2022-10-06 00:25:27: PID: 5098: **** Regulation loop needs 5 seconds (LV2) at 62 cleanup /var/www/html/openWB/regel.sh
2022-10-06 00:25:27: PID: 5098: Überschuss -13; mindestens 500 (LV1) at 104 nurpvlademodus nurpv.sh
2022-10-06 00:25:27: PID: 5098: uberschuss -13 wattbezug 13 ladestatus 0 llsoll 0 pvwatt 0 mindestuberschussphasen 500 wattkombiniert -13 schaltschwelle 0 (LV2) at 583 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:26: PID: 5098: anzahlphasen 1 (LV1) at 582 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:25: PID: 5098: Timing Umschaltung: 900 / 60 (LV1) at 17 u1p3pswitch u1p3p.sh
2022-10-06 00:25:25: PID: 5098: automatische Umschaltung aktiv (LV1) at 16 u1p3pswitch u1p3p.sh
2022-10-06 00:25:25: PID: 5098: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 183 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:25: PID: 5098: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1300 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: plugstatlp1 0 plugstatlp2 0 plugstatlp3 0 (LV1) at 1299 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1298 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: EVU 1:V/1A 2: V/-1A 3: V/-1A (LV1) at 1297 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: lla3 0 llv3 239.1 llas13 llas23 soclp1 0 soclp2 (LV1) at 1296 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: lla2 0 llv2 239.8 llas12 llas22 sofortll 14 hausverbrauch 504 wattbezug 13 uberschuss -13 (LV1) at 1295 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: lla1 0 llv1 238.5 llas11 llas21 mindestuberschuss 500 abschaltuberschuss 0 lademodus 2 (LV1) at 1294 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: pv1watt 0 pv2watt pvwatt 0 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1293 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5098: speicherleistung -491 speichersoc 64 (LV1) at 1288 loadvars loadvars.sh
2022-10-06 00:25:24: PID: 5294: EVU RET: 0 (LV2) at 16 main modules/bezug_solaredge/main.sh
2022-10-06 00:25:24: PID: 20741: legacy run server: Completed running command in 0.25s: ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:25:24: PID: 20741: soc.modules.common.store._api: Saving CounterState(power_factors=[0.6809000000000001, -0.40590000000000004, -0.3529], frequency=50.0, exported=6410741.0, power=13.0, imported=2677279.0, currents=[1.5, -1.3, -1.2000000000000002], powers=[252.0, -129.0, -110.0], voltages=[238.49, 239.64000000000001, 239.27])
2022-10-06 00:25:24: PID: 20741: modules.solaredge.scale: Registers [6410741, 2008752, 3784095, 3800843, 2677279, 4304288, 994324, 561617], Scale 0
2022-10-06 00:25:24: PID: 20741: modules.solaredge.scale: Registers [6809, -4059, -3529], Scale -2
2022-10-06 00:25:24: PID: 20741: modules.solaredge.scale: Registers [5000], Scale -2
2022-10-06 00:25:24: PID: 20741: modules.solaredge.scale: Registers [23849, 23964, 23927, 0, 0, 0, 0], Scale -2
2022-10-06 00:25:24: PID: 20741: modules.solaredge.scale: Registers [15, 13, 12], Scale -1
2022-10-06 00:25:24: PID: 20741: modules.solaredge.scale: Registers [-13, -252, 129, 110], Scale 0
2022-10-06 00:25:24: PID: 20741: modules.solaredge.device: Start device reading {'componentNone': <modules.solaredge.counter.SolaredgeCounter object at 0x74f28790>}
2022-10-06 00:25:24: PID: 20741: modules.solaredge.device: Solaredge ModbusID: 1
2022-10-06 00:25:24: PID: 20741: modules.solaredge.device: Synergy Units: 1
2022-10-06 00:25:24: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: None, Externer WR: None, 2. Speicher: None, Speicherleistung subtrahieren: None 2. IP: None, Num: None
2022-10-06 00:25:24: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, None, None, None]
2022-10-06 00:25:24: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:502
