Bei mir klappt das PV laden noch überhaupt nicht, er fängt ständig an zu laden, obwohl kein Überschuss vorhanden ist.
Die Werte passen soweit, aber vll liegt es auch an meiner Struktur. Kann einer evtl helfen?
2023-01-27 15:07:21,818 - {control.data:334} - {DEBUG:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=32, battery_capacity=82, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str=''))
2023-01-27 15:07:21,818 - {control.data:334} - {DEBUG:MainThread} - ev1
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='E-Up', max_current_multi_phases=16, max_phases=2, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=15, min_current=6, max_current_single_phase=16, battery_capacity=32, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=1, ev_template=1, name='E-Up', tag_id=[], get=Get(soc=55, soc_timestamp='01/27/2023, 10:58:02', force_soc_update=False, range=126.0, fault_state=0, fault_str='Kein Fehler.'))
2023-01-27 15:07:21,818 - {control.data:334} - {DEBUG:MainThread} - ev2
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='ID.4', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=20, min_current=6, max_current_single_phase=16, battery_capacity=77, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=6, required_currents=[0.0, 0.0, 6], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.PV_CHARGING: 'pv_charging'>, chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=2, ev_template=2, name='ID.4', tag_id=[], get=Get(soc=58, soc_timestamp='01/27/2023, 15:03:21', force_soc_update=False, range=210.0, fault_state=0, fault_str='Kein Fehler.'))
2023-01-27 15:07:21,819 - {control.data:334} - {DEBUG:MainThread} - et0
2023-01-27 15:07:21,819 - {control.data:334} - {DEBUG:MainThread} - et1
2023-01-27 15:07:21,819 - {control.data:334} - {DEBUG:MainThread} - et2
2023-01-27 15:07:21,820 - {control.data:314} - {DEBUG:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=0, control_range=[-230, 0], feed_in_yield=0, phase_switch_delay=8, phases_to_use=0, rundown_power=0, rundown_soc=80, switch_off_delay=60, switch_off_soc=80, switch_off_threshold=50, switch_on_delay=60, switch_on_soc=95, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), standby=Standby(phases_to_use=1), stop=Stop(phases_to_use=1), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=20, unbalanced_load=True), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.259, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-01-27 15:07:21,820 - {control.data:315} - {DEBUG:MainThread} - graph_data
2023-01-27 15:07:21,820 - {control.data:316} - {DEBUG:MainThread} - optional_data
2023-01-27 15:07:21,820 - {control.data:334} - {DEBUG:MainThread} - pv1
PvData(config=Config(max_ac_out=12000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=7100, monthly_exported=0, yearly_exported=0, exported=654700, fault_state=0, fault_str='Kein Fehler.', power=-1990))
2023-01-27 15:07:21,820 - {control.data:334} - {DEBUG:MainThread} - pv5
PvData(config=Config(max_ac_out=2500), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=2211.488, monthly_exported=0, yearly_exported=0, exported=13260.836, fault_state=0, fault_str='Kein Fehler.', power=-116.3))
2023-01-27 15:07:21,820 - {control.data:318} - {DEBUG:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=9311.488, monthly_exported=0, yearly_exported=0, exported=667960.495, power=-2082.5))
