Ich habe gerade mal mein Auto wieder für eine halbe Stunde an die Wallbox (go-e V2) gesteckt. In diesem Zeitraum treten die Fehler auf. Nach dem Abstecken ist wieder Ruhe. Hier Auszüge aus dem Log im Level 2:
2022-08-23 12:05:01: PID: 6173: ##### cron5min.sh started ##### (LV0)
2022-08-23 12:05:02: PID: 6173: push buttons disabled (LV0)
2022-08-23 12:05:02: PID: 6173: rse disabled (LV0)
2022-08-23 12:05:04: PID: 6173: ##### cron5min.sh finished ##### (LV0)
----------------------------------Auto eingesteckt, aber noch keine Ladung gestartet, Fehler tritt wieder auf
2022-08-23 12:06:25: PID: 2040: soc.modules.common.fault_state: Sma Sunny Boy/Tripower Wechselrichter: FaultState FaultStateLevel.ERROR, FaultStr modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>), Traceback:
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>)
File "/var/www/html/openWB/packages/modules/sma_sunny_boy/device.py", line 169, in read_inverter
state, produces_dc_power = inverter1.read()
File "/var/www/html/openWB/packages/modules/sma_sunny_boy/inverter.py", line 37, in read
power_total = self.__tcp_client.read_holding_registers(30775, ModbusDataType.INT_32, unit=3)
str(e)) from e
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
2022-08-23 12:06:29: PID: 17543: **** WARNING **** Regulation loop needs 8 seconds (LV0)
2022-08-23 12:09:15: PID: 2040: soc.modules.common.fault_state: Sma Sunny Boy/Tripower Wechselrichter: FaultState FaultStateLevel.ERROR, FaultStr modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>), Traceback:
str(e)) from e
2022-08-23 12:09:19: PID: 8831: **** WARNING **** Regulation loop needs 8 seconds (LV0)
2022-08-23 12:10:01: PID: 15778: ##### cron5min.sh started ##### (LV0)
2022-08-23 12:10:02: PID: 15778: push buttons disabled (LV0)
2022-08-23 12:10:02: PID: 15778: rse disabled (LV0)
2022-08-23 12:10:03: PID: 15778: ##### cron5min.sh finished ##### (LV0)
2022-08-23 12:10:11: PID: 17437: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-08-23 12:10:12: PID: 2040: legacy run server: Log level changed WARNING -> DEBUG
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.21
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: 0
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: none, none, none
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: 0
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: 0
2022-08-23 12:10:12: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2022-08-23 12:10:12: PID: 2040: soc.modules.common.store._api: Saving InverterState(power=-3981, exported=16235802, currents=[0.0, 0.0, 0.0])
2022-08-23 12:10:12: PID: 2040: legacy run server: Completed running command in 0.10s: ["modules.sma_sunny_boy.device","inverter","192.168.88.21","0","none","none","none","0","0","0","1"]
2022-08-23 12:10:12: PID: 17632: RET: 0 (LV2) at 12 main modules/wr_tripower9000/main.sh
2022-08-23 12:10:12: PID: 2040: legacy run server: Received command ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.22
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: None
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: None, None, None
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: None
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: None
2022-08-23 12:10:12: PID: 2040: modules.sma_sunny_boy.device: Start device reading {'componentNone': <modules.sma_sunny_boy.bat.SunnyBoyBat object at 0x74337d50>}
2022-08-23 12:10:12: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy Speicher']
2022-08-23 12:10:13: PID: 2040: soc.modules.common.store._api: Saving BatState(imported=2540145, soc=100, power=0, exported=2047199)
2022-08-23 12:10:13: PID: 2040: legacy run server: Completed running command in 0.15s: ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:13: PID: 17648: RET: 0 (LV2) at 24 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:13: PID: 17648: BattLeistung: 0 (LV1) at 28 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:13: PID: 17437: Request to run SoC-Module: soc_manuallp2 (LV2) at 4 run_soc_module loadvars.sh
2022-08-23 12:10:13: PID: 17437: Calling SoC-Module: modules/soc_manuallp2/main.sh (LV2) at 8 run_soc_module loadvars.sh
2022-08-23 12:10:13: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:13: PID: 2040: SoC Manual: Charged: 306.9 kWh -> 306.9 kWh = 0 kWh
2022-08-23 12:10:13: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (84%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:13: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:13: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:14: PID: 2040: legacy run server: Received command ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:14: PID: 2040: modules.sma_shm.device: Beginning update
2022-08-23 12:10:14: PID: 2040: soc.modules.common.component_context: Update Komponenten ['SMA Home Manager Zähler']
2022-08-23 12:10:14: PID: 2040: soc.modules.common.component_context: Update Komponente ['SMA Home Manager Zähler']
