2026-02-22 14:52:20,891 - {root:161} - {INFO:MainThread} - # ***Start***
2026-02-22 14:52:20,902 - {root:61} - {DEBUG:MainThread} - Lock für handler10Sec erworben.
2026-02-22 14:52:21,003 - {modules.common.component_context:29} - {DEBUG:device0} - Update Komponente ['Virtueller Zähler']
2026-02-22 14:52:21,013 - {modules.common.component_context:29} - {DEBUG:set values cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:21,016 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=None, exported=None, power=0, frequency=50, serial_number=None)
2026-02-22 14:52:22,628 - {modules.chargepoints.external_openwb.chargepoint_module:85} - {DEBUG:set values cp1} - Empfange MQTT Daten für Ladepunkt 1: {'openWB/internal_chargepoint/0/get/error_timestamp': None, 'openWB/internal_chargepoint/0/get/voltages': [221.43, 221.49, 222.2], 'openWB/internal_chargepoint/0/get/currents': [0, 0, 0], 'openWB/internal_chargepoint/0/get/frequency': 49.92, 'openWB/internal_chargepoint/0/get/power_factors': [0.0, 0.0, 0.0], 'openWB/internal_chargepoint/0/get/imported': 0, 'openWB/internal_chargepoint/0/get/exported': 0, 'openWB/internal_chargepoint/0/get/power': 0, 'openWB/internal_chargepoint/0/get/powers': [0, 0, 0], 'openWB/internal_chargepoint/0/get/phases_in_use': 1, 'openWB/internal_chargepoint/0/get/charge_state': False, 'openWB/internal_chargepoint/0/get/plug_state': False, 'openWB/internal_chargepoint/0/get/evse_current': 0, 'openWB/internal_chargepoint/0/get/max_evse_current': None, 'openWB/internal_chargepoint/0/get/serial_number': '631205', 'openWB/internal_chargepoint/0/get/fault_str': 'Kein Fehler.', 'openWB/internal_chargepoint/0/get/fault_state': 0, 'openWB/internal_chargepoint/0/get/vehicle_id': None, 'openWB/internal_chargepoint/0/get/rfid': None, 'openWB/internal_chargepoint/0/get/version': '2.1.9', 'openWB/internal_chargepoint/0/get/current_branch': 'Release', 'openWB/internal_chargepoint/0/get/current_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]'}
2026-02-22 14:52:22,653 - {modules.common.store._api:26} - {DEBUG:set values cp1} - Raw data ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[221.43, 221.49, 222.2], frequency=49.92, imported=0, exported=0, power=0, serial_number=631205, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, max_evse_current=None, vehicle_id=None, current_branch=Release, current_commit=2026-01-19 13:34:35 +0100 [91b8c3a05], version=2.1.9, evse_signaling=None, max_charge_power=None, max_discharge_power=None)
2026-02-22 14:52:22,701 - {modules.common.component_context:29} - {DEBUG:update values cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:22,704 - {modules.common.store._api:31} - {INFO:update values cp1} - Saving ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[221.43, 221.49, 222.2], frequency=49.92, imported=0, exported=0, power=0, serial_number=631205, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, max_evse_current=None, vehicle_id=None, current_branch=Release, current_commit=2026-01-19 13:34:35 +0100 [91b8c3a05], version=2.1.9, evse_signaling=None, max_charge_power=None, max_discharge_power=None)
2026-02-22 14:52:22,919 - {modules.common.component_context:29} - {DEBUG:component0} - Update Komponente ['Virtueller Zähler']
2026-02-22 14:52:22,923 - {modules.common.simcount._simcount:42} - {DEBUG:component0} - Previous state: SimCounterState(timestamp=1771768332.5993183, power=0, imported=0.0, exported=0)
2026-02-22 14:52:22,926 - {modules.common.simcount._calculate:11} - {DEBUG:component0} - time passed: 0.00286787, power1: 0, power2: 0
2026-02-22 14:52:22,930 - {modules.common.simcount._calculate:27} - {DEBUG:component0} - power did not change sign. Total energy: 0
2026-02-22 14:52:22,932 - {modules.common.simcount._simcount:65} - {DEBUG:component0} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1771768342.923642, power=0, imported=0.0, exported=0)
2026-02-22 14:52:22,937 - {modules.common.store._api:31} - {INFO:component0} - Saving CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=0.0, exported=0, power=0, frequency=50, serial_number=None)
2026-02-22 14:52:23,136 - {control.counter:163} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [35.0, 35.0, 35.0]A
2026-02-22 14:52:23,139 - {control.counter:190} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 24000W
2026-02-22 14:52:23,149 - {control.chargepoint.chargepoint:72} - {INFO:MainThread} - LP 1: Keine Ladung, da der Ladepunkt gesperrt ist.