2022-10-06 00:25:24: PID: 20741: legacy run server: Received command ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:25:23: PID: 5268: BAT RET: (LV2) at 20 main modules/speicher_solaredge/main.sh
2022-10-06 00:25:23: PID: 20741: legacy run server: Completed running command in 0.17s: ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
2022-10-06 00:25:23: PID: 20741: soc.modules.common.store._api: Saving InverterState(currents=[-1.34, -1.32, -1.3], exported=14490249.0, power=0)
2022-10-06 00:25:23: PID: 20741: soc.modules.common.store._api: Saving BatState(soc=64.0, exported=863857644.3570603, imported=2150417358, power=-491.0)
2022-10-06 00:25:23: PID: 20741: modules.common.simcount._simcount: imported: 0 kWh, exported: 1.35706 kWh, new state: SimCounterState(exported=863857644.3570603, imported=2150417358, power=-491.0, timestamp=1665008723.4074667)
2022-10-06 00:25:23: PID: 20741: modules.common.simcount._calculate: power did not change sign. Total energy: -1.35706
2022-10-06 00:25:23: PID: 20741: modules.common.simcount._calculate: time passed: 0.00276387, power1: -491, power2: -491
2022-10-06 00:25:23: PID: 20741: modules.common.simcount._simcount: Previous state: SimCounterState(exported=863857643, imported=2150417358, power=-491.0, timestamp=1665008713.4575334)
2022-10-06 00:25:23: PID: 20741: modules.solaredge.scale: Registers [134, 132, 130], Scale -2
2022-10-06 00:25:23: PID: 20741: modules.solaredge.scale: Registers [14490249], Scale 0
2022-10-06 00:25:23: PID: 20741: modules.solaredge.scale: Registers [4290], Scale -1
2022-10-06 00:25:23: PID: 20741: soc.modules.common.component_context: Update Komponente ['Solaredge Wechselrichter']
2022-10-06 00:25:23: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: 1, Externer WR: 0, 2. Speicher: 0, Speicherleistung subtrahieren: 0 2. IP: none, Num: 1
2022-10-06 00:25:23: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, none, none, none]
2022-10-06 00:25:23: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:
2022-10-06 00:25:23: PID: 20741: legacy run server: Received command ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
2022-10-06 00:25:22: PID: 5098: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:17: PID: 3778: **** Regulation loop needs 5 seconds (LV2) at 62 cleanup /var/www/html/openWB/regel.sh
2022-10-06 00:25:17: PID: 3778: Überschuss -2; mindestens 500 (LV1) at 104 nurpvlademodus nurpv.sh
2022-10-06 00:25:17: PID: 3778: uberschuss -2 wattbezug 2 ladestatus 0 llsoll 0 pvwatt 0 mindestuberschussphasen 500 wattkombiniert -2 schaltschwelle 0 (LV2) at 583 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:17: PID: 3778: anzahlphasen 1 (LV1) at 582 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:15: PID: 3778: Timing Umschaltung: 900 / 60 (LV1) at 17 u1p3pswitch u1p3p.sh
2022-10-06 00:25:15: PID: 3778: automatische Umschaltung aktiv (LV1) at 16 u1p3pswitch u1p3p.sh
2022-10-06 00:25:15: PID: 3778: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 183 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:15: PID: 3778: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1300 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: plugstatlp1 0 plugstatlp2 0 plugstatlp3 0 (LV1) at 1299 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1298 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: EVU 1:V/1A 2: V/-1A 3: V/-1A (LV1) at 1297 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: lla3 0 llv3 239.1 llas13 llas23 soclp1 0 soclp2 (LV1) at 1296 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: lla2 0 llv2 239.9 llas12 llas22 sofortll 14 hausverbrauch 493 wattbezug 2 uberschuss -2 (LV1) at 1295 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: lla1 0 llv1 238.6 llas11 llas21 mindestuberschuss 500 abschaltuberschuss 0 lademodus 2 (LV1) at 1294 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: pv1watt 0 pv2watt pvwatt 0 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1293 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3778: speicherleistung -491 speichersoc 64 (LV1) at 1288 loadvars loadvars.sh