2022-08-23 12:10:14: PID: 2040: soc.modules.common.store._api: Saving CounterState(imported=3800143.0999999996, powers=[-1242.1, -1291.4, -1340.4], frequency=49.986, power=-3874.0, exported=8855049.2, power_factors=[0.999, 1.0, 0.999], voltages=[232.716, 232.854, 233.491], currents=[-5.357, -5.56, -5.758])
2022-08-23 12:10:14: PID: 2040: modules.sma_shm.device: All components updated
2022-08-23 12:10:14: PID: 2040: modules.sma_shm.device: Update complete
2022-08-23 12:10:14: PID: 2040: legacy run server: Completed running command in 0.30s: ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:14: PID: 17808: EVU RET: 0 (LV2) at 15 main modules/bezug_smashm/main.sh
2022-08-23 12:10:14: PID: 17437: speicherleistung 0 speichersoc 100 (LV1) at 1291 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 17437: pv1watt -3981 pv2watt pvwatt -3981 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1296 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 17437: lla1 0 llv1 224 llas11 0 llas21 mindestuberschuss 1250 abschaltuberschuss 0 lademodus 3 (LV1) at 1297 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 17437: lla2 0 llv2 226 llas12 0 llas22 sofortll 6 hausverbrauch 107 wattbezug -3874 uberschuss 3874 (LV1) at 1298 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:14: PID: 2040: SoC Manual: Charged: 2351 kWh -> 2351 kWh = 0 kWh
2022-08-23 12:10:14: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (86%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:14: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:14: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:14: PID: 17437: lla3 0 llv3 226 llas13 0 llas23 soclp1 0 soclp2 0 (LV1) at 1299 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 17437: EVU 1:V/-5A 2: V/-5A 3: V/-5A (LV1) at 1300 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 17437: lp1enabled 1 lp2enabled 0 lp3enabled 1 (LV1) at 1301 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 17437: plugstatlp1 1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1302 loadvars loadvars.sh
2022-08-23 12:10:14: PID: 17437: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1303 loadvars loadvars.sh
2022-08-23 12:10:15: PID: 17437: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-08-23 12:10:16: PID: 17437: **** Regulation loop needs 5 seconds (LV2) at 55 cleanup /var/www/html/openWB/regel.sh
2022-08-23 12:10:21: PID: 18858: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-08-23 12:10:22: PID: 2040: legacy run server: Received command ["modules.sma_sunny_boy.device","inverter","192.168.88.21","0","none","none","none","0","0","0","1"]
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.21
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: 0
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: none, none, none
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: 0
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: 0
2022-08-23 12:10:22: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2022-08-23 12:10:22: PID: 2040: soc.modules.common.store._api: Saving InverterState(power=-3908, exported=16235813, currents=[0.0, 0.0, 0.0])
2022-08-23 12:10:22: PID: 2040: legacy run server: Completed running command in 0.10s: ["modules.sma_sunny_boy.device","inverter","192.168.88.21","0","none","none","none","0","0","0","1"]
2022-08-23 12:10:22: PID: 19053: RET: 0 (LV2) at 12 main modules/wr_tripower9000/main.sh
2022-08-23 12:10:22: PID: 2040: legacy run server: Received command ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.22
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: None
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: None, None, None
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: None
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: None
2022-08-23 12:10:22: PID: 2040: modules.sma_sunny_boy.device: Start device reading {'componentNone': <modules.sma_sunny_boy.bat.SunnyBoyBat object at 0x7432ce90>}
2022-08-23 12:10:22: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy Speicher']
2022-08-23 12:10:22: PID: 2040: soc.modules.common.store._api: Saving BatState(imported=2540145, soc=100, power=0, exported=2047199)
2022-08-23 12:10:22: PID: 2040: legacy run server: Completed running command in 0.14s: ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:22: PID: 19069: RET: 0 (LV2) at 24 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:22: PID: 19069: BattLeistung: 0 (LV1) at 28 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:23: PID: 18858: Request to run SoC-Module: soc_manuallp2 (LV2) at 4 run_soc_module loadvars.sh
2022-08-23 12:10:23: PID: 18858: Calling SoC-Module: modules/soc_manuallp2/main.sh (LV2) at 8 run_soc_module loadvars.sh
2022-08-23 12:10:23: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:23: PID: 2040: SoC Manual: Charged: 306.9 kWh -> 306.9 kWh = 0 kWh