2026-02-22 14:52:23,157 - {modules.common.simcount._simcount:42} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1771768333.1317785, power=0, imported=0.0, exported=0)
2026-02-22 14:52:23,166 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.0027849, power1: 0, power2: 0
2026-02-22 14:52:23,169 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 0
2026-02-22 14:52:23,180 - {modules.common.simcount._simcount:65} - {DEBUG:MainThread} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1771768343.1574278, power=0, imported=0.0, exported=0)
2026-02-22 14:52:23,194 - {control.data:262} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=False, power_limit_mode='no_limit', bat_control_permitted=False), get=Get(power_limit_controllable=False, soc=0, daily_exported=0, daily_imported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, exported=0, power=0), set=Set(charging_power_left=0, power_limit=None, regulate_up=False, hysteresis_discharge=False))
2026-02-22 14:52:23,206 - {control.data:263} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=0, daily_exported=0, power=0, imported=0, exported=0))
2026-02-22 14:52:23,215 - {control.data:295} - {INFO:MainThread} - cp1
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, limit=LoadmanagementLimit(message=None, limiting_value=None), min_current=6, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, template_phases=None, timestamp_charge_start=None, timestamp_chargemode_changed=None, timestamp_last_phase_switch=0, timestamp_phase_switch_buffer_start=None, timestamp_switch_on_off=None), get=Get(charge_state=False, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=38.0), current_branch='Release', current_commit='2026-01-19 13:34:35 +0100 [91b8c3a05]', currents=[0, 0, 0], daily_imported=0.0, daily_exported=0.0, error_timestamp=None, evse_current=0, evse_signaling=None, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, max_charge_power=None, max_discharge_power=None, max_evse_current=None, phases_in_use=1, plug_state=False, power=0, powers=[0, 0, 0], rfid_timestamp=None, rfid=None, serial_number='631205', soc=None, soc_timestamp=None, state_str='Keine Ladung, da der Ladepunkt gesperrt ist.', vehicle_id=None, version='2.1.9', voltages=[221.43, 221.49, 222.2]), set=Set(charge_template=ChargeTemplate(data=ChargeTemplateData(id=0, name='Standard-Lade-Profil', prio=True, load_default=False, time_charging=TimeCharging(active=False, plans=[]), chargemode=Chargemode(selected='instant_charging', eco_charging=EcoCharging(current=6, dc_current=145, limit=Limit(selected='none', amount=50000, soc=50), max_price=0.0002, phases_to_use=3), pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, feed_in_limit=False, limit=Limit(selected='soc', amount=50000, soc=100), min_current=0, min_soc_current=10, min_soc=0, phases_to_use=0, phases_to_use_min_soc=3), scheduled_charging=ScheduledCharging(plans=[]), instant_charging=InstantCharging(current=20, dc_current=145, limit=Limit(selected='none', amount=1000, soc=50), phases_to_use=3)))), current=0, energy_to_charge=0, ev_prev=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', charged_energy_by_source={'bat': 0, 'cp': 0, 'grid': 0, 'pv': 0}, costs=0, end=None, exported_at_mode_switch=0, exported_at_plugtime=0, exported_since_mode_switch=0, exported_since_plugged=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, timestamp_mode_switch=None, ev=-1, prio=False, rfid=None, serial_number=None, soc_at_start=None, soc_at_end=None, range_at_start=None, range_at_end=None), manual_lock=True, phases_to_use=1, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, current_prev=0, target_current=0, charging_ev_data=<control.ev.ev.Ev object at 0x6de9aaa8>, ocpp_transaction_id=None, charge_state_prev=False), config=Config(configuration={'duo_num': 0, 'ip_address': 'localhost', 'mode': 'pro_plus'}, ev=0, name='Interne openWB', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=False, id=1, ocpp_chargebox_id=None))
2026-02-22 14:52:23,249 - {control.data:295} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans=[], wait_for_charging_end=False), charging_type='AC', id=0, max_current_multi_phases=16, max_current_single_phase=16, dc_max_current=435, name='Ladepunkt-Profil', disable_after_unplug=True, valid_tags=[])
2026-02-22 14:52:23,265 - {control.data:295} - {INFO:MainThread} - counter0
CounterData(config=Config(max_power_errorcase=7000, max_currents=[35, 35, 35], max_total_power=24000), get=Get(powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], frequency=50, daily_exported=0, daily_imported=0, imported=0.0, exported=0, fault_state=0, fault_str='Kein Fehler.', power=0, serial_number=None), set=Set(error_timer=None, reserved_surplus=0, released_surplus=0, raw_power_left=24000, raw_currents_left=[35.0, 35.0, 35.0], surplus_power_left=0))
2026-02-22 14:52:23,270 - {control.data:267} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(home_consumption_source_id=None, consider_less_charging=False), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=0, smarthome_power_excluded_from_home_consumption=0, invalid_home_consumption=0, daily_yield_home_consumption=0, imported_home_consumption=0.0, disengageable_smarthome_power=0))
2026-02-22 14:52:23,277 - {control.data:295} - {INFO:MainThread} - ct0
2026-02-22 14:52:23,285 - {control.data:295} - {INFO:MainThread} - ct1
ChargeTemplateData(id=0, name='Lade-Profil', prio=False, load_default=False, time_charging=TimeCharging(active=False, plans=[]), chargemode=Chargemode(selected='instant_charging', eco_charging=EcoCharging(current=6, dc_current=145, limit=Limit(selected='none', amount=50000, soc=50), max_price=0.0002, phases_to_use=3), pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, feed_in_limit=False, limit=Limit(selected='none', amount=50000, soc=50), min_current=0, min_soc_current=10, min_soc=0, phases_to_use=0, phases_to_use_min_soc=3), scheduled_charging=ScheduledCharging(plans=[]), instant_charging=InstantCharging(current=16, dc_current=145, limit=Limit(selected='none', amount=50000, soc=50), phases_to_use=3)))
2026-02-22 14:52:23,292 - {control.data:295} - {INFO:MainThread} - ev0
EvData(set=Set(soc_error_counter=0), charge_template=0, ev_template=1, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=38.0, soc_request_timestamp=1771699093.721366, soc_timestamp=1771699107.45, force_soc_update=False, range=186, fault_state=0, fault_str='Kein Fehler.'))