2022-10-06 00:25:14: PID: 3977: EVU RET: 0 (LV2) at 16 main modules/bezug_solaredge/main.sh
2022-10-06 00:25:14: PID: 20741: legacy run server: Completed running command in 0.25s: ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:25:14: PID: 20741: soc.modules.common.store._api: Saving CounterState(power_factors=[0.6829999999999999, -0.4449, -0.3899], frequency=50.0, exported=6410741.0, power=2.0, imported=2677279.0, currents=[1.4000000000000001, -1.2000000000000002, -1.1], powers=[241.0, -129.0, -109.0], voltages=[238.47, 239.54, 239.13])
2022-10-06 00:25:14: PID: 20741: modules.solaredge.scale: Registers [6410741, 2008752, 3784095, 3800842, 2677279, 4304287, 994324, 561617], Scale 0
2022-10-06 00:25:14: PID: 20741: modules.solaredge.scale: Registers [6830, -4449, -3899], Scale -2
2022-10-06 00:25:14: PID: 20741: modules.solaredge.scale: Registers [5000], Scale -2
2022-10-06 00:25:14: PID: 20741: modules.solaredge.scale: Registers [23847, 23954, 23913, 0, 0, 0, 0], Scale -2
2022-10-06 00:25:14: PID: 20741: modules.solaredge.scale: Registers [14, 12, 11], Scale -1
2022-10-06 00:25:14: PID: 20741: modules.solaredge.scale: Registers [-2, -241, 129, 109], Scale 0
2022-10-06 00:25:14: PID: 20741: modules.solaredge.device: Start device reading {'componentNone': <modules.solaredge.counter.SolaredgeCounter object at 0x74f2fd30>}
2022-10-06 00:25:14: PID: 20741: modules.solaredge.device: Solaredge ModbusID: 1
2022-10-06 00:25:14: PID: 20741: modules.solaredge.device: Synergy Units: 1
2022-10-06 00:25:14: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: None, Externer WR: None, 2. Speicher: None, Speicherleistung subtrahieren: None 2. IP: None, Num: None
2022-10-06 00:25:14: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, None, None, None]
2022-10-06 00:25:14: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:502
2022-10-06 00:25:14: PID: 20741: legacy run server: Received command ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:25:13: PID: 3951: BAT RET: (LV2) at 20 main modules/speicher_solaredge/main.sh
2022-10-06 00:25:13: PID: 20741: legacy run server: Completed running command in 0.18s: ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
2022-10-06 00:25:13: PID: 20741: soc.modules.common.store._api: Saving InverterState(currents=[-1.27, -1.29, -1.25], exported=14490248.0, power=0)
2022-10-06 00:25:13: PID: 20741: soc.modules.common.store._api: Saving BatState(soc=64.0, exported=863857643.3283212, imported=2150417358, power=-491.0)
2022-10-06 00:25:13: PID: 20741: modules.common.simcount._simcount: imported: 0 kWh, exported: 1.32832 kWh, new state: SimCounterState(exported=863857643.3283212, imported=2150417358, power=-491.0, timestamp=1665008713.4575334)
2022-10-06 00:25:13: PID: 20741: modules.common.simcount._calculate: power did not change sign. Total energy: -1.32832
2022-10-06 00:25:13: PID: 20741: modules.common.simcount._calculate: time passed: 0.00270259, power1: -492, power2: -491
2022-10-06 00:25:13: PID: 20741: modules.common.simcount._simcount: Previous state: SimCounterState(exported=863857642, imported=2150417358, power=-492.0, timestamp=1665008703.7282224)
2022-10-06 00:25:13: PID: 20741: modules.solaredge.scale: Registers [127, 129, 125], Scale -2
2022-10-06 00:25:13: PID: 20741: modules.solaredge.scale: Registers [14490248], Scale 0
2022-10-06 00:25:13: PID: 20741: modules.solaredge.scale: Registers [4230], Scale -1
2022-10-06 00:25:13: PID: 20741: soc.modules.common.component_context: Update Komponente ['Solaredge Wechselrichter']