2023-01-27 15:07:21,820 - {control.data:334} - {DEBUG:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.200.180', 'current_commit': '2023-01-27 07:55:01 +0100 [ff4a03ca]', 'current_branch': 'master', 'current_branch_commit': '2023-01-27 07:55:01 +0100 [ff4a03ca]', 'current_missing_commits': [], 'boot_done': True, 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.101.1', 'datastore_version': 6, 'lastlivevaluesJson': {'timestamp': 1674828431, 'time': '15:07:11', 'grid': 0.0, 'counter6-power': 1.059, 'counter7-power': 0.028, 'counter8-power': 0.079, 'house-power': 0.575, 'charging-all': 0.0, 'pv-all': 2.054, 'cp3-power': 0.0, 'cp4-power': 0.0, 'ev1-soc': 55, 'ev2-soc': 58, 'bat-all-power': 0.341, 'bat-all-soc': 60}, 'module_update_completed': True}
2023-01-27 15:07:21,821 - {control.data:347} - {DEBUG:MainThread} - device0
{'name': 'Q.Cells', 'type': 'solax', 'id': 0, 'configuration': {'modbus_id': 1, 'ip_address': '192.168.200.165'}}
2023-01-27 15:07:21,822 - {control.data:349} - {DEBUG:MainThread} - component0
{'name': 'Q.Cells Zähler', 'type': 'counter', 'id': 0, 'configuration': {}}
2023-01-27 15:07:21,823 - {control.data:349} - {DEBUG:MainThread} - component1
{'name': 'Q.Cells Wechselrichter', 'type': 'inverter', 'id': 1, 'configuration': {}}
2023-01-27 15:07:21,823 - {control.data:349} - {DEBUG:MainThread} - component2
{'name': 'Q.Cells Speicher', 'type': 'bat', 'id': 2, 'configuration': {}}
2023-01-27 15:07:21,824 - {control.data:347} - {DEBUG:MainThread} - device1
{'name': 'Growatt', 'type': 'json', 'id': 1, 'configuration': {'url': 'http://192.168.200.80/status'}}
2023-01-27 15:07:21,824 - {control.data:349} - {DEBUG:MainThread} - component5
{'name': 'Growatt über Shelly', 'type': 'inverter', 'id': 5, 'configuration': {'jq_power': '.meters[0].power*-1', 'jq_exported': None}}
2023-01-27 15:07:21,824 - {control.data:347} - {DEBUG:MainThread} - device2
{'name': 'Wärmepumpe', 'type': 'openwb_flex', 'id': 2, 'configuration': {'port': 8899, 'ip_address': '192.168.200.86'}}
2023-01-27 15:07:21,824 - {control.data:349} - {DEBUG:MainThread} - component6
{'name': 'Wärmepumpe', 'type': 'counter', 'id': 6, 'configuration': {'id': 117, 'version': 2}}
2023-01-27 15:07:21,824 - {control.data:347} - {DEBUG:MainThread} - device3
{'name': 'Lüftungsanlage', 'type': 'json', 'id': 3, 'configuration': {'url': 'http://192.168.200.181/rpc/Shelly.GetStatus'}}
2023-01-27 15:07:21,824 - {control.data:349} - {DEBUG:MainThread} - component7
{'name': 'Lüftungsanlage', 'type': 'counter', 'id': 7, 'configuration': {'jq_power': '."switch:0".apower', 'jq_exported': None, 'jq_imported': None}}
2023-01-27 15:07:21,824 - {control.data:347} - {DEBUG:MainThread} - device4
{'name': 'Waschmaschine', 'type': 'json', 'id': 4, 'configuration': {'url': 'http://192.168.200.187/rpc/Shelly.GetStatus'}}
2023-01-27 15:07:21,824 - {control.data:349} - {DEBUG:MainThread} - component8
{'name': 'Waschmaschine', 'type': 'counter', 'id': 8, 'configuration': {'jq_power': '."switch:0".apower', 'jq_exported': None, 'jq_imported': None}}
2023-01-27 15:07:21,824 - {control.data:321} - {DEBUG:MainThread} -
2023-01-27 15:07:21,825 - {control.algorithm.algorithm:26} - {DEBUG:MainThread} - # Algorithmus
2023-01-27 15:07:21,825 - {control.algorithm.algorithm:72} - {DEBUG:MainThread} - Ladepunkt 4: Prüfen, ob Phasenumschaltung durchgeführt werden soll.