2026-02-22 14:52:23,296 - {control.data:295} - {INFO:MainThread} - et0
EvTemplateData(dc_min_current=0, dc_max_current=0, id=0, name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=10, max_current_single_phase=16, battery_capacity=82000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40, bidi=False)
2026-02-22 14:52:23,301 - {control.data:295} - {INFO:MainThread} - et1
EvTemplateData(dc_min_current=20, dc_max_current=150, id=1, name='HK-IP 101', max_current_multi_phases=16, max_phases=3, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=22000, min_current=6, max_current_single_phase=16, battery_capacity=70000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40, bidi=False)
2026-02-22 14:52:23,306 - {control.data:271} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(pv_charging=PvCharging(bat_power_reserve=200, bat_power_reserve_active=True, control_range=[0, 230], feed_in_yield=0, phase_switch_delay=7, bat_power_discharge=1000, bat_power_discharge_active=True, min_bat_soc=50, max_bat_soc=50, bat_mode='ev_mode', retry_failed_phase_switches=False, switch_off_delay=60, switch_off_threshold=0, switch_on_delay=30, switch_on_threshold=1500), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='primary', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp=None, http_api=False, mqtt_bridge=False, temporary_charge_templates_active=False, prices=Prices(bat=0.0002, cp=0, grid=0.0003, pv=0.00015), range_unit='km')
2026-02-22 14:52:23,312 - {control.data:272} - {INFO:MainThread} - general_data-display
primary
2026-02-22 14:52:23,315 - {control.data:273} - {INFO:MainThread} - graph_data
2026-02-22 14:52:23,318 - {control.data:276} - {INFO:MainThread} - optional_data
OptionalData(electricity_pricing=ElectricityPricing(configured=False, flexible_tariff=FlexibleTariff(get=PricingGet(fault_state=0, fault_str='Kein Fehler.', prices={})), grid_fee=GridFee(get=PricingGet(fault_state=0, fault_str='Kein Fehler.', prices={})), get=ElectricityPricingGet(next_query_time=None, _prices={})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x6de870e8>), led=Led(active=False), rfid=Rfid(active=False), dc_charging=False, ocpp=Ocpp(active=False, boot_notification_sent=False, _url=None, version='ocpp1.6'))
2026-02-22 14:52:23,324 - {control.data:278} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=False), get=Get(daily_exported=0, fault_str=0, fault_state=0, monthly_exported=0, yearly_exported=0, exported=0, power=0))
2026-02-22 14:52:23,327 - {control.data:295} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'backup_cloud': {'backup_before_update': True}, 'ip_address': '172.16.23.201', 'current_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]', 'current_branch': 'Release', 'current_branch_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]', 'current_missing_commits': [], 'installAssistantDone': True, 'dataprotection_acknowledged': True, 'datastore_version': [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107], 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'serial_number': 'owbd107pro10445', 'version': '2.1.9', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1771768333, 'time': '14:52:13', 'grid': 0.0, 'house-power': 0.0, 'charging-all': 0.0, 'cp1-power': 0.0, 'ev0-soc': 38.0}, 'secondary_auto_update': True, 'module_update_completed': True, 'mac_address': 'b8:27:eb:05:01:39'}
2026-02-22 14:52:23,336 - {control.data:308} - {INFO:MainThread} - device0
{'name': 'Virtuelles Gerät', 'type': 'virtual', 'vendor': 'generic', 'id': 0, 'configuration': {}}
2026-02-22 14:52:23,339 - {control.data:310} - {INFO:MainThread} - component0
{'name': 'Virtueller Zähler', 'info': {'manufacturer': None, 'model': None}, 'type': 'counter', 'id': 0, 'configuration': {'external_consumption': 0}}
2026-02-22 14:52:23,342 - {control.data:282} - {INFO:MainThread} -
2026-02-22 14:52:23,345 - {control.algorithm.algorithm:27} - {INFO:MainThread} - # Algorithmus
2026-02-22 14:52:23,347 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Mindestrom setzen**
2026-02-22 14:52:23,352 - {control.algorithm.algorithm:34} - {INFO:MainThread} - **Soll-Strom setzen**
2026-02-22 14:52:23,357 - {control.algorithm.algorithm:38} - {INFO:MainThread} - **PV-geführten Strom setzen**
2026-02-22 14:52:23,361 - {control.counter:253} - {DEBUG:MainThread} - Anpassen des Regelbereichs 115.0W
2026-02-22 14:52:23,365 - {control.counter:511} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 115.0W
2026-02-22 14:52:23,372 - {control.algorithm.algorithm:45} - {INFO:MainThread} - **Bidi-(Ent-)Lade-Strom setzen**
2026-02-22 14:52:23,376 - {control.counter:526} - {DEBUG:MainThread} - Nullpunktanpassung 0W
2026-02-22 14:52:23,379 - {control.algorithm.bidi_charging:16} - {DEBUG:MainThread} - Nullpunktanpassung 0W
2026-02-22 14:52:23,383 - {control.process:30} - {INFO:MainThread} - # Ladung starten.
