Victron Venus OS Whimported Batterie
Ich bin auf der Suche nach Tipps wie man whimported bzw whexported mit einen raspi Venus OS für die openwb einrichtet. Soc und Speicherleistung hab ich in den venus mqtt topics gefunden und mit node red eingerichtet. Die beiden anderen topics finde ich nicht. Maximal ah werden angegeben.
Danke für Tipps.
Gruss andre
Danke für Tipps.
Gruss andre
Re: Victron Venus OS Whimported Batterie
Im Zweifelsfall via modbus - siehe die entpsrechende Registerliste von Victron?
Die Frage ist aber auch vermutlich besser im Victron-Forum aufgehoben?
com.victronenergy.multi Energy from AC-in-1 to AC-out 4546 uint32 100 /Energy/AcIn1ToAcOut no kWh
com.victronenergy.multi Energy from AC-in-1 to battery 4548 uint32 100 /Energy/AcIn1ToInverter no kWh
com.victronenergy.multi Energy from AC-in-2 to AC-out 4550 uint32 100 /Energy/AcIn2ToAcOut no kWh
com.victronenergy.multi Energy from AC-in-2 to battery 4552 uint32 100 /Energy/AcIn2ToInverter no kWh
com.victronenergy.multi Energy from AC-out to AC-in-1 4554 uint32 100 /Energy/AcOutToAcIn1 no kWh
com.victronenergy.multi Energy from AC-out to AC-in-2 4556 uint32 100 /Energy/AcOutToAcIn2 no kWh
com.victronenergy.multi Energy from battery to AC-in-1 4558 uint32 100 /Energy/InverterToAcIn1 no kWh
com.victronenergy.multi Energy from battery to AC-in-2 4560 uint32 100 /Energy/InverterToAcIn2 no kWh
com.victronenergy.multi Energy from battery to AC-out 4562 uint32 100 /Energy/InverterToAcOut no kWh
com.victronenergy.multi Energy from AC-out to battery 4564 uint32 100 /Energy/OutToInverter no kWh
com.victronenergy.multi Energy from solar to AC-in-1 4566 uint32 100 /Energy/SolarToAcIn1 no kWh
com.victronenergy.multi Energy from solar to AC-in-2 4568 uint32 100 /Energy/SolarToAcIn2 no kWh
com.victronenergy.multi Energy from solar to AC-out 4570 uint32 100 /Energy/SolarToAcOut no kWh
com.victronenergy.multi Energy from solar to battery 4572 uint32 100 /Energy/SolarToBattery no kWh
Hallo sledge,
Danke für den Tipp. Ich hatte gehofft das es auch hier im Forum tüftler gibt die vor diesem Problem standen und evtl eine Lösung gefunden haben. Mit Modbus TCP kenn ich mich nicht aus und erste Google Ergebnisse sind für mich böhmische Dörfer.
Gruss
Andre
Gruss
Andre
Du wirst die mqtt-Topics sicherlich schon mit mqtt-explorer oder ähnlichem durchforstet haben.
Bei einem Überflug über meine Topics finde ich nichts entsprechendes.
Aber wenn Du Ah als history-Werte hast, brauchst Du doch nur mit dem Nominal-Spannungswert (e.g. 48V) zu multiplizieren - das sollte doch als Näherung für die meisten Anwendungsfälle genügen?
Gruß, Tom
Gruß, Tom
Hallo Tom,
das ist richtig. Stehe leider nicht so im Stoff mit Node Red und hatte da auf entsprechende Tipps gehofft. Habe mit dem calculator node gespielt, vorher noch ein json Objekt draus gemacht, kriege es aber nicht hin. Aber ja, ah mal Volt müsste das richtige Ergebnis sein. Nur wie wir das umgesetzt?
André
André
Nun, was Du gänzlich nun beantwortet lässt: Was willst Du wo und wozu machen?
Hier zB lese ich die Victron-Daten über MQTT und Modbus aus - mit meinem FHEM-System. Dort ist es dann mit einzwei Perl-Komandos erledigt. Andere verwenden HomeAssistant, wieder andere usw... Was ich direkt auf dem Verbo / Venus OS erledigen möchte, mache ich mit bash, wieder andere mit Python... Du siehst: Viele Wege und Rom...
Ohne weitere Infos wird das sehr zäh. Und wenn Du es mit nodered machen möchtest: Da bin ich der Falsche, gibt aber sicherlich dutzende Anfängerkurse. Da kommt man idR nicht drum rum. Eine "copy'n'paste" Lösung wirst Du vermutlich nicht finden.
Und: Ich vermute nach wie vor dass Du im Victron-Forum besser aufgehoben bist. Bisher wird mir aus Deiner Frage nicht klar, was es mit openwb zu tun hat.
Mir fehlen die Werte für whimported bzw whexported auf der Speicherseite der openwb. Venus stellt diese leider nicht direkt via mqtt bereit, sondern müsste berechnet werden (ah x Batteriespannung). Beide, venus und openwb nutzen mqtt und kommunizieren schon miteinander daher war meine idee das jemand aus dem Forum ein ähnliches Problem vielleicht schon gelöst hat. Wie wichtig jetzt whimported bzw whexported in der openwb sind kann ich nicht beurteilen da beide Werte bei mir 0 sind. Noch eine extra Instanz ala fhem reinzubringen birgt die Gefahr einer weiteren fehlerquelle, meine Meinung.
Andre
Andre
Da wir ja vermutlich ein ähnliches Setup haben, müsstet du mir mal kurz verraten, auf welcher Speicherseite in der openwb die beiden Werte fehlen.
Mir ist da bisher nichts aufgefallen? Auf der Status-Seite sehe ich, was ich bisher geladen / entnommen habe... das passt alles.
Hier zum Beispiel. Ich vermute das auch oben Balkendiagrammme noch zur Anzeige kommen.
Andre
Andre
Das wird /und wurde) unmittelbar nach der Konfiguration bei mir richtig angezeigt.
Ich vermute, dass Du unter Venus OS Modbus noch nicht aktiviert hast? Geht unter "Settings -> Services". Verscuh das mal, dann sollte "zeitnah" bei den Balken usw etwas erscheinen.