2023-01-27 15:07:21,825 - {control.ev:484} - {DEBUG:MainThread} - Genutzter Strom: 6.0A, Überschuss: 0W, benötigte neue Leistung: 460W
2023-01-27 15:07:21,827 - {control.counter:362} - {DEBUG:MainThread} - LP4 Switch-Off-Threshold prüfen: 50W, Schwelle: 50W, freigegebener Überschuss 0W, Einspeisegrenze 0W
2023-01-27 15:07:21,828 - {control.algorithm.algorithm:32} - {DEBUG:MainThread} - **Mindestrom setzen**
2023-01-27 15:07:21,831 - {control.algorithm.min_current:18} - {DEBUG:MainThread} - Mode-Tuple (<Chargemode.PV_CHARGING: 'pv_charging'>, <Chargemode.PV_CHARGING: 'pv_charging'>, False), Zähler 0
2023-01-27 15:07:21,832 - {control.counter:174} - {DEBUG:MainThread} - Zähler 0: [51.79, 51.69, 52.54]A verbleibende Ströme, 35126.484669189456W verbleibende Leistung
2023-01-27 15:07:21,832 - {control.algorithm.common:87} - {DEBUG:MainThread} - LP4: Stromstärke 6A
2023-01-27 15:07:21,833 - {control.algorithm.algorithm:34} - {DEBUG:MainThread} - **Sollstrom setzen**
2023-01-27 15:07:21,836 - {control.counter:203} - {DEBUG:MainThread} - Überschuss zur PV-geführten Ladung: 1191.4846691894563W
2023-01-27 15:07:21,837 - {control.counter:466} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 1191.4846691894563W
2023-01-27 15:07:21,837 - {control.counter:466} - {DEBUG:MainThread} - Zähler 6: Begrenzung der verbleibenden Leistung auf 1191.4846691894563W
2023-01-27 15:07:21,838 - {control.counter:466} - {DEBUG:MainThread} - Zähler 7: Begrenzung der verbleibenden Leistung auf 1191.4846691894563W
2023-01-27 15:07:21,838 - {control.counter:466} - {DEBUG:MainThread} - Zähler 8: Begrenzung der verbleibenden Leistung auf 1191.4846691894563W
2023-01-27 15:07:21,838 - {control.algorithm.algorithm:40} - {DEBUG:MainThread} - **PV-geführten Strom setzen**
2023-01-27 15:07:21,840 - {control.algorithm.filter_chargepoints:118} - {DEBUG:MainThread} - Geordnete Ladepunkte [4]
2023-01-27 15:07:21,841 - {control.algorithm.surplus_controlled:41} - {DEBUG:MainThread} - Mode-Tuple (<Chargemode.PV_CHARGING: 'pv_charging'>, <Chargemode.PV_CHARGING: 'pv_charging'>, False), Zähler 0
2023-01-27 15:07:21,841 - {control.loadmanagement:82} - {DEBUG:MainThread} - Leistungsüberschreitung auf 1191.4846691894563W korrigieren: [0.0, 0.0, 10.0]
2023-01-27 15:07:21,841 - {control.counter:181} - {DEBUG:MainThread} - Zähler 0: [51.79, 51.69, 47.35963187308932]A verbleibende Ströme, 2.2737367544323206e-13W verbleibender Überschuss
2023-01-27 15:07:21,841 - {control.algorithm.common:87} - {DEBUG:MainThread} - LP4: Stromstärke 11.180368126910679A
2023-01-27 15:07:21,842 - {control.process:22} - {DEBUG:MainThread} - # Ladung starten.
2023-01-27 15:07:21,843 - {control.chargelog:52} - {DEBUG:MainThread} - imported_since_mode_switch 289.96999999997206 counter 665091.0
2023-01-27 15:07:21,845 - {control.process:106} - {INFO:MainThread} - LP4: set current 11.18 A
2023-01-27 15:07:21,846 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-27 15:07:21,850 - {soc.modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-01-27 15:07:21,878 - {control.counter:191} - {DEBUG:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-01-27 15:07:22,041 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-01-27 15:07:30,113 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-01-27 15:07:30,114 - {root:61} - {INFO:MainThread} - # ***Start***
2023-01-27 15:07:30,148 - {modules.devices.solax.device:55} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.solax.counter.SolaxCounter object at 0xb1d229b8>, 'component1': <modules.devices.solax.inverter.SolaxInverter object at 0xb1d22298>, 'component2': <modules.devices.solax.bat.SolaxBat object at 0xb13f5c10>}
2023-01-27 15:07:30,149 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['Q.Cells Zähler']
2023-01-27 15:07:30,149 - {soc.modules.common.component_context:51} - {DEBUG:device1} - Update Komponenten ['Growatt über Shelly']
2023-01-27 15:07:30,156 - {urllib3.connectionpool:227} - {DEBUG:device1} - Starting new HTTP connection (1): 192.168.200.80:80
2023-01-27 15:07:30,157 - {modules.devices.openwb_flex.device:50} - {DEBUG:device2} - Start device reading {'component6': <modules.devices.openwb_flex.counter.EvuKitFlex object at 0xb1d33448>}