2022-08-23 12:10:23: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (84%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:23: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:23: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:24: PID: 2040: legacy run server: Received command ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:24: PID: 2040: modules.sma_shm.device: Beginning update
2022-08-23 12:10:24: PID: 2040: soc.modules.common.component_context: Update Komponenten ['SMA Home Manager Zähler']
2022-08-23 12:10:24: PID: 2040: soc.modules.common.component_context: Update Komponente ['SMA Home Manager Zähler']
2022-08-23 12:10:24: PID: 2040: soc.modules.common.store._api: Saving CounterState(imported=3800143.0999999996, powers=[-1142.2, -1190.3, -1239.9], frequency=49.999, power=-3572.4, exported=8855059.8, power_factors=[0.999, 1.0, 0.999], voltages=[232.208, 232.404, 233.455], currents=[-4.936, -5.136, -5.33])
2022-08-23 12:10:24: PID: 2040: modules.sma_shm.device: All components updated
2022-08-23 12:10:24: PID: 2040: modules.sma_shm.device: Update complete
2022-08-23 12:10:24: PID: 2040: legacy run server: Completed running command in 0.37s: ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:24: PID: 19229: EVU RET: 0 (LV2) at 15 main modules/bezug_smashm/main.sh
2022-08-23 12:10:24: PID: 18858: speicherleistung 0 speichersoc 100 (LV1) at 1291 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 18858: pv1watt -3908 pv2watt pvwatt -3908 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1296 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 18858: lla1 0 llv1 224 llas11 0 llas21 mindestuberschuss 1250 abschaltuberschuss 0 lademodus 3 (LV1) at 1297 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 18858: lla2 0 llv2 226 llas12 0 llas22 sofortll 6 hausverbrauch 336 wattbezug -3572 uberschuss 3572 (LV1) at 1298 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:24: PID: 2040: SoC Manual: Charged: 2351 kWh -> 2351 kWh = 0 kWh
2022-08-23 12:10:24: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (86%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:24: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:24: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:24: PID: 18858: lla3 0 llv3 225 llas13 0 llas23 soclp1 0 soclp2 0 (LV1) at 1299 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 18858: EVU 1:V/-4A 2: V/-5A 3: V/-5A (LV1) at 1300 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 18858: lp1enabled 1 lp2enabled 0 lp3enabled 1 (LV1) at 1301 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 18858: plugstatlp1 1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1302 loadvars loadvars.sh
2022-08-23 12:10:24: PID: 18858: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1303 loadvars loadvars.sh
2022-08-23 12:10:25: PID: 18858: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-08-23 12:10:26: PID: 18858: **** Regulation loop needs 5 seconds (LV2) at 55 cleanup /var/www/html/openWB/regel.sh
2022-08-23 12:10:31: PID: 20275: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-08-23 12:10:32: PID: 2040: legacy run server: Received command ["modules.sma_sunny_boy.device","inverter","192.168.88.21","0","none","none","none","0","0","0","1"]
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.21
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: 0
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: none, none, none
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: 0
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: 0
2022-08-23 12:10:32: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2022-08-23 12:10:32: PID: 2040: soc.modules.common.store._api: Saving InverterState(power=-3670, exported=16235824, currents=[0.0, 0.0, 0.0])
2022-08-23 12:10:32: PID: 2040: legacy run server: Completed running command in 0.10s: ["modules.sma_sunny_boy.device","inverter","192.168.88.21","0","none","none","none","0","0","0","1"]
2022-08-23 12:10:32: PID: 20471: RET: 0 (LV2) at 12 main modules/wr_tripower9000/main.sh
2022-08-23 12:10:32: PID: 2040: legacy run server: Received command ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.22
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: None
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: None, None, None
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: None
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: None
2022-08-23 12:10:32: PID: 2040: modules.sma_sunny_boy.device: Start device reading {'componentNone': <modules.sma_sunny_boy.bat.SunnyBoyBat object at 0x74337fb0>}
2022-08-23 12:10:32: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy Speicher']
2022-08-23 12:10:33: PID: 2040: soc.modules.common.store._api: Saving BatState(imported=2540145, soc=100, power=0, exported=2047199)
2022-08-23 12:10:33: PID: 2040: legacy run server: Completed running command in 0.18s: ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:33: PID: 20487: RET: 0 (LV2) at 24 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:33: PID: 20487: BattLeistung: 0 (LV1) at 28 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:33: PID: 20275: Request to run SoC-Module: soc_manuallp2 (LV2) at 4 run_soc_module loadvars.sh
