html/openWB/packages/modules/vehicles/bmwbc/api.py", line 188, in fetch_soc
    soc, range = loop.run_until_complete(_fetch_soc(user_id, password, vin, captcha_token, vnum))
  File "/usr/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete
    return future.result()
  File "/var/www/html/openWB/packages/modules/vehicles/bmwbc/api.py", line 141, in _fetch_soc
    await account.get_vehicles()
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/account.py", line 114, in get_vehicles
    await self._init_vehicles()
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/account.py", line 86, in _init_vehicles
    vehicle_list_response = await client.post(
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1905, in post
    return await self.request(
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1585, in request
    return await self.send(request, auth=auth, follow_redirects=follow_redirects)
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1674, in send
    response = await self._send_handling_auth(
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1699, in _send_handling_auth
    request = await auth_flow.__anext__()
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 88, in async_auth_flow
    await self.login()
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 137, in login
    token_data = await self._login_row_na()
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 199, in _login_row_na
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1702, in _send_handling_auth
    response = await self._send_handling_redirects(
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1760, in _send_handling_redirects
    raise exc
  File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1742, in _send_handling_redirects
    await hook(response)
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 413, in raise_for_status_event_handler
    await handle_httpstatuserror(ex, module="AUTH", log_handler=_LOGGER)
  File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/utils.py", line 89, in handle_httpstatuserror
    raise _ex_to_raise(_err_message) from ex
bimmer_connected.models.MyBMWAuthError: HTTPStatusError: invalid_client - Client authentication failed (e.g., login failure, unknown client, no client authentication included or unsupported authentication method)
2025-09-30 10:09:28,235 - {modules.common.configurable_vehicle:56} - {DEBUG:fetch soc_ev3} - Vehicle Instance <class 'modules.vehicles.bmwbc.config.BMWbc'>
2025-09-30 10:09:28,240 - {modules.common.configurable_vehicle:57} - {DEBUG:fetch soc_ev3} - Calculated SoC-State CalculatedSocState(imported_start=0, manual_soc=None, soc_start=0)
2025-09-30 10:09:28,252 - {modules.common.configurable_vehicle:58} - {DEBUG:fetch soc_ev3} - Vehicle Update Data VehicleUpdateData(plug_state=True, charge_state=True, imported=1460661.99, battery_capacity=19000, efficiency=90, soc_from_cp=None, timestamp_soc_from_cp=None, soc_timestamp=None)
2025-09-30 10:09:28,256 - {modules.common.configurable_vehicle:59} - {DEBUG:fetch soc_ev3} - General Config GeneralVehicleConfig(use_soc_from_cp=False, request_interval_charging=300, request_interval_not_charging=43200, request_only_plugged=False)
2025-09-30 10:09:28,260 - {modules.common.component_context:26} - {DEBUG:fetch soc_ev3} - Update Komponente ['BMW & Mini ']
2025-09-30 10:09:28,264 - {asyncio:59} - {DEBUG:fetch soc_ev3} - Using selector: EpollSelector
Habt Ihr eine Idee
rleidner
Has thanked: 101 times
Been thanked: 200 times
Re: BMW i5 SoC geht nicht
Beitrag von rleidner »
chwunder hat geschrieben: Di Sep 30, 2025 8:20 am Habt Ihr eine Idee
Ja, BMW hat das bisherige Verfahren für Anwendungen wie openWB abgeschaltet, siehe auch : viewtopic.php?p=133390#p133390
Has thanked: 166 times
Been thanked: 392 times
Alternativ geht eine Direktauslesung mit der openWB Pro über das Typ2 Kabel.