2023-01-27 15:07:30,157 - {soc.modules.common.component_context:24} - {DEBUG:device2} - Update Komponente ['Wärmepumpe']
2023-01-27 15:07:30,158 - {soc.modules.common.component_context:51} - {DEBUG:device3} - Update Komponenten ['Lüftungsanlage']
2023-01-27 15:07:30,160 - {soc.modules.common.component_context:51} - {DEBUG:device4} - Update Komponenten ['Waschmaschine']
2023-01-27 15:07:30,165 - {urllib3.connectionpool:227} - {DEBUG:device3} - Starting new HTTP connection (1): 192.168.200.181:80
2023-01-27 15:07:30,168 - {urllib3.connectionpool:227} - {DEBUG:device4} - Starting new HTTP connection (1): 192.168.200.187:80
2023-01-27 15:07:30,169 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-27 15:07:30,172 - {soc.modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-01-27 15:07:30,209 - {urllib3.connectionpool:452} - {DEBUG:device3} - http://192.168.200.181:80 "GET /rpc/Shelly.GetStatus HTTP/1.1" 200 745
2023-01-27 15:07:30,210 - {soc.modules.common.req:11} - {DEBUG:device3} - Get-Response: {"ble":{},"cloud":{"connected":true},"input:0":{"id":0,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP", "output":true, "apower":27.7, "voltage":220.4, "current":0.217, "aenergy":{"total":14108.714,"by_minute":[214.056,449.615,448.149],"minute_ts":1674828447},"temperature":{"tC":40.7, "tF":105.2}},"sys":{"mac":"4855199A4364","restart_required":false,"time":"15:07","unixtime":1674828450,"uptime":1744599,"ram_size":249088,"ram_free":141904,"fs_size":458752,"fs_free":110592,"cfg_rev":11,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"0.13.0-beta1"}}},"wifi":{"sta_ip":"192.168.200.181","status":"got ip","ssid":"FRITZ!Box Fon WLAN 7390","rssi":-62},"ws":{"connected":false}}
2023-01-27 15:07:30,212 - {urllib3.connectionpool:452} - {DEBUG:device4} - http://192.168.200.187:80 "GET /rpc/Shelly.GetStatus HTTP/1.1" 200 697
2023-01-27 15:07:30,213 - {soc.modules.common.req:11} - {DEBUG:device4} - Get-Response: {"ble":{},"cloud":{"connected":true},"input:0":{"id":0,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"SHC", "output":true, "apower":66.8, "voltage":230.2, "current":0.5, "aenergy":{"total":825.287,"by_minute":[492.717,982.863,994.332],"minute_ts":1674828448},"temperature":{"tC":51.5, "tF":124.8}},"sys":{"mac":"4855199AFAF8","restart_required":false,"time":"15:07","unixtime":1674828451,"uptime":3030,"ram_size":249152,"ram_free":173388,"fs_size":458752,"fs_free":237568,"cfg_rev":14,"available_updates":{"beta":{"version":"0.13.0-beta1"},"stable":{"version":"0.12.0"}}},"wifi":{"sta_ip":"192.168.200.187","status":"got ip","ssid":"FRITZ!Box Fon WLAN 7390","rssi":-60}}
2023-01-27 15:07:30,365 - {urllib3.connectionpool:452} - {DEBUG:device1} - http://192.168.200.80:80 "GET /status HTTP/1.1" 200 1050
2023-01-27 15:07:30,499 - {soc.modules.common.req:11} - {DEBUG:device1} - Get-Response: {"wifi_sta":{"connected":true,"ssid":"FRITZ!Box Fon WLAN 7390","ip":"192.168.200.80","rssi":-31},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"15:07","unixtime":1674828451,"serial":3273,"has_update":false,"mac":"F4CFA2E3B708","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"source":"input"}],"meters":[{"power":116.40,"overpower":0.00,"is_valid":true,"timestamp":1674832051,"counters":[115.696, 115.321, 116.023],"total":240243}],"inputs":[{"input":0,"event":"","event_cnt":0}],"temperature":22.93,"overtemperature":false,"tmp":{"tC":22.93,"tF":73.28, "is_valid":true},"temperature_status":"Normal","ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20221108-153925/v1.12.1-1PM-fix-g2821131","old_version":"20221108-153925/v1.12.1-1PM-fix-g2821131"},"ram_total":51272,"ram_free":38980,"fs_size":233681,"fs_free":148090,"uptime":110388}
2023-01-27 15:07:30,639 - {modules.common.simcount._simcount:38} - {DEBUG:device4} - Previous state: SimCounterState(timestamp=1674828441.25325, power=64.0, imported=512.2163431116309, exported=0)
2023-01-27 15:07:30,639 - {modules.common.simcount._calculate:13} - {DEBUG:device4} - time passed: 0.0026072, power1: 64, power2: 66.8
2023-01-27 15:07:30,639 - {modules.common.simcount._calculate:29} - {DEBUG:device4} - power did not change sign. Total energy: 0.170511