2022-10-06 00:25:13: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: 1, Externer WR: 0, 2. Speicher: 0, Speicherleistung subtrahieren: 0 2. IP: none, Num: 1
2022-10-06 00:25:13: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, none, none, none]
2022-10-06 00:25:13: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:
2022-10-06 00:25:13: PID: 20741: legacy run server: Received command ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
2022-10-06 00:25:12: PID: 3778: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:07: PID: 2076: **** Regulation loop needs 5 seconds (LV2) at 62 cleanup /var/www/html/openWB/regel.sh
2022-10-06 00:25:07: PID: 2076: Überschuss 0; mindestens 500 (LV1) at 104 nurpvlademodus nurpv.sh
2022-10-06 00:25:07: PID: 2076: uberschuss 0 wattbezug 0 ladestatus 0 llsoll 0 pvwatt 0 mindestuberschussphasen 500 wattkombiniert 0 schaltschwelle 0 (LV2) at 583 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:07: PID: 2076: anzahlphasen 1 (LV1) at 582 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:06: PID: 2076: Timing Umschaltung: 900 / 60 (LV1) at 17 u1p3pswitch u1p3p.sh
2022-10-06 00:25:06: PID: 2076: automatische Umschaltung aktiv (LV1) at 16 u1p3pswitch u1p3p.sh
2022-10-06 00:25:06: PID: 2076: Zeit zum abfragen aller Werte 4 Sekunden (LV1) at 183 main /var/www/html/openWB/regel.sh
2022-10-06 00:25:05: PID: 2076: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1300 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: plugstatlp1 0 plugstatlp2 0 plugstatlp3 0 (LV1) at 1299 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1298 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: EVU 1:V/1A 2: V/-1A 3: V/-1A (LV1) at 1297 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: lla3 0 llv3 238.8 llas13 llas23 soclp1 0 soclp2 (LV1) at 1296 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: lla2 0 llv2 239.6 llas12 llas22 sofortll 14 hausverbrauch 492 wattbezug 0 uberschuss 0 (LV1) at 1295 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: lla1 0 llv1 238.4 llas11 llas21 mindestuberschuss 500 abschaltuberschuss 0 lademodus 2 (LV1) at 1294 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: pv1watt 0 pv2watt pvwatt 0 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1293 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2076: speicherleistung -492 speichersoc 64 (LV1) at 1288 loadvars loadvars.sh
2022-10-06 00:25:05: PID: 2629: EVU RET: 0 (LV2) at 16 main modules/bezug_solaredge/main.sh
2022-10-06 00:25:05: PID: 20741: legacy run server: Completed running command in 0.20s: ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:25:05: PID: 20741: soc.modules.common.store._api: Saving CounterState(power_factors=[0.6718999999999999, -0.4499, -0.39890000000000003], frequency=50.0, exported=6410741.0, power=-0.0, imported=2677279.0, currents=[1.5, -1.1, -1.1], powers=[239.0, -130.0, -108.0], voltages=[238.73000000000002, 239.78, 239.48000000000002])
2022-10-06 00:25:05: PID: 20741: modules.solaredge.scale: Registers [6410741, 2008752, 3784095, 3800842, 2677279, 4304286, 994324, 561617], Scale 0
2022-10-06 00:25:05: PID: 20741: modules.solaredge.scale: Registers [6719, -4499, -3989], Scale -2
2022-10-06 00:25:05: PID: 2103: ##### cron5min.sh finished ##### (LV0) at 318 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:05: PID: 20741: modules.solaredge.scale: Registers [5000], Scale -2
2022-10-06 00:25:04: PID: 20741: modules.solaredge.scale: Registers [23873, 23978, 23948, 0, 0, 0, 0], Scale -2
2022-10-06 00:25:04: PID: 20741: modules.solaredge.scale: Registers [15, 11, 11], Scale -1
2022-10-06 00:25:04: PID: 20741: modules.solaredge.scale: Registers [0, -239, 130, 108], Scale 0
2022-10-06 00:25:04: PID: 20741: modules.solaredge.device: Start device reading {'componentNone': <modules.solaredge.counter.SolaredgeCounter object at 0x74fa4d30>}