2026-02-22 14:52:23,404 - {modules.common.component_context:29} - {DEBUG:set current cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:30,907 - {root:161} - {INFO:MainThread} - # ***Start***
2026-02-22 14:52:30,917 - {root:61} - {DEBUG:MainThread} - Lock für handler10Sec erworben.
2026-02-22 14:52:30,983 - {modules.common.component_context:29} - {DEBUG:device0} - Update Komponente ['Virtueller Zähler']
2026-02-22 14:52:30,993 - {modules.common.component_context:29} - {DEBUG:set values cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:30,990 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=None, exported=None, power=0, frequency=50, serial_number=None)
2026-02-22 14:52:32,160 - {modules.chargepoints.external_openwb.chargepoint_module:85} - {DEBUG:set values cp1} - Empfange MQTT Daten für Ladepunkt 1: {'openWB/internal_chargepoint/0/get/error_timestamp': None, 'openWB/internal_chargepoint/0/get/voltages': [221.6, 221.35, 222.27], 'openWB/internal_chargepoint/0/get/currents': [0, 0, 0], 'openWB/internal_chargepoint/0/get/frequency': 49.94, 'openWB/internal_chargepoint/0/get/power_factors': [0.0, 0.0, 0.0], 'openWB/internal_chargepoint/0/get/imported': 0, 'openWB/internal_chargepoint/0/get/exported': 0, 'openWB/internal_chargepoint/0/get/power': 0, 'openWB/internal_chargepoint/0/get/powers': [0, 0, 0], 'openWB/internal_chargepoint/0/get/phases_in_use': 1, 'openWB/internal_chargepoint/0/get/charge_state': False, 'openWB/internal_chargepoint/0/get/plug_state': False, 'openWB/internal_chargepoint/0/get/evse_current': 0, 'openWB/internal_chargepoint/0/get/max_evse_current': None, 'openWB/internal_chargepoint/0/get/serial_number': '631205', 'openWB/internal_chargepoint/0/get/fault_str': 'Kein Fehler.', 'openWB/internal_chargepoint/0/get/fault_state': 0, 'openWB/internal_chargepoint/0/get/vehicle_id': None, 'openWB/internal_chargepoint/0/get/rfid': None, 'openWB/internal_chargepoint/0/get/version': '2.1.9', 'openWB/internal_chargepoint/0/get/current_branch': 'Release', 'openWB/internal_chargepoint/0/get/current_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]'}
2026-02-22 14:52:32,195 - {modules.common.store._api:26} - {DEBUG:set values cp1} - Raw data ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[221.6, 221.35, 222.27], frequency=49.94, imported=0, exported=0, power=0, serial_number=631205, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, max_evse_current=None, vehicle_id=None, current_branch=Release, current_commit=2026-01-19 13:34:35 +0100 [91b8c3a05], version=2.1.9, evse_signaling=None, max_charge_power=None, max_discharge_power=None)
2026-02-22 14:52:32,263 - {modules.common.component_context:29} - {DEBUG:update values cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:32,266 - {modules.common.store._api:31} - {INFO:update values cp1} - Saving ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[221.6, 221.35, 222.27], frequency=49.94, imported=0, exported=0, power=0, serial_number=631205, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, max_evse_current=None, vehicle_id=None, current_branch=Release, current_commit=2026-01-19 13:34:35 +0100 [91b8c3a05], version=2.1.9, evse_signaling=None, max_charge_power=None, max_discharge_power=None)
2026-02-22 14:52:32,487 - {modules.common.component_context:29} - {DEBUG:component0} - Update Komponente ['Virtueller Zähler']
2026-02-22 14:52:32,491 - {modules.common.simcount._simcount:42} - {DEBUG:component0} - Previous state: SimCounterState(timestamp=1771768342.923642, power=0, imported=0.0, exported=0)
2026-02-22 14:52:32,494 - {modules.common.simcount._calculate:11} - {DEBUG:component0} - time passed: 0.00265758, power1: 0, power2: 0
2026-02-22 14:52:32,496 - {modules.common.simcount._calculate:27} - {DEBUG:component0} - power did not change sign. Total energy: 0
2026-02-22 14:52:32,499 - {modules.common.simcount._simcount:65} - {DEBUG:component0} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1771768352.4909196, power=0, imported=0.0, exported=0)
2026-02-22 14:52:32,503 - {modules.common.store._api:31} - {INFO:component0} - Saving CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=0.0, exported=0, power=0, frequency=50, serial_number=None)
2026-02-22 14:52:32,678 - {control.counter:163} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [35.0, 35.0, 35.0]A
2026-02-22 14:52:32,689 - {control.counter:190} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 24000W
2026-02-22 14:52:32,726 - {control.chargepoint.chargepoint:72} - {INFO:MainThread} - LP 1: Keine Ladung, da der Ladepunkt gesperrt ist.