2023-01-27 15:07:30,640 - {modules.common.simcount._simcount:47} - {DEBUG:device4} - imported: 0.170511 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1674828450.6391537, power=66.8, imported=512.3868536979721, exported=0)
2023-01-27 15:07:30,640 - {modules.common.simcount._simcount:38} - {DEBUG:device3} - Previous state: SimCounterState(timestamp=1674828440.9711366, power=26.8, imported=7470.973602517247, exported=0)
2023-01-27 15:07:30,642 - {soc.modules.common.store._api:26} - {DEBUG:device4} - Raw data CounterState(voltages=[230.0, 230.0, 230.0], powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=512.3868536979721, exported=0, power=66.8, frequency=50)
2023-01-27 15:07:30,643 - {modules.common.simcount._calculate:13} - {DEBUG:device3} - time passed: 0.00268605, power1: 26.8, power2: 27.7
2023-01-27 15:07:30,644 - {modules.common.simcount._calculate:29} - {DEBUG:device3} - power did not change sign. Total energy: 0.0731948
2023-01-27 15:07:30,645 - {modules.common.simcount._simcount:47} - {DEBUG:device3} - imported: 0.0731948 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1674828450.6409047, power=27.7, imported=7471.046797289633, exported=0)
2023-01-27 15:07:30,646 - {soc.modules.common.store._api:26} - {DEBUG:device3} - Raw data CounterState(voltages=[230.0, 230.0, 230.0], powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=7471.046797289633, exported=0, power=27.7, frequency=50)
2023-01-27 15:07:30,648 - {modules.common.simcount._simcount:38} - {DEBUG:device1} - Previous state: SimCounterState(timestamp=1674828441.1192062, power=-116.3, imported=0.0, exported=13260.836212628803)
2023-01-27 15:07:30,652 - {modules.common.simcount._calculate:13} - {DEBUG:device1} - time passed: 0.00264715, power1: -116.3, power2: -116.4
2023-01-27 15:07:30,653 - {modules.common.simcount._calculate:29} - {DEBUG:device1} - power did not change sign. Total energy: -0.307996
2023-01-27 15:07:30,656 - {modules.common.simcount._simcount:47} - {DEBUG:device1} - imported: 0 Wh, exported: 0.307996 Wh, new state: SimCounterState(timestamp=1674828450.6489592, power=-116.4, imported=0.0, exported=13261.144208950478)
2023-01-27 15:07:30,659 - {soc.modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-116.4, exported=13261.144208950478, dc_power=None)
2023-01-27 15:07:30,783 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[230.0, 230.0, 230.0], powers=[-47, -35, 55], currents=[-0.20434782608695654, -0.15217391304347827, 0.2391304347826087], power_factors=[0.0, 0.0, 0.0], imported=1442140, exported=63460, power=0, frequency=50.0)
2023-01-27 15:07:30,784 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['Q.Cells Wechselrichter']
2023-01-27 15:07:30,939 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-2033, exported=654700, dc_power=None)
2023-01-27 15:07:30,940 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['Q.Cells Speicher']
2023-01-27 15:07:30,952 - {modules.common.simcount._simcount:38} - {DEBUG:device2} - Previous state: SimCounterState(timestamp=1674828441.5610554, power=1059.7546691894531, imported=109063.26657898765, exported=0)
2023-01-27 15:07:30,952 - {modules.common.simcount._calculate:13} - {DEBUG:device2} - time passed: 0.00260871, power1: 1059.75, power2: 1058.28
2023-01-27 15:07:30,952 - {modules.common.simcount._calculate:29} - {DEBUG:device2} - power did not change sign. Total energy: 2.76268
2023-01-27 15:07:30,952 - {modules.common.simcount._simcount:47} - {DEBUG:device2} - imported: 2.76268 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1674828450.9524283, power=1058.2836303710938, imported=109066.029257811, exported=0)
2023-01-27 15:07:30,953 - {soc.modules.common.store._api:26} - {DEBUG:device2} - Raw data CounterState(voltages=[228.75701904296875, 230.65081787109375, 230.25904846191406], powers=[290.2722473144531, 373.996826171875, 394.0145568847656], currents=[2.730811834335327, 2.6825313568115234, 3.1030547618865967], power_factors=[0.46959981322288513, 0.6082114577293396, 0.5520184636116028], imported=109066.029257811, exported=0, power=1058.2836303710938, frequency=49.9210319519043)