2022-10-06 00:25:04: PID: 20741: modules.solaredge.device: Solaredge ModbusID: 1
2022-10-06 00:25:04: PID: 20741: modules.solaredge.device: Synergy Units: 1
2022-10-06 00:25:04: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: None, Externer WR: None, 2. Speicher: None, Speicherleistung subtrahieren: None 2. IP: None, Num: None
2022-10-06 00:25:04: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, None, None, None]
2022-10-06 00:25:04: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:502
2022-10-06 00:25:04: PID: 20741: legacy run server: Received command ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:25:04: PID: 2103: logfile cleanup triggered (LV1) at 315 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:04: PID: 2103: starting evsecheck (LV1) at 311 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:03: PID: 2582: BAT RET: (LV2) at 20 main modules/speicher_solaredge/main.sh
2022-10-06 00:25:03: Load: 2.85 3.03 2.99
2022-10-06 00:25:03: PID: 20741: legacy run server: Completed running command in 0.26s: ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
2022-10-06 00:25:03: PID: 20741: soc.modules.common.store._api: Saving InverterState(currents=[-1.28, -1.3, -1.28], exported=14490247.0, power=0)
2022-10-06 00:25:03: PID: 20741: soc.modules.common.store._api: Saving BatState(soc=64.0, exported=863857642.5513507, imported=2150417358, power=-492.0)
2022-10-06 00:25:03: PID: 20741: modules.common.simcount._simcount: imported: 0 kWh, exported: 1.55135 kWh, new state: SimCounterState(exported=863857642.5513507, imported=2150417358, power=-492.0, timestamp=1665008703.7282224)
2022-10-06 00:25:03: PID: 20741: modules.common.simcount._calculate: power did not change sign. Total energy: -1.55135
2022-10-06 00:25:03: PID: 20741: modules.common.simcount._calculate: time passed: 0.00315315, power1: -492, power2: -492
2022-10-06 00:25:03: PID: 20741: modules.common.simcount._simcount: Previous state: SimCounterState(exported=863857641, imported=2150417358, power=-492.0, timestamp=1665008692.3768756)
2022-10-06 00:25:03: PID: 2103: pingcheck configured; starting (LV1) at 301 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:03: PID: 20741: modules.solaredge.scale: Registers [128, 130, 128], Scale -2
2022-10-06 00:25:03: PID: 20741: modules.solaredge.scale: Registers [14490247], Scale 0
2022-10-06 00:25:03: PID: 20741: modules.solaredge.scale: Registers [4280], Scale -1
2022-10-06 00:25:03: PID: 20741: soc.modules.common.component_context: Update Komponente ['Solaredge Wechselrichter']
2022-10-06 00:25:03: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: 1, Externer WR: 0, 2. Speicher: 0, Speicherleistung subtrahieren: 0 2. IP: none, Num: 1
2022-10-06 00:25:03: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, none, none, none]
2022-10-06 00:25:03: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:
2022-10-06 00:25:03: PID: 20741: legacy run server: Received command ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
2022-10-06 00:25:03: PID: 2366: push buttons disabled (LV1) at 39 pushButtonsSetup /var/www/html/openWB/runs/pushButtons/pushButtonsHelper.sh
2022-10-06 00:25:03: PID: 2366: rse disabled (LV1) at 39 rseSetup /var/www/html/openWB/runs/rse/rseHelper.sh