2026-02-22 14:52:32,730 - {modules.common.simcount._simcount:42} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1771768343.1574278, power=0, imported=0.0, exported=0)
2026-02-22 14:52:32,746 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00265914, power1: 0, power2: 0
2026-02-22 14:52:32,749 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 0
2026-02-22 14:52:32,753 - {modules.common.simcount._simcount:65} - {DEBUG:MainThread} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1771768352.7303324, power=0, imported=0.0, exported=0)
2026-02-22 14:52:32,765 - {control.data:262} - {INFO:MainThread} - bat_all_data
2026-02-22 14:52:32,771 - {control.data:263} - {INFO:MainThread} - cp_all_data
2026-02-22 14:52:32,777 - {control.data:295} - {INFO:MainThread} - cp1
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, limit=LoadmanagementLimit(message=None, limiting_value=None), min_current=6, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, template_phases=None, timestamp_charge_start=None, timestamp_chargemode_changed=None, timestamp_last_phase_switch=0, timestamp_phase_switch_buffer_start=None, timestamp_switch_on_off=None), get=Get(charge_state=False, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=38.0), current_branch='Release', current_commit='2026-01-19 13:34:35 +0100 [91b8c3a05]', currents=[0, 0, 0], daily_imported=0.0, daily_exported=0.0, error_timestamp=None, evse_current=0, evse_signaling=None, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, max_charge_power=None, max_discharge_power=None, max_evse_current=None, phases_in_use=1, plug_state=False, power=0, powers=[0, 0, 0], rfid_timestamp=None, rfid=None, serial_number='631205', soc=None, soc_timestamp=None, state_str='Keine Ladung, da der Ladepunkt gesperrt ist.', vehicle_id=None, version='2.1.9', voltages=[221.6, 221.35, 222.27]), set=Set(charge_template=ChargeTemplate(data=ChargeTemplateData(id=0, name='Standard-Lade-Profil', prio=True, load_default=False, time_charging=TimeCharging(active=False, plans=[]), chargemode=Chargemode(selected='instant_charging', eco_charging=EcoCharging(current=6, dc_current=145, limit=Limit(selected='none', amount=50000, soc=50), max_price=0.0002, phases_to_use=3), pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, feed_in_limit=False, limit=Limit(selected='soc', amount=50000, soc=100), min_current=0, min_soc_current=10, min_soc=0, phases_to_use=0, phases_to_use_min_soc=3), scheduled_charging=ScheduledCharging(plans=[]), instant_charging=InstantCharging(current=20, dc_current=145, limit=Limit(selected='none', amount=1000, soc=50), phases_to_use=3)))), current=0, energy_to_charge=0, ev_prev=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', charged_energy_by_source={'bat': 0, 'cp': 0, 'grid': 0, 'pv': 0}, costs=0, end=None, exported_at_mode_switch=0, exported_at_plugtime=0, exported_since_mode_switch=0, exported_since_plugged=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, timestamp_mode_switch=None, ev=-1, prio=False, rfid=None, serial_number=None, soc_at_start=None, soc_at_end=None, range_at_start=None, range_at_end=None), manual_lock=True, phases_to_use=1, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, current_prev=0, target_current=0, charging_ev_data=<control.ev.ev.Ev object at 0x6deb3430>, ocpp_transaction_id=None, charge_state_prev=False), config=Config(configuration={'duo_num': 0, 'ip_address': 'localhost', 'mode': 'pro_plus'}, ev=0, name='Interne openWB', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=False, id=1, ocpp_chargebox_id=None))
2026-02-22 14:52:32,806 - {control.data:295} - {INFO:MainThread} - cpt0
2026-02-22 14:52:32,811 - {control.data:295} - {INFO:MainThread} - counter0
2026-02-22 14:52:32,817 - {control.data:267} - {INFO:MainThread} - counter_all_data
2026-02-22 14:52:32,821 - {control.data:295} - {INFO:MainThread} - ct0
2026-02-22 14:52:32,828 - {control.data:295} - {INFO:MainThread} - ct1
2026-02-22 14:52:32,834 - {control.data:295} - {INFO:MainThread} - ev0
2026-02-22 14:52:32,838 - {control.data:295} - {INFO:MainThread} - et0
2026-02-22 14:52:32,843 - {control.data:295} - {INFO:MainThread} - et1
2026-02-22 14:52:32,847 - {control.data:271} - {INFO:MainThread} - general_data
2026-02-22 14:52:32,854 - {control.data:272} - {INFO:MainThread} - general_data-display
primary
2026-02-22 14:52:32,856 - {control.data:273} - {INFO:MainThread} - graph_data
2026-02-22 14:52:32,859 - {control.data:276} - {INFO:MainThread} - optional_data
OptionalData(electricity_pricing=ElectricityPricing(configured=False, flexible_tariff=FlexibleTariff(get=PricingGet(fault_state=0, fault_str='Kein Fehler.', prices={})), grid_fee=GridFee(get=PricingGet(fault_state=0, fault_str='Kein Fehler.', prices={})), get=ElectricityPricingGet(next_query_time=None, _prices={})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x6de93928>), led=Led(active=False), rfid=Rfid(active=False), dc_charging=False, ocpp=Ocpp(active=False, boot_notification_sent=False, _url=None, version='ocpp1.6'))