2023-01-27 15:07:31,095 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1674828441.6255186, power=-978, imported=36076.60554866487, exported=28448.570771577728)
2023-01-27 15:07:31,095 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.0026305, power1: -978, power2: -2032
2023-01-27 15:07:31,096 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: -3.95891
2023-01-27 15:07:31,096 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 0 Wh, exported: 3.95891 Wh, new state: SimCounterState(timestamp=1674828451.0953362, power=-2032, imported=36076.60554866487, exported=28452.529681451557)
2023-01-27 15:07:31,097 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=36076.60554866487, exported=28452.529681451557, power=-2032, soc=60)
2023-01-27 15:07:31,101 - {soc.modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['Q.Cells Wechselrichter']
2023-01-27 15:07:31,101 - {soc.modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['Q.Cells Speicher']
2023-01-27 15:07:31,102 - {soc.modules.common.store._api:26} - {DEBUG:component1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-2033, exported=654700, dc_power=None)
2023-01-27 15:07:31,102 - {soc.modules.common.component_context:24} - {DEBUG:component5} - Update Komponente ['Growatt über Shelly']
2023-01-27 15:07:31,104 - {soc.modules.common.store._api:30} - {DEBUG:component2} - Saving BatState(imported=36076.60554866487, exported=28452.529681451557, power=-2032, soc=60)
2023-01-27 15:07:31,105 - {soc.modules.common.store._api:30} - {DEBUG:component1} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-2033, exported=654700, dc_power=None)
2023-01-27 15:07:31,105 - {soc.modules.common.component_context:24} - {DEBUG:component6} - Update Komponente ['Wärmepumpe']
2023-01-27 15:07:31,106 - {soc.modules.common.store._api:26} - {DEBUG:component5} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-116.4, exported=13261.144208950478, dc_power=None)
2023-01-27 15:07:31,109 - {soc.modules.common.component_context:24} - {DEBUG:component7} - Update Komponente ['Lüftungsanlage']
2023-01-27 15:07:31,111 - {soc.modules.common.component_context:24} - {DEBUG:component8} - Update Komponente ['Waschmaschine']
2023-01-27 15:07:31,113 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-27 15:07:31,116 - {soc.modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2023-01-27 15:07:31,124 - {soc.modules.common.store._api:30} - {DEBUG:component6} - Saving CounterState(voltages=[228.75701904296875, 230.65081787109375, 230.25904846191406], powers=[290.2722473144531, 373.996826171875, 394.0145568847656], currents=[2.730811834335327, 2.6825313568115234, 3.1030547618865967], power_factors=[0.46959981322288513, 0.6082114577293396, 0.5520184636116028], imported=109066.029257811, exported=0, power=1058.2836303710938, frequency=49.9210319519043)
2023-01-27 15:07:31,126 - {soc.modules.common.store._api:30} - {DEBUG:component5} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-116.4, exported=13261.144208950478, dc_power=None)
2023-01-27 15:07:31,144 - {soc.modules.common.store._api:30} - {DEBUG:component7} - Saving CounterState(voltages=[230.0, 230.0, 230.0], powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=7471.046797289633, exported=0, power=27.7, frequency=50)
2023-01-27 15:07:31,145 - {soc.modules.common.store._api:30} - {DEBUG:component8} - Saving CounterState(voltages=[230.0, 230.0, 230.0], powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=512.3868536979721, exported=0, power=66.8, frequency=50)
2023-01-27 15:07:31,247 - {soc.modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['Q.Cells Zähler']
2023-01-27 15:07:31,248 - {soc.modules.common.store._api:30} - {DEBUG:component0} - Saving CounterState(voltages=[230.0, 230.0, 230.0], powers=[-47, -35, 55], currents=[-0.20434782608695654, -0.15217391304347827, 0.2391304347826087], power_factors=[0.0, 0.0, 0.0], imported=1442140, exported=63460, power=0, frequency=50.0)
2023-01-27 15:07:31,302 - {control.counter:137} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 0: [51.96, 51.86, 62.43]
2023-01-27 15:07:31,304 - {control.counter:166} - {DEBUG:MainThread} - Verbleibende Leistung an Zähler 0: 37556.1936303711