2022-10-06 00:25:03: PID: 2366: external openWB or daemon mode not configured; checking network setup (LV1) at 92 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:03: PID: 2366: legacy run server is already running (LV1) at 78 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:03: PID: 2366: Starting legacy run server... (LV1) at 71 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:03: PID: 2366: smarthomemq is already running (LV1) at 64 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:03: PID: 2366: Using smarthomemq (LV2) at 53 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:03: PID: 2366: Starting smart home handler... (LV1) at 45 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:03: PID: 2366: mqtt handler is already running (LV1) at 38 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:02: PID: 2366: Starting MQTT handler... (LV1) at 35 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:02: PID: 2366: modbus tcp server already running (LV1) at 28 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:02: PID: 2366: Starting modbus server... (LV1) at 25 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:02: PID: 2366: Starting OpenWB services (LV0) at 22 start /var/www/html/openWB/runs/services.sh
2022-10-06 00:25:02: PID: 2103: current ip: 192.168.2.131 (LV1) at 294 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:02: PID: 2103: updating daily yield stats (LV1) at 164 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:02: PID: 2103: electricity provider not set up; skipping price update (LV2) at 160 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:02: PID: 2103: Netzschutz konfiguriert; aktuelle Frequenz: 4992 (LV1) at 109 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:02: PID: 2103: daily csv updated: /var/www/html/openWB/web/logging/data/daily/20221006.csv (LV1) at 101 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:02: PID: 2103: ##### cron5min.sh started ##### (LV0) at 23 main /var/www/html/openWB/runs/cron5min.sh
2022-10-06 00:25:02: PID: 2076: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
2022-10-06 00:24:55: PID: 659: **** Regulation loop needs 4 seconds (LV2) at 62 cleanup /var/www/html/openWB/regel.sh
2022-10-06 00:24:55: PID: 659: Überschuss 0; mindestens 500 (LV1) at 104 nurpvlademodus nurpv.sh
2022-10-06 00:24:55: PID: 659: uberschuss 0 wattbezug 0 ladestatus 0 llsoll 0 pvwatt 0 mindestuberschussphasen 500 wattkombiniert 0 schaltschwelle 0 (LV2) at 583 main /var/www/html/openWB/regel.sh
2022-10-06 00:24:55: PID: 659: anzahlphasen 1 (LV1) at 582 main /var/www/html/openWB/regel.sh
2022-10-06 00:24:55: PID: 659: Timing Umschaltung: 900 / 60 (LV1) at 17 u1p3pswitch u1p3p.sh
2022-10-06 00:24:55: PID: 659: automatische Umschaltung aktiv (LV1) at 16 u1p3pswitch u1p3p.sh
2022-10-06 00:24:55: PID: 659: Zeit zum abfragen aller Werte 3 Sekunden (LV1) at 183 main /var/www/html/openWB/regel.sh
2022-10-06 00:24:53: PID: 659: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1300 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: plugstatlp1 0 plugstatlp2 0 plugstatlp3 0 (LV1) at 1299 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1298 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: EVU 1:V/1A 2: V/-1A 3: V/-1A (LV1) at 1297 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: lla3 0 llv3 238.9 llas13 llas23 soclp1 0 soclp2 (LV1) at 1296 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: lla2 0 llv2 239.6 llas12 llas22 sofortll 14 hausverbrauch 492 wattbezug 0 uberschuss 0 (LV1) at 1295 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: lla1 0 llv1 238.4 llas11 llas21 mindestuberschuss 500 abschaltuberschuss 0 lademodus 2 (LV1) at 1294 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: pv1watt 0 pv2watt pvwatt 0 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1293 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 659: speicherleistung -492 speichersoc 64 (LV1) at 1288 loadvars loadvars.sh
2022-10-06 00:24:53: PID: 878: EVU RET: 0 (LV2) at 16 main modules/bezug_solaredge/main.sh