2026-02-22 14:52:32,865 - {control.data:278} - {INFO:MainThread} - pv_all_data
2026-02-22 14:52:32,869 - {control.data:295} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'backup_cloud': {'backup_before_update': True}, 'ip_address': '172.16.23.201', 'current_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]', 'current_branch': 'Release', 'current_branch_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]', 'current_missing_commits': [], 'installAssistantDone': True, 'dataprotection_acknowledged': True, 'datastore_version': [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107], 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'serial_number': 'owbd107pro10445', 'version': '2.1.9', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1771768343, 'time': '14:52:23', 'grid': 0.0, 'house-power': 0.0, 'charging-all': 0.0, 'cp1-power': 0.0, 'ev0-soc': 38.0}, 'secondary_auto_update': True, 'module_update_completed': True, 'mac_address': 'b8:27:eb:05:01:39'}
2026-02-22 14:52:32,877 - {control.data:308} - {INFO:MainThread} - device0
2026-02-22 14:52:32,881 - {control.data:310} - {INFO:MainThread} - component0
2026-02-22 14:52:32,884 - {control.data:282} - {INFO:MainThread} -
2026-02-22 14:52:32,886 - {control.algorithm.algorithm:27} - {INFO:MainThread} - # Algorithmus
2026-02-22 14:52:32,889 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Mindestrom setzen**
2026-02-22 14:52:32,893 - {control.algorithm.algorithm:34} - {INFO:MainThread} - **Soll-Strom setzen**
2026-02-22 14:52:32,897 - {control.algorithm.algorithm:38} - {INFO:MainThread} - **PV-geführten Strom setzen**
2026-02-22 14:52:32,899 - {control.counter:253} - {DEBUG:MainThread} - Anpassen des Regelbereichs 115.0W
2026-02-22 14:52:32,902 - {control.counter:511} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 115.0W
2026-02-22 14:52:32,907 - {control.algorithm.algorithm:45} - {INFO:MainThread} - **Bidi-(Ent-)Lade-Strom setzen**
2026-02-22 14:52:32,909 - {control.counter:526} - {DEBUG:MainThread} - Nullpunktanpassung 0W
2026-02-22 14:52:32,912 - {control.algorithm.bidi_charging:16} - {DEBUG:MainThread} - Nullpunktanpassung 0W
2026-02-22 14:52:32,915 - {control.process:30} - {INFO:MainThread} - # Ladung starten.
2026-02-22 14:52:32,927 - {modules.common.component_context:29} - {DEBUG:set current cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:40,465 - {root:161} - {INFO:MainThread} - # ***Start***
2026-02-22 14:52:40,475 - {root:61} - {DEBUG:MainThread} - Lock für handler10Sec erworben.
2026-02-22 14:52:40,516 - {modules.common.component_context:29} - {DEBUG:device0} - Update Komponente ['Virtueller Zähler']
2026-02-22 14:52:40,523 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=None, exported=None, power=0, frequency=50, serial_number=None)
2026-02-22 14:52:40,530 - {modules.common.component_context:29} - {DEBUG:set values cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:41,650 - {modules.chargepoints.external_openwb.chargepoint_module:85} - {DEBUG:set values cp1} - Empfange MQTT Daten für Ladepunkt 1: {'openWB/internal_chargepoint/0/get/error_timestamp': None, 'openWB/internal_chargepoint/0/get/voltages': [221.72, 221.54, 222.36], 'openWB/internal_chargepoint/0/get/currents': [0, 0, 0], 'openWB/internal_chargepoint/0/get/frequency': 49.94, 'openWB/internal_chargepoint/0/get/power_factors': [0.0, 0.0, 0.0], 'openWB/internal_chargepoint/0/get/imported': 0, 'openWB/internal_chargepoint/0/get/exported': 0, 'openWB/internal_chargepoint/0/get/power': 0, 'openWB/internal_chargepoint/0/get/powers': [0, 0, 0], 'openWB/internal_chargepoint/0/get/phases_in_use': 1, 'openWB/internal_chargepoint/0/get/charge_state': False, 'openWB/internal_chargepoint/0/get/plug_state': False, 'openWB/internal_chargepoint/0/get/evse_current': 0, 'openWB/internal_chargepoint/0/get/max_evse_current': None, 'openWB/internal_chargepoint/0/get/serial_number': '631205', 'openWB/internal_chargepoint/0/get/fault_str': 'Kein Fehler.', 'openWB/internal_chargepoint/0/get/fault_state': 0, 'openWB/internal_chargepoint/0/get/vehicle_id': None, 'openWB/internal_chargepoint/0/get/rfid': None, 'openWB/internal_chargepoint/0/get/version': '2.1.9', 'openWB/internal_chargepoint/0/get/current_branch': 'Release', 'openWB/internal_chargepoint/0/get/current_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]'}
2026-02-22 14:52:41,685 - {modules.common.store._api:26} - {DEBUG:set values cp1} - Raw data ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[221.72, 221.54, 222.36], frequency=49.94, imported=0, exported=0, power=0, serial_number=631205, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, max_evse_current=None, vehicle_id=None, current_branch=Release, current_commit=2026-01-19 13:34:35 +0100 [91b8c3a05], version=2.1.9, evse_signaling=None, max_charge_power=None, max_discharge_power=None)