2023-01-27 15:07:31,304 - {control.counter:137} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 6: [12.27, 12.32, 11.9]
2023-01-27 15:07:31,304 - {control.counter:137} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 7: [15.0, 15.0, 15.0]
2023-01-27 15:07:31,304 - {control.counter:137} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 8: [15.0, 15.0, 15.0]
2023-01-27 15:07:31,306 - {control.chargepoint:354} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2023-01-27 15:07:31,309 - {control.chargepoint:701} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-01-27 15:07:31,309 - {control.chargepoint:692} - {DEBUG:MainThread} - Phasenzahl Lademodus: 1
2023-01-27 15:07:31,311 - {control.chargepoint:867} - {DEBUG:MainThread} - LP 4, EV: ID.4 (EV-Nr.2): Theoretisch benötigter Strom 6A, Lademodus pv_charging, Submodus: Chargemode.PV_CHARGING, Phasen: 1, Priorität: False, max. Ist-Strom: 10.57
2023-01-27 15:07:31,312 - {control.bat_all:145} - {INFO:MainThread} - -978W verbliebende Speicher-Leistung
2023-01-27 15:07:31,313 - {control.data:334} - {DEBUG:MainThread} - bat2
BatData(get=Get(soc=60, daily_exported=1090.11, daily_imported=7185.59, imported=36076.61, exported=28452.53, fault_state=0, fault_str='Kein Fehler.', power=-2032))
2023-01-27 15:07:31,315 - {control.data:305} - {DEBUG:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=61, daily_exported=1090.11, daily_imported=7185.59, imported=36076.61, exported=28448.57, power=-978), set=Set(charging_power_left=-978, switch_on_soc_reached=False))
2023-01-27 15:07:31,315 - {control.data:306} - {DEBUG:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=1063.050000001, daily_exported=0, power=2403.41, imported=4207642.89, exported=0))
2023-01-27 15:07:31,315 - {control.data:334} - {DEBUG:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=55), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=3542546.88, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[231.39, 230.47, 228.48]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0xb1331070>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': '192.168.200.33', 'duo_num': 1}}, power_module={}, ev=1, name='Stellplatz', type='external_openwb', template=1, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-01-27 15:07:31,315 - {control.data:334} - {DEBUG:MainThread} - cp4
ChargepointData(get=Get(charge_state=True, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=58), currents=[10.57, 0.03, 0.03], daily_imported=1063.05, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=665096.01, phases_in_use=1, plug_state=True, power=2403.41, rfid_timestamp=None, rfid=None, state_str=None, voltages=[228.02, 230.88, 231.65]), set=Set(change_ev_permitted=[True, ''], charging_ev=2, charging_ev_prev=2, current=11.18, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', imported_at_mode_switch=664801.03, imported_at_plugtime=664513.98, imported_since_mode_switch=289.96999999997206, imported_since_plugged=577.0200000000186, range_charged=1.4498499999998604, time_charged='0:14', timestamp_start_charging='01/27/2023, 14:53:22'), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time='01/27/2023, 14:39:41', required_power=1380.0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0xb13a05b0>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': '192.168.200.125', 'duo_num': 1}}, power_module={}, ev=2, name='Garage', type='external_openwb', template=1, connected_phases=3, phase_1=3, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=4))
2023-01-27 15:07:31,316 - {control.data:334} - {DEBUG:MainThread} - cpt0
2023-01-27 15:07:31,317 - {control.data:334} - {DEBUG:MainThread} - cpt1
2023-01-27 15:07:31,317 - {control.data:334} - {DEBUG:MainThread} - cpt2
2023-01-27 15:07:31,318 - {control.data:334} - {DEBUG:MainThread} - counter0
CounterData(config=Config(max_currents=[50, 50, 50], max_total_power=34000), get=Get(powers=[-47, -35, 55], currents=[-0.2, -0.15, 0.24], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], unbalanced_load=0, frequency=50.0, daily_exported=400, daily_imported=5440, imported=1442140, exported=63460, fault_state=0, fault_str='Kein Fehler.', power=0), set=Set(reserved_surplus=0, released_surplus=0, raw_power_left=37556.1936303711, raw_currents_left=[51.96, 51.86, 62.43], surplus_power_left=0, state_str=''))