2022-08-23 12:10:33: PID: 20275: Calling SoC-Module: modules/soc_manuallp2/main.sh (LV2) at 8 run_soc_module loadvars.sh
2022-08-23 12:10:33: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:33: PID: 2040: SoC Manual: Charged: 306.9 kWh -> 306.9 kWh = 0 kWh
2022-08-23 12:10:33: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (84%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:33: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:33: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:34: PID: 2040: legacy run server: Received command ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:34: PID: 2040: modules.sma_shm.device: Beginning update
2022-08-23 12:10:34: PID: 2040: soc.modules.common.component_context: Update Komponenten ['SMA Home Manager Zähler']
2022-08-23 12:10:34: PID: 2040: soc.modules.common.component_context: Update Komponente ['SMA Home Manager Zähler']
2022-08-23 12:10:34: PID: 2040: soc.modules.common.store._api: Saving CounterState(imported=3800143.0999999996, powers=[-1112.2, -1139.8, -1190.7], frequency=49.993, power=-3442.7, exported=8855069.600000001, power_factors=[0.999, 1.0, 0.998], voltages=[232.142, 232.116, 233.131], currents=[-4.814, -4.927, -5.128])
2022-08-23 12:10:34: PID: 2040: modules.sma_shm.device: All components updated
2022-08-23 12:10:34: PID: 2040: modules.sma_shm.device: Update complete
2022-08-23 12:10:34: PID: 2040: legacy run server: Completed running command in 0.20s: ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:34: PID: 20647: EVU RET: 0 (LV2) at 15 main modules/bezug_smashm/main.sh
2022-08-23 12:10:34: PID: 20275: speicherleistung 0 speichersoc 100 (LV1) at 1291 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 20275: pv1watt -3670 pv2watt pvwatt -3670 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1296 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 20275: lla1 0 llv1 224 llas11 0 llas21 mindestuberschuss 1250 abschaltuberschuss 0 lademodus 3 (LV1) at 1297 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 20275: lla2 0 llv2 225 llas12 0 llas22 sofortll 6 hausverbrauch 228 wattbezug -3442 uberschuss 3442 (LV1) at 1298 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:34: PID: 20275: lla3 0 llv3 224 llas13 0 llas23 soclp1 0 soclp2 0 (LV1) at 1299 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 2040: SoC Manual: Charged: 2351 kWh -> 2351 kWh = 0 kWh
2022-08-23 12:10:34: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (86%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:34: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:34: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:34: PID: 20275: EVU 1:V/-4A 2: V/-4A 3: V/-5A (LV1) at 1300 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 20275: lp1enabled 1 lp2enabled 0 lp3enabled 1 (LV1) at 1301 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 20275: plugstatlp1 1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1302 loadvars loadvars.sh
2022-08-23 12:10:34: PID: 20275: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1303 loadvars loadvars.sh
2022-08-23 12:10:35: PID: 20275: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-08-23 12:10:36: PID: 20275: **** Regulation loop needs 5 seconds (LV2) at 55 cleanup /var/www/html/openWB/regel.sh
2022-08-23 12:10:41: PID: 21693: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-08-23 12:10:42: PID: 2040: legacy run server: Received command ["modules.sma_sunny_boy.device","inverter","192.168.88.21","0","none","none","none","0","0","0","1"]
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.21
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: 0
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: none, none, none
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: 0
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: 0
2022-08-23 12:10:42: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2022-08-23 12:10:42: PID: 2040: soc.modules.common.store._api: Saving InverterState(power=-3798, exported=16235834, currents=[0.0, 0.0, 0.0])
2022-08-23 12:10:42: PID: 2040: legacy run server: Completed running command in 0.12s: ["modules.sma_sunny_boy.device","inverter","192.168.88.21","0","none","none","none","0","0","0","1"]
2022-08-23 12:10:42: PID: 21888: RET: 0 (LV2) at 12 main modules/wr_tripower9000/main.sh
2022-08-23 12:10:42: PID: 2040: legacy run server: Received command ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.88.22
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Webbox: None
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus weitere IPs: None, None, None
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Version: None
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: SMA Modbus Hybrid: None