2026-02-22 14:52:41,747 - {modules.common.component_context:29} - {DEBUG:update values cp1} - Update Komponente ['Ladepunkt']
2026-02-22 14:52:41,750 - {modules.common.store._api:31} - {INFO:update values cp1} - Saving ChargepointState(currents=[0, 0, 0], powers=[0, 0, 0], voltages=[221.72, 221.54, 222.36], frequency=49.94, imported=0, exported=0, power=0, serial_number=631205, phases_in_use=1, charge_state=False, plug_state=False, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[0.0, 0.0, 0.0], soc=None, soc_timestamp=None, evse_current=0, max_evse_current=None, vehicle_id=None, current_branch=Release, current_commit=2026-01-19 13:34:35 +0100 [91b8c3a05], version=2.1.9, evse_signaling=None, max_charge_power=None, max_discharge_power=None)
2026-02-22 14:52:41,974 - {modules.common.component_context:29} - {DEBUG:component0} - Update Komponente ['Virtueller Zähler']
2026-02-22 14:52:41,977 - {modules.common.simcount._simcount:42} - {DEBUG:component0} - Previous state: SimCounterState(timestamp=1771768352.4909196, power=0, imported=0.0, exported=0)
2026-02-22 14:52:41,981 - {modules.common.simcount._calculate:11} - {DEBUG:component0} - time passed: 0.00263527, power1: 0, power2: 0
2026-02-22 14:52:41,984 - {modules.common.simcount._calculate:27} - {DEBUG:component0} - power did not change sign. Total energy: 0
2026-02-22 14:52:41,988 - {modules.common.simcount._simcount:65} - {DEBUG:component0} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1771768361.977902, power=0, imported=0.0, exported=0)
2026-02-22 14:52:41,997 - {modules.common.store._api:31} - {INFO:component0} - Saving CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=0.0, exported=0, power=0, frequency=50, serial_number=None)
2026-02-22 14:52:42,177 - {control.counter:163} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [35.0, 35.0, 35.0]A
2026-02-22 14:52:42,183 - {control.counter:190} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 24000W
2026-02-22 14:52:42,190 - {control.chargepoint.chargepoint:72} - {INFO:MainThread} - LP 1: Keine Ladung, da der Ladepunkt gesperrt ist.
2026-02-22 14:52:42,194 - {modules.common.simcount._simcount:42} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1771768352.7303324, power=0, imported=0.0, exported=0)
2026-02-22 14:52:42,198 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00262884, power1: 0, power2: 0
2026-02-22 14:52:42,205 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 0
2026-02-22 14:52:42,215 - {modules.common.simcount._simcount:65} - {DEBUG:MainThread} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1771768362.194158, power=0, imported=0.0, exported=0)
2026-02-22 14:52:42,227 - {control.data:262} - {INFO:MainThread} - bat_all_data
2026-02-22 14:52:42,233 - {control.data:263} - {INFO:MainThread} - cp_all_data
2026-02-22 14:52:42,241 - {control.data:295} - {INFO:MainThread} - cp1
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, limit=LoadmanagementLimit(message=None, limiting_value=None), min_current=6, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, template_phases=None, timestamp_charge_start=None, timestamp_chargemode_changed=None, timestamp_last_phase_switch=0, timestamp_phase_switch_buffer_start=None, timestamp_switch_on_off=None), get=Get(charge_state=False, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=38.0), current_branch='Release', current_commit='2026-01-19 13:34:35 +0100 [91b8c3a05]', currents=[0, 0, 0], daily_imported=0.0, daily_exported=0.0, error_timestamp=None, evse_current=0, evse_signaling=None, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, max_charge_power=None, max_discharge_power=None, max_evse_current=None, phases_in_use=1, plug_state=False, power=0, powers=[0, 0, 0], rfid_timestamp=None, rfid=None, serial_number='631205', soc=None, soc_timestamp=None, state_str='Keine Ladung, da der Ladepunkt gesperrt ist.', vehicle_id=None, version='2.1.9', voltages=[221.72, 221.54, 222.36]), set=Set(charge_template=ChargeTemplate(data=ChargeTemplateData(id=0, name='Standard-Lade-Profil', prio=True, load_default=False, time_charging=TimeCharging(active=False, plans=[]), chargemode=Chargemode(selected='instant_charging', eco_charging=EcoCharging(current=6, dc_current=145, limit=Limit(selected='none', amount=50000, soc=50), max_price=0.0002, phases_to_use=3), pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, feed_in_limit=False, limit=Limit(selected='soc', amount=50000, soc=100), min_current=0, min_soc_current=10, min_soc=0, phases_to_use=0, phases_to_use_min_soc=3), scheduled_charging=ScheduledCharging(plans=[]), instant_charging=InstantCharging(current=20, dc_current=145, limit=Limit(selected='none', amount=1000, soc=50), phases_to_use=3)))), current=0, energy_to_charge=0, ev_prev=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', charged_energy_by_source={'bat': 