Json abfrage PV
pvhpsb
Json abfrage PV
Beitrag von pvhpsb »
Entschuldigung für mein schlechtes Deutsch.
Ich versuche, Daten mit JSON zu erhalten, aber ich weiß nicht, welche Daten in Modulconfiguration PV Json eingestellt werden sollen.
Bitte hilf mir.
Vielen Dank im Voraus Patrick
openWB Version: 1.9.275
Json abfrage:
"ActTime" : 1662469122,
"AstrTwilightEnd" : "22:19",
"AstrTwilightStart" : "05:00",
"CivTwilightEnd" : "20:52",
"CivTwilightStart" : "06:27",
"DayLength" : "13:16",
"NautTwilightEnd" : "21:33",
"NautTwilightStart" : "05:46",
"ServerTime" : "2022-09-06 14:58:42",
"SunAtSouth" : "13:39",
"Sunrise" : "07:02",
"Sunset" : "20:17",
"app_version" : "2022.1",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CounterToday" : "6.000 kWh",
"CustomImage" : 0,
"Data" : "257.300 kWh",
"Description" : "",
"EnergyMeterMode" : "",
"Favorite" : 0,
"HardwareDisabled" : false,
"HardwareID" : 49,
"HardwareName" : "Growatt Panelen",
"HardwareType" : "Growatt Web Inverter",
"HardwareTypeVal" : 94,
"HaveTimeout" : false,
"ID" : "00310001",
"LastUpdate" : "2022-09-06 14:58:10",
"Name" : "Growatt Panelen - Inverter (kWh)",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" :
0
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "kWh",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "General",
"TypeImg" : "current",
"Unit" : 1,
"Usage" : "2874.9 Watt",
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "8664"
"status" : "OK",
"title" : "Devices"
Been thanked: 45 times
Re: Json abfrage PV
Csn you Tell, which data exactly you want to Extrakt from the JSON?
I guess the Data" : "257.300 kWh as Total Energy
And Usage" : "2874.9 Watt", as actual Power?
Regards
pvhpsb
Re: Json abfrage PV
Those are the correct values.
Regards,
Patrick
Re: Json abfrage PV
So to get the usage, use
.result[].Usage|split(" ")[0]|tonumber|round
As Filter
And for Data replace Usage with Data.
That should do the job. If Data ist factor 1000 too small, add *1000 to the end if the filter
Regards
pvhpsb
Re: Json abfrage PV
That was the solution.
Thank you.
Best Regards,
Patrick
Re: Json abfrage PV
Franco99
Re: Json abfrage PV
Beitrag von Franco99 »
Hallo, ich habe eine ähnliche Frage, denn ich möchte unter pv2 per json die Werte für aktuelle Leistung(W) und Tagesertag(Wh) einlesen, damit die in der OpenWB als summierte Werte aus pv1 und pv2 erscheinen. Leider kenne ich mich mit json nicht aus. Vielleicht könnt ihr mir helfen.
invertersserial116484422211nameBKW Garten.txt
(1.92 KiB) 71-mal heruntergeladen
13.3 KwP ost-west PV-Anlage
BKW 1.7 KwP 800VA AC
Sungrow SH10RT
BYD HVS 7.7
OpenWB Custom series 2. Release 2.1.7 Patch 1
Kia EV6
Cupra Tavascan Endurance
Re: Json abfrage PV
.total.power.v|round
.total.YieldTotal.v*1000
Evtl. Hier auch noch |round dahinter.
Franco99
Re: Json abfrage PV
Vielen Dank für die schnelle Unterstützung. Habe aber noch diese Fehlermeldung. Der Gesamtertrag von 0.652 kWh ist auch zu niedrig. Müsste bei knapp 4 kWh liegen
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
Re: Json abfrage PV
Also aus deiner Datei geht hervor, dass du 32kWh gesamt hast, wie kommst du auf 4kWh? Das Ergebnis 0,6... kann auch nicht sein