2022-08-23 12:10:42: PID: 2040: modules.sma_sunny_boy.device: Start device reading {'componentNone': <modules.sma_sunny_boy.bat.SunnyBoyBat object at 0x74315c70>}
2022-08-23 12:10:42: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy Speicher']
2022-08-23 12:10:42: PID: 2040: soc.modules.common.store._api: Saving BatState(imported=2540145, soc=100, power=0, exported=2047199)
2022-08-23 12:10:42: PID: 2040: legacy run server: Completed running command in 0.15s: ["modules.sma_sunny_boy.device","bat","192.168.88.22"]
2022-08-23 12:10:42: PID: 21904: RET: 0 (LV2) at 24 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:42: PID: 21904: BattLeistung: 0 (LV1) at 28 main modules/speicher_sbs25/main.sh
2022-08-23 12:10:43: PID: 21693: Request to run SoC-Module: soc_manuallp2 (LV2) at 4 run_soc_module loadvars.sh
2022-08-23 12:10:43: PID: 21693: Calling SoC-Module: modules/soc_manuallp2/main.sh (LV2) at 8 run_soc_module loadvars.sh
2022-08-23 12:10:43: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:43: PID: 2040: SoC Manual: Charged: 306.9 kWh -> 306.9 kWh = 0 kWh
2022-08-23 12:10:43: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (84%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:43: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:43: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","2","84","28"]
2022-08-23 12:10:44: PID: 2040: legacy run server: Received command ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:44: PID: 2040: modules.sma_shm.device: Beginning update
2022-08-23 12:10:44: PID: 2040: soc.modules.common.component_context: Update Komponenten ['SMA Home Manager Zähler']
2022-08-23 12:10:44: PID: 2040: soc.modules.common.component_context: Update Komponente ['SMA Home Manager Zähler']
2022-08-23 12:10:44: PID: 2040: soc.modules.common.store._api: Saving CounterState(imported=3800143.0999999996, powers=[-1181.6, -1207.1, -1258.5], frequency=49.989, power=-3647.2, exported=8855079.5, power_factors=[0.999, 1.0, 0.999], voltages=[232.159, 232.068, 233.306], currents=[-5.11, -5.216, -5.413])
2022-08-23 12:10:44: PID: 2040: modules.sma_shm.device: All components updated
2022-08-23 12:10:44: PID: 2040: modules.sma_shm.device: Update complete
2022-08-23 12:10:44: PID: 2040: legacy run server: Completed running command in 0.41s: ["modules.sma_shm.device","counter","none"]
2022-08-23 12:10:44: PID: 22065: EVU RET: 0 (LV2) at 15 main modules/bezug_smashm/main.sh
2022-08-23 12:10:44: PID: 21693: speicherleistung 0 speichersoc 100 (LV1) at 1291 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 21693: pv1watt -3798 pv2watt pvwatt -3798 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1296 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 21693: lla1 0 llv1 223 llas11 0 llas21 mindestuberschuss 1250 abschaltuberschuss 0 lademodus 3 (LV1) at 1297 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 21693: lla2 0 llv2 226 llas12 0 llas22 sofortll 6 hausverbrauch 151 wattbezug -3647 uberschuss 3647 (LV1) at 1298 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 2040: legacy run server: Received command ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:44: PID: 2040: SoC Manual: Charged: 2351 kWh -> 2351 kWh = 0 kWh
2022-08-23 12:10:44: PID: 2040: SoC Manual: SoC-Gain: Charged (0 kWh) * efficiency (86%) / battery-size (28 kWh) = 0.0%
2022-08-23 12:10:44: PID: 2040: SoC Manual: 0% + 0 kWh = 0%
2022-08-23 12:10:44: PID: 21693: lla3 0 llv3 225 llas13 0 llas23 soclp1 0 soclp2 0 (LV1) at 1299 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 2040: legacy run server: Completed running command in 0.01s: ["soc_manual.soc_manual","1","86","28"]
2022-08-23 12:10:44: PID: 21693: EVU 1:V/-5A 2: V/-5A 3: V/-5A (LV1) at 1300 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 21693: lp1enabled 1 lp2enabled 0 lp3enabled 1 (LV1) at 1301 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 21693: plugstatlp1 1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1302 loadvars loadvars.sh
2022-08-23 12:10:44: PID: 21693: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1303 loadvars loadvars.sh
----------- musste ein paar Zwischenereignisse löschen
2022-08-23 12:14:22: PID: 2040: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2022-08-23 12:14:25: PID: 2040: soc.modules.common.fault_state: Sma Sunny Boy/Tripower Wechselrichter: FaultState FaultStateLevel.ERROR, FaultStr modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 8 bytes (0 received)', <FaultStateLevel.ERROR: 2>), Traceback:
-----------------------Auto wieder abgesteckt, jetzt ist wieder Ruhe
2022-08-23 12:36:33: PID: 2040: legacy run server: Changing log level DEBUG -> WARNING
2022-08-23 12:40:02: PID: 13678: ##### cron5min.sh started ##### (LV0)
2022-08-23 12:40:03: PID: 13678: push buttons disabled (LV0)
2022-08-23 12:40:03: PID: 13678: rse disabled (LV0)
2022-08-23 12:40:04: PID: 13678: ##### cron5min.sh finished ##### (LV0)