2022-10-06 00:24:53: PID: 20741: legacy run server: Completed running command in 0.25s: ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:24:53: PID: 20741: soc.modules.common.store._api: Saving CounterState(power_factors=[0.6769, -0.4339, -0.38189999999999996], frequency=49.99, exported=6410741.0, power=-0.0, imported=2677279.0, currents=[1.4000000000000001, -1.2000000000000002, -1.2000000000000002], powers=[241.0, -129.0, -111.0], voltages=[238.38, 239.32, 239.19])
2022-10-06 00:24:53: PID: 20741: modules.solaredge.scale: Registers [6410741, 2008752, 3784094, 3800842, 2677279, 4304286, 994324, 561617], Scale 0
2022-10-06 00:24:53: PID: 20741: modules.solaredge.scale: Registers [6769, -4339, -3819], Scale -2
2022-10-06 00:24:53: PID: 20741: modules.solaredge.scale: Registers [4999], Scale -2
2022-10-06 00:24:53: PID: 20741: modules.solaredge.scale: Registers [23838, 23932, 23919, 0, 0, 0, 0], Scale -2
2022-10-06 00:24:53: PID: 20741: modules.solaredge.scale: Registers [14, 12, 12], Scale -1
2022-10-06 00:24:53: PID: 20741: modules.solaredge.scale: Registers [0, -241, 129, 111], Scale 0
2022-10-06 00:24:53: PID: 20741: modules.solaredge.device: Start device reading {'componentNone': <modules.solaredge.counter.SolaredgeCounter object at 0x74f24210>}
2022-10-06 00:24:53: PID: 20741: modules.solaredge.device: Solaredge ModbusID: 1
2022-10-06 00:24:53: PID: 20741: modules.solaredge.device: Synergy Units: 1
2022-10-06 00:24:53: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: None, Externer WR: None, 2. Speicher: None, Speicherleistung subtrahieren: None 2. IP: None, Num: None
2022-10-06 00:24:53: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, None, None, None]
2022-10-06 00:24:53: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:502
2022-10-06 00:24:53: PID: 20741: legacy run server: Received command ["modules.solaredge.device","counter","192.168.2.134","502","1"]
2022-10-06 00:24:52: PID: 852: BAT RET: (LV2) at 20 main modules/speicher_solaredge/main.sh
2022-10-06 00:24:52: PID: 20741: legacy run server: Completed running command in 0.15s: ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
2022-10-06 00:24:52: PID: 20741: soc.modules.common.store._api: Saving InverterState(currents=[-1.21, -1.22, -1.21], exported=14490245.0, power=0)
2022-10-06 00:24:52: PID: 20741: soc.modules.common.store._api: Saving BatState(soc=64.0, exported=863857641.3585731, imported=2150417358, power=-492.0)
2022-10-06 00:24:52: PID: 20741: modules.common.simcount._simcount: imported: 0 kWh, exported: 1.35857 kWh, new state: SimCounterState(exported=863857641.3585731, imported=2150417358, power=-492.0, timestamp=1665008692.3768756)
2022-10-06 00:24:52: PID: 20741: modules.common.simcount._calculate: power did not change sign. Total energy: -1.35857
2022-10-06 00:24:52: PID: 20741: modules.common.simcount._calculate: time passed: 0.00276414, power1: -491, power2: -492
2022-10-06 00:24:52: PID: 20741: modules.common.simcount._simcount: Previous state: SimCounterState(exported=863857640, imported=2150417358, power=-491.0, timestamp=1665008682.4259844)
2022-10-06 00:24:52: PID: 20741: modules.solaredge.scale: Registers [121, 122, 121], Scale -2
2022-10-06 00:24:52: PID: 20741: modules.solaredge.scale: Registers [14490245], Scale 0
2022-10-06 00:24:52: PID: 20741: modules.solaredge.scale: Registers [4280], Scale -1
2022-10-06 00:24:52: PID: 20741: soc.modules.common.component_context: Update Komponente ['Solaredge Wechselrichter']
2022-10-06 00:24:52: PID: 20741: modules.solaredge.device: Solaredge Bat-WR-gleiche IP: 1, Externer WR: 0, 2. Speicher: 0, Speicherleistung subtrahieren: 0 2. IP: none, Num: 1
2022-10-06 00:24:52: PID: 20741: modules.solaredge.device: Solaredge Slave-IDs: [1, none, none, none]
2022-10-06 00:24:52: PID: 20741: modules.solaredge.device: Solaredge IP: 192.168.2.134:
2022-10-06 00:24:52: PID: 20741: legacy run server: Received command ["modules.solaredge.device","inverter","192.168.2.134","","1","none","none","none","1","0","0","0","
(LV0)