0, 'cp': 0, 'grid': 0, 'pv': 0}, costs=0, end=None, exported_at_mode_switch=0, exported_at_plugtime=0, exported_since_mode_switch=0, exported_since_plugged=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, timestamp_mode_switch=None, ev=-1, prio=False, rfid=None, serial_number=None, soc_at_start=None, soc_at_end=None, range_at_start=None, range_at_end=None), manual_lock=True, phases_to_use=1, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, current_prev=0, target_current=0, charging_ev_data=<control.ev.ev.Ev object at 0x6deb1898>, ocpp_transaction_id=None, charge_state_prev=False), config=Config(configuration={'duo_num': 0, 'ip_address': 'localhost', 'mode': 'pro_plus'}, ev=0, name='Interne openWB', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=False, id=1, ocpp_chargebox_id=None))
2026-02-22 14:52:42,278 - {control.data:295} - {INFO:MainThread} - cpt0
2026-02-22 14:52:42,288 - {control.data:295} - {INFO:MainThread} - counter0
2026-02-22 14:52:42,303 - {control.data:267} - {INFO:MainThread} - counter_all_data
2026-02-22 14:52:42,309 - {control.data:295} - {INFO:MainThread} - ct0
2026-02-22 14:52:42,317 - {control.data:295} - {INFO:MainThread} - ct1
2026-02-22 14:52:42,326 - {control.data:295} - {INFO:MainThread} - ev0
2026-02-22 14:52:42,330 - {control.data:295} - {INFO:MainThread} - et0
2026-02-22 14:52:42,337 - {control.data:295} - {INFO:MainThread} - et1
2026-02-22 14:52:42,342 - {control.data:271} - {INFO:MainThread} - general_data
2026-02-22 14:52:42,349 - {control.data:272} - {INFO:MainThread} - general_data-display
primary
2026-02-22 14:52:42,353 - {control.data:273} - {INFO:MainThread} - graph_data
2026-02-22 14:52:42,357 - {control.data:276} - {INFO:MainThread} - optional_data
OptionalData(electricity_pricing=ElectricityPricing(configured=False, flexible_tariff=FlexibleTariff(get=PricingGet(fault_state=0, fault_str='Kein Fehler.', prices={})), grid_fee=GridFee(get=PricingGet(fault_state=0, fault_str='Kein Fehler.', prices={})), get=ElectricityPricingGet(next_query_time=None, _prices={})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x6deb2e68>), led=Led(active=False), rfid=Rfid(active=False), dc_charging=False, ocpp=Ocpp(active=False, boot_notification_sent=False, _url=None, version='ocpp1.6'))
2026-02-22 14:52:42,363 - {control.data:278} - {INFO:MainThread} - pv_all_data
2026-02-22 14:52:42,367 - {control.data:295} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'backup_cloud': {'backup_before_update': True}, 'ip_address': '172.16.23.201', 'current_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]', 'current_branch': 'Release', 'current_branch_commit': '2026-01-19 13:34:35 +0100 [91b8c3a05]', 'current_missing_commits': [], 'installAssistantDone': True, 'dataprotection_acknowledged': True, 'datastore_version': [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107], 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'serial_number': 'owbd107pro10445', 'version': '2.1.9', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1771768352, 'time': '14:52:32', 'grid': 0.0, 'house-power': 0.0, 'charging-all': 0.0, 'cp1-power': 0.0, 'ev0-soc': 38.0}, 'secondary_auto_update': True, 'module_update_completed': True, 'mac_address': 'b8:27:eb:05:01:39'}
2026-02-22 14:52:42,378 - {control.data:308} - {INFO:MainThread} - device0
2026-02-22 14:52:42,382 - {control.data:310} - {INFO:MainThread} - component0
2026-02-22 14:52:42,385 - {control.data:282} - {INFO:MainThread} -
2026-02-22 14:52:42,387 - {control.algorithm.algorithm:27} - {INFO:MainThread} - # Algorithmus
2026-02-22 14:52:42,390 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Mindestrom setzen**
2026-02-22 14:52:42,394 - {control.algorithm.algorithm:34} - {INFO:MainThread} - **Soll-Strom setzen**
2026-02-22 14:52:42,398 - {control.algorithm.algorithm:38} - {INFO:MainThread} - **PV-geführten Strom setzen**
2026-02-22 14:52:42,401 - {control.counter:253} - {DEBUG:MainThread} - Anpassen des Regelbereichs 115.0W
2026-02-22 14:52:42,404 - {control.counter:511} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 115.0W
2026-02-22 14:52:42,408 - {control.algorithm.algorithm:45} - {INFO:MainThread} - **Bidi-(Ent-)Lade-Strom setzen**
2026-02-22 14:52:42,411 - {control.counter:526} - {DEBUG:MainThread} - Nullpunktanpassung 0W
2026-02-22 14:52:42,413 - {control.algorithm.bidi_charging:16} - {DEBUG:MainThread} - Nullpunktanpassung 0W
2026-02-22 14:52:42,416 - {control.process:30} - {INFO:MainThread} - # Ladung starten.
2026-02-22 14:52:42,442 - {modules.common.component_context:29} - {DEBUG:set current cp1} - Update Komponente ['Ladepunkt']