2023-01-27 15:07:31,318 - {control.data:334} - {DEBUG:MainThread} - counter6
CounterData(config=Config(max_currents=[16, 16, 16], max_total_power=11000), get=Get(powers=[290.27, 374.0, 394.01], currents=[2.73, 2.68, 3.1], voltages=[228.76, 230.65, 230.26], power_factors=[0.47, 0.61, 0.55], unbalanced_load=0, frequency=49.9210319519043, daily_exported=0, daily_imported=6161.49640360876, imported=109066.029257811, exported=0, fault_state=0, fault_str='Kein Fehler.', power=1058.2836303710938), set=Set(reserved_surplus=0, released_surplus=0, raw_power_left=None, raw_currents_left=[12.27, 12.32, 11.9], surplus_power_left=0, state_str=''))
2023-01-27 15:07:31,318 - {control.data:334} - {DEBUG:MainThread} - counter7
CounterData(config=Config(max_currents=[16, 16, 16], max_total_power=11000), get=Get(powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], unbalanced_load=0, frequency=50, daily_exported=0, daily_imported=411.732726657989, imported=7471.046797289633, exported=0, fault_state=0, fault_str='Kein Fehler.', power=27.7), set=Set(reserved_surplus=0, released_surplus=0, raw_power_left=None, raw_currents_left=[15.0, 15.0, 15.0], surplus_power_left=0, state_str=''))
2023-01-27 15:07:31,319 - {control.data:334} - {DEBUG:MainThread} - counter8
CounterData(config=Config(max_currents=[16, 16, 16], max_total_power=11000), get=Get(powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], unbalanced_load=0, frequency=50, daily_exported=0, daily_imported=475.59578937757, imported=512.3868536979721, exported=0, fault_state=0, fault_str='Kein Fehler.', power=66.8), set=Set(reserved_surplus=0, released_surplus=0, raw_power_left=None, raw_currents_left=[15.0, 15.0, 15.0], surplus_power_left=0, state_str=''))
2023-01-27 15:07:31,320 - {control.data:310} - {DEBUG:MainThread} - counter_all_data
CounterAllData(get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}, {'id': 5, 'type': 'inverter', 'children': []}, {'id': 6, 'type': 'counter', 'children': []}, {'id': 7, 'type': 'counter', 'children': []}, {'id': 8, 'type': 'counter', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=625.206369628906, invalid_home_consumption=0, daily_yield_home_consumption=12978.508999999001))
2023-01-27 15:07:31,320 - {control.data:334} - {DEBUG:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='stop', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2023-01-27 15:07:31,320 - {control.data:334} - {DEBUG:MainThread} - ct1
ChargeTemplateData(name='Ladung E-Up', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=16, min_current=0, feed_in_limit=False, min_soc=30, max_soc=80), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='none', amount=5000, soc=35))))
2023-01-27 15:07:31,320 - {control.data:334} - {DEBUG:MainThread} - ct2
ChargeTemplateData(name='Ladung ID.4', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=16, min_current=0, feed_in_limit=False, min_soc=20, max_soc=80), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='none', amount=1000, soc=50))))
2023-01-27 15:07:31,320 - {control.data:334} - {DEBUG:MainThread} - ev0
2023-01-27 15:07:31,320 - {control.data:334} - {DEBUG:MainThread} - ev1
2023-01-27 15:07:31,322 - {control.data:334} - {DEBUG:MainThread} - ev2
2023-01-27 15:07:31,325 - {control.data:334} - {DEBUG:MainThread} - et0
2023-01-27 15:07:31,326 - {control.data:334} - {DEBUG:MainThread} - et1
2023-01-27 15:07:31,326 - {control.data:334} - {DEBUG:MainThread} - et2
2023-01-27 15:07:31,326 - {control.data:314} - {DEBUG:MainThread} - general_data
2023-01-27 15:07:31,327 - {control.data:315} - {DEBUG:MainThread} - graph_data
2023-01-27 15:07:31,327 - {control.data:316} - {DEBUG:MainThread} - optional_data
2023-01-27 15:07:31,327 - {control.data:334} - {DEBUG:MainThread} - pv1
PvData(config=Config(max_ac_out=12000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=7100, monthly_exported=0, yearly_exported=0, exported=654700, fault_state=0, fault_str='Kein Fehler.', power=-2033))
2023-01-27 15:07:31,327 - {control.data:334} - {DEBUG:MainThread} - pv5
