Support: Manuell + Berechnung
turbowheeler
Re: Support: Manuell + Berechnung
Beitrag von turbowheeler »
LutzB hat geschrieben: So Aug 29, 2021 10:31 am Du kannst den Debugmode auf 2 stellen, dann gibt es im ev-soc Log mehr Details zur Berechnung.
Hier ein Ausschnitt aus dem Log wo der Soc während einer Ladeunterbrechung von 68 auf 67 zurückgestellt wird:
2021-08-31 15:57:15: Lp1: --- Manual SoC end --- (LV1) at 136 main modules/soc_manual/main.sh
2021-08-31 15:57:15: Lp1: newSoc: 67 (LV1) at 128 main modules/soc_manual/main.sh
2021-08-31 15:57:15: Lp1: currentSocDiff: 0 (LV1) at 120 main modules/soc_manual/main.sh
2021-08-31 15:57:15: Lp1: currentEffectiveMeterDiff: 0 (93 %) (LV1) at 118 main modules/soc_manual/main.sh
2021-08-31 15:57:15: Lp1: currentMeterDiff: 0 (LV1) at 116 main modules/soc_manual/main.sh
2021-08-31 15:57:14: Lp1: currentSoc: 68 (LV1) at 112 main modules/soc_manual/main.sh
2021-08-31 15:57:14: Lp1: manualMeter: 0 (LV1) at 103 main modules/soc_manual/main.sh
2021-08-31 15:57:14: Lp1: manual SoC: 67 (LV1) at 92 main modules/soc_manual/main.sh
2021-08-31 15:57:14: Lp1: currentMeter: 0 (LV1) at 82 main modules/soc_manual/main.sh
2021-08-31 15:57:14: Lp1: Calculating manual SoC (LV1) at 75 main modules/soc_manual/main.sh
2021-08-31 15:57:14: Lp1: timer = 20000 (LV1) at 69 main modules/soc_manual/main.sh
2021-08-31 15:57:05: Lp1: --- Manual SoC end --- (LV1) at 136 main modules/soc_manual/main.sh
2021-08-31 15:57:05: Lp1: newSoc: 68 (LV1) at 128 main modules/soc_manual/main.sh
2021-08-31 15:57:05: Lp1: currentSocDiff: 1 (LV1) at 120 main modules/soc_manual/main.sh
2021-08-31 15:57:05: Lp1: currentEffectiveMeterDiff: .58590 (93 %) (LV1) at 118 main modules/soc_manual/main.sh
2021-08-31 15:57:04: Lp1: currentMeterDiff: .63 (LV1) at 116 main modules/soc_manual/main.sh
2021-08-31 15:57:04: Lp1: currentSoc: 68 (LV1) at 112 main modules/soc_manual/main.sh
2021-08-31 15:57:04: Lp1: manualMeter: 0 (LV1) at 103 main modules/soc_manual/main.sh
2021-08-31 15:57:04: Lp1: manual SoC: 67 (LV1) at 92 main modules/soc_manual/main.sh
2021-08-31 15:57:04: Lp1: currentMeter: 0.63 (LV1) at 82 main modules/soc_manual/main.sh
2021-08-31 15:57:04: Lp1: Calculating manual SoC (LV1) at 75 main modules/soc_manual/main.sh
2021-08-31 15:57:04: Lp1: timer = 1 (LV1) at 69 main modules/soc_manual/main.sh
Evtl. ist es ein Hinweis, das der "currentMeter" bzw. "currentMeterDiff" plötzlich wieder auf 0 steht?
philipp123
Beitrag von philipp123 »
HSC hat geschrieben: Di Aug 31, 2021 2:09 pm ....muss gestehen, dass ich letztens immer nur auf LP 2 mit Berechnung geladen habe, LP 1 steht lfd. auf 100 %.
Kann ich aber morgen mal testen.....
Wäre gut, wenn du mal testen kannst. Mein 2. Ladepunkt ist gerade wegen Baumaterial nur schwer erreichbar. Da ist das Kabel zu kurz :lol:
Und alles umstellen...
LP2: go-e V2
Kostal Plenticore Plus
e-up BJ 2021, SOC mit OVMS
9 x Smarthome mit Shellys
Hast Du kein Verlängerungskabel? 🤭🤣
Ja, mache ich, aber eben fehlen die Autos.🤷‍♂️
philipp123 hat geschrieben: Di Aug 31, 2021 2:30 pm
....eben getestet, Berechnung funktioniert, allerdings habe ich hier noch die 1.9.246 (2021-07-20 13:23:39 drauf.
Vlt. ziehe ich heute abend das Update noch drauf, dann schaue ich morgen nochmal.
philipp123
HSC hat geschrieben: Di Aug 31, 2021 4:31 pm ....eben getestet, Berechnung funktioniert, allerdings habe ich hier noch die 1.9.246 (2021-07-20 13:23:39 drauf.
Danke für deine Rückmeldung. Dann kann ich mir das Austauschen der IPs sparen.
Ich habe beschlossen, ich schlafe einfach heute Nacht und wenn morgen die Sonne aufgeht tut alles wunderbar :lol:
LP2: go-e V2
Nu genau! 👍
Update 1.9.248 (2021-08-31 19:00:19 ist installiert, bislang alles top.
Morgen nachmittag mehr zur Berechnung mit aktueller SW.
Berechnung funktioniert auch mit aktueller nightly auf beiden LP.
philipp123
HSC hat geschrieben: Mi Sep 01, 2021 2:57 pm Berechnung funktioniert auch mit aktueller nightly auf beiden LP.
Danke für deine Untestützung! Jetzt tut es bei mir auch. Hing wirklich mit dem "defekten" 2. Ladepunkt zusammen. Hatte beide am Start auf 74%.
Detailergebnisse der Ladung dann später im Optimierung go-e-Modul-Thread.
LP2: go-e V2
turbowheeler
turbowheeler hat geschrieben: Di Aug 31, 2021 2:16 pm
Was könnte denn die Ursache dafür sein, dass bei mir der "currentMeter" bzw. "currentMeterDiff" plötzlich wieder auf 0 steht?
